Project: 5747 (Run 3, Clone 16, Gen 1280)
Tynat
Post by Tynat »
This was the only UNSTABLE_MACHINE failure with this WU. The GPU client then went on to a different WU without issue.
[07:08:26] + Received work.
[07:08:26] Trying to send all finished work units
[07:08:26] + No unsent completed units remaining.
[07:08:26] + Closed connections
[07:08:31]
[07:08:31] + Processing work unit
[07:08:31] Core required: FahCore_11.exe
[07:08:31] Core found.
[07:08:31] Working on queue slot 01 [July 3 07:08:31 UTC]
[07:08:31] + Working ...
[07:08:31] - Calling '.\FahCore_11.exe -dir work/ -suffix 01 -priority 96 -nocpulock -checkpoint 15 -verbose -lifeline 3580 -version 623'
[07:08:31]
[07:08:31] *------------------------------*
[07:08:31] Folding@Home GPU Core - Beta
[07:08:31] Version 1.24 (Mon Feb 9 11:00:12 PST 2009)
[07:08:31]
[07:08:31] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[07:08:31] Build host: amoeba
[07:08:31] Board Type: AMD
[07:08:31] Core      :
[07:08:31] Preparing to commence simulation
[07:08:31] - Looking at optimizations...
[07:08:31] - Created dyn
[07:08:31] - Files status OK
[07:08:31] - Expanded 18451 -> 167984 (decompressed 910.4 percent)
[07:08:31] Called DecompressByteArray: compressed_data_size=18451 data_size=167984, decompressed_data_size=167984 diff=0
[07:08:31] - Digital signature verified
[07:08:31]
[07:08:31] Project: 5747 (Run 3, Clone 16, Gen 1280)
[07:08:31]
[07:08:31] Assembly optimizations on if available.
[07:08:31] Entering M.D.
[07:08:37] Tpr hash work/wudata_01.tpr:  1798737060 2029399965 1990539163 2300162998 2674837144
[07:08:37] Run: exception thrown during GuardedRun
[07:08:37] Run: exception thrown in GuardedRun -- Gromacs cannot continue further.
[07:08:37] Going to send back what have done -- stepsTotalG=0
[07:08:37] Work fraction=0.0000 steps=0.
[07:08:41] logfile size=0 infoLength=0 edr=0 trr=23
[07:08:41] - Writing 635 bytes of core data to disk...
[07:08:41] Done: 123 -> 124 (compressed to 100.8 percent)
[07:08:41]   ... Done.
[07:08:41]
[07:08:41] Folding@home Core Shutdown: UNSTABLE_MACHINE
[07:08:45] CoreStatus = 7A (122)
[07:08:45] Sending work to server
[07:08:45] Project: 5747 (Run 3, Clone 16, Gen 1280)
[07:08:45] - Read packet limit of 540015616... Set to 524286976.
[07:08:45] + Attempting to send results [July 3 07:08:45 UTC]
[07:08:45] - Reading file work/wuresults_01.dat from core
[07:08:45]   (Read 636 bytes from disk)
[07:08:45] Connecting to http://171.64.65.102:8080/
[07:08:46] Posted data.
[07:08:46] Initial: 0000; - Uploaded at ~1 kB/s
[07:08:46] - Averaged speed for that direction ~173 kB/s
[07:08:46] + Results successfully sent
[07:08:46] Thank you for your contribution to Folding@Home.
All clients stopped due to Stanford's upcoming September 2011 decision
Re: Project: 5747 (Run 3, Clone 16, Gen 1280)
Reported as bad.
Tynat
Post by Tynat »
Thanks toTOW.
