I've just submitted the partial results using qfix[06:30:55] Completed 550000 out of 2500000 steps (22 percent)
[06:51:32] Gromacs cannot continue further.
[06:51:32] Going to send back what have done.
[06:51:32] logfile size: 22974
[06:51:32] - Writing 23510 bytes of core data to disk
[06:51:32] Done.
[06:51:32] - Failed to delete work/wudata_01.sas
[06:51:32] - Failed to delete work/wudata_01.goe
[06:51:32] Warning: check for stray files
[06:51:32]
[06:51:32] Folding@home Core Shutdown: EARLY_UNIT_END
[06:51:32]
[06:51:36] CoreStatus = 7B (123)
[06:51:36] Client-core communications error: ERROR 0x7b
[06:51:36] Deleting current work unit & continuing
Project: 3065 (Run 5, Clone 0, Gen 33) : Early Unit End
Here's the log :
Re: Project: 3065 (Run 5, Clone 0, Gen 33) : Early Unit End
Work units do not usually generate 0x7b errors, as this is not a fah error. You are either having network issues, or to much overclocking. Especially when someone else has completed this WU successfully. Sorry.
Hi Mr xxx (team 0),
Your WU (P3065 R5 C0 G33) was added to the stats database on 2008-03-04 18:55:00 for 1837 points of credit.
Hi Mr xxx (team 0),
Thanks ... I'll investigate deeeper.
