Project: 5743 (Run 4, Clone 80, Gen 170)
tinokun
Post by tinokun »
Failed 5 times.
[13:21:17] - Preparing to get new work unit...
[13:21:17] Cleaning up work directory
[13:21:17] + Attempting to get work packet
[13:21:17] Passkey found
[13:21:17] - Will indicate memory of 6077 MB
[13:21:17] Gpu type=1 species=4.
[13:21:17] - Connecting to assignment server
[13:21:17] Connecting to http://assign-GPU.stanford.edu:8080/
[13:21:18] Posted data.
[13:21:18] Initial: 40AB; - Successful: assigned to (171.64.65.102).
[13:21:18] + News From Folding@Home: Welcome to Folding@Home
[13:21:18] Loaded queue successfully.
[13:21:18] Gpu type=1 species=4.
[13:21:18] Sent data
[13:21:18] Connecting to http://171.64.65.102:8080/
[13:21:19] Posted data.
[13:21:19] Initial: 0000; - Receiving payload (expected size: 70641)
[13:21:20] - Downloaded at ~68 kB/s
[13:21:20] - Averaged speed for that direction ~70 kB/s
[13:21:20] + Received work.
[13:21:20] Trying to send all finished work units
[13:21:20] + No unsent completed units remaining.
[13:21:20] + Closed connections
[13:21:20]
[13:21:20] + Processing work unit
[13:21:20] Core required: FahCore_11.exe
[13:21:20] Core found.
[13:21:20] Working on queue slot 04 [July 26 13:21:20 UTC]
[13:21:20] + Working ...
[13:21:20] - Calling '.\FahCore_11.exe -dir work/ -suffix 04 -nice 19 -nocpulock -checkpoint 30 -verbose -lifeline 4316 -version 630'
[13:21:20]
[13:21:20] *------------------------------*
[13:21:20] Folding@Home GPU Core - Beta
[13:21:20] Version 1.24 (Mon Feb 9 11:00:12 PST 2009)
[13:21:20]
[13:21:20] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[13:21:20] Build host: amoeba
[13:21:20] Board Type: AMD
[13:21:20] Core      :
[13:21:20] Preparing to commence simulation
[13:21:20] - Looking at optimizations...
[13:21:20] - Created dyn
[13:21:20] - Files status OK
[13:21:20] - Expanded 70129 -> 360060 (decompressed 513.4 percent)
[13:21:20] Called DecompressByteArray: compressed_data_size=70129 data_size=360060, decompressed_data_size=360060 diff=0
[13:21:20] - Digital signature verified
[13:21:20]
[13:21:20] Project: 5743 (Run 4, Clone 80, Gen 170)
[13:21:20]
[13:21:20] Assembly optimizations on if available.
[13:21:20] Entering M.D.
[13:21:26] Tpr hash work/wudata_04.tpr:  1236892082 448594059 1544938142 85903380 3515457988
[13:21:27] Working on Protein
[13:21:28] Client config found, loading data.
[13:21:28] Starting GUI Server
[13:21:32] mdrun_gpu returned
[13:21:32] Nonzero force sum on GPU
[13:21:32]
[13:21:32] Folding@home Core Shutdown: UNSTABLE_MACHINE
[13:21:34] CoreStatus = 7A (122)
[13:21:35] Sending work to server
[13:21:35] Project: 5743 (Run 4, Clone 80, Gen 170)
[13:21:35] - Read packet limit of 540015616... Set to 524286976.
[13:21:35] - Error: Could not get length of results file work/wuresults_04.dat
[13:21:35] - Error: Could not read unit 04 file. Removing from queue.
[13:21:35] Trying to send all finished work units
[13:21:35] + No unsent completed units remaining.
[13:21:35] - Preparing to get new work unit...
[13:21:35] Cleaning up work directory
[13:21:35] + Attempting to get work packet
[13:21:35] Passkey found
[13:21:35] - Will indicate memory of 6077 MB
[13:21:35] Gpu type=1 species=4.
[13:21:35] - Connecting to assignment server
[13:21:35] Connecting to http://assign-GPU.stanford.edu:8080/
[13:21:35] Posted data.
[13:21:35] Initial: 40AB; - Successful: assigned to (171.64.65.102).
[13:21:35] + News From Folding@Home: Welcome to Folding@Home
[13:21:36] Loaded queue successfully.
[13:21:36] Gpu type=1 species=4.
[13:21:36] Sent data
[13:21:36] Connecting to http://171.64.65.102:8080/
[13:21:36] Posted data.
[13:21:36] Initial: 0000; - Receiving payload (expected size: 70641)
[13:21:37] - Downloaded at ~68 kB/s
[13:21:37] - Averaged speed for that direction ~70 kB/s
[13:21:37] + Received work.
[13:21:37] Trying to send all finished work units
[13:21:37] + No unsent completed units remaining.
[13:21:37] + Closed connections
[13:21:42]
[13:21:42] + Processing work unit
[13:21:42] Core required: FahCore_11.exe
[13:21:42] Core found.
[13:21:42] Working on queue slot 05 [July 26 13:21:42 UTC]
[13:21:42] + Working ...
[13:21:42] - Calling '.\FahCore_11.exe -dir work/ -suffix 05 -nice 19 -nocpulock -checkpoint 30 -verbose -lifeline 4316 -version 630'
[13:21:43]
[13:21:43] *------------------------------*
[13:21:43] Folding@Home GPU Core - Beta
[13:21:43] Version 1.24 (Mon Feb 9 11:00:12 PST 2009)
[13:21:43]
[13:21:43] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[13:21:43] Build host: amoeba
[13:21:43] Board Type: AMD
[13:21:43] Core      :
[13:21:43] Preparing to commence simulation
[13:21:43] - Looking at optimizations...
[13:21:43] - Created dyn
[13:21:43] - Files status OK
[13:21:43] - Expanded 70129 -> 360060 (decompressed 513.4 percent)
[13:21:43] Called DecompressByteArray: compressed_data_size=70129 data_size=360060, decompressed_data_size=360060 diff=0
[13:21:43] - Digital signature verified
[13:21:43]
[13:21:43] Project: 5743 (Run 4, Clone 80, Gen 170)
[13:21:43]
[13:21:43] Assembly optimizations on if available.
[13:21:43] Entering M.D.
[13:21:49] Tpr hash work/wudata_05.tpr:  1236892082 448594059 1544938142 85903380 3515457988
[13:21:49] Working on Protein
[13:21:50] Client config found, loading data.
[13:21:50] Starting GUI Server
[13:21:54] mdrun_gpu returned
[13:21:54] Nonzero force sum on GPU
[13:21:54]
[13:21:54] Folding@home Core Shutdown: UNSTABLE_MACHINE
[13:21:57] CoreStatus = 7A (122)
[13:21:57] Sending work to server
[13:21:57] Project: 5743 (Run 4, Clone 80, Gen 170)
[13:21:57] - Read packet limit of 540015616... Set to 524286976.
[13:21:57] - Error: Could not get length of results file work/wuresults_05.dat
[13:21:57] - Error: Could not read unit 05 file. Removing from queue.
[13:21:57] Trying to send all finished work units
[13:21:57] + No unsent completed units remaining.
[13:21:57] - Preparing to get new work unit...
[13:21:57] Cleaning up work directory
[13:21:57] + Attempting to get work packet
[13:21:57] Passkey found
[13:21:57] - Will indicate memory of 6077 MB
[13:21:57] Gpu type=1 species=4.
[13:21:57] - Connecting to assignment server
[13:21:57] Connecting to http://assign-GPU.stanford.edu:8080/
[13:21:58] Posted data.
[13:21:58] Initial: 40AB; - Successful: assigned to (171.64.65.102).
[13:21:58] + News From Folding@Home: Welcome to Folding@Home
[13:21:58] Loaded queue successfully.
[13:21:58] Gpu type=1 species=4.
[13:21:58] Sent data
[13:21:58] Connecting to http://171.64.65.102:8080/
[13:21:58] Initial: 0000; - Receiving payload (expected size: 70641)
[13:22:00] - Downloaded at ~34 kB/s
[13:22:00] - Averaged speed for that direction ~63 kB/s
[13:22:00] + Received work.
[13:22:00] Trying to send all finished work units
[13:22:00] + No unsent completed units remaining.
[13:22:00] + Closed connections
[13:22:05]
[13:22:05] + Processing work unit
[13:22:05] Core required: FahCore_11.exe
[13:22:05] Core found.
[13:22:05] Working on queue slot 06 [July 26 13:22:05 UTC]
[13:22:05] + Working ...
[13:22:05] - Calling '.\FahCore_11.exe -dir work/ -suffix 06 -nice 19 -nocpulock -checkpoint 30 -verbose -lifeline 4316 -version 630'
[13:22:05]
[13:22:05] *------------------------------*
[13:22:05] Folding@Home GPU Core - Beta
[13:22:05] Version 1.24 (Mon Feb 9 11:00:12 PST 2009)
[13:22:05]
[13:22:05] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[13:22:05] Build host: amoeba
[13:22:05] Board Type: AMD
[13:22:05] Core      :
[13:22:05] Preparing to commence simulation
[13:22:05] - Looking at optimizations...
[13:22:05] - Created dyn
[13:22:05] - Files status OK
[13:22:05] - Expanded 70129 -> 360060 (decompressed 513.4 percent)
[13:22:05] Called DecompressByteArray: compressed_data_size=70129 data_size=360060, decompressed_data_size=360060 diff=0
[13:22:05] - Digital signature verified
[13:22:05]
[13:22:05] Project: 5743 (Run 4, Clone 80, Gen 170)
[13:22:05]
[13:22:05] Assembly optimizations on if available.
[13:22:05] Entering M.D.
[13:22:11] Tpr hash work/wudata_06.tpr:  1236892082 448594059 1544938142 85903380 3515457988
[13:22:11] Working on Protein
[13:22:12] Client config found, loading data.
[13:22:12] Starting GUI Server
[13:22:16] mdrun_gpu returned
[13:22:16] Nonzero force sum on GPU
[13:22:16]
[13:22:16] Folding@home Core Shutdown: UNSTABLE_MACHINE
[13:22:19] CoreStatus = 7A (122)
[13:22:19] Sending work to server
[13:22:19] Project: 5743 (Run 4, Clone 80, Gen 170)
[13:22:19] - Read packet limit of 540015616... Set to 524286976.
[13:22:19] - Error: Could not get length of results file work/wuresults_06.dat
[13:22:19] - Error: Could not read unit 06 file. Removing from queue.
[13:22:19] Trying to send all finished work units
[13:22:19] + No unsent completed units remaining.
[13:22:19] - Preparing to get new work unit...
[13:22:19] Cleaning up work directory
[13:22:19] + Attempting to get work packet
[13:22:19] Passkey found
[13:22:19] - Will indicate memory of 6077 MB
[13:22:19] Gpu type=1 species=4.
[13:22:19] - Connecting to assignment server
[13:22:19] Connecting to http://assign-GPU.stanford.edu:8080/
[13:22:20] Posted data.
[13:22:20] Initial: 40AB; - Successful: assigned to (171.64.65.102).
[13:22:20] + News From Folding@Home: Welcome to Folding@Home
[13:22:20] Loaded queue successfully.
[13:22:20] Gpu type=1 species=4.
[13:22:20] Sent data
[13:22:20] Connecting to http://171.64.65.102:8080/
[13:22:20] Initial: 0000; - Receiving payload (expected size: 70641)
[13:22:22] - Downloaded at ~34 kB/s
[13:22:22] - Averaged speed for that direction ~57 kB/s
[13:22:22] + Received work.
[13:22:22] Trying to send all finished work units
[13:22:22] + No unsent completed units remaining.
[13:22:22] + Closed connections
[13:22:27]
[13:22:27] + Processing work unit
[13:22:27] Core required: FahCore_11.exe
[13:22:27] Core found.
[13:22:27] Working on queue slot 07 [July 26 13:22:27 UTC]
[13:22:27] + Working ...
[13:22:27] - Calling '.\FahCore_11.exe -dir work/ -suffix 07 -nice 19 -nocpulock -checkpoint 30 -verbose -lifeline 4316 -version 630'
[13:22:27]
[13:22:27] *------------------------------*
[13:22:27] Folding@Home GPU Core - Beta
[13:22:27] Version 1.24 (Mon Feb 9 11:00:12 PST 2009)
[13:22:27]
[13:22:27] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[13:22:27] Build host: amoeba
[13:22:27] Board Type: AMD
[13:22:27] Core      :
[13:22:27] Preparing to commence simulation
[13:22:27] - Looking at optimizations...
[13:22:27] - Created dyn
[13:22:27] - Files status OK
[13:22:27] - Expanded 70129 -> 360060 (decompressed 513.4 percent)
[13:22:27] Called DecompressByteArray: compressed_data_size=70129 data_size=360060, decompressed_data_size=360060 diff=0
[13:22:27] - Digital signature verified
[13:22:27]
[13:22:27] Project: 5743 (Run 4, Clone 80, Gen 170)
[13:22:27]
[13:22:27] Assembly optimizations on if available.
[13:22:27] Entering M.D.
[13:22:33] Tpr hash work/wudata_07.tpr:  1236892082 448594059 1544938142 85903380 3515457988
[13:22:33] Working on Protein
[13:22:34] Client config found, loading data.
[13:22:34] Starting GUI Server
[13:22:38] mdrun_gpu returned
[13:22:38] Nonzero force sum on GPU
[13:22:38]
[13:22:38] Folding@home Core Shutdown: UNSTABLE_MACHINE
[13:22:41] CoreStatus = 7A (122)
[13:22:41] Sending work to server
[13:22:41] Project: 5743 (Run 4, Clone 80, Gen 170)
[13:22:41] - Read packet limit of 540015616... Set to 524286976.
[13:22:41] - Error: Could not get length of results file work/wuresults_07.dat
[13:22:41] - Error: Could not read unit 07 file. Removing from queue.
[13:22:41] Trying to send all finished work units
[13:22:41] + No unsent completed units remaining.
[13:22:41] - Preparing to get new work unit...
[13:22:41] Cleaning up work directory
[13:22:41] + Attempting to get work packet
[13:22:41] Passkey found
[13:22:41] - Will indicate memory of 6077 MB
[13:22:41] Gpu type=1 species=4.
[13:22:41] - Connecting to assignment server
[13:22:41] Connecting to http://assign-GPU.stanford.edu:8080/
[13:22:42] Posted data.
[13:22:42] Initial: 40AB; - Successful: assigned to (171.64.65.102).
[13:22:42] + News From Folding@Home: Welcome to Folding@Home
[13:22:42] Loaded queue successfully.
[13:22:42] Gpu type=1 species=4.
[13:22:42] Sent data
[13:22:42] Connecting to http://171.64.65.102:8080/
[13:22:43] Posted data.
[13:22:43] Initial: 0000; - Receiving payload (expected size: 70641)
[13:22:44] - Downloaded at ~68 kB/s
[13:22:44] - Averaged speed for that direction ~59 kB/s
[13:22:44] + Received work.
[13:22:44] Trying to send all finished work units
[13:22:44] + No unsent completed units remaining.
[13:22:44] + Closed connections
[13:22:49]
[13:22:49] + Processing work unit
[13:22:49] Core required: FahCore_11.exe
[13:22:49] Core found.
[13:22:49] Working on queue slot 08 [July 26 13:22:49 UTC]
[13:22:49] + Working ...
[13:22:49] - Calling '.\FahCore_11.exe -dir work/ -suffix 08 -nice 19 -nocpulock -checkpoint 30 -verbose -lifeline 4316 -version 630'
[13:22:49]
[13:22:49] *------------------------------*
[13:22:49] Folding@Home GPU Core - Beta
[13:22:49] Version 1.24 (Mon Feb 9 11:00:12 PST 2009)
[13:22:49]
[13:22:49] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[13:22:49] Build host: amoeba
[13:22:49] Board Type: AMD
[13:22:49] Core      :
[13:22:49] Preparing to commence simulation
[13:22:49] - Looking at optimizations...
[13:22:49] - Created dyn
[13:22:49] - Files status OK
[13:22:49] - Expanded 70129 -> 360060 (decompressed 513.4 percent)
[13:22:49] Called DecompressByteArray: compressed_data_size=70129 data_size=360060, decompressed_data_size=360060 diff=0
[13:22:49] - Digital signature verified
[13:22:49]
[13:22:49] Project: 5743 (Run 4, Clone 80, Gen 170)
[13:22:49]
[13:22:49] Assembly optimizations on if available.
[13:22:49] Entering M.D.
[13:22:55] Tpr hash work/wudata_08.tpr:  1236892082 448594059 1544938142 85903380 3515457988
[13:22:56] Working on Protein
[13:22:56] Client config found, loading data.
[13:22:56] Starting GUI Server
[13:23:00] mdrun_gpu returned
[13:23:00] Nonzero force sum on GPU
[13:23:00]
[13:23:00] Folding@home Core Shutdown: UNSTABLE_MACHINE
[13:23:03] CoreStatus = 7A (122)
[13:23:03] Sending work to server
[13:23:03] Project: 5743 (Run 4, Clone 80, Gen 170)
[13:23:03] - Read packet limit of 540015616... Set to 524286976.
[13:23:03] - Error: Could not get length of results file work/wuresults_08.dat
[13:23:03] - Error: Could not read unit 08 file. Removing from queue.
[13:23:03] EUE limit exceeded. Pausing 24 hours.
Thanks.
Re: Project: 5743 (Run 4, Clone 80, Gen 170)
Marked a a bad WU.
