Project: 5742 (Run 1, Clone 64, Gen 998)
slymer
Post by slymer »
This is the other work unit that has issues running. As stated in the other post, this one won't run, but other work units (besides the two I've posted) work fine.
My GPUs are not overclocked. They are 2 HD4850 Saphire cards w/1GB ram each.
[01:23:31] Folding@Home GPU Core - Beta
[01:23:31] Version 1.24 (Mon Feb 9 11:00:12 PST 2009)
[01:23:31]
[01:23:31] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[01:23:31] Build host: amoeba
[01:23:31] Board Type: AMD
[01:23:31] Core      :
[01:23:31] Preparing to commence simulation
[01:23:31] - Looking at optimizations...
[01:23:31] - Created dyn
[01:23:31] - Files status OK
[01:23:31] - Expanded 70183 -> 360060 (decompressed 513.0 percent)
[01:23:31] Called DecompressByteArray: compressed_data_size=70183 data_size=360060, decompressed_data_size=360060 diff=0
[01:23:31] - Digital signature verified
[01:23:31]
[01:23:31] Project: 5742 (Run 1, Clone 64, Gen 998)
[01:23:31]
[01:23:31] Assembly optimizations on if available.
[01:23:31] Entering M.D.
[01:23:37] Tpr hash work/wudata_08.tpr:  3794373252 833849474 3945531015 1417006855 2442204935
[01:23:38] Working on Protein
[01:23:38] Client config found, loading data.
[01:23:38] Starting GUI Server
[01:23:44] mdrun_gpu returned
[01:23:44] Nonzero force sum on GPU
[01:23:44]
[01:23:44] Folding@home Core Shutdown: UNSTABLE_MACHINE
[01:23:48] CoreStatus = 7A (122)
[01:23:48] Sending work to server
[01:23:48] Project: 5742 (Run 1, Clone 64, Gen 998)
[01:23:48] - Error: Could not get length of results file work/wuresults_08.dat
[01:23:48] - Error: Could not read unit 08 file. Removing from queue.
[01:23:48] EUE limit exceeded. Pausing 24 hours.
Re: Project: 5742 (Run 1, Clone 64, Gen 998)
I've reported this as a bad WU.
Where is the other post?
