Multiple Successful Uploads, Same WU
Racer43
Post by Racer43 »
I am having problems with the following three WU.
P5744 R1 C85 G203
I have received, processed and successfully returned this project 3 times, all on 7/5/10.
P5744 R2 C287 G0
I have received, processed and successfully returned this project 5 times, once on 7/6/10 and 4 times on 7/7/10.
P5740 R0 C350 G0
I have received, processed and successfully returned this project 2 times, and it is currently processing for a 3rd time as I write, all on 7/8/10.
Any ideas? :shock: :shock:
Team 163828, Always Broke Folding :mrgreen:
Folding towards the Top 1000 teams with: a Phenom II X2 laptop and an Athlon 64 X2 5000+ with a Sapphire HD 6570 :shock:
Re: Multiple Successful Uploads, Same WU
Can you show us the FAHlog.txt file. Without it, we can't tell you your uploads are correct.
Racer43
Post by Racer43 »
From what I see here, they all uploaded correctly.
Added code tags. ~sorto'
[b][20:26:31] Project: 5744 (Run 1, Clone 85, Gen 203)[/b]
[20:26:31] Assembly optimizations on if available.
[20:26:31] Entering M.D.
[20:26:36] Tpr hash work/wudata_08.tpr:  2077751607 553612916 2565899292 2751529153 2739341835
[20:26:37] Working on Protein
[20:26:37] Client config found, loading data.
[20:26:37] Starting GUI Server
[20:29:04] Completed 1%
[00:21:59] Completed 100%
[00:21:59] Successful run
[00:21:59] DynamicWrapper: Finished Work Unit: sleep=10000
[00:22:10] Reserved 153456 bytes for xtc file; Cosm status=0
[00:22:10] Allocated 153456 bytes for xtc file
[00:22:10] - Reading up to 153456 from "work/wudata_08.xtc": Read 153456
[00:22:10] Read 153456 bytes from xtc file; available packet space=786277008
[00:22:10] xtc file hash check passed.
[00:22:10] Reserved 23472 23472 786277008 bytes for arc file=<work/wudata_08.trr> Cosm status=0
[00:22:10] Allocated 23472 bytes for arc file
[00:22:10] - Reading up to 23472 from "work/wudata_08.trr": Read 23472
[00:22:10] Read 23472 bytes from arc file; available packet space=786253536
[00:22:10] trr file hash check passed.
[00:22:10] Allocated 560 bytes for edr file
[00:22:10] Read bedfile
[00:22:10] edr file hash check passed.
[00:22:10] Allocated 0 bytes for logfile
[00:22:10] Could not open/read logfile=<work/wudata_08.log>; Cosm status=-1
[00:22:10] GuardedRun: success in DynamicWrapper
[00:22:10] GuardedRun: done
[00:22:10] Run: GuardedRun completed.
[00:22:13] - Writing 178000 bytes of core data to disk...
[00:22:13] Done: 177488 -> 176070 (compressed to 99.2 percent)
[00:22:13]   ... Done.
[00:22:13] - Shutting down core
[00:22:13]
[00:22:13] Folding@home Core Shutdown: FINISHED_UNIT
[00:22:16] CoreStatus = 64 (100)
[00:22:16] Unit 8 finished with 95 percent of time to deadline remaining.
[00:22:16] Updated performance fraction: 0.904591
[00:22:16] Sending work to server
[00:22:16] Project: 5744 (Run 1, Clone 85, Gen 203)
[00:22:16] - Read packet limit of 540015616... Set to 524286976.
[00:22:16] + Attempting to send results [July 5 00:22:16 UTC]
[00:22:16] - Reading file work/wuresults_08.dat from core
[00:22:16]   (Read 176582 bytes from disk)
[00:22:16] Connecting to http://171.64.65.102:8080/
[00:22:20] Posted data.
[00:22:21] Initial: 0000; - Uploaded at ~34 kB/s
[00:22:21] - Averaged speed for that direction ~39 kB/s
[b][00:22:21] + Results successfully sent
[00:22:21] Thank you for your contribution to Folding@Home.
[00:22:21] + Number of Units Completed: 322[/b]
[00:22:45] Project: 5745 (Run 4, Clone 120, Gen 123)
[00:22:45] Assembly optimizations on if available.
[00:22:45] Entering M.D.
[00:22:51] Tpr hash work/wudata_09.tpr:  1568299775 249066397 3074246375 3263264893 3842544858
[00:22:51] Working on Protein
[00:22:52] Client config found, loading data.
[00:22:52] Starting GUI Server
[00:25:19] Completed 1%
[04:26:08] Completed 100%
[04:26:08] Successful run
[04:26:08] DynamicWrapper: Finished Work Unit: sleep=10000
[04:26:18] Reserved 153912 bytes for xtc file; Cosm status=0
[04:26:18] Allocated 153912 bytes for xtc file
[04:26:18] - Reading up to 153912 from "work/wudata_09.xtc": Read 153912
[04:26:18] Read 153912 bytes from xtc file; available packet space=786276552
[04:26:18] xtc file hash check passed.
[04:26:18] Reserved 23472 23472 786276552 bytes for arc file=<work/wudata_09.trr> Cosm status=0
[04:26:18] Allocated 23472 bytes for arc file
[04:26:18] - Reading up to 23472 from "work/wudata_09.trr": Read 23472
[04:26:18] Read 23472 bytes from arc file; available packet space=786253080
[04:26:18] trr file hash check passed.
[04:26:18] Allocated 560 bytes for edr file
[04:26:18] Read bedfile
[04:26:18] edr file hash check passed.
[04:26:18] Allocated 0 bytes for logfile
[04:26:18] Could not open/read logfile=<work/wudata_09.log>; Cosm status=-1
[04:26:18] GuardedRun: success in DynamicWrapper
[04:26:18] GuardedRun: done
[04:26:18] Run: GuardedRun completed.
[04:26:21] - Writing 178456 bytes of core data to disk...
[04:26:21] Done: 177944 -> 176569 (compressed to 99.2 percent)
[04:26:21] - Shutting down core
[04:26:21] Folding@home Core Shutdown: FINISHED_UNIT
[04:26:25] CoreStatus = 64 (100)
[04:26:25] Unit 9 finished with 94 percent of time to deadline remaining.
[04:26:25] Updated performance fraction: 0.912391
[04:26:25] Sending work to server
[04:26:25] Project: 5745 (Run 4, Clone 120, Gen 123)
[04:26:25] - Read packet limit of 540015616... Set to 524286976.
[04:26:25] + Attempting to send results [July 5 04:26:25 UTC]
[04:26:25] - Reading file work/wuresults_09.dat from core
[04:26:25]   (Read 177081 bytes from disk)
[04:26:25] Connecting to http://171.64.65.102:8080/
[04:26:29] Posted data.
[04:26:29] Initial: 0000; - Uploaded at ~43 kB/s
[04:26:29] - Averaged speed for that direction ~40 kB/s
[04:26:29] + Results successfully sent
[04:26:29] Thank you for your contribution to Folding@Home.
[04:26:29] + Number of Units Completed: 323
[04:26:51] Folding@Home GPU Core - Beta
[04:26:51] Version 1.24 (Mon Feb 9 11:00:12 PST 2009)
[04:26:51]
[04:26:51] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[04:26:51] Build host: amoeba
[04:26:51] Board Type: AMD
[04:26:51] Core      :
[04:26:51] Preparing to commence simulation
[04:26:51] - Looking at optimizations...
[04:26:51] - Created dyn
[04:26:51] - Files status OK
[04:26:52] - Expanded 68565 -> 357580 (decompressed 521.5 percent)
[04:26:52] Called DecompressByteArray: compressed_data_size=68565 data_size=357580, decompressed_data_size=357580 diff=0
[04:26:52] - Digital signature verified
[b][04:26:52] Project: 5744 (Run 1, Clone 85, Gen 203)[/b]
[04:26:52]
[04:26:52] Assembly optimizations on if available.
[04:26:52] Entering M.D.
[04:26:57] Tpr hash work/wudata_00.tpr:  2077751607 553612916 2565899292 2751529153 2739341835
[04:26:58] Working on Protein
[04:26:58] Client config found, loading data.
[04:26:58] Starting GUI Server
[04:29:26] Completed 1%
[08:23:36] Completed 100%
[08:23:36] Successful run
[08:23:36] DynamicWrapper: Finished Work Unit: sleep=10000
[08:23:47] Reserved 153456 bytes for xtc file; Cosm status=0
[08:23:47] Allocated 153456 bytes for xtc file
[08:23:47] - Reading up to 153456 from "work/wudata_00.xtc": Read 153456
[08:23:47] Read 153456 bytes from xtc file; available packet space=786277008
[08:23:47] xtc file hash check passed.
[08:23:47] Reserved 23472 23472 786277008 bytes for arc file=<work/wudata_00.trr> Cosm status=0
[08:23:47] Allocated 23472 bytes for arc file
[08:23:47] - Reading up to 23472 from "work/wudata_00.trr": Read 23472
[08:23:47] Read 23472 bytes from arc file; available packet space=786253536
[08:23:47] trr file hash check passed.
[08:23:47] Allocated 560 bytes for edr file
[08:23:47] Read bedfile
[08:23:47] edr file hash check passed.
[08:23:47] Allocated 0 bytes for logfile
[08:23:47] Could not open/read logfile=<work/wudata_00.log>; Cosm status=-1
[08:23:47] GuardedRun: success in DynamicWrapper
[08:23:47] GuardedRun: done
[08:23:47] Run: GuardedRun completed.
[08:23:48] - Writing 178000 bytes of core data to disk...
[08:23:48] Done: 177488 -> 176070 (compressed to 99.2 percent)
[08:23:48] - Shutting down core
[08:23:48] Folding@home Core Shutdown: FINISHED_UNIT
[08:23:52] CoreStatus = 64 (100)
[08:23:52] Unit 0 finished with 95 percent of time to deadline remaining.
[08:23:52] Updated performance fraction: 0.918940
[08:23:52] Sending work to server
[08:23:52] Project: 5744 (Run 1, Clone 85, Gen 203)
[08:23:52] - Read packet limit of 540015616... Set to 524286976.
[08:23:52] + Attempting to send results [July 5 08:23:52 UTC]
[08:23:52] - Reading file work/wuresults_00.dat from core
[08:23:52]   (Read 176582 bytes from disk)
[08:23:52] Connecting to http://171.64.65.102:8080/
[08:23:56] Posted data.
[08:23:56] Initial: 0000; - Uploaded at ~43 kB/s
[08:23:56] - Averaged speed for that direction ~41 kB/s
[b][08:23:56] + Results successfully sent
[08:23:56] Thank you for your contribution to Folding@Home.
[08:23:56] + Number of Units Completed: 324[/b]
[08:24:15] Project: 5736 (Run 1, Clone 252, Gen 0)
[08:24:15]
[08:24:15] Assembly optimizations on if available.
[08:24:15] Entering M.D.
[08:24:21] Tpr hash work/wudata_01.tpr:  3576427608 1401349316 219440573 706501138 2040578082
[08:24:21] Working on Protein
[08:24:22] Client config found, loading data.
[08:24:22] Starting GUI Server
[08:29:04] Completed 1%
[16:16:52] Completed 100%
[16:16:52] Successful run
[16:17:02] GuardedRun: success in DynamicWrapper
[16:17:02] GuardedRun: done
[16:17:02] Run: GuardedRun completed.
[16:17:05] - Writing 253672 bytes of core data to disk...
[16:17:06] Done: 253160 -> 252166 (compressed to 99.6 percent)
[16:17:07] Folding@home Core Shutdown: FINISHED_UNIT
[16:17:11] CoreStatus = 64 (100)
[16:17:11] Unit 1 finished with 89 percent of time to deadline remaining.
[16:17:11] Updated performance fraction: 0.913257
[16:17:11] Sending work to server
[16:17:11] Project: 5736 (Run 1, Clone 252, Gen 0)
[16:17:11] - Read packet limit of 540015616... Set to 524286976.
[16:17:17] + Results successfully sent
[16:17:17] Thank you for your contribution to Folding@Home.
[16:17:17] + Number of Units Completed: 325
[16:18:04]
[16:18:04] *------------------------------*
[16:18:04] Folding@Home GPU Core - Beta
[16:18:04] Version 1.24 (Mon Feb 9 11:00:12 PST 2009)
[16:18:04]
[16:18:04] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[16:18:04] Build host: amoeba
[16:18:04] Board Type: AMD
[16:18:04] Core      :
[16:18:04] Preparing to commence simulation
[16:18:04] - Looking at optimizations...
[16:18:04] - Created dyn
[16:18:04] - Files status OK
[16:18:04] - Expanded 68565 -> 357580 (decompressed 521.5 percent)
[16:18:04] Called DecompressByteArray: compressed_data_size=68565 data_size=357580, decompressed_data_size=357580 diff=0
[16:18:04] - Digital signature verified
[16:18:04]
[b][16:18:04] Project: 5744 (Run 1, Clone 85, Gen 203)[/b]
[16:18:04]
[16:18:04] Assembly optimizations on if available.
[16:18:04] Entering M.D.
[16:18:10] Tpr hash work/wudata_02.tpr:  2077751607 553612916 2565899292 2751529153 2739341835
[16:18:10] Working on Protein
[16:18:11] Client config found, loading data.
[16:18:11] Starting GUI Server
[16:21:02] Completed 1%
[20:13:48] Completed 100%
[20:13:48] Successful run
[20:13:48] DynamicWrapper: Finished Work Unit: sleep=10000
[20:13:58] Reserved 153456 bytes for xtc file; Cosm status=0
[20:13:58] Allocated 153456 bytes for xtc file
[20:13:58] - Reading up to 153456 from "work/wudata_02.xtc": Read 153456
[20:13:58] Read 153456 bytes from xtc file; available packet space=786277008
[20:13:58] xtc file hash check passed.
[20:13:58] Reserved 23472 23472 786277008 bytes for arc file=<work/wudata_02.trr> Cosm status=0
[20:13:58] Allocated 23472 bytes for arc file
[20:13:58] - Reading up to 23472 from "work/wudata_02.trr": Read 23472
[20:13:58] Read 23472 bytes from arc file; available packet space=786253536
[20:13:58] trr file hash check passed.
[20:13:58] Allocated 560 bytes for edr file
[20:13:58] Read bedfile
[20:13:58] edr file hash check passed.
[20:13:58] Allocated 0 bytes for logfile
[20:13:58] Could not open/read logfile=<work/wudata_02.log>; Cosm status=-1
[20:13:58] GuardedRun: success in DynamicWrapper
[20:13:58] GuardedRun: done
[20:13:58] Run: GuardedRun completed.
[20:14:00] - Writing 178000 bytes of core data to disk...
[20:14:00] Done: 177488 -> 176070 (compressed to 99.2 percent)
[20:14:00]   ... Done.
[20:14:01] - Shutting down core
[20:14:01]
[20:14:01] Folding@home Core Shutdown: FINISHED_UNIT
[20:14:04] CoreStatus = 64 (100)
[20:14:04] Unit 2 finished with 95 percent of time to deadline remaining.
[20:14:04] Updated performance fraction: 0.919680
[20:14:04] Sending work to server
[20:14:04] Project: 5744 (Run 1, Clone 85, Gen 203)
[20:14:04] - Read packet limit of 540015616... Set to 524286976.
[20:14:04] + Attempting to send results [July 5 20:14:04 UTC]
[20:14:04] - Reading file work/wuresults_02.dat from core
[20:14:04]   (Read 176582 bytes from disk)
[20:14:04] Connecting to http://171.64.65.102:8080/
[20:14:08] Posted data.
[20:14:08] Initial: 0000; - Uploaded at ~43 kB/s
[20:14:08] - Averaged speed for that direction ~41 kB/s
[b][20:14:08] + Results successfully sent
[20:14:08] Thank you for your contribution to Folding@Home.
[20:14:08] + Number of Units Completed: 326[/b]
[20:14:20] + Processing work unit
[20:14:20] Core required: FahCore_11.exe
[20:14:20] Core found.
[20:14:20] Working on queue slot 03 [July 5 20:14:20 UTC]
[20:14:20] + Working ...
[20:14:20] - Calling '.\FahCore_11.exe -dir work/ -suffix 03 -priority 96 -checkpoint 3 -verbose -lifeline 1732 -version 623'
[20:14:20] Project: 5733 (Run 0, Clone 271, Gen 1)
[20:14:28] Starting GUI Server
[20:19:09] Completed 1%
[03:54:12] Completed 100%
[03:54:13] Successful run
[03:54:26] Folding@home Core Shutdown: FINISHED_UNIT
[03:54:30] CoreStatus = 64 (100)
[03:54:30] Unit 3 finished with 89 percent of time to deadline remaining.
[03:54:30] Updated performance fraction: 0.914440
[03:54:30] Sending work to server
[03:54:30] Project: 5733 (Run 0, Clone 271, Gen 1)
[03:54:30] - Read packet limit of 540015616... Set to 524286976.
[03:54:35] + Results successfully sent
[03:54:35] Thank you for your contribution to Folding@Home.
[03:54:35] + Number of Units Completed: 327
[03:54:41] Project: 5737 (Run 0, Clone 256, Gen 1)
[03:54:41] Assembly optimizations on if available.
[03:54:41] Entering M.D.
[03:54:47] Tpr hash work/wudata_04.tpr:  200620731 2517496847 4089926994 1542391023 2472681336
[03:54:48] Working on Protein
[03:54:49] Client config found, loading data.
[03:54:49] Starting GUI Server
[03:59:30] Completed 1%
[11:42:29] Completed 100%
[11:42:29] Successful run
[11:42:44] Folding@home Core Shutdown: FINISHED_UNIT
[11:42:47] CoreStatus = 64 (100)
[11:42:47] Unit 4 finished with 89 percent of time to deadline remaining.
[11:42:47] Updated performance fraction: 0.909881
[11:42:47] Sending work to server
[11:42:47] Project: 5737 (Run 0, Clone 256, Gen 1)
[11:42:47] - Read packet limit of 540015616... Set to 524286976.
[11:42:54] Project: 5737 (Run 0, Clone 256, Gen 1)
[11:42:54] - Read packet limit of 540015616... Set to 524286976.
[11:43:02] + Results successfully sent
[11:43:02] Thank you for your contribution to Folding@Home.
[11:43:02] + Number of Units Completed: 328
[11:43:03] Project: 5737 (Run 2, Clone 290, Gen 0)
[11:43:03] Assembly optimizations on if available.
[11:43:03] Entering M.D.
[11:43:10] Tpr hash work/wudata_05.tpr:  1565513225 4198790007 1599240319 4163108737 841469523
[11:43:10] Working on Protein
[11:43:12] Client config found, loading data.
[11:43:12] Starting GUI Server
[11:48:32] Completed 1%
[19:28:13] Completed 100%
[19:28:13] Successful run
[19:28:24] Folding@home Core Shutdown: FINISHED_UNIT
[19:28:28] CoreStatus = 64 (100)
[19:28:28] Unit 5 finished with 89 percent of time to deadline remaining.
[19:28:28] Updated performance fraction: 0.906357
[19:28:28] Sending work to server
[19:28:28] Project: 5737 (Run 2, Clone 290, Gen 0)
[19:28:28] - Read packet limit of 540015616... Set to 524286976.
[19:28:33] + Results successfully sent
[19:28:33] Thank you for your contribution to Folding@Home.
[19:28:33] + Number of Units Completed: 329
[19:28:39]
[19:28:39] *------------------------------*
[19:28:39] Folding@Home GPU Core - Beta
[19:28:39] Version 1.24 (Mon Feb 9 11:00:12 PST 2009)
[19:28:39] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[19:28:39] Build host: amoeba
[19:28:39] Board Type: AMD
[19:28:39] Core      :
[19:28:39] Preparing to commence simulation
[19:28:39] - Looking at optimizations...
[19:28:39] - Created dyn
[19:28:39] - Files status OK
[19:28:39] - Expanded 64741 -> 357580 (decompressed 552.3 percent)
[19:28:39] Called DecompressByteArray: compressed_data_size=64741 data_size=357580, decompressed_data_size=357580 diff=0
[19:28:39] - Digital signature verified
[19:28:39]
[b][19:28:39] Project: 5744 (Run 2, Clone 287, Gen 0)[/b]
[19:28:39]
[19:28:39] Assembly optimizations on if available.
[19:28:39] Entering M.D.
[19:28:45] Tpr hash work/wudata_06.tpr:  390798426 4280854593 2646104359 1365375954 4104247605
[19:28:46] Working on Protein
[19:28:47] Client config found, loading data.
[19:28:47] Starting GUI Server
[19:31:13] Completed 1%
[23:23:31] Completed 100%
[23:23:31] Successful run
[23:23:31] DynamicWrapper: Finished Work Unit: sleep=10000
[23:23:41] Reserved 153852 bytes for xtc file; Cosm status=0
[23:23:41] Allocated 153852 bytes for xtc file
[23:23:41] - Reading up to 153852 from "work/wudata_06.xtc": Read 153852
[23:23:41] Read 153852 bytes from xtc file; available packet space=786276612
[23:23:41] xtc file hash check passed.
[23:23:41] Reserved 23472 23472 786276612 bytes for arc file=<work/wudata_06.trr> Cosm status=0
[23:23:41] Allocated 23472 bytes for arc file
[23:23:41] - Reading up to 23472 from "work/wudata_06.trr": Read 23472
[23:23:41] Read 23472 bytes from arc file; available packet space=786253140
[23:23:41] trr file hash check passed.
[23:23:41] Allocated 560 bytes for edr file
[23:23:41] Read bedfile
[23:23:41] edr file hash check passed.
[23:23:41] Allocated 0 bytes for logfile
[23:23:41] Could not open/read logfile=<work/wudata_06.log>; Cosm status=-1
[23:23:41] GuardedRun: success in DynamicWrapper
[23:23:41] GuardedRun: done
[23:23:41] Run: GuardedRun completed.
[23:23:43] - Writing 178396 bytes of core data to disk...
[23:23:43] Done: 177884 -> 176512 (compressed to 99.2 percent)
[23:23:43]   ... Done.
[23:23:44] - Shutting down core
[23:23:44]
[23:23:44] Folding@home Core Shutdown: FINISHED_UNIT
[23:23:47] CoreStatus = 64 (100)
[23:23:47] Unit 6 finished with 95 percent of time to deadline remaining.
[23:23:47] Updated performance fraction: 0.914200
[23:23:47] Sending work to server
[23:23:47] Project: 5744 (Run 2, Clone 287, Gen 0)
[23:23:47] - Read packet limit of 540015616... Set to 524286976.
[23:23:47] + Attempting to send results [July 6 23:23:47 UTC]
[23:23:47] - Reading file work/wuresults_06.dat from core
[23:23:47]   (Read 177024 bytes from disk)
[23:23:47] Connecting to http://171.64.65.102:8080/
[23:23:51] Posted data.
[23:23:51] Initial: 0000; - Uploaded at ~43 kB/s
[23:23:51] - Averaged speed for that direction ~43 kB/s
[b][23:23:51] + Results successfully sent
[23:23:51] Thank you for your contribution to Folding@Home.
[23:23:51] + Number of Units Completed: 330[/b]
[23:26:57] Folding@Home GPU Core - Beta
[23:26:57] Version 1.24 (Mon Feb 9 11:00:12 PST 2009)
[23:26:57]
[23:26:57] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[23:26:57] Build host: amoeba
[23:26:57] Board Type: AMD
[23:26:57] Core      :
[23:26:57] Preparing to commence simulation
[23:26:57] - Looking at optimizations...
[23:26:57] - Created dyn
[23:26:57] - Files status OK
[23:26:57] - Expanded 64741 -> 357580 (decompressed 552.3 percent)
[23:26:57] Called DecompressByteArray: compressed_data_size=64741 data_size=357580, decompressed_data_size=357580 diff=0
[23:26:57] - Digital signature verified
[23:26:57]
[b][23:26:57] Project: 5744 (Run 2, Clone 287, Gen 0)[/b]
[23:26:57]
[23:26:57] Assembly optimizations on if available.
[23:26:57] Entering M.D.
[23:27:03] Tpr hash work/wudata_07.tpr:  390798426 4280854593 2646104359 1365375954 4104247605
[23:27:04] Working on Protein
[23:27:04] Client config found, loading data.
[23:27:04] Starting GUI Server
[23:29:30] Completed 1%
[03:25:37] Completed 100%
[03:25:37] Successful run
[03:25:37] DynamicWrapper: Finished Work Unit: sleep=10000
[03:25:47] Reserved 153852 bytes for xtc file; Cosm status=0
[03:25:47] Allocated 153852 bytes for xtc file
[03:25:47] - Reading up to 153852 from "work/wudata_07.xtc": Read 153852
[03:25:47] Read 153852 bytes from xtc file; available packet space=786276612
[03:25:47] xtc file hash check passed.
[03:25:47] Reserved 23472 23472 786276612 bytes for arc file=<work/wudata_07.trr> Cosm status=0
[03:25:47] Allocated 23472 bytes for arc file
[03:25:47] - Reading up to 23472 from "work/wudata_07.trr": Read 23472
[03:25:47] Read 23472 bytes from arc file; available packet space=786253140
[03:25:47] trr file hash check passed.
[03:25:47] Allocated 560 bytes for edr file
[03:25:47] Read bedfile
[03:25:47] edr file hash check passed.
[03:25:47] Allocated 18937 bytes for logfile
[03:25:47] Read logfile
[03:25:47] GuardedRun: success in DynamicWrapper
[03:25:47] GuardedRun: done
[03:25:47] Run: GuardedRun completed.
[03:25:49] - Writing 197333 bytes of core data to disk...
[03:25:49] Done: 196821 -> 184278 (compressed to 93.6 percent)
[03:25:49]   ... Done.
[03:25:49] - Shutting down core
[03:25:49]
[03:25:49] Folding@home Core Shutdown: FINISHED_UNIT
[03:25:53] CoreStatus = 64 (100)
[03:25:53] Unit 7 finished with 94 percent of time to deadline remaining.
[03:25:53] Updated performance fraction: 0.920298
[03:25:53] Sending work to server
[03:25:53] Project: 5744 (Run 2, Clone 287, Gen 0)
[03:25:53] - Read packet limit of 540015616... Set to 524286976.
[03:25:53] + Attempting to send results [July 7 03:25:53 UTC]
[03:25:53] - Reading file work/wuresults_07.dat from core
[03:25:53]   (Read 184790 bytes from disk)
[03:25:53] Connecting to http://171.64.65.102:8080/
[03:25:57] Posted data.
[03:25:57] Initial: 0000; - Uploaded at ~45 kB/s
[03:25:57] - Averaged speed for that direction ~43 kB/s
[b][03:25:57] + Results successfully sent
[03:25:57] Thank you for your contribution to Folding@Home.
[03:25:57] + Number of Units Completed: 331[/b]
[03:26:03] Project: 5740 (Run 4, Clone 321, Gen 0)
[03:26:03]
[03:26:03] Assembly optimizations on if available.
[03:26:03] Entering M.D.
[03:26:09] Tpr hash work/wudata_08.tpr:  1197349152 215434372 2548856567 2253879003 2297470116
[03:26:09] Working on Protein
[03:26:10] Client config found, loading data.
[03:26:10] Starting GUI Server
[03:28:41] Completed 1%
[07:21:35] Completed 100%
[07:21:35] Successful run
[07:21:35] DynamicWrapper: Finished Work Unit: sleep=10000
[07:21:45] Reserved 153724 bytes for xtc file; Cosm status=0
[07:21:45] Allocated 153724 bytes for xtc file
[07:21:45] - Reading up to 153724 from "work/wudata_08.xtc": Read 153724
[07:21:45] Read 153724 bytes from xtc file; available packet space=786276740
[07:21:45] xtc file hash check passed.
[07:21:45] Reserved 23472 23472 786276740 bytes for arc file=<work/wudata_08.trr> Cosm status=0
[07:21:45] Allocated 23472 bytes for arc file
[07:21:45] - Reading up to 23472 from "work/wudata_08.trr": Read 23472
[07:21:45] Read 23472 bytes from arc file; available packet space=786253268
[07:21:45] trr file hash check passed.
[07:21:45] Allocated 560 bytes for edr file
[07:21:45] Read bedfile
[07:21:45] edr file hash check passed.
[07:21:45] Allocated 0 bytes for logfile
[07:21:45] Could not open/read logfile=<work/wudata_08.log>; Cosm status=-1
[07:21:45] GuardedRun: success in DynamicWrapper
[07:21:45] GuardedRun: done
[07:21:45] Run: GuardedRun completed.
[07:21:48] - Writing 178268 bytes of core data to disk...
[07:21:48] Done: 177756 -> 176355 (compressed to 99.2 percent)
[07:21:48]   ... Done.
[07:21:48] - Shutting down core
[07:21:48]
[07:21:48] Folding@home Core Shutdown: FINISHED_UNIT
[07:21:51] CoreStatus = 64 (100)
[07:21:51] Unit 8 finished with 95 percent of time to deadline remaining.
[07:21:51] Updated performance fraction: 0.925322
[07:21:51] Sending work to server
[07:21:51] Project: 5740 (Run 4, Clone 321, Gen 0)
[07:21:51] - Read packet limit of 540015616... Set to 524286976.
[07:21:51] + Attempting to send results [July 7 07:21:51 UTC]
[07:21:51] - Reading file work/wuresults_08.dat from core
[07:21:51]   (Read 176867 bytes from disk)
[07:21:51] Connecting to http://171.64.65.102:8080/
[07:21:55] Posted data.
[07:21:55] Initial: 0000; - Uploaded at ~43 kB/s
[07:21:55] - Averaged speed for that direction ~43 kB/s
[07:21:55] + Results successfully sent
[07:21:55] Thank you for your contribution to Folding@Home.
[07:21:55] + Number of Units Completed: 332
[07:22:01] *------------------------------*
[07:22:01] Folding@Home GPU Core - Beta
[07:22:01] Version 1.24 (Mon Feb 9 11:00:12 PST 2009)
[07:22:01] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[07:22:01] Build host: amoeba
[07:22:01] Board Type: AMD
[07:22:01] Core      :
[07:22:01] Preparing to commence simulation
[07:22:01] - Looking at optimizations...
[07:22:01] - Created dyn
[07:22:01] - Files status OK
[07:22:01] - Expanded 64741 -> 357580 (decompressed 552.3 percent)
[07:22:01] Called DecompressByteArray: compressed_data_size=64741 data_size=357580, decompressed_data_size=357580 diff=0
[07:22:01] - Digital signature verified
[07:22:01]
[b][07:22:01] Project: 5744 (Run 2, Clone 287, Gen 0)[/b]
[07:22:01]
[07:22:01] Assembly optimizations on if available.
[07:22:01] Entering M.D.
[07:22:07] Tpr hash work/wudata_09.tpr:  390798426 4280854593 2646104359 1365375954 4104247605
[07:22:08] Working on Protein
[07:22:09] Client config found, loading data.
[07:22:09] Starting GUI Server
[07:24:35] Completed 1%
[11:16:55] Completed 100%
[11:16:55] Successful run
[11:16:55] DynamicWrapper: Finished Work Unit: sleep=10000
[11:17:06] Reserved 153852 bytes for xtc file; Cosm status=0
[11:17:06] Allocated 153852 bytes for xtc file
[11:17:06] - Reading up to 153852 from "work/wudata_09.xtc": Read 153852
[11:17:06] Read 153852 bytes from xtc file; available packet space=786276612
[11:17:06] xtc file hash check passed.
[11:17:06] Reserved 23472 23472 786276612 bytes for arc file=<work/wudata_09.trr> Cosm status=0
[11:17:06] Allocated 23472 bytes for arc file
[11:17:06] - Reading up to 23472 from "work/wudata_09.trr": Read 23472
[11:17:06] Read 23472 bytes from arc file; available packet space=786253140
[11:17:06] trr file hash check passed.
[11:17:06] Allocated 560 bytes for edr file
[11:17:06] Read bedfile
[11:17:06] edr file hash check passed.
[11:17:06] Allocated 0 bytes for logfile
[11:17:06] Could not open/read logfile=<work/wudata_09.log>; Cosm status=-1
[11:17:06] GuardedRun: success in DynamicWrapper
[11:17:06] GuardedRun: done
[11:17:06] Run: GuardedRun completed.
[11:17:07] - Writing 178396 bytes of core data to disk...
[11:17:07] Done: 177884 -> 176512 (compressed to 99.2 percent)
[11:17:07]   ... Done.
[11:17:07] - Shutting down core
[11:17:07]
[11:17:07] Folding@home Core Shutdown: FINISHED_UNIT
[11:17:11] CoreStatus = 64 (100)
[11:17:11] Unit 9 finished with 95 percent of time to deadline remaining.
[11:17:11] Updated performance fraction: 0.929370
[11:17:11] Sending work to server
[11:17:11] Project: 5744 (Run 2, Clone 287, Gen 0)
[11:17:11] - Read packet limit of 540015616... Set to 524286976.
[11:17:11] + Attempting to send results [July 7 11:17:11 UTC]
[11:17:11] - Reading file work/wuresults_09.dat from core
[11:17:11]   (Read 177024 bytes from disk)
[11:17:11] Connecting to http://171.64.65.102:8080/
[11:17:15] Posted data.
[11:17:15] Initial: 0000; - Uploaded at ~43 kB/s
[11:17:15] - Averaged speed for that direction ~43 kB/s
[b][11:17:15] + Results successfully sent
[11:17:15] Thank you for your contribution to Folding@Home.
[11:17:15] + Number of Units Completed: 333[/b]
[11:17:21] Project: 5746 (Run 3, Clone 260, Gen 0)
[11:17:21]
[11:17:21] Assembly optimizations on if available.
[11:17:21] Entering M.D.
[11:17:27] Tpr hash work/wudata_00.tpr:  4262281662 1709239184 974017581 3027315846 1764277105
[11:17:27] Working on Protein
[11:17:28] Client config found, loading data.
[11:17:28] Starting GUI Server
[11:19:54] Completed 1%
[15:12:18] Completed 100%
[15:12:18] Successful run
[15:12:18] DynamicWrapper: Finished Work Unit: sleep=10000
[15:12:29] Reserved 154212 bytes for xtc file; Cosm status=0
[15:12:29] Allocated 154212 bytes for xtc file
[15:12:29] - Reading up to 154212 from "work/wudata_00.xtc": Read 154212
[15:12:29] Read 154212 bytes from xtc file; available packet space=786276252
[15:12:29] xtc file hash check passed.
[15:12:29] Reserved 23472 23472 786276252 bytes for arc file=<work/wudata_00.trr> Cosm status=0
[15:12:29] Allocated 23472 bytes for arc file
[15:12:29] - Reading up to 23472 from "work/wudata_00.trr": Read 23472
[15:12:29] Read 23472 bytes from arc file; available packet space=786252780
[15:12:29] trr file hash check passed.
[15:12:29] Allocated 560 bytes for edr file
[15:12:29] Read bedfile
[15:12:29] edr file hash check passed.
[15:12:29] Allocated 0 bytes for logfile
[15:12:29] Could not open/read logfile=<work/wudata_00.log>; Cosm status=-1
[15:12:29] GuardedRun: success in DynamicWrapper
[15:12:29] GuardedRun: done
[15:12:29] Run: GuardedRun completed.
[15:12:29] - Writing 178756 bytes of core data to disk...
[15:12:29] Done: 178244 -> 176851 (compressed to 99.2 percent)
[15:12:29]   ... Done.
[15:12:29] - Shutting down core
[15:12:29]
[15:12:29] Folding@home Core Shutdown: FINISHED_UNIT
[15:12:33] CoreStatus = 64 (100)
[15:12:33] Unit 0 finished with 95 percent of time to deadline remaining.
[15:12:33] Updated performance fraction: 0.932607
[15:12:33] Sending work to server
[15:12:33] Project: 5746 (Run 3, Clone 260, Gen 0)
[15:12:33] - Read packet limit of 540015616... Set to 524286976.
[15:12:33] + Attempting to send results [July 7 15:12:33 UTC]
[15:12:33] - Reading file work/wuresults_00.dat from core
[15:12:33]   (Read 177363 bytes from disk)
[15:12:33] Connecting to http://171.64.65.102:8080/
[15:12:39] Posted data.
[15:12:40] Initial: 0000; - Uploaded at ~24 kB/s
[15:12:40] - Averaged speed for that direction ~39 kB/s
[15:12:40] + Results successfully sent
[15:12:40] Thank you for your contribution to Folding@Home.
[15:12:40] + Number of Units Completed: 334
[15:12:47] Folding@Home GPU Core - Beta
[15:12:47] Version 1.24 (Mon Feb 9 11:00:12 PST 2009)
[15:12:47]
[15:12:47] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[15:12:47] Build host: amoeba
[15:12:47] Board Type: AMD
[15:12:47] Core      :
[15:12:47] Preparing to commence simulation
[15:12:47] - Looking at optimizations...
[15:12:47] - Created dyn
[15:12:47] - Files status OK
[15:12:47] - Expanded 64741 -> 357580 (decompressed 552.3 percent)
[15:12:47] Called DecompressByteArray: compressed_data_size=64741 data_size=357580, decompressed_data_size=357580 diff=0
[15:12:47] - Digital signature verified
[15:12:47]
[b][15:12:47] Project: 5744 (Run 2, Clone 287, Gen 0)[/b]
[15:12:47]
[15:12:47] Assembly optimizations on if available.
[15:12:47] Entering M.D.
[15:12:53] Tpr hash work/wudata_01.tpr:  390798426 4280854593 2646104359 1365375954 4104247605
[15:12:53] Working on Protein
[15:12:54] Client config found, loading data.
[15:12:54] Starting GUI Server
[15:15:20] Completed 1%
[19:22:50] Completed 100%
[19:22:50] Successful run
[19:22:50] DynamicWrapper: Finished Work Unit: sleep=10000
[19:23:00] Reserved 153852 bytes for xtc file; Cosm status=0
[19:23:00] Allocated 153852 bytes for xtc file
[19:23:00] - Reading up to 153852 from "work/wudata_01.xtc": Read 153852
[19:23:00] Read 153852 bytes from xtc file; available packet space=786276612
[19:23:00] xtc file hash check passed.
[19:23:00] Reserved 23472 23472 786276612 bytes for arc file=<work/wudata_01.trr> Cosm status=0
[19:23:00] Allocated 23472 bytes for arc file
[19:23:00] - Reading up to 23472 from "work/wudata_01.trr": Read 23472
[19:23:00] Read 23472 bytes from arc file; available packet space=786253140
[19:23:00] trr file hash check passed.
[19:23:00] Allocated 560 bytes for edr file
[19:23:00] Read bedfile
[19:23:00] edr file hash check passed.
[19:23:00] Allocated 30929 bytes for logfile
[19:23:00] Read logfile
[19:23:00] GuardedRun: success in DynamicWrapper
[19:23:00] GuardedRun: done
[19:23:00] Run: GuardedRun completed.
[19:23:04] - Writing 209325 bytes of core data to disk...
[19:23:04] Done: 208813 -> 185444 (compressed to 88.8 percent)
[19:23:04]   ... Done.
[19:23:04] - Shutting down core
[19:23:04]
[19:23:04] Folding@home Core Shutdown: FINISHED_UNIT
[19:23:08] CoreStatus = 64 (100)
[19:23:08] Unit 1 finished with 94 percent of time to deadline remaining.
[19:23:08] Updated performance fraction: 0.934496
[19:23:08] Sending work to server
[19:23:08] Project: 5744 (Run 2, Clone 287, Gen 0)
[19:23:08] - Read packet limit of 540015616... Set to 524286976.
[19:23:08] + Attempting to send results [July 7 19:23:08 UTC]
[19:23:08] - Reading file work/wuresults_01.dat from core
[19:23:08]   (Read 185956 bytes from disk)
[19:23:08] Connecting to http://171.64.65.102:8080/
[19:23:12] Posted data.
[19:23:12] Initial: 0000; - Uploaded at ~45 kB/s
[19:23:12] - Averaged speed for that direction ~41 kB/s
[b][19:23:12] + Results successfully sent
[19:23:12] Thank you for your contribution to Folding@Home.
[19:23:12] + Number of Units Completed: 335[/b]
[19:29:28] Folding@Home GPU Core - Beta
[19:29:28] Version 1.24 (Mon Feb 9 11:00:12 PST 2009)
[19:29:28]
[19:29:28] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[19:29:28] Build host: amoeba
[19:29:28] Board Type: AMD
[19:29:28] Core      :
[19:29:28] Preparing to commence simulation
[19:29:28] - Looking at optimizations...
[19:29:28] - Created dyn
[19:29:28] - Files status OK
[19:29:28] - Expanded 64741 -> 357580 (decompressed 552.3 percent)
[19:29:28] Called DecompressByteArray: compressed_data_size=64741 data_size=357580, decompressed_data_size=357580 diff=0
[19:29:28] - Digital signature verified
[19:29:28]
[b][19:29:28] Project: 5744 (Run 2, Clone 287, Gen 0)[/b]
[19:29:28]
[19:29:28] Assembly optimizations on if available.
[19:29:28] Entering M.D.
[19:29:34] Tpr hash work/wudata_02.tpr:  390798426 4280854593 2646104359 1365375954 4104247605
[19:29:34] Working on Protein
[19:29:35] Client config found, loading data.
[19:29:35] Starting GUI Server
[19:32:01] Completed 1%
[23:24:00] Completed 100%
[23:24:00] Successful run
[23:24:00] DynamicWrapper: Finished Work Unit: sleep=10000
[23:24:10] Reserved 153852 bytes for xtc file; Cosm status=0
[23:24:10] Allocated 153852 bytes for xtc file
[23:24:10] - Reading up to 153852 from "work/wudata_02.xtc": Read 153852
[23:24:10] Read 153852 bytes from xtc file; available packet space=786276612
[23:24:10] xtc file hash check passed.
[23:24:10] Reserved 23472 23472 786276612 bytes for arc file=<work/wudata_02.trr> Cosm status=0
[23:24:10] Allocated 23472 bytes for arc file
[23:24:10] - Reading up to 23472 from "work/wudata_02.trr": Read 23472
[23:24:10] Read 23472 bytes from arc file; available packet space=786253140
[23:24:10] trr file hash check passed.
[23:24:10] Allocated 560 bytes for edr file
[23:24:10] Read bedfile
[23:24:10] edr file hash check passed.
[23:24:10] Allocated 0 bytes for logfile
[23:24:10] Could not open/read logfile=<work/wudata_02.log>; Cosm status=-1
[23:24:10] GuardedRun: success in DynamicWrapper
[23:24:10] GuardedRun: done
[23:24:10] Run: GuardedRun completed.
[23:24:13] - Writing 178396 bytes of core data to disk...
[23:24:13] Done: 177884 -> 176512 (compressed to 99.2 percent)
[23:24:13]   ... Done.
[23:24:13] - Shutting down core
[23:24:13]
[23:24:13] Folding@home Core Shutdown: FINISHED_UNIT
[23:24:16] CoreStatus = 64 (100)
[23:24:16] Unit 2 finished with 95 percent of time to deadline remaining.
[23:24:16] Updated performance fraction: 0.936726
[23:24:16] Sending work to server
[23:24:16] Project: 5744 (Run 2, Clone 287, Gen 0)
[23:24:16] - Read packet limit of 540015616... Set to 524286976.
[23:24:16] + Attempting to send results [July 7 23:24:16 UTC]
[23:24:16] - Reading file work/wuresults_02.dat from core
[23:24:16]   (Read 177024 bytes from disk)
[23:24:16] Connecting to http://171.64.65.102:8080/
[23:24:20] Posted data.
[23:24:20] Initial: 0000; - Uploaded at ~43 kB/s
[23:24:20] - Averaged speed for that direction ~41 kB/s
[b][23:24:20] + Results successfully sent
[23:24:20] Thank you for your contribution to Folding@Home.
[23:24:20] + Number of Units Completed: 336[/b]
[23:24:26] *------------------------------*
[23:24:26] Folding@Home GPU Core - Beta
[23:24:26] Version 1.24 (Mon Feb 9 11:00:12 PST 2009)
[23:24:26]
[23:24:26] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[23:24:26] Build host: amoeba
[23:24:26] Board Type: AMD
[23:24:26] Core      :
[23:24:26] Preparing to commence simulation
[23:24:26] - Looking at optimizations...
[23:24:26] - Created dyn
[23:24:26] - Files status OK
[23:24:26] - Expanded 66151 -> 360060 (decompressed 544.3 percent)
[23:24:26] Called DecompressByteArray: compressed_data_size=66151 data_size=360060, decompressed_data_size=360060 diff=0
[23:24:26] - Digital signature verified
[23:24:26]
[b][23:24:26] Project: 5740 (Run 0, Clone 350, Gen 0)[/b]
[23:24:26]
[23:24:26] Assembly optimizations on if available.
[23:24:26] Entering M.D.
[23:24:32] Tpr hash work/wudata_03.tpr:  803256146 3968865341 1154374203 2117390551 2559747182
[23:24:32] Working on Protein
[23:24:33] Client config found, loading data.
[23:24:33] Starting GUI Server
[23:26:59] Completed 1%
[03:19:08] Completed 100%
[03:19:08] Successful run
[03:19:08] DynamicWrapper: Finished Work Unit: sleep=10000
[03:19:18] Reserved 154116 bytes for xtc file; Cosm status=0
[03:19:18] Allocated 154116 bytes for xtc file
[03:19:18] - Reading up to 154116 from "work/wudata_03.xtc": Read 154116
[03:19:18] Read 154116 bytes from xtc file; available packet space=786276348
[03:19:18] xtc file hash check passed.
[03:19:18] Reserved 23472 23472 786276348 bytes for arc file=<work/wudata_03.trr> Cosm status=0
[03:19:18] Allocated 23472 bytes for arc file
[03:19:18] - Reading up to 23472 from "work/wudata_03.trr": Read 23472
[03:19:18] Read 23472 bytes from arc file; available packet space=786252876
[03:19:18] trr file hash check passed.
[03:19:18] Allocated 560 bytes for edr file
[03:19:18] Read bedfile
[03:19:18] edr file hash check passed.
[03:19:18] Allocated 0 bytes for logfile
[03:19:18] Could not open/read logfile=<work/wudata_03.log>; Cosm status=-1
[03:19:18] GuardedRun: success in DynamicWrapper
[03:19:18] GuardedRun: done
[03:19:18] Run: GuardedRun completed.
[03:19:19] - Writing 178660 bytes of core data to disk...
[03:19:19] Done: 178148 -> 176692 (compressed to 99.1 percent)
[03:19:19]   ... Done.
[03:19:19] - Shutting down core
[03:19:19]
[03:19:19] Folding@home Core Shutdown: FINISHED_UNIT
[03:19:24] CoreStatus = 64 (100)
[03:19:24] Unit 3 finished with 95 percent of time to deadline remaining.
[03:19:24] Updated performance fraction: 0.938503
[03:19:24] Sending work to server
[03:19:24] Project: 5740 (Run 0, Clone 350, Gen 0)
[03:19:24] - Read packet limit of 540015616... Set to 524286976.
[03:19:24] + Attempting to send results [July 8 03:19:24 UTC]
[03:19:24] - Reading file work/wuresults_03.dat from core
[03:19:24]   (Read 177204 bytes from disk)
[03:19:24] Connecting to http://171.64.65.102:8080/
[03:19:28] Posted data.
[03:19:28] Initial: 0000; - Uploaded at ~34 kB/s
[03:19:29] - Averaged speed for that direction ~40 kB/s
[b][03:19:29] + Results successfully sent
[03:19:29] Thank you for your contribution to Folding@Home.
[03:19:29] + Number of Units Completed: 337[/b]
[03:19:34] Project: 5739 (Run 0, Clone 339, Gen 0)
[03:19:34]
[03:19:34] Assembly optimizations on if available.
[03:19:34] Entering M.D.
[03:19:41] Tpr hash work/wudata_04.tpr:  301086244 2445893902 3279086452 2785410949 2303582768
[03:19:41] Working on Protein
[03:19:42] Client config found, loading data.
[03:19:42] Starting GUI Server
[03:24:23] Completed 1%
[14:01:30] Completed 75%
[14:06:33] ***** Got a SIGTERM signal (2)
[14:06:33] Killing all core threads
Folding@Home Client Shutdown.  (I manually shut down to reboot system)
Next log file
--- Opening Log file [July 8 14:06:48 UTC]
                          http://folding.stanford.edu
Launch directory: C:\Program Files\Folding@home\Folding@home-gpu
Arguments: -forcegpu ati_r700 -verbosity 9 -advmethods
[14:06:48] - Ask before connecting: No
[14:06:48] - User name: TRSGPU (Team 163828)
[14:06:48] - User ID: 2C7ADCFC655715EA
[14:06:48] - Machine ID: 2
[14:06:48]
[14:06:48] Loaded queue successfully.
[14:06:48] Initialization complete
[14:06:49]
[14:06:49] + Processing work unit
[14:06:49] Core required: FahCore_11.exe
[14:06:49] Core found.
[14:06:49] - Autosending finished units... [July 8 14:06:49 UTC]
[14:06:49] Trying to send all finished work units
[14:06:49] + No unsent completed units remaining.
[14:06:49] - Autosend completed
[14:06:49] Working on queue slot 04 [July 8 14:06:49 UTC]
[14:06:49] + Working ...
[14:06:49] - Calling '.\FahCore_11.exe -dir work/ -suffix 04 -priority 96 -checkpoint 3 -verbose -lifeline 3272 -version 623'
[14:06:50]
[14:06:50] *------------------------------*
[14:06:50] Folding@Home GPU Core - Beta
[14:06:50] Version 1.24 (Mon Feb 9 11:00:12 PST 2009)
[14:06:50]
[14:06:50] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[14:06:50] Build host: amoeba
[14:06:50] Board Type: AMD
[14:06:50] Core      :
[14:06:50] Preparing to commence simulation
[14:06:50] - Looking at optimizations...
[14:06:50] - Files status OK
[14:06:50] - Expanded 90739 -> 489152 (decompressed 539.0 percent)
[14:06:50] Called DecompressByteArray: compressed_data_size=90739 data_size=489152, decompressed_data_size=489152 diff=0
[14:06:50] - Digital signature verified
[14:06:50]
[14:06:50] Project: 5739 (Run 0, Clone 339, Gen 0)
[14:06:50]
[14:06:52] Assembly optimizations on if available.
[14:06:52] Entering M.D.
[14:06:57] Will resume from checkpoint file
[14:06:57] Tpr hash work/wudata_04.tpr:  301086244 2445893902 3279086452 2785410949 2303582768
[14:07:07] Working on Protein
[14:07:18] Client config found, loading data.
[14:07:18] Starting GUI Server
[14:07:30] Resuming from checkpoint
[14:07:30] fcCheckPointResume: retreived and current tpr file hash:
[14:07:30]    0    301086244    301086244
[14:07:30]    1   2445893902   2445893902
[14:07:30]    2   3279086452   3279086452
[14:07:30]    3   2785410949   2785410949
[14:07:30]    4   2303582768   2303582768
[14:07:30] Verified work/wudata_04.log
[14:07:30] Verified work/wudata_04.edr
[14:07:30] Verified work/wudata_04.xtc
[14:07:30] Completed 75%
[14:15:28] *------------------------------*
[14:15:28] Folding@Home GPU Core - Beta
[14:15:28] Version 1.24 (Mon Feb 9 11:00:12 PST 2009)
[14:15:28]
[14:15:28] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[14:15:28] Build host: amoeba
[14:15:28] Board Type: AMD
[14:15:28] Core      :
[14:15:28] Preparing to commence simulation
[14:15:28] - Ensuring status. Please wait.
[14:15:38] - Looking at optimizations...
[14:15:38] - Working with standard loops on this execution.
[14:15:38] - Previous termination of core was improper.
[14:15:38] - Files status OK
[14:15:38] - Expanded 90739 -> 489152 (decompressed 539.0 percent)
[14:15:38] Called DecompressByteArray: compressed_data_size=90739 data_size=489152, decompressed_data_size=489152 diff=0
[14:15:38] - Digital signature verified
[14:15:38]
[14:15:38] Project: 5739 (Run 0, Clone 339, Gen 0)
[14:15:38]
[14:15:38] Entering M.D.
[14:15:44] Will resume from checkpoint file
[14:15:44] Tpr hash work/wudata_04.tpr:  301086244 2445893902 3279086452 2785410949 2303582768
[14:15:45] Working on Protein
[14:15:46] Client config found, loading data.
[14:15:47] Starting GUI Server
[14:15:53] Resuming from checkpoint
[14:15:53] fcCheckPointResume: retreived and current tpr file hash:
[14:15:53]    0    301086244    301086244
[14:15:53]    1   2445893902   2445893902
[14:15:53]    2   3279086452   3279086452
[14:15:53]    3   2785410949   2785410949
[14:15:53]    4   2303582768   2303582768
[14:15:53] Verified work/wudata_04.log
[14:15:53] Verified work/wudata_04.edr
[14:15:53] Verified work/wudata_04.xtc
[14:15:53] Completed 75%
[14:15:54] mdrun_gpu returned
[14:15:54] Calculated & specified T inconsisitent
[14:15:54]
[14:15:54] Folding@home Core Shutdown: UNSTABLE_MACHINE
[14:15:57] CoreStatus = 7A (122)
[14:15:57] Sending work to server
[14:15:57] Project: 5739 (Run 0, Clone 339, Gen 0)
[14:15:57] - Read packet limit of 540015616... Set to 524286976.
[14:15:57] - Error: Could not get length of results file work/wuresults_04.dat
[14:15:57] - Error: Could not read unit 04 file. Removing from queue.
[14:15:57] Trying to send all finished work units
[14:15:57] + No unsent completed units remaining.
[14:15:57] - Preparing to get new work unit...
[14:15:57] + Attempting to get work packet
[14:15:57] - Will indicate memory of 3070 MB
[14:15:57] - Detect CPU. Vendor: AuthenticAMD, Family: 15, Model: 11, Stepping: 2
[14:15:57] - Connecting to assignment server
[14:15:57] Connecting to http://assign-GPU.stanford.edu:8080/
[14:15:57] Posted data.
[14:15:57] Initial: 40AB; - Successful: assigned to (171.64.65.102).
[14:16:03]
[14:16:03] *------------------------------*
[14:16:03] Folding@Home GPU Core - Beta
[14:16:03] Version 1.24 (Mon Feb 9 11:00:12 PST 2009)
[14:16:03]
[14:16:03] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[14:16:03] Build host: amoeba
[14:16:03] Board Type: AMD
[14:16:03] Core      :
[14:16:03] Preparing to commence simulation
[14:16:03] - Looking at optimizations...
[14:16:03] - Created dyn
[14:16:03] - Files status OK
[14:16:03] - Expanded 66151 -> 360060 (decompressed 544.3 percent)
[14:16:03] Called DecompressByteArray: compressed_data_size=66151 data_size=360060, decompressed_data_size=360060 diff=0
[14:16:03] - Digital signature verified
[14:16:03]
[b][14:16:03] Project: 5740 (Run 0, Clone 350, Gen 0)[/b]
[14:16:03]
[14:16:03] Assembly optimizations on if available.
[14:16:03] Entering M.D.
[14:16:09] Tpr hash work/wudata_05.tpr:  803256146 3968865341 1154374203 2117390551 2559747182
[14:16:09] Working on Protein
[14:16:10] Client config found, loading data.
[14:16:10] Starting GUI Server
[14:20:10] Completed 1%
[14:24:23] Completed 2%
[14:29:08] ***** Got a SIGTERM signal (2)
[14:29:08] Killing all core threads
[14:29:20] *------------------------------*
[14:29:20] Folding@Home GPU Core - Beta
[14:29:20] Version 1.24 (Mon Feb 9 11:00:12 PST 2009)
[14:29:20]
[14:29:20] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[14:29:20] Build host: amoeba
[14:29:20] Board Type: AMD
[14:29:20] Core      :
[14:29:20] Preparing to commence simulation
[14:29:20] - Looking at optimizations...
[14:29:20] - Files status OK
[14:29:20] - Expanded 66151 -> 360060 (decompressed 544.3 percent)
[14:29:20] Called DecompressByteArray: compressed_data_size=66151 data_size=360060, decompressed_data_size=360060 diff=0
[14:29:20] - Digital signature verified
[14:29:20]
[b][14:29:20] Project: 5740 (Run 0, Clone 350, Gen 0)[/b]
[14:29:20]
[14:29:20] Assembly optimizations on if available.
[14:29:20] Entering M.D.
[14:29:26] Will resume from checkpoint file
[14:29:26] Tpr hash work/wudata_05.tpr:  803256146 3968865341 1154374203 2117390551 2559747182
[14:29:29] Working on Protein
[14:29:29] Client config found, loading data.
[14:29:30] Starting GUI Server
[14:29:36] Resuming from checkpoint
[14:29:36] fcCheckPointResume: retreived and current tpr file hash:
[14:29:36]    0    803256146    803256146
[14:29:36]    1   3968865341   3968865341
[14:29:36]    2   1154374203   1154374203
[14:29:36]    3   2117390551   2117390551
[14:29:36]    4   2559747182   2559747182
[14:29:36] Verified work/wudata_05.log
[14:29:36] Verified work/wudata_05.edr
[14:29:36] Verified work/wudata_05.xtc
[14:29:36] Completed 2%
[15:18:54] Completed 18%
[15:19:31] + Paused
[15:19:35] ***** Got a SIGTERM signal (2)
[15:19:35] Killing all core threads
[15:19:57]
[15:19:57] *------------------------------*
[15:19:57] Folding@Home GPU Core - Beta
[15:19:57] Version 1.24 (Mon Feb 9 11:00:12 PST 2009)
[15:19:57]
[15:19:57] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[15:19:57] Build host: amoeba
[15:19:57] Board Type: AMD
[15:19:57] Core      :
[15:19:57] Preparing to commence simulation
[15:19:57] - Looking at optimizations...
[15:19:57] - Files status OK
[15:19:57] - Expanded 66151 -> 360060 (decompressed 544.3 percent)
[15:19:57] Called DecompressByteArray: compressed_data_size=66151 data_size=360060, decompressed_data_size=360060 diff=0
[15:19:57] - Digital signature verified
[15:19:57]
[b][15:19:57] Project: 5740 (Run 0, Clone 350, Gen 0)[/b]
[15:19:57]
[15:19:57] Assembly optimizations on if available.
[15:19:57] Entering M.D.
[15:20:03] Will resume from checkpoint file
[15:20:03] Tpr hash work/wudata_05.tpr:  803256146 3968865341 1154374203 2117390551 2559747182
[15:20:04] Working on Protein
[15:20:04] Client config found, loading data.
[15:20:04] Starting GUI Server
[15:20:11] Resuming from checkpoint
[15:20:11] fcCheckPointResume: retreived and current tpr file hash:
[15:20:11]    0    803256146    803256146
[15:20:11]    1   3968865341   3968865341
[15:20:11]    2   1154374203   1154374203
[15:20:11]    3   2117390551   2117390551
[15:20:11]    4   2559747182   2559747182
[15:20:11] Verified work/wudata_05.log
[15:20:11] Verified work/wudata_05.edr
[15:20:11] Verified work/wudata_05.xtc
[15:20:11] Completed 18%
[18:35:22] Completed 100%
[18:35:22] Successful run
[18:35:22] DynamicWrapper: Finished Work Unit: sleep=10000
[18:35:32] Reserved 153780 bytes for xtc file; Cosm status=0
[18:35:32] Allocated 153780 bytes for xtc file
[18:35:32] - Reading up to 153780 from "work/wudata_05.xtc": Read 153780
[18:35:32] Read 153780 bytes from xtc file; available packet space=786276684
[18:35:32] xtc file hash check passed.
[18:35:32] Reserved 23472 23472 786276684 bytes for arc file=<work/wudata_05.trr> Cosm status=0
[18:35:32] Allocated 23472 bytes for arc file
[18:35:32] - Reading up to 23472 from "work/wudata_05.trr": Read 23472
[18:35:32] Read 23472 bytes from arc file; available packet space=786253212
[18:35:32] trr file hash check passed.
[18:35:32] Allocated 560 bytes for edr file
[18:35:32] Read bedfile
[18:35:32] edr file hash check passed.
[18:35:32] Allocated 30527 bytes for logfile
[18:35:32] Read logfile
[18:35:32] GuardedRun: success in DynamicWrapper
[18:35:32] GuardedRun: done
[18:35:32] Run: GuardedRun completed.
[18:35:36] - Writing 208851 bytes of core data to disk...
[18:35:36] Done: 208339 -> 185259 (compressed to 88.9 percent)
[18:35:36]   ... Done.
[18:35:36] - Shutting down core
[18:35:36]
[18:35:36] Folding@home Core Shutdown: FINISHED_UNIT
[18:35:40] CoreStatus = 64 (100)
[18:35:40] Unit 5 finished with 94 percent of time to deadline remaining.
[18:35:40] Updated performance fraction: 0.938779
[18:35:40] Sending work to server
[18:35:40] Project: 5740 (Run 0, Clone 350, Gen 0)
[18:35:40] - Read packet limit of 540015616... Set to 524286976.
[18:35:40] + Attempting to send results [July 8 18:35:40 UTC]
[18:35:40] - Reading file work/wuresults_05.dat from core
[18:35:40]   (Read 185771 bytes from disk)
[18:35:40] Connecting to http://171.64.65.102:8080/
[18:35:44] Posted data.
[18:35:45] Initial: 0000; - Uploaded at ~36 kB/s
[18:35:45] - Averaged speed for that direction ~39 kB/s
[b][18:35:45] + Results successfully sent
[18:35:45] Thank you for your contribution to Folding@Home.
[18:35:45] + Number of Units Completed: 338[/b]
[b][18:35:50] Project: 5740 (Run 0, Clone 350, Gen 0)[/b]
[18:35:50]
[18:35:50] Assembly optimizations on if available.
[18:35:50] Entering M.D.
[18:35:56] Tpr hash work/wudata_06.tpr:  803256146 3968865341 1154374203 2117390551 2559747182
[18:35:57] Working on Protein
[18:35:57] Client config found, loading data.
[18:35:57] Starting GUI Server
[18:38:24] Completed 1%
[22:33:11] Completed 100%
[22:33:11] Successful run
[22:33:11] DynamicWrapper: Finished Work Unit: sleep=10000
[22:33:21] Reserved 154116 bytes for xtc file; Cosm status=0
[22:33:21] Allocated 154116 bytes for xtc file
[22:33:21] - Reading up to 154116 from "work/wudata_06.xtc": Read 154116
[22:33:21] Read 154116 bytes from xtc file; available packet space=786276348
[22:33:21] xtc file hash check passed.
[22:33:21] Reserved 23472 23472 786276348 bytes for arc file=<work/wudata_06.trr> Cosm status=0
[22:33:21] Allocated 23472 bytes for arc file
[22:33:21] - Reading up to 23472 from "work/wudata_06.trr": Read 23472
[22:33:21] Read 23472 bytes from arc file; available packet space=786252876
[22:33:21] trr file hash check passed.
[22:33:21] Allocated 560 bytes for edr file
[22:33:21] Read bedfile
[22:33:21] edr file hash check passed.
[22:33:21] Allocated 25265 bytes for logfile
[22:33:21] Read logfile
[22:33:21] GuardedRun: success in DynamicWrapper
[22:33:21] GuardedRun: done
[22:33:21] Run: GuardedRun completed.
[22:33:25] - Writing 203925 bytes of core data to disk...
[22:33:26] Done: 203413 -> 185127 (compressed to 91.0 percent)
[22:33:26]   ... Done.
[22:33:26] - Shutting down core
[22:33:26]
[22:33:26] Folding@home Core Shutdown: FINISHED_UNIT
[22:33:30] CoreStatus = 64 (100)
[22:33:30] Unit 6 finished with 94 percent of time to deadline remaining.
[22:33:30] Updated performance fraction: 0.940020
[22:33:30] Sending work to server
[22:33:30] Project: 5740 (Run 0, Clone 350, Gen 0)
[22:33:30] - Read packet limit of 540015616... Set to 524286976.
[22:33:30] + Attempting to send results [July 8 22:33:30 UTC]
[22:33:30] - Reading file work/wuresults_06.dat from core
[22:33:30]   (Read 185639 bytes from disk)
[22:33:30] Connecting to http://171.64.65.102:8080/
[22:33:33] Posted data.
[22:33:34] Initial: 0000; - Uploaded at ~45 kB/s
[22:33:34] - Averaged speed for that direction ~40 kB/s
[b][22:33:34] + Results successfully sent
[22:33:34] Thank you for your contribution to Folding@Home.
[22:33:34] + Number of Units Completed: 339[/b]
I only see one report from you -- unless you're using another UserName:
Hi TRSGPU (team 163828),
Your WU (P5744 R1 C85 G203) was added to the stats database on 2010-07-04 18:08:59 for 384 points of credit. That would be Jul 7, 01:08 UTC which is consistent with the first upload at [July 5 00:22:16 UTC], allowing for the time to update the stats.
I'll ask if anybody can shed any more light on this one.
Tynat
Post by Tynat »
Please edit your post and put the log inside the code tag.
All clients stopped due to Stanford's upcoming September 2011 decision
Racer43
Post by Racer43 »
Tynat, I have no idea to what you refer.
Bruce, that is the second time I've done that to you by not listing the user name. That is the correct user name. And I am now doing P5740 R0 C350 G0 for the 4th time.
Two have been reported as of 08:30 PDT.
Your WU (P5740 R0 C350 G0) was added to the stats database on 2010-07-07 21:08:52 for 384 points of credit.
Your WU (P5740 R0 C350 G0) was added to the stats database on 2010-07-08 16:09:07 for 384 points of credit.
Tynat
Post by Tynat »
Racer43 wrote:Tynat, I have no idea to what you refer.
  1. Paste log text into editor.
  2. Highlight log text.
  3. Press "Code" button.
  4. Preview.
An alternative way is:
1) Select Code Button
2) Copy Text (FAHLog)
3) Paste it between the code so that it appears like this:
[code]FAHLog appears like this[/code]
4) Preview Post
Racer43
Post by Racer43 »
This is becoming frustrating; my GPU is processing P5740 R0 B350 G0 for the 5th time as I write this. Bruce, any news?
Tynat and PantherX, thank you. I understand what you mean now regarding code.
No news.
I asked for information this morning but have not heard an answer.
I suggest you change MachineID to an unused value and dump that WU. I don't like to make that recommendation, but sometimes it's the only option.
Racer43
Post by Racer43 »
Thank you, Bruce. I tried the MachineID, and when I restarted, it picked right back up where it had left off with the 6th iteration of P5740 R0 B350 G0.
codysluder
Post by codysluder »
Racer43 wrote:Thank you, Bruce. I tried the MachineID, and when I restarted, it picked right back up where it had left off with the 6th iteration of P5740 R0 B350 G0.
Did you use -delete xx to dump the current wu or did you delete files? Please post FAHlog of the new MachineID run.
sortofageek
Post by sortofageek »
bruce wrote:Two have been reported as of 08:30 PDT.
And a third has now appeared:
Your WU (P5740 R0 C350 G0) was added to the stats database on 2010-07-10 13:09:01 for 384 points of credit.
Racer43
Post by Racer43 »
After processing P5740 R0 C350 G0 8 times, I not seen it for over 3 days. Maybe it finally tired of my machine and moved on to greener pastures. Thank you all for your suggestions and explanations.
