Project: 2685 (Run 1, Clone 15, Gen 11)
filu
Post by filu »
Yesterday I sent the results of p2685 to Stanford. Unfortunately, the statistics are not reported that fact. I would like to know what happened with that?. It seems to me that my work in vain.
--- Opening Log file [July 23 10:46:19 UTC]
                       Folding@Home Client Version 6.29
                          http://folding.stanford.edu
Launch directory: C:\SMP
Executable: folding@home-win32-x86.exe
Arguments: -smp -bigadv -forceasm -verbosity 9 -oneunit
[10:46:19] - Ask before connecting: No
[10:46:19] - User name: filu (Team 276)
[10:46:19] - User ID: 7BB258343FAF3D9B
[10:46:19] - Machine ID: 1
[10:46:19]
[10:46:19] Loaded queue successfully.
[10:46:19]
[10:46:19] - Autosending finished units... [July 23 10:46:19 UTC]
[10:46:19] + Processing work unit
[10:46:19] Trying to send all finished work units
[10:46:19] Core required: FahCore_a3.exe
[10:46:19] + No unsent completed units remaining.
[10:46:19] Core found.
[10:46:19] - Autosend completed
[10:46:19] Working on queue slot 09 [July 23 10:46:19 UTC]
[10:46:19] + Working ...
[10:46:19] - Calling '.\FahCore_a3.exe -dir work/ -nice 19 -suffix 09 -np 8 -priority 96 -nocpulock -checkpoint 15 -forceasm -verbose -lifeline 2652 -version 629'
[10:46:19]
[10:46:19] *------------------------------*
[10:46:19] Folding@Home Gromacs SMP Core
[10:46:19] Version 2.22 (Mar 12, 2010)
[10:46:19]
[10:46:19] Preparing to commence simulation
[10:46:19] - Assembly optimizations manually forced on.
[10:46:19] - Not checking prior termination.
[10:46:24] - Expanded 26601515 -> 32949201 (decompressed 123.8 percent)
[10:46:24] Called DecompressByteArray: compressed_data_size=26601515 data_size=32949201, decompressed_data_size=32949201 diff=0
[10:46:24] - Digital signature verified
[10:46:24]
[10:46:24] Project: 2685 (Run 1, Clone 15, Gen 11)
[10:46:24]
[10:46:25] Assembly optimizations on if available.
[10:46:25] Entering M.D.
[10:46:31] Using Gromacs checkpoints
[10:46:35] Resuming from checkpoint
[10:46:35] Verified work/wudata_09.log
[10:46:35] Verified work/wudata_09.trr
[10:46:35] Verified work/wudata_09.xtc
[10:46:35] Verified work/wudata_09.edr
[10:46:36] Completed 246470 out of 250000 steps  (98%)
[10:59:40] Completed 247500 out of 250000 steps  (99%)
[11:31:22] Completed 250000 out of 250000 steps  (100%)
[11:31:34] DynamicWrapper: Finished Work Unit: sleep=10000
[11:31:43]
[11:31:43] Finished Work Unit:
[11:31:43] - Reading up to 56404128 from "work/wudata_09.trr": Read 56404128
[11:31:44] trr file hash check passed.
[11:31:44] - Reading up to 50309664 from "work/wudata_09.xtc": Read 50309664
[11:31:44] xtc file hash check passed.
[11:31:44] edr file hash check passed.
[11:31:44] logfile size: 206275
[11:31:44] Leaving Run
[11:31:44] - Writing 107088007 bytes of core data to disk...
[11:31:46]   ... Done.
[11:32:07] - Shutting down core
[11:32:07]
[11:32:07] Folding@home Core Shutdown: FINISHED_UNIT
[11:32:15] CoreStatus = 64 (100)
[11:32:15] Unit 9 finished with 60 percent of time to deadline remaining.
[11:32:15] Updated performance fraction: 0.803075
[11:32:15] Sending work to server
[11:32:15] Project: 2685 (Run 1, Clone 15, Gen 11)
[11:32:15] + Attempting to send results [July 23 11:32:15 UTC]
[11:32:15] - Reading file work/wuresults_09.dat from core
[11:32:15]   (Read 107088007 bytes from disk)
[11:32:15] Connecting to http://171.67.108.22:8080/
[12:08:50] Posted data.
[12:08:51] Initial: 0000; - Uploaded at ~47 kB/s
[12:08:51] - Averaged speed for that direction ~57 kB/s
[12:08:51] + Results successfully sent
[12:08:51] Thank you for your contribution to Folding@Home.
[12:08:51] + Number of Units Completed: 209
[12:08:59] Trying to send all finished work units
[12:08:59] + No unsent completed units remaining.
i7-2600K@4.8 Asus P8P67 EVO 2x2GB GTX480
i7-920@4.0 GA-EX58-UD5 3x2GB 2xGTX560Ti
2x Xeon 5620 6x 2GB
2x Xeon 5645 6x 2GB
Re: Problem with results of p2685
You can remove the -forceasm flag as it is useless for the SMP Client. Also check the Official Stats first not the third party one. Link to the Official one is given on top.
filu
Post by filu »
PantherX wrote:Also check the Official Stats first not the third party one
I checked the Official Stats. The difference in points is about 4000 points, not 73,000.
PantherX wrote:You can remove the -forceasm flag as it is useless for the SMP Client
Thanks, I'll remove it.
2x Xeon 5620 6x 2GB
2x Xeon 5645 6x 2GB
I'm seeing duplicate result from your, both with an error code :
Hi filu (team 276),
Your WU (P2685 R1 C15 G11) was added to the stats database on 2010-07-22 06:17:05 for 0 points of credit.
Error code corresponding to an EUE or incomplete results.
Hi filu (team 276),
Your WU (P2685 R1 C15 G11) was added to the stats database on 2010-07-23 06:09:37 for 0 points of credit.
Error code corresponding to a duplicate WU.
filu
Post by filu »
toTOW wrote:I'm seeing duplicate result from your, both with an error code :
Hi filu (team 276),
Hi filu (team 276),
Thank you for your note.
I don't know what happened. I had on this day the problems with the supply of electricity, but I don't see EUE in the log files.
Seems to me that only I waste my money and time :? .
2x Xeon 5620 6x 2GB
2x Xeon 5645 6x 2GB
codysluder
Post by codysluder »
To diagnose the real problem, we really need to see the log for the entire WU, beginning from the download and including everything up to the part that you posted. (Some of the information may have been moved to Fahlog-Prev.)
filu
Post by filu »
codysluder wrote:(Some of the information may have been moved to Fahlog-Prev.)
So I looked at both files (fahlog and fahlog-prev).
2x Xeon 5620 6x 2GB
2x Xeon 5645 6x 2GB
bollix47
Post by bollix47 »
1. EUEs are not the only type of errors that can appear in the logs.
2. You need to search for Project: 2685 (Run 1, Clone 15, Gen 11) in both logs and determine how many times it has been run and why.
filu
Post by filu »
Fahlog-Prev
[16:46:50] + Attempting to send results [July 18 16:46:50 UTC]
[16:46:50] - Reading file work/wuresults_07.dat from core
[16:46:50]   (Read 20536259 bytes from disk)
[16:46:50] Connecting to http://130.237.232.140:8080/
[16:52:16] Posted data.
[16:52:16] Initial: 0000; - Uploaded at ~61 kB/s
[16:52:17] - Averaged speed for that direction ~59 kB/s
[16:52:17] + Results successfully sent
[16:52:17] Thank you for your contribution to Folding@Home.
[16:52:17] + Number of Units Completed: 207
[16:52:21] Trying to send all finished work units
[16:52:21] + No unsent completed units remaining.
[16:52:21] - Preparing to get new work unit...
[16:52:21] Cleaning up work directory
[16:52:22] + Attempting to get work packet
[16:52:22] Passkey found
[16:52:22] - Will indicate memory of 6141 MB
[16:52:22] - Connecting to assignment server
[16:52:22] Connecting to http://assign.stanford.edu:8080/
[16:52:23] Posted data.
[16:52:23] Initial: 43AB; - Successful: assigned to (171.67.108.22).
[16:52:23] + News From Folding@Home: Welcome to Folding@Home
[16:52:23] Loaded queue successfully.
[16:52:23] Connecting to http://171.67.108.22:8080/
[16:52:32] Posted data.
[16:52:32] Initial: 0000; - Receiving payload (expected size: 26641247)
[16:57:51] - Downloaded at ~81 kB/s
[16:57:51] - Averaged speed for that direction ~322 kB/s
[16:57:51] + Received work.
[16:57:51] Trying to send all finished work units
[16:57:51] + No unsent completed units remaining.
[16:57:51] + Closed connections
[16:57:51]
[16:57:51] + Processing work unit
[16:57:51] Core required: FahCore_a3.exe
[16:57:51] Core found.
[16:57:51] Working on queue slot 08 [July 18 16:57:51 UTC]
[16:57:51] + Working ...
[16:57:51] - Calling '.\FahCore_a3.exe -dir work/ -nice 19 -suffix 08 -np 8 -priority 96 -nocpulock -checkpoint 15 -service -forceasm -verbose -lifeline 1516 -version 629'
[16:57:51]
[16:57:51] *------------------------------*
[16:57:51] Folding@Home Gromacs SMP Core
[16:57:51] Version 2.22 (Mar 12, 2010)
[16:57:51]
[16:57:51] Preparing to commence simulation
[16:57:51] - Assembly optimizations manually forced on.
[16:57:51] - Not checking prior termination.
[16:57:56] - Expanded 26640735 -> 33000273 (decompressed 123.8 percent)
[16:57:56] Called DecompressByteArray: compressed_data_size=26640735 data_size=33000273, decompressed_data_size=33000273 diff=0
[16:57:56] - Digital signature verified
[16:57:56]
[16:57:56] Project: 2685 (Run 3, Clone 8, Gen 5)
[16:57:56]
[16:57:56] Assembly optimizations on if available.
[16:57:56] Entering M.D.
[16:58:06] Completed 0 out of 250000 steps  (0%)
[17:27:12] - Autosending finished units... [July 18 17:27:12 UTC]
[17:27:12] Trying to send all finished work units
[17:27:12] + No unsent completed units remaining.
[17:27:12] - Autosend completed
[17:31:57] Completed 2500 out of 250000 steps  (1%)
[18:05:45] Completed 5000 out of 250000 steps  (2%)
[18:39:32] Completed 7500 out of 250000 steps  (3%)
[19:13:21] Completed 10000 out of 250000 steps  (4%)
[19:47:06] Completed 12500 out of 250000 steps  (5%)
[20:20:53] Completed 15000 out of 250000 steps  (6%)
[20:54:39] Completed 17500 out of 250000 steps  (7%)
[21:28:27] Completed 20000 out of 250000 steps  (8%)
[22:02:18] Completed 22500 out of 250000 steps  (9%)
[22:36:20] Completed 25000 out of 250000 steps  (10%)
[23:10:11] Completed 27500 out of 250000 steps  (11%)
[23:27:12] - Autosending finished units... [July 18 23:27:12 UTC]
[23:27:12] Trying to send all finished work units
[23:27:12] + No unsent completed units remaining.
[23:27:12] - Autosend completed
[23:44:37] Completed 30000 out of 250000 steps  (12%)
[00:18:30] Completed 32500 out of 250000 steps  (13%)
[00:52:29] Completed 35000 out of 250000 steps  (14%)
[01:26:27] Completed 37500 out of 250000 steps  (15%)
[02:00:30] Completed 40000 out of 250000 steps  (16%)
[02:34:33] Completed 42500 out of 250000 steps  (17%)
[03:08:40] Completed 45000 out of 250000 steps  (18%)
[03:42:44] Completed 47500 out of 250000 steps  (19%)
[04:16:51] Completed 50000 out of 250000 steps  (20%)
[04:50:55] Completed 52500 out of 250000 steps  (21%)
[05:25:00] Completed 55000 out of 250000 steps  (22%)
[05:27:12] - Autosending finished units... [July 19 05:27:12 UTC]
[05:27:12] Trying to send all finished work units
[05:27:12] + No unsent completed units remaining.
[05:27:12] - Autosend completed
[05:59:07] Completed 57500 out of 250000 steps  (23%)
[06:33:02] Completed 60000 out of 250000 steps  (24%)
[07:07:03] Completed 62500 out of 250000 steps  (25%)
[07:41:06] Completed 65000 out of 250000 steps  (26%)
[08:15:05] Completed 67500 out of 250000 steps  (27%)
[08:49:01] Completed 70000 out of 250000 steps  (28%)
[09:23:00] Completed 72500 out of 250000 steps  (29%)
[09:56:54] Completed 75000 out of 250000 steps  (30%)
[10:30:48] Completed 77500 out of 250000 steps  (31%)
[11:04:36] Completed 80000 out of 250000 steps  (32%)
[11:27:12] - Autosending finished units... [July 19 11:27:12 UTC]
[11:27:12] Trying to send all finished work units
[11:27:12] + No unsent completed units remaining.
[11:27:12] - Autosend completed
[11:38:24] Completed 82500 out of 250000 steps  (33%)
[12:12:11] Completed 85000 out of 250000 steps  (34%)
[12:46:02] Completed 87500 out of 250000 steps  (35%)
[13:19:51] Completed 90000 out of 250000 steps  (36%)
[13:53:40] Completed 92500 out of 250000 steps  (37%)
[14:27:28] Completed 95000 out of 250000 steps  (38%)
[15:01:17] Completed 97500 out of 250000 steps  (39%)
[15:35:04] Completed 100000 out of 250000 steps  (40%)
[16:08:50] Completed 102500 out of 250000 steps  (41%)
[16:42:36] Completed 105000 out of 250000 steps  (42%)
[17:16:25] Completed 107500 out of 250000 steps  (43%)
[17:27:12] - Autosending finished units... [July 19 17:27:12 UTC]
[17:50:14] Completed 110000 out of 250000 steps  (44%)
[18:24:00] Completed 112500 out of 250000 steps  (45%)
[18:57:44] Completed 115000 out of 250000 steps  (46%)
[19:31:32] Completed 117500 out of 250000 steps  (47%)
[20:05:15] Completed 120000 out of 250000 steps  (48%)
[20:38:57] Completed 122500 out of 250000 steps  (49%)
[21:12:41] Completed 125000 out of 250000 steps  (50%)
[21:46:26] Completed 127500 out of 250000 steps  (51%)
[22:20:13] Completed 130000 out of 250000 steps  (52%)
[22:54:01] Completed 132500 out of 250000 steps  (53%)
[23:27:12] - Autosending finished units... [July 19 23:27:12 UTC]
[23:27:42] Completed 135000 out of 250000 steps  (54%)
[00:01:28] Completed 137500 out of 250000 steps  (55%)
[00:35:12] Completed 140000 out of 250000 steps  (56%)
[01:08:54] Completed 142500 out of 250000 steps  (57%)
[01:42:41] Completed 145000 out of 250000 steps  (58%)
[02:16:29] Completed 147500 out of 250000 steps  (59%)
[02:50:15] Completed 150000 out of 250000 steps  (60%)
[03:23:58] Completed 152500 out of 250000 steps  (61%)
[03:57:43] Completed 155000 out of 250000 steps  (62%)
[04:31:30] Completed 157500 out of 250000 steps  (63%)
[05:05:15] Completed 160000 out of 250000 steps  (64%)
[05:27:12] - Autosending finished units... [July 20 05:27:12 UTC]
[05:39:02] Completed 162500 out of 250000 steps  (65%)
[06:12:50] Completed 165000 out of 250000 steps  (66%)
[06:46:39] Completed 167500 out of 250000 steps  (67%)
[07:20:28] Completed 170000 out of 250000 steps  (68%)
[07:54:15] Completed 172500 out of 250000 steps  (69%)
[08:28:01] Completed 175000 out of 250000 steps  (70%)
[09:01:50] Completed 177500 out of 250000 steps  (71%)
[09:35:38] Completed 180000 out of 250000 steps  (72%)
[10:09:33] Completed 182500 out of 250000 steps  (73%)
[10:43:22] Completed 185000 out of 250000 steps  (74%)
[11:17:09] Completed 187500 out of 250000 steps  (75%)
[11:27:12] - Autosending finished units... [July 20 11:27:12 UTC]
[11:50:56] Completed 190000 out of 250000 steps  (76%)
[12:25:01] Completed 192500 out of 250000 steps  (77%)
[12:59:10] Completed 195000 out of 250000 steps  (78%)
[13:33:12] Completed 197500 out of 250000 steps  (79%)
[14:07:17] Completed 200000 out of 250000 steps  (80%)
[14:41:20] Completed 202500 out of 250000 steps  (81%)
[15:15:25] Completed 205000 out of 250000 steps  (82%)
[15:49:20] Completed 207500 out of 250000 steps  (83%)
[16:23:11] Completed 210000 out of 250000 steps  (84%)
[16:57:02] Completed 212500 out of 250000 steps  (85%)
[17:27:12] - Autosending finished units... [July 20 17:27:12 UTC]
[17:30:56] Completed 215000 out of 250000 steps  (86%)
[18:05:02] Completed 217500 out of 250000 steps  (87%)
[18:38:52] Completed 220000 out of 250000 steps  (88%)
[19:12:44] Completed 222500 out of 250000 steps  (89%)
[19:46:46] Completed 225000 out of 250000 steps  (90%)
[20:20:48] Completed 227500 out of 250000 steps  (91%)
[20:54:53] Completed 230000 out of 250000 steps  (92%)
[21:28:54] Completed 232500 out of 250000 steps  (93%)
[22:02:56] Completed 235000 out of 250000 steps  (94%)
[22:36:54] Completed 237500 out of 250000 steps  (95%)
[23:10:41] Completed 240000 out of 250000 steps  (96%)
[23:27:12] - Autosending finished units... [July 20 23:27:12 UTC]
[23:44:32] Completed 242500 out of 250000 steps  (97%)
[00:18:19] Completed 245000 out of 250000 steps  (98%)
[00:52:19] Completed 247500 out of 250000 steps  (99%)
[01:26:07] Completed 250000 out of 250000 steps  (100%)
[01:26:18] DynamicWrapper: Finished Work Unit: sleep=10000
[01:26:29]
[01:26:29] Finished Work Unit:
[01:26:29] - Reading up to 56491680 from "work/wudata_08.trr": Read 56491680
[01:26:29] trr file hash check passed.
[01:26:29] - Reading up to 50348432 from "work/wudata_08.xtc": Read 50348432
[01:26:29] xtc file hash check passed.
[01:26:29] edr file hash check passed.
[01:26:29] logfile size: 203301
[01:26:29] Leaving Run
[01:26:33] - Writing 107211353 bytes of core data to disk...
[01:26:34]   ... Done.
[01:26:57] - Shutting down core
[01:26:57]
[01:26:57] Folding@home Core Shutdown: FINISHED_UNIT
[01:27:04] CoreStatus = 64 (100)
[01:27:04] Unit 8 finished with 61 percent of time to deadline remaining.
[01:27:04] Updated performance fraction: 0.853842
[01:27:04] Sending work to server
[01:27:04] Project: 2685 (Run 3, Clone 8, Gen 5)
[01:27:04] + Attempting to send results [July 21 01:27:04 UTC]
[01:27:04] - Reading file work/wuresults_08.dat from core
[01:27:04]   (Read 107211353 bytes from disk)
[01:27:04] Connecting to http://171.67.108.22:8080/
[01:55:11] Posted data.
[01:55:11] Initial: 0000; - Uploaded at ~61 kB/s
[01:55:16] - Averaged speed for that direction ~59 kB/s
[01:55:16] + Results successfully sent
[01:55:16] Thank you for your contribution to Folding@Home.
[01:55:16] + Number of Units Completed: 208
[01:55:24] Trying to send all finished work units
[01:55:24] + No unsent completed units remaining.
[01:55:24] - Preparing to get new work unit...
[01:55:24] Cleaning up work directory
[01:55:27] + Attempting to get work packet
[01:55:27] Passkey found
[01:55:27] - Will indicate memory of 6141 MB
[01:55:27] - Connecting to assignment server
[01:55:27] Connecting to http://assign.stanford.edu:8080/
[01:55:28] Posted data.
[01:55:28] Initial: 43AB; - Successful: assigned to (171.67.108.22).
[01:55:28] + News From Folding@Home: Welcome to Folding@Home
[01:55:29] Loaded queue successfully.
[01:55:29] Connecting to http://171.67.108.22:8080/
[01:55:41] Posted data.
[01:55:41] Initial: 0000; - Receiving payload (expected size: 26602027)
[01:56:19] - Downloaded at ~683 kB/s
[01:56:19] - Averaged speed for that direction ~394 kB/s
[01:56:19] + Received work.
[01:56:19] Trying to send all finished work units
[01:56:19] + No unsent completed units remaining.
[01:56:19] + Closed connections
[01:56:19]
[01:56:19] + Processing work unit
[01:56:19] Core required: FahCore_a3.exe
[01:56:19] Core found.
[01:56:19] Working on queue slot 09 [July 21 01:56:19 UTC]
[01:56:19] + Working ...
[01:56:19] - Calling '.\FahCore_a3.exe -dir work/ -nice 19 -suffix 09 -np 8 -priority 96 -nocpulock -checkpoint 15 -service -forceasm -verbose -lifeline 1516 -version 629'
[01:56:20]
[01:56:20] *------------------------------*
[01:56:20] Folding@Home Gromacs SMP Core
[01:56:20] Version 2.22 (Mar 12, 2010)
[01:56:20]
[01:56:20] Preparing to commence simulation
[01:56:20] - Assembly optimizations manually forced on.
[01:56:20] - Not checking prior termination.
[01:56:24] - Expanded 26601515 -> 32949201 (decompressed 123.8 percent)
[01:56:24] Called DecompressByteArray: compressed_data_size=26601515 data_size=32949201, decompressed_data_size=32949201 diff=0
[01:56:25] - Digital signature verified
[01:56:25]
[01:56:25] Project: 2685 (Run 1, Clone 15, Gen 11)
[01:56:25]
[01:56:25] Assembly optimizations on if available.
[01:56:25] Entering M.D.
[01:56:34] Completed 0 out of 250000 steps  (0%)
[02:30:16] Completed 2500 out of 250000 steps  (1%)
[03:03:56] Completed 5000 out of 250000 steps  (2%)
[03:37:36] Completed 7500 out of 250000 steps  (3%)
[04:11:16] Completed 10000 out of 250000 steps  (4%)
[04:44:57] Completed 12500 out of 250000 steps  (5%)
[05:18:43] Completed 15000 out of 250000 steps  (6%)
[05:27:12] - Autosending finished units... [July 21 05:27:12 UTC]
[05:52:36] Completed 17500 out of 250000 steps  (7%)
[06:26:26] Completed 20000 out of 250000 steps  (8%)
[07:00:19] Completed 22500 out of 250000 steps  (9%)
[07:34:00] Completed 25000 out of 250000 steps  (10%)
[08:07:41] Completed 27500 out of 250000 steps  (11%)
[08:41:23] Completed 30000 out of 250000 steps  (12%)
[09:15:11] Completed 32500 out of 250000 steps  (13%)
[09:48:52] Completed 35000 out of 250000 steps  (14%)
[10:22:33] Completed 37500 out of 250000 steps  (15%)
[10:56:15] Completed 40000 out of 250000 steps  (16%)
[11:27:12] - Autosending finished units... [July 21 11:27:12 UTC]
[11:30:00] Completed 42500 out of 250000 steps  (17%)
[12:03:42] Completed 45000 out of 250000 steps  (18%)
[12:37:28] Completed 47500 out of 250000 steps  (19%)
[13:11:20] Completed 50000 out of 250000 steps  (20%)
[13:45:03] Completed 52500 out of 250000 steps  (21%)
[14:18:50] Completed 55000 out of 250000 steps  (22%)
[14:52:37] Completed 57500 out of 250000 steps  (23%)
[15:26:16] Completed 60000 out of 250000 steps  (24%)
[15:59:56] Completed 62500 out of 250000 steps  (25%)
[16:33:36] Completed 65000 out of 250000 steps  (26%)
[17:07:21] Completed 67500 out of 250000 steps  (27%)
[17:27:12] - Autosending finished units... [July 21 17:27:12 UTC]
[17:40:58] Completed 70000 out of 250000 steps  (28%)
[18:14:42] Completed 72500 out of 250000 steps  (29%)
[18:48:19] Completed 75000 out of 250000 steps  (30%)
[19:21:55] Completed 77500 out of 250000 steps  (31%)
[19:55:32] Completed 80000 out of 250000 steps  (32%)
[20:29:10] Completed 82500 out of 250000 steps  (33%)
[21:02:47] Completed 85000 out of 250000 steps  (34%)
[21:36:24] Completed 87500 out of 250000 steps  (35%)
[22:10:00] Completed 90000 out of 250000 steps  (36%)
[22:43:39] Completed 92500 out of 250000 steps  (37%)
[23:17:16] Completed 95000 out of 250000 steps  (38%)
[23:27:12] - Autosending finished units... [July 21 23:27:12 UTC]
[23:50:51] Completed 97500 out of 250000 steps  (39%)
[00:24:26] Completed 100000 out of 250000 steps  (40%)
[00:58:05] Completed 102500 out of 250000 steps  (41%)
[01:31:42] Completed 105000 out of 250000 steps  (42%)
[02:05:16] Completed 107500 out of 250000 steps  (43%)
[02:38:52] Completed 110000 out of 250000 steps  (44%)
[03:12:32] Completed 112500 out of 250000 steps  (45%)
[03:46:09] Completed 115000 out of 250000 steps  (46%)
[04:19:45] Completed 117500 out of 250000 steps  (47%)
[04:53:20] Completed 120000 out of 250000 steps  (48%)
[05:26:59] Completed 122500 out of 250000 steps  (49%)
[05:27:12] - Autosendin[code]
g finished units... [July 22 05:27:12 UTC]
[06:00:50] Completed 125000 out of 250000 steps (50%)
[06:34:43] Completed 127500 out of 250000 steps (51%)
[07:08:36] Completed 130000 out of 250000 steps (52%)
[07:42:30] Completed 132500 out of 250000 steps (53%)
[08:16:25] Completed 135000 out of 250000 steps (54%)
[08:50:19] Completed 137500 out of 250000 steps (55%)
[09:24:14] Completed 140000 out of 250000 steps (56%)
[09:58:13] Completed 142500 out of 250000 steps (57%)
[10:32:09] Completed 145000 out of 250000 steps (58%)
[/code]
Fahlog
--- Opening Log file [July 22 13:07:42 UTC]
Service: C:\SMP\folding@home-win32-x86
Arguments: -svcstart -smp -bigadv -forceasm -verbosity 9 -d C:\SMP
Launched as a service.
Entered C:\SMP to do work.
[13:07:42] - Ask before connecting: No
[13:07:42] - User name: filu (Team 276)
[13:07:42] - User ID: 7BB258343FAF3D9B
[13:07:42] - Machine ID: 1
[13:07:42]
[13:07:42] Loaded queue successfully.
[13:07:42]
[13:07:42] + Processing work unit
[13:07:42] Core required: FahCore_a3.exe
[13:07:42] - Autosending finished units... [July 22 13:07:42 UTC]
[13:07:42] Trying to send all finished work units
[13:07:42] + No unsent completed units remaining.
[13:07:42] - Autosend completed
[13:07:42] Core found.
[13:07:42] Working on queue slot 09 [July 22 13:07:42 UTC]
[13:07:42] + Working ...
[13:07:42] - Calling '.\FahCore_a3.exe -dir work/ -nice 19 -suffix 09 -np 8 -priority 96 -nocpulock -checkpoint 15 -service -forceasm -verbose -lifeline 1820 -version 629'
[13:07:42]
[13:07:42] *------------------------------*
[13:07:42] Folding@Home Gromacs SMP Core
[13:07:42] Version 2.22 (Mar 12, 2010)
[13:07:42]
[13:07:42] Preparing to commence simulation
[13:07:42] - Ensuring status. Please wait.
[13:07:52] - Assembly optimizations manually forced on.
[13:07:52] - Not checking prior termination.
[13:07:56] - Expanded 26601515 -> 32949201 (decompressed 123.8 percent)
[13:07:56] Called DecompressByteArray: compressed_data_size=26601515 data_size=32949201, decompressed_data_size=32949201 diff=0
[13:07:56] - Digital signature verified
[13:07:56]
[13:07:56] Project: 2685 (Run 1, Clone 15, Gen 11)
[13:07:56]
[13:07:57] Assembly optimizations on if available.
[13:07:57] Entering M.D.
[13:08:02] Using Gromacs checkpoints
[13:08:07] Resuming from checkpoint
[13:08:08] Verified work/wudata_09.log
[13:08:08] Verified work/wudata_09.trr
[13:08:08] Verified work/wudata_09.xtc
[13:08:08] Verified work/wudata_09.edr
[13:08:09] Completed 146800 out of 250000 steps  (58%)
[13:17:02] Completed 147500 out of 250000 steps  (59%)
[13:48:35] Completed 150000 out of 250000 steps  (60%)
[14:20:08] Completed 152500 out of 250000 steps  (61%)
--- Opening Log file [July 22 14:34:57 UTC]
[14:34:57] - Ask before connecting: No
[14:34:57] - User name: filu (Team 276)
[14:34:57] - User ID: 7BB258343FAF3D9B
[14:34:57] - Machine ID: 1
[14:34:57]
[14:34:58] Loaded queue successfully.
[14:34:58]
[14:34:58] + Processing work unit
[14:34:58] Core required: FahCore_a3.exe
[14:34:58] - Autosending finished units... [July 22 14:34:58 UTC]
[14:34:58] Trying to send all finished work units
[14:34:58] + No unsent completed units remaining.
[14:34:58] - Autosend completed
[14:34:58] Core found.
[14:34:58] Working on queue slot 09 [July 22 14:34:58 UTC]
[14:34:58] + Working ...
[14:34:58] - Calling '.\FahCore_a3.exe -dir work/ -nice 19 -suffix 09 -np 8 -priority 96 -nocpulock -checkpoint 15 -service -forceasm -verbose -lifeline 1472 -version 629'
[14:34:58]
[14:34:58] *------------------------------*
[14:34:58] Folding@Home Gromacs SMP Core
[14:34:58] Version 2.22 (Mar 12, 2010)
[14:34:58]
[14:34:58] Preparing to commence simulation
[14:34:58] - Ensuring status. Please wait.
[14:35:08] - Assembly optimizations manually forced on.
[14:35:08] - Not checking prior termination.
[14:35:13] - Expanded 26601515 -> 32949201 (decompressed 123.8 percent)
[14:35:13] Called DecompressByteArray: compressed_data_size=26601515 data_size=32949201, decompressed_data_size=32949201 diff=0
[14:35:13] - Digital signature verified
[14:35:13]
[14:35:13] Project: 2685 (Run 1, Clone 15, Gen 11)
[14:35:13]
[14:35:16] Assembly optimizations on if available.
[14:35:16] Entering M.D.
[14:35:22] Using Gromacs checkpoints
[14:35:28] Resuming from checkpoint
[14:35:28] Verified work/wudata_09.log
[14:35:29] Verified work/wudata_09.trr
[14:35:29] Verified work/wudata_09.xtc
[14:35:29] Verified work/wudata_09.edr
[14:35:30] Completed 152740 out of 250000 steps  (61%)
[15:04:04] Completed 155000 out of 250000 steps  (62%)
[15:35:36] Completed 157500 out of 250000 steps  (63%)
[16:07:06] Completed 160000 out of 250000 steps  (64%)
[16:38:37] Completed 162500 out of 250000 steps  (65%)
[17:10:05] Completed 165000 out of 250000 steps  (66%)
[17:41:36] Completed 167500 out of 250000 steps  (67%)
[18:13:05] Completed 170000 out of 250000 steps  (68%)
[18:44:35] Completed 172500 out of 250000 steps  (69%)
[19:16:05] Completed 175000 out of 250000 steps  (70%)
[19:47:36] Completed 177500 out of 250000 steps  (71%)
[20:19:06] Completed 180000 out of 250000 steps  (72%)
[20:34:58] - Autosending finished units... [July 22 20:34:58 UTC]
[20:34:58] Trying to send all finished work units
[20:34:58] + No unsent completed units remaining.
[20:34:58] - Autosend completed
[20:51:04] Completed 182500 out of 250000 steps  (73%)
[21:22:38] Completed 185000 out of 250000 steps  (74%)
[21:54:21] Completed 187500 out of 250000 steps  (75%)
--- Opening Log file [July 22 22:18:51 UTC]
[22:18:51] - Ask before connecting: No
[22:18:51] - User name: filu (Team 276)
[22:18:51] - User ID: 7BB258343FAF3D9B
[22:18:51] - Machine ID: 1
[22:18:51]
[22:18:51] Loaded queue successfully.
[22:18:51]
[22:18:51] + Processing work unit
[22:18:51] Core required: FahCore_a3.exe
[22:18:51] - Autosending finished units... [July 22 22:18:51 UTC]
[22:18:51] Trying to send all finished work units
[22:18:51] + No unsent completed units remaining.
[22:18:51] - Autosend completed
[22:18:51] Core found.
[22:18:51] Working on queue slot 09 [July 22 22:18:51 UTC]
[22:18:51] + Working ...
[22:18:51] - Calling '.\FahCore_a3.exe -dir work/ -nice 19 -suffix 09 -np 8 -priority 96 -nocpulock -checkpoint 15 -service -forceasm -verbose -lifeline 1496 -version 629'
[22:18:52]
[22:18:52] *------------------------------*
[22:18:52] Folding@Home Gromacs SMP Core
[22:18:52] Version 2.22 (Mar 12, 2010)
[22:18:52]
[22:18:52] Preparing to commence simulation
[22:18:52] - Ensuring status. Please wait.
[22:19:02] - Assembly optimizations manually forced on.
[22:19:02] - Not checking prior termination.
[22:19:11] - Expanded 26601515 -> 32949201 (decompressed 123.8 percent)
[22:19:11] Called DecompressByteArray: compressed_data_size=26601515 data_size=32949201, decompressed_data_size=32949201 diff=0
[22:19:11] - Digital signature verified
[22:19:11]
[22:19:11] Project: 2685 (Run 1, Clone 15, Gen 11)
[22:19:11]
[22:19:14] Assembly optimizations on if available.
[22:19:14] Entering M.D.
[22:19:20] Using Gromacs checkpoints
[22:19:25] Resuming from checkpoint
[22:19:26] Verified work/wudata_09.log
[22:19:26] Verified work/wudata_09.trr
[22:19:26] Verified work/wudata_09.xtc
[22:19:26] Verified work/wudata_09.edr
[22:19:27] Completed 188370 out of 250000 steps  (75%)
[22:40:51] Completed 190000 out of 250000 steps  (76%)
[23:12:32] Completed 192500 out of 250000 steps  (77%)
[23:44:04] Completed 195000 out of 250000 steps  (78%)
[00:15:35] Completed 197500 out of 250000 steps  (79%)
[00:47:08] Completed 200000 out of 250000 steps  (80%)
--- Opening Log file [July 23 00:51:57 UTC]
[00:51:57] - Ask before connecting: No
[00:51:57] - User name: filu (Team 276)
[00:51:57] - User ID: 7BB258343FAF3D9B
[00:51:57] - Machine ID: 1
[00:51:57]
[00:51:57] Loaded queue successfully.
[00:51:57]
[00:51:57] + Processing work unit
[00:51:57] Core required: FahCore_a3.exe
[00:51:57] - Autosending finished units... [July 23 00:51:57 UTC]
[00:51:57] Trying to send all finished work units
[00:51:57] Core found.
[00:51:57] + No unsent completed units remaining.
[00:51:57] - Autosend completed
[00:51:57] Working on queue slot 09 [July 23 00:51:57 UTC]
[00:51:57] + Working ...
[00:51:57] - Calling '.\FahCore_a3.exe -dir work/ -nice 19 -suffix 09 -np 8 -priority 96 -nocpulock -checkpoint 15 -service -forceasm -verbose -lifeline 1652 -version 629'
[00:51:58]
[00:51:58] *------------------------------*
[00:51:58] Folding@Home Gromacs SMP Core
[00:51:58] Version 2.22 (Mar 12, 2010)
[00:51:59]
[00:51:59] Preparing to commence simulation
[00:51:59] - Ensuring status. Please wait.
[00:52:08] - Assembly optimizations manually forced on.
[00:52:08] - Not checking prior termination.
[00:52:13] - Expanded 26601515 -> 32949201 (decompressed 123.8 percent)
[00:52:13] Called DecompressByteArray: compressed_data_size=26601515 data_size=32949201, decompressed_data_size=32949201 diff=0
[00:52:13] - Digital signature verified
[00:52:13]
[00:52:13] Project: 2685 (Run 1, Clone 15, Gen 11)
[00:52:13]
[00:52:16] Assembly optimizations on if available.
[00:52:16] Entering M.D.
[00:52:22] Using Gromacs checkpoints
[00:52:29] Resuming from checkpoint
[00:52:29] Verified work/wudata_09.log
[00:52:29] Verified work/wudata_09.trr
[00:52:30] Verified work/wudata_09.xtc
[00:52:30] Verified work/wudata_09.edr
[00:52:31] Completed 200185 out of 250000 steps  (80%)
[01:21:53] Completed 202500 out of 250000 steps  (81%)
[01:53:28] Completed 205000 out of 250000 steps  (82%)
[02:24:59] Completed 207500 out of 250000 steps  (83%)
[02:56:35] Completed 210000 out of 250000 steps  (84%)
[03:28:07] Completed 212500 out of 250000 steps  (85%)
[03:59:40] Completed 215000 out of 250000 steps  (86%)
[04:31:11] Completed 217500 out of 250000 steps  (87%)
[05:02:44] Completed 220000 out of 250000 steps  (88%)
[05:34:16] Completed 222500 out of 250000 steps  (89%)
[06:05:51] Completed 225000 out of 250000 steps  (90%)
[06:37:47] Completed 227500 out of 250000 steps  (91%)
[06:51:57] - Autosending finished units... [July 23 06:51:57 UTC]
[06:51:57] Trying to send all finished work units
[06:51:57] + No unsent completed units remaining.
[06:51:57] - Autosend completed
[07:09:24] Completed 230000 out of 250000 steps  (92%)
[07:41:00] Completed 232500 out of 250000 steps  (93%)
[08:12:36] Completed 235000 out of 250000 steps  (94%)
[08:44:12] Completed 237500 out of 250000 steps  (95%)
[09:15:48] Completed 240000 out of 250000 steps  (96%)
[09:47:27] Completed 242500 out of 250000 steps  (97%)
[10:19:00] Completed 245000 out of 250000 steps  (98%)
[10:45:27] Service stop request received.
[10:45:27] ***** Got a SIGTERM signal (2)
[10:45:27] Killing all core threads
[10:45:27] Could not get process id information.  Please kill core process manually
Folding@Home Client Shutdown.
[10:46:19]
[10:46:19]
[10:46:19]
[10:46:19]
[10:46:24]
[10:46:24]
[11:31:43]
[11:32:07]
[12:08:59] + -oneunit flag given and have now finished a unit. Exiting.***** Got a SIGTERM signal (2)
[12:08:59] Killing all core threads
[12:08:59] Could not get process id information.  Please kill core process manually
--- Opening Log file [July 23 12:18:42 UTC]
[12:18:42] - Ask before connecting: No
[12:18:42] - User name: filu (Team 276)
[12:18:42] - User ID: 7BB258343FAF3D9B
[12:18:42] - Machine ID: 1
[12:18:42]
[12:18:42] Loaded queue successfully.
[12:18:42] - Preparing to get new work unit...
[12:18:42] Cleaning up work directory
[12:18:42] - Autosending finished units... [July 23 12:18:42 UTC]
[12:18:42] Trying to send all finished work units
[12:18:42] + No unsent completed units remaining.
[12:18:42] - Autosend completed
[12:18:44] + Attempting to get work packet
[12:18:44] Passkey found
[12:18:44] - Will indicate memory of 6141 MB
[12:18:44] - Detect CPU. Vendor: GenuineIntel, Family: 6, Model: 10, Stepping: 5
[12:18:44] - Connecting to assignment server
[12:18:44] Connecting to http://assign.stanford.edu:8080/
[12:18:45] Posted data.
[12:18:45] Initial: 43AB; - Successful: assigned to (171.67.108.22).
[12:18:45] + News From Folding@Home: Welcome to Folding@Home
[12:18:45] Loaded queue successfully.
[12:18:45] Connecting to http://171.67.108.22:8080/
[12:18:54] Posted data.
[12:18:54] Initial: 0000; - Receiving payload (expected size: 24818398)
--- Opening Log file [July 23 12:23:41 UTC]
[12:23:41] - Ask before connecting: No
[12:23:41] - User name: filu (Team 276)
[12:23:41] - User ID: 7BB258343FAF3D9B
[12:23:41] - Machine ID: 1
[12:23:41]
[12:23:41] Loaded queue successfully.
[12:23:41] - Preparing to get new work unit...
[12:23:41] Cleaning up work directory
[12:23:41] - Autosending finished units... [July 23 12:23:41 UTC]
[12:23:41] Trying to send all finished work units
[12:23:41] + No unsent completed units remaining.
[12:23:41] - Autosend completed
[12:23:41] + Attempting to get work packet
[12:23:41] Passkey found
[12:23:41] - Will indicate memory of 6141 MB
[12:23:41] - Detect CPU. Vendor: GenuineIntel, Family: 6, Model: 10, Stepping: 5
[12:23:41] - Connecting to assignment server
[12:23:41] Connecting to http://assign.stanford.edu:8080/
[12:23:41] - Could not CosmHTTPOpen
[12:23:41] + Could not connect to Assignment Server
[12:23:41] Connecting to http://assign2.stanford.edu:80/
[12:23:41] + Could not connect to Assignment Server 2
[12:23:41] + Couldn't get work instructions.
[12:23:41] - Attempt #1  to get work failed, and no other work to do.
Waiting before retry.
[12:23:50] + Attempting to get work packet
[12:23:50] Passkey found
[12:23:50] - Will indicate memory of 6141 MB
[12:23:50] - Connecting to assignment server
[12:23:50] Connecting to http://assign.stanford.edu:8080/
[12:23:50] - Could not CosmHTTPOpen
[12:23:50] + Could not connect to Assignment Server
[12:23:50] Connecting to http://assign2.stanford.edu:80/
[12:23:50] + Could not connect to Assignment Server 2
[12:23:50] + Couldn't get work instructions.
[12:23:50] - Attempt #2  to get work failed, and no other work to do.
[12:24:08] + Attempting to get work packet
[12:24:08] Passkey found
[12:24:08] - Will indicate memory of 6141 MB
[12:24:08] - Connecting to assignment server
[12:24:08] Connecting to http://assign.stanford.edu:8080/
[12:24:08] - Could not CosmHTTPOpen
[12:24:08] + Could not connect to Assignment Server
[12:24:08] Connecting to http://assign2.stanford.edu:80/
[12:24:08] + Could not connect to Assignment Server 2
[12:24:08] + Couldn't get work instructions.
[12:24:08] - Attempt #3  to get work failed, and no other work to do.
[12:24:29] + Attempting to get work packet
[12:24:29] Passkey found
[12:24:29] - Will indicate memory of 6141 MB
[12:24:29] - Connecting to assignment server
[12:24:29] Connecting to http://assign.stanford.edu:8080/
[12:24:29] - Could not CosmHTTPOpen
[12:24:29] + Could not connect to Assignment Server
[12:24:29] Connecting to http://assign2.stanford.edu:80/
[12:24:29] + Could not connect to Assignment Server 2
[12:24:29] + Couldn't get work instructions.
[12:24:29] - Attempt #4  to get work failed, and no other work to do.
--- Opening Log file [July 23 14:07:49 UTC]
Service: C:\SMP\Folding@home-Win32-x86.exe
Arguments: -svcstart -smp -bigadv -verbosity 9 -forceasm -d C:\SMP
[14:07:49] - Ask before connecting: No
[14:07:49] - User name: filu (Team 276)
[14:07:49] - User ID: 4162500453DD2E1E
[14:07:49] - Machine ID: 1
[14:07:49]
[14:07:49] Loaded queue successfully.
[14:07:49] - Preparing to get new work unit...
[14:07:49] Cleaning up work directory
[14:07:49] - Autosending finished units... [July 23 14:07:49 UTC]
[14:07:49] Trying to send all finished work units
[14:07:49] + No unsent completed units remaining.
[14:07:49] - Autosend completed
[14:07:49] + Attempting to get work packet
[14:07:49] Passkey found
[14:07:49] - Will indicate memory of 6141 MB
[14:07:49] - Detect CPU. Vendor: GenuineIntel, Family: 6, Model: 10, Stepping: 5
[14:07:49] - Connecting to assignment server
[14:07:49] Connecting to http://assign.stanford.edu:8080/
[14:07:50] Posted data.
[14:07:50] Initial: 43AB; - Successful: assigned to (171.67.108.22).
[14:07:50] + News From Folding@Home: Welcome to Folding@Home
[14:07:50] Loaded queue successfully.
[14:07:50] Connecting to http://171.67.108.22:8080/
[14:08:01] Posted data.
[14:08:01] Initial: 0000; - Receiving payload (expected size: 24825768)
[14:09:43] - Downloaded at ~237 kB/s
[14:09:43] - Averaged speed for that direction ~363 kB/s
[14:09:43] + Received work.
[14:09:43] + Closed connections
[14:09:43]
[14:09:43] + Processing work unit
[14:09:43] Core required: FahCore_a3.exe
[14:09:43] Core found.
[14:09:43] Working on queue slot 00 [July 23 14:09:43 UTC]
[14:09:43] + Working ...
[14:09:43] - Calling '.\FahCore_a3.exe -dir work/ -nice 19 -suffix 00 -np 8 -priority 96 -nocpulock -checkpoint 15 -service -forceasm -verbose -lifeline 524 -version 629'
[14:09:43]
[14:09:43] *------------------------------*
[14:09:43] Folding@Home Gromacs SMP Core
[14:09:43] Version 2.22 (Mar 12, 2010)
[14:09:43]
[14:09:43] Preparing to commence simulation
[14:09:43] - Assembly optimizations manually forced on.
[14:09:43] - Not checking prior termination.
[14:09:47] - Expanded 24825256 -> 30791309 (decompressed 124.0 percent)
[14:09:47] Called DecompressByteArray: compressed_data_size=24825256 data_size=30791309, decompressed_data_size=30791309 diff=0
[14:09:47] - Digital signature verified
[14:09:47]
[14:09:47] Project: 2684 (Run 2, Clone 13, Gen 11)
[14:09:47]
[14:09:48] Assembly optimizations on if available.
[14:09:48] Entering M.D.
[14:09:58] Completed 0 out of 250000 steps  (0%)
[14:52:57] Completed 2500 out of 250000 steps  (1%)
[15:35:01] Completed 5000 out of 250000 steps  (2%)
[16:16:43] Completed 7500 out of 250000 steps  (3%)
[16:58:15] Completed 10000 out of 250000 steps  (4%)
[17:40:01] Completed 12500 out of 250000 steps  (5%)
[18:21:50] Completed 15000 out of 250000 steps  (6%)
[19:03:20] Completed 17500 out of 250000 steps  (7%)
[19:44:48] Completed 20000 out of 250000 steps  (8%)
[20:07:49] - Autosending finished units... [July 23 20:07:49 UTC]
[20:07:49] Trying to send all finished work units
[20:07:49] + No unsent completed units remaining.
[20:07:49] - Autosend completed
[20:26:47] Completed 22500 out of 250000 steps  (9%)
[21:08:36] Completed 25000 out of 250000 steps  (10%)
[21:50:31] Completed 27500 out of 250000 steps  (11%)
[22:32:00] Completed 30000 out of 250000 steps  (12%)
[23:13:30] Completed 32500 out of 250000 steps  (13%)
[23:55:33] Completed 35000 out of 250000 steps  (14%)
[00:37:11] Completed 37500 out of 250000 steps  (15%)
[01:18:59] Completed 40000 out of 250000 steps  (16%)
[02:01:18] Completed 42500 out of 250000 steps  (17%)
[02:07:49] - Autosending finished units... [July 24 02:07:49 UTC]
[02:07:49] Trying to send all finished work units
[02:07:49] + No unsent completed units remaining.
[02:07:49] - Autosend completed
[02:43:01] Completed 45000 out of 250000 steps  (18%)
[03:24:35] Completed 47500 out of 250000 steps  (19%)
[04:06:29] Completed 50000 out of 250000 steps  (20%)
[04:48:19] Completed 52500 out of 250000 steps  (21%)
[05:30:17] Completed 55000 out of 250000 steps  (22%)
[06:12:11] Completed 57500 out of 250000 steps  (23%)
[06:54:12] Completed 60000 out of 250000 steps  (24%)
[07:36:04] Completed 62500 out of 250000 steps  (25%)
[08:07:49] - Autosending finished units... [July 24 08:07:49 UTC]
[08:07:49] Trying to send all finished work units
[08:07:49] + No unsent completed units remaining.
[08:07:49] - Autosend completed
[08:17:55] Completed 65000 out of 250000 steps  (26%)
[08:59:37] Completed 67500 out of 250000 steps  (27%)
[09:41:49] Completed 70000 out of 250000 steps  (28%)
[10:23:17] Completed 72500 out of 250000 steps  (29%)
[11:05:21] Completed 75000 out of 250000 steps  (30%)
[11:47:09] Completed 77500 out of 250000 steps  (31%)
[12:28:57] Completed 80000 out of 250000 steps  (32%)
[13:11:09] Completed 82500 out of 250000 steps  (33%)
[13:52:50] Completed 85000 out of 250000 steps  (34%)
[14:07:49] - Autosending finished units... [July 24 14:07:49 UTC]
[14:34:29] Completed 87500 out of 250000 steps  (35%)
[14:57:44] Received EVENT= from OS -- shutting down w/ INTERRUPTED signal; events=[CtrlC= Close= Break= Shutdown= LogOff=]
[14:57:44] Folding@home Core Shutdown: INTERRUPTED
[14:57:48] CoreStatus = 66 (102)
[14:57:48] + Shutdown requested by user. Exiting.***** Got a SIGTERM signal (2)
[14:57:48] Killing all core threads
[14:57:48] Could not get process id information.  Please kill core process manually
--- Opening Log file [July 24 14:58:29 UTC]
[14:58:29] - Ask before connecting: No
[14:58:29] - User name: filu (Team 276)
[14:58:29] - User ID: 4162500453DD2E1E
[14:58:29] - Machine ID: 1
[14:58:29]
[14:58:29] Loaded queue successfully.
[14:58:29]
[14:58:29] + Processing work unit
[14:58:29] Core required: FahCore_a3.exe
[14:58:29] - Autosending finished units... [July 24 14:58:29 UTC]
[14:58:29] Trying to send all finished work units
[14:58:29] Core found.
[14:58:29] + No unsent completed units remaining.
[14:58:29] - Autosend completed
[14:58:29] Working on queue slot 00 [July 24 14:58:29 UTC]
[14:58:29] + Working ...
[14:58:29] - Calling '.\FahCore_a3.exe -dir work/ -nice 19 -suffix 00 -np 8 -priority 96 -nocpulock -checkpoint 15 -service -forceasm -verbose -lifeline 1148 -version 629'
[14:58:30]
[14:58:30] *------------------------------*
[14:58:30] Folding@Home Gromacs SMP Core
[14:58:30] Version 2.22 (Mar 12, 2010)
[14:58:30]
[14:58:30] Preparing to commence simulation
[14:58:30] - Assembly optimizations manually forced on.
[14:58:30] - Not checking prior termination.
[14:58:37] - Expanded 24825256 -> 30791309 (decompressed 124.0 percent)
[14:58:37] Called DecompressByteArray: compressed_data_size=24825256 data_size=30791309, decompressed_data_size=30791309 diff=0
[14:58:37] - Digital signature verified
[14:58:37]
[14:58:37] Project: 2684 (Run 2, Clone 13, Gen 11)
[14:58:37]
[14:58:38] Assembly optimizations on if available.
[14:58:38] Entering M.D.
[14:58:44] Using Gromacs checkpoints
[14:58:53] Resuming from checkpoint
[14:58:54] Verified work/wudata_00.log
[14:58:54] Verified work/wudata_00.trr
[14:58:55] Verified work/wudata_00.xtc
[14:58:55] Verified work/wudata_00.edr
[14:58:56] Completed 88725 out of 250000 steps  (35%)
[15:19:18] Received EVENT= from OS -- shutting down w/ INTERRUPTED signal; events=[CtrlC= Close= Break= Shutdown= LogOff=]
[15:19:18] Folding@home Core Shutdown: INTERRUPTED
--- Opening Log file [July 24 15:20:05 UTC]
[15:20:05] - Ask before connecting: No
[15:20:05] - User name: filu (Team 276)
[15:20:05] - User ID: 4162500453DD2E1E
[15:20:05] - Machine ID: 1
[15:20:05]
[15:20:05] Loaded queue successfully.
[15:20:05]
[15:20:05] + Processing work unit
[15:20:05] Core required: FahCore_a3.exe
[15:20:05] - Autosending finished units... [July 24 15:20:05 UTC]
[15:20:05] Trying to send all finished work units
[15:20:05] + No unsent completed units remaining.
[15:20:05] - Autosend completed
[15:20:05] Core found.
[15:20:05] Working on queue slot 00 [July 24 15:20:05 UTC]
[15:20:05] + Working ...
[15:20:05] - Calling '.\FahCore_a3.exe -dir work/ -nice 19 -suffix 00 -np 8 -priority 96 -nocpulock -checkpoint 15 -service -forceasm -verbose -lifeline 1204 -version 629'
[15:20:05]
[15:20:05] *------------------------------*
[15:20:05] Folding@Home Gromacs SMP Core
[15:20:05] Version 2.22 (Mar 12, 2010)
[15:20:05]
[15:20:05] Preparing to commence simulation
[15:20:05] - Assembly optimizations manually forced on.
[15:20:05] - Not checking prior termination.
[15:20:09] - Expanded 24825256 -> 30791309 (decompressed 124.0 percent)
[15:20:09] Called DecompressByteArray: compressed_data_size=24825256 data_size=30791309, decompressed_data_size=30791309 diff=0
[15:20:09] - Digital signature verified
[15:20:09]
[15:20:09] Project: 2684 (Run 2, Clone 13, Gen 11)
[15:20:09]
[15:20:10] Assembly optimizations on if available.
[15:20:10] Entering M.D.
[15:20:16] Using Gromacs checkpoints
[15:20:23] Resuming from checkpoint
[15:20:24] Verified work/wudata_00.log
[15:20:25] Verified work/wudata_00.trr
[15:20:25] Verified work/wudata_00.xtc
[15:20:25] Verified work/wudata_00.edr
[15:20:26] Completed 89435 out of 250000 steps  (35%)
[15:30:02] Completed 90000 out of 250000 steps  (36%)
[16:14:14] Completed 92500 out of 250000 steps  (37%)
[16:55:33] Completed 95000 out of 250000 steps  (38%)
2x Xeon 5620 6x 2GB
2x Xeon 5645 6x 2GB
Punchy
Post by Punchy »
Did you copy this same FAH setup including work folders to another location (on this system or another) and run it simultaneously?
filu
Post by filu »
I never do in this way
2x Xeon 5620 6x 2GB
2x Xeon 5645 6x 2GB
Punchy
Post by Punchy »
Do you have any other systems running bigadv? If so, I'd check their logs for the same WU.
Personally, I prefer to track all my bigadv WUs by using my passkey as a search option here: (http://fah-web.stanford.edu/cgi-bin/mai ... =userstats)
filu
Re: Project: 2685 (Run 1, Clone 15, Gen 11)
Post by filu »
Punchy wrote:Do you have any other systems running bigadv? If so, I'd check their logs for the same WU.
I have two computers dedicated to bigadv calculations. At each one I have only one operating system, and never moving a work folder and file queue.dat between f@h clients.
2x Xeon 5620 6x 2GB
2x Xeon 5645 6x 2GB
Punchy
Post by Punchy »
filu wrote: I have two computers dedicated to bigadv calculations. At each one I have only one operating system, and never moving a work folder and file queue.dat between f@h clients.
Have you checked the logs of the other computer running bigadv? There is always the potential of an assignment server issue, and perhaps your second computer received the same WU and returned the errors that the mods see in the logs.
