Project: 5746 (Run 2, Clone 56, Gen 298)
Tynat
Post by Tynat »
There were four prior UNSTABLE_MACHINE failures with this WU previous to this one and one additional after restarting the GPU client.
[08:27:29] + Received work.
[08:27:29] Trying to send all finished work units
[08:27:29] + No unsent completed units remaining.
[08:27:29] + Closed connections
[08:27:34]
[08:27:34] + Processing work unit
[08:27:34] Core required: FahCore_11.exe
[08:27:34] Core found.
[08:27:34] Working on queue slot 05 [July 1 08:27:34 UTC]
[08:27:34] + Working ...
[08:27:34] - Calling '.\FahCore_11.exe -dir work/ -suffix 05 -priority 96 -nocpulock -checkpoint 15 -verbose -lifeline 1068 -version 623'
[08:27:34]
[08:27:34] *------------------------------*
[08:27:34] Folding@Home GPU Core - Beta
[08:27:34] Version 1.24 (Mon Feb 9 11:00:12 PST 2009)
[08:27:34]
[08:27:34] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[08:27:34] Build host: amoeba
[08:27:34] Board Type: AMD
[08:27:34] Core      :
[08:27:34] Preparing to commence simulation
[08:27:34] - Looking at optimizations...
[08:27:35] - Created dyn
[08:27:35] - Files status OK
[08:27:35] - Expanded 68607 -> 357580 (decompressed 521.2 percent)
[08:27:35] Called DecompressByteArray: compressed_data_size=68607 data_size=357580, decompressed_data_size=357580 diff=0
[08:27:35] - Digital signature verified
[08:27:35]
[08:27:35] Project: 5746 (Run 2, Clone 56, Gen 298)
[08:27:35]
[08:27:35] Assembly optimizations on if available.
[08:27:35] Entering M.D.
[08:27:40] Tpr hash work/wudata_05.tpr:  2418777322 3661751350 3537767603 3357611553 3472569265
[08:27:41] Working on Protein
[08:27:41] Client config found, loading data.
[08:27:42] Starting GUI Server
[08:27:47] mdrun_gpu returned
[08:27:47] SHAKE violations on GPU
[08:27:47]
[08:27:47] Folding@home Core Shutdown: UNSTABLE_MACHINE
[08:27:51] CoreStatus = 7A (122)
[08:27:51] Sending work to server
[08:27:51] Project: 5746 (Run 2, Clone 56, Gen 298)
[08:27:51] - Read packet limit of 540015616... Set to 524286976.
[08:27:51] - Error: Could not get length of results file work/wuresults_05.dat
[08:27:51] - Error: Could not read unit 05 file. Removing from queue.
[08:27:51] EUE limit exceeded. Pausing 24 hours.
All clients stopped due to Stanford's upcoming September 2011 decision
Re: Project: 5746 (Run 2, Clone 56, Gen 298)
Reported as a bad WU
Tynat
Post by Tynat »
Thanks Bruce.
