Project: 5744 (Run 0, Clone 82, Gen 107)
SonicWRX
Post by SonicWRX »
I got enough of these to shut me down for 24 hours when i started it back up it did this again on the same WU
[12:02:32] - Preparing to get new work unit...
[12:02:32] + Attempting to get work packet
[12:02:32] - Connecting to assignment server
[12:02:33] - Successful: assigned to (171.64.65.102).
[12:02:33] + News From Folding@Home: Welcome to Folding@Home
[12:02:33] Loaded queue successfully.
[12:02:34] + Closed connections
[12:02:34]
[12:02:34] + Processing work unit
[12:02:34] Core required: FahCore_11.exe
[12:02:34] Core found.
[12:02:34] Working on queue slot 01 [July 3 12:02:34 UTC]
[12:02:34] + Working ...
[12:02:34]
[12:02:34] *------------------------------*
[12:02:34] Folding@Home GPU Core - Beta
[12:02:34] Version 1.24 (Mon Feb 9 11:00:12 PST 2009)
[12:02:34]
[12:02:34] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[12:02:34] Build host: amoeba
[12:02:34] Board Type: AMD
[12:02:34] Core      :
[12:02:34] Preparing to commence simulation
[12:02:34] - Looking at optimizations...
[12:02:34] - Created dyn
[12:02:34] - Files status OK
[12:02:34] - Expanded 68705 -> 357580 (decompressed 520.4 percent)
[12:02:34] Called DecompressByteArray: compressed_data_size=68705 data_size=357580, decompressed_data_size=357580 diff=0
[12:02:34] - Digital signature verified
[12:02:34]
[12:02:34] Project: 5744 (Run 0, Clone 82, Gen 107)
[12:02:34]
[12:02:34] Assembly optimizations on if available.
[12:02:34] Entering M.D.
[12:02:40] Tpr hash work/wudata_01.tpr:  3188787671 1739385601 1940216886 2859180985 3816163346
[12:02:40] Working on Protein
[12:02:41] Client config found, loading data.
[12:02:41] Starting GUI Server
[12:02:45] mdrun_gpu returned
[12:02:45] SHAKE violations on GPU
[12:02:45]
[12:02:45] Folding@home Core Shutdown: UNSTABLE_MACHINE
[12:02:48] CoreStatus = 7A (122)
[12:02:48] Sending work to server
[12:02:48] Project: 5744 (Run 0, Clone 82, Gen 107)
[12:02:48] - Read packet limit of 540015616... Set to 524286976.
[12:02:48] - Error: Could not get length of results file work/wuresults_01.dat
[12:02:48] - Error: Could not read unit 01 file. Removing from queue.
[12:02:48] - Preparing to get new work unit...
[12:02:48] + Attempting to get work packet
[12:02:48] - Connecting to assignment server
[12:02:49] - Successful: assigned to (171.64.65.102).
[12:02:49] + News From Folding@Home: Welcome to Folding@Home
[12:02:49] Loaded queue successfully.
[12:02:50] + Closed connections
[12:02:55]
[12:02:55] + Processing work unit
[12:02:55] Core required: FahCore_11.exe
[12:02:55] Core found.
[12:02:55] Working on queue slot 02 [July 3 12:02:55 UTC]
[12:02:55] + Working ...
[12:02:55]
[12:02:55] *------------------------------*
[12:02:55] Folding@Home GPU Core - Beta
[12:02:55] Version 1.24 (Mon Feb 9 11:00:12 PST 2009)
[12:02:55]
[12:02:55] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[12:02:55] Build host: amoeba
[12:02:55] Board Type: AMD
[12:02:55] Core      :
[12:02:55] Preparing to commence simulation
[12:02:55] - Looking at optimizations...
[12:02:55] - Created dyn
[12:02:55] - Files status OK
[12:02:55] - Expanded 68705 -> 357580 (decompressed 520.4 percent)
[12:02:55] Called DecompressByteArray: compressed_data_size=68705 data_size=357580, decompressed_data_size=357580 diff=0
[12:02:55] - Digital signature verified
[12:02:55]
[12:02:55] Project: 5744 (Run 0, Clone 82, Gen 107)
[12:02:55]
[12:02:55] Assembly optimizations on if available.
[12:02:55] Entering M.D.
[12:03:01] Tpr hash work/wudata_02.tpr:  3188787671 1739385601 1940216886 2859180985 3816163346
[12:03:01] Working on Protein
[12:03:03] Client config found, loading data.
[12:03:03] Starting GUI Server
[12:03:06] mdrun_gpu returned
[12:03:06] SHAKE violations on GPU
[12:03:06]
[12:03:06] Folding@home Core Shutdown: UNSTABLE_MACHINE
[12:03:10] CoreStatus = 7A (122)
[12:03:10] Sending work to server
[12:03:10] Project: 5744 (Run 0, Clone 82, Gen 107)
[12:03:10] - Read packet limit of 540015616... Set to 524286976.
[12:03:10] - Error: Could not get length of results file work/wuresults_02.dat
[12:03:10] - Error: Could not read unit 02 file. Removing from queue.
Re: Project: 5744 (Run 0, Clone 82, Gen 107)
Marked as a bad WU.
