Project: 5744 (Run 1, Clone 100, Gen 361)
slymer
Post by slymer »
every time I get this work unit it errors out. It claims I have an unstable machine, but this is only reported by a select few work units. I will post each separately.
[17:15:27] Folding@Home GPU Core - Beta
[17:15:27] Version 1.24 (Mon Feb 9 11:00:12 PST 2009)
[17:15:27]
[17:15:27] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[17:15:27] Build host: amoeba
[17:15:27] Board Type: AMD
[17:15:27] Core      :
[17:15:27] Preparing to commence simulation
[17:15:27] - Looking at optimizations...
[17:15:27] - Created dyn
[17:15:27] - Files status OK
[17:15:27] - Expanded 68562 -> 357580 (decompressed 521.5 percent)
[17:15:27] Called DecompressByteArray: compressed_data_size=68562 data_size=357580, decompressed_data_size=357580 diff=0
[17:15:27] - Digital signature verified
[17:15:27]
[17:15:27] Project: 5744 (Run 1, Clone 100, Gen 361)
[17:15:27]
[17:15:27] Assembly optimizations on if available.
[17:15:27] Entering M.D.
[17:15:33] Tpr hash work/wudata_00.tpr:  1477839935 1092303722 3511353941 2322473075 2461123317
[17:15:33] Working on Protein
[17:15:33] Client config found, loading data.
[17:15:34] Starting GUI Server
[17:15:38] mdrun_gpu returned
[17:15:38] Nonzero force sum on GPU
[17:15:38]
[17:15:38] Folding@home Core Shutdown: UNSTABLE_MACHINE
[17:15:41] CoreStatus = 7A (122)
[17:15:41] Sending work to server
[17:15:41] Project: 5744 (Run 1, Clone 100, Gen 361)
[17:15:41] - Error: Could not get length of results file work/wuresults_00.dat
[17:15:41] - Error: Could not read unit 00 file. Removing from queue.
[17:15:41] EUE limit exceeded. Pausing 24 hours.
Re: Project: 5744 (Run 1, Clone 100, Gen 361)
I've reported this one as a bad WU.
tinokun
Post by tinokun »
Got the same one today.
[10:23:10] - Preparing to get new work unit...
[10:23:10] Cleaning up work directory
[10:23:10] + Attempting to get work packet
[10:23:10] Passkey found
[10:23:10] - Will indicate memory of 6077 MB
[10:23:10] Gpu type=1 species=4.
[10:23:10] - Connecting to assignment server
[10:23:10] Connecting to http://assign-GPU.stanford.edu:8080/
[10:23:12] Posted data.
[10:23:12] Initial: 40AB; - Successful: assigned to (171.64.65.102).
[10:23:12] + News From Folding@Home: Welcome to Folding@Home
[10:23:12] Loaded queue successfully.
[10:23:12] Gpu type=1 species=4.
[10:23:12] Sent data
[10:23:12] Connecting to http://171.64.65.102:8080/
[10:23:12] Initial: 0000; - Receiving payload (expected size: 69074)
[10:23:13] - Downloaded at ~67 kB/s
[10:23:13] - Averaged speed for that direction ~68 kB/s
[10:23:13] + Received work.
[10:23:13] Trying to send all finished work units
[10:23:13] + No unsent completed units remaining.
[10:23:13] + Closed connections
[10:23:13]
[10:23:13] + Processing work unit
[10:23:13] Core required: FahCore_11.exe
[10:23:13] Core found.
[10:23:13] Working on queue slot 01 [July 29 10:23:13 UTC]
[10:23:13] + Working ...
[10:23:13] - Calling '.\FahCore_11.exe -dir work/ -suffix 01 -nice 19 -nocpulock -checkpoint 30 -verbose -lifeline 2928 -version 630'
[10:23:14]
[10:23:14] *------------------------------*
[10:23:14] Folding@Home GPU Core - Beta
[10:23:14] Version 1.24 (Mon Feb 9 11:00:12 PST 2009)
[10:23:14]
[10:23:14] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[10:23:14] Build host: amoeba
[10:23:14] Board Type: AMD
[10:23:14] Core      :
[10:23:14] Preparing to commence simulation
[10:23:14] - Looking at optimizations...
[10:23:14] - Created dyn
[10:23:14] - Files status OK
[10:23:14] - Expanded 68562 -> 357580 (decompressed 521.5 percent)
[10:23:14] Called DecompressByteArray: compressed_data_size=68562 data_size=357580, decompressed_data_size=357580 diff=0
[10:23:14] - Digital signature verified
[10:23:14]
[10:23:14] Project: 5744 (Run 1, Clone 100, Gen 361)
[10:23:14]
[10:23:14] Assembly optimizations on if available.
[10:23:14] Entering M.D.
[10:23:20] Tpr hash work/wudata_01.tpr:  1477839935 1092303722 3511353941 2322473075 2461123317
[10:23:20] Working on Protein
[10:23:21] Client config found, loading data.
[10:23:21] Starting GUI Server
[10:23:25] mdrun_gpu returned
[10:23:25] Nonzero force sum on GPU
[10:23:25]
[10:23:25] Folding@home Core Shutdown: UNSTABLE_MACHINE
[10:23:28] CoreStatus = 7A (122)
[10:23:28] Sending work to server
[10:23:28] Project: 5744 (Run 1, Clone 100, Gen 361)
[10:23:28] - Read packet limit of 540015616... Set to 524286976.
[10:23:28] - Error: Could not get length of results file work/wuresults_01.dat
[10:23:28] - Error: Could not read unit 01 file. Removing from queue.
[10:23:28] Trying to send all finished work units
[10:23:28] + No unsent completed units remaining.
[10:23:28] - Preparing to get new work unit...
[10:23:28] Cleaning up work directory
[10:23:28] + Attempting to get work packet
[10:23:28] Passkey found
[10:23:28] - Will indicate memory of 6077 MB
[10:23:28] Gpu type=1 species=4.
[10:23:28] - Connecting to assignment server
[10:23:28] Connecting to http://assign-GPU.stanford.edu:8080/
[10:23:29] Posted data.
[10:23:29] Initial: 40AB; - Successful: assigned to (171.64.65.102).
[10:23:29] + News From Folding@Home: Welcome to Folding@Home
[10:23:29] Loaded queue successfully.
[10:23:29] Gpu type=1 species=4.
[10:23:29] Sent data
[10:23:29] Connecting to http://171.64.65.102:8080/
[10:23:29] Initial: 0000; - Receiving payload (expected size: 69074)
[10:23:31] - Downloaded at ~33 kB/s
[10:23:31] - Averaged speed for that direction ~61 kB/s
[10:23:31] + Received work.
[10:23:31] Trying to send all finished work units
[10:23:31] + No unsent completed units remaining.
[10:23:31] + Closed connections
[10:23:36]
[10:23:36] + Processing work unit
[10:23:36] Core required: FahCore_11.exe
[10:23:36] Core found.
[10:23:36] Working on queue slot 02 [July 29 10:23:36 UTC]
[10:23:36] + Working ...
[10:23:36] - Calling '.\FahCore_11.exe -dir work/ -suffix 02 -nice 19 -nocpulock -checkpoint 30 -verbose -lifeline 2928 -version 630'
[10:23:36]
[10:23:36] *------------------------------*
[10:23:36] Folding@Home GPU Core - Beta
[10:23:36] Version 1.24 (Mon Feb 9 11:00:12 PST 2009)
[10:23:36]
[10:23:36] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[10:23:36] Build host: amoeba
[10:23:36] Board Type: AMD
[10:23:36] Core      :
[10:23:36] Preparing to commence simulation
[10:23:36] - Looking at optimizations...
[10:23:36] - Created dyn
[10:23:36] - Files status OK
[10:23:36] - Expanded 68562 -> 357580 (decompressed 521.5 percent)
[10:23:36] Called DecompressByteArray: compressed_data_size=68562 data_size=357580, decompressed_data_size=357580 diff=0
[10:23:36] - Digital signature verified
[10:23:36]
[10:23:36] Project: 5744 (Run 1, Clone 100, Gen 361)
[10:23:36]
[10:23:36] Assembly optimizations on if available.
[10:23:36] Entering M.D.
[10:23:42] Tpr hash work/wudata_02.tpr:  1477839935 1092303722 3511353941 2322473075 2461123317
[10:23:42] Working on Protein
[10:23:43] Client config found, loading data.
[10:23:43] Starting GUI Server
[10:23:47] mdrun_gpu returned
[10:23:47] Nonzero force sum on GPU
[10:23:47]
[10:23:47] Folding@home Core Shutdown: UNSTABLE_MACHINE
[10:23:50] CoreStatus = 7A (122)
[10:23:50] Sending work to server
[10:23:50] Project: 5744 (Run 1, Clone 100, Gen 361)
[10:23:50] - Read packet limit of 540015616... Set to 524286976.
[10:23:50] - Error: Could not get length of results file work/wuresults_02.dat
[10:23:50] - Error: Could not read unit 02 file. Removing from queue.
[10:23:50] Trying to send all finished work units
[10:23:50] + No unsent completed units remaining.
[10:23:50] - Preparing to get new work unit...
[10:23:50] Cleaning up work directory
[10:23:50] + Attempting to get work packet
[10:23:50] Passkey found
[10:23:50] - Will indicate memory of 6077 MB
[10:23:50] Gpu type=1 species=4.
[10:23:50] - Connecting to assignment server
[10:23:50] Connecting to http://assign-GPU.stanford.edu:8080/
[10:23:52] Posted data.
[10:23:52] Initial: 40AB; - Successful: assigned to (171.64.65.102).
[10:23:52] + News From Folding@Home: Welcome to Folding@Home
[10:23:52] Loaded queue successfully.
[10:23:52] Gpu type=1 species=4.
[10:23:52] Sent data
[10:23:52] Connecting to http://171.64.65.102:8080/
[10:23:53] Posted data.
[10:23:53] Initial: 0000; - Receiving payload (expected size: 69074)
[10:23:54] - Downloaded at ~67 kB/s
[10:23:54] - Averaged speed for that direction ~62 kB/s
[10:23:54] + Received work.
[10:23:54] Trying to send all finished work units
[10:23:54] + No unsent completed units remaining.
[10:23:54] + Closed connections
[10:23:59]
[10:23:59] + Processing work unit
[10:23:59] Core required: FahCore_11.exe
[10:23:59] Core found.
[10:23:59] Working on queue slot 03 [July 29 10:23:59 UTC]
[10:23:59] + Working ...
[10:23:59] - Calling '.\FahCore_11.exe -dir work/ -suffix 03 -nice 19 -nocpulock -checkpoint 30 -verbose -lifeline 2928 -version 630'
[10:23:59]
[10:23:59] *------------------------------*
[10:23:59] Folding@Home GPU Core - Beta
[10:23:59] Version 1.24 (Mon Feb 9 11:00:12 PST 2009)
[10:23:59]
[10:23:59] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[10:23:59] Build host: amoeba
[10:23:59] Board Type: AMD
[10:23:59] Core      :
[10:23:59] Preparing to commence simulation
[10:23:59] - Looking at optimizations...
[10:23:59] - Created dyn
[10:23:59] - Files status OK
[10:23:59] - Expanded 68562 -> 357580 (decompressed 521.5 percent)
[10:23:59] Called DecompressByteArray: compressed_data_size=68562 data_size=357580, decompressed_data_size=357580 diff=0
[10:23:59] - Digital signature verified
[10:23:59]
[10:23:59] Project: 5744 (Run 1, Clone 100, Gen 361)
[10:23:59]
[10:23:59] Assembly optimizations on if available.
[10:23:59] Entering M.D.
[10:24:05] Tpr hash work/wudata_03.tpr:  1477839935 1092303722 3511353941 2322473075 2461123317
[10:24:06] Working on Protein
[10:24:06] Client config found, loading data.
[10:24:06] Starting GUI Server
[10:24:11] mdrun_gpu returned
[10:24:11] Nonzero force sum on GPU
[10:24:11]
[10:24:11] Folding@home Core Shutdown: UNSTABLE_MACHINE
[10:24:13] CoreStatus = 7A (122)
[10:24:13] Sending work to server
[10:24:13] Project: 5744 (Run 1, Clone 100, Gen 361)
[10:24:13] - Read packet limit of 540015616... Set to 524286976.
[10:24:13] - Error: Could not get length of results file work/wuresults_03.dat
[10:24:13] - Error: Could not read unit 03 file. Removing from queue.
[10:24:13] Trying to send all finished work units
[10:24:13] + No unsent completed units remaining.
[10:24:13] - Preparing to get new work unit...
[10:24:13] Cleaning up work directory
[10:24:14] + Attempting to get work packet
[10:24:14] Passkey found
[10:24:14] - Will indicate memory of 6077 MB
[10:24:14] Gpu type=1 species=4.
[10:24:14] - Connecting to assignment server
[10:24:14] Connecting to http://assign-GPU.stanford.edu:8080/
[10:24:14] Posted data.
[10:24:14] Initial: 40AB; - Successful: assigned to (171.64.65.102).
[10:24:14] + News From Folding@Home: Welcome to Folding@Home
[10:24:15] Loaded queue successfully.
[10:24:15] Gpu type=1 species=4.
[10:24:15] Sent data
[10:24:15] Connecting to http://171.64.65.102:8080/
[10:24:15] Posted data.
[10:24:15] Initial: 0000; - Receiving payload (expected size: 69074)
[10:24:17] - Downloaded at ~33 kB/s
[10:24:17] - Averaged speed for that direction ~56 kB/s
[10:24:17] + Received work.
[10:24:17] Trying to send all finished work units
[10:24:17] + No unsent completed units remaining.
[10:24:17] + Closed connections
[10:24:22]
[10:24:22] + Processing work unit
[10:24:22] Core required: FahCore_11.exe
[10:24:22] Core found.
[10:24:22] Working on queue slot 04 [July 29 10:24:22 UTC]
[10:24:22] + Working ...
[10:24:22] - Calling '.\FahCore_11.exe -dir work/ -suffix 04 -nice 19 -nocpulock -checkpoint 30 -verbose -lifeline 2928 -version 630'
[10:24:22]
[10:24:22] *------------------------------*
[10:24:22] Folding@Home GPU Core - Beta
[10:24:22] Version 1.24 (Mon Feb 9 11:00:12 PST 2009)
[10:24:22]
[10:24:22] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[10:24:22] Build host: amoeba
[10:24:22] Board Type: AMD
[10:24:22] Core      :
[10:24:22] Preparing to commence simulation
[10:24:22] - Looking at optimizations...
[10:24:22] - Created dyn
[10:24:22] - Files status OK
[10:24:22] - Expanded 68562 -> 357580 (decompressed 521.5 percent)
[10:24:22] Called DecompressByteArray: compressed_data_size=68562 data_size=357580, decompressed_data_size=357580 diff=0
[10:24:22] - Digital signature verified
[10:24:22]
[10:24:22] Project: 5744 (Run 1, Clone 100, Gen 361)
[10:24:22]
[10:24:22] Assembly optimizations on if available.
[10:24:22] Entering M.D.
[10:24:28] Tpr hash work/wudata_04.tpr:  1477839935 1092303722 3511353941 2322473075 2461123317
[10:24:28] Working on Protein
[10:24:29] Client config found, loading data.
[10:24:29] Starting GUI Server
[10:24:33] mdrun_gpu returned
[10:24:33] Nonzero force sum on GPU
[10:24:33]
[10:24:33] Folding@home Core Shutdown: UNSTABLE_MACHINE
[10:24:36] CoreStatus = 7A (122)
[10:24:36] Sending work to server
[10:24:36] Project: 5744 (Run 1, Clone 100, Gen 361)
[10:24:36] - Read packet limit of 540015616... Set to 524286976.
[10:24:36] - Error: Could not get length of results file work/wuresults_04.dat
[10:24:36] - Error: Could not read unit 04 file. Removing from queue.
[10:24:36] Trying to send all finished work units
[10:24:36] + No unsent completed units remaining.
[10:24:36] - Preparing to get new work unit...
[10:24:36] Cleaning up work directory
[10:24:36] + Attempting to get work packet
[10:24:36] Passkey found
[10:24:36] - Will indicate memory of 6077 MB
[10:24:36] Gpu type=1 species=4.
[10:24:36] - Connecting to assignment server
[10:24:36] Connecting to http://assign-GPU.stanford.edu:8080/
[10:24:37] Posted data.
[10:24:37] Initial: 40AB; - Successful: assigned to (171.64.65.102).
[10:24:37] + News From Folding@Home: Welcome to Folding@Home
[10:24:37] Loaded queue successfully.
[10:24:37] Gpu type=1 species=4.
[10:24:37] Sent data
[10:24:37] Connecting to http://171.64.65.102:8080/
[10:24:37] Initial: 0000; - Receiving payload (expected size: 69074)
[10:24:39] - Downloaded at ~33 kB/s
[10:24:39] - Averaged speed for that direction ~52 kB/s
[10:24:39] + Received work.
[10:24:39] Trying to send all finished work units
[10:24:39] + No unsent completed units remaining.
[10:24:39] + Closed connections
[10:24:44]
[10:24:44] + Processing work unit
[10:24:44] Core required: FahCore_11.exe
[10:24:44] Core found.
[10:24:44] Working on queue slot 05 [July 29 10:24:44 UTC]
[10:24:44] + Working ...
[10:24:44] - Calling '.\FahCore_11.exe -dir work/ -suffix 05 -nice 19 -nocpulock -checkpoint 30 -verbose -lifeline 2928 -version 630'
[10:24:44]
[10:24:44] *------------------------------*
[10:24:44] Folding@Home GPU Core - Beta
[10:24:44] Version 1.24 (Mon Feb 9 11:00:12 PST 2009)
[10:24:44]
[10:24:44] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[10:24:44] Build host: amoeba
[10:24:44] Board Type: AMD
[10:24:44] Core      :
[10:24:44] Preparing to commence simulation
[10:24:44] - Looking at optimizations...
[10:24:44] - Created dyn
[10:24:44] - Files status OK
[10:24:44] - Expanded 68562 -> 357580 (decompressed 521.5 percent)
[10:24:44] Called DecompressByteArray: compressed_data_size=68562 data_size=357580, decompressed_data_size=357580 diff=0
[10:24:44] - Digital signature verified
[10:24:44]
[10:24:44] Project: 5744 (Run 1, Clone 100, Gen 361)
[10:24:44]
[10:24:44] Assembly optimizations on if available.
[10:24:44] Entering M.D.
[10:24:50] Tpr hash work/wudata_05.tpr:  1477839935 1092303722 3511353941 2322473075 2461123317
[10:24:50] Working on Protein
[10:24:51] Client config found, loading data.
[10:24:51] Starting GUI Server
[10:24:55] mdrun_gpu returned
[10:24:55] Nonzero force sum on GPU
[10:24:55]
[10:24:55] Folding@home Core Shutdown: UNSTABLE_MACHINE
[10:24:58] CoreStatus = 7A (122)
[10:24:58] Sending work to server
[10:24:58] Project: 5744 (Run 1, Clone 100, Gen 361)
[10:24:58] - Read packet limit of 540015616... Set to 524286976.
[10:24:58] - Error: Could not get length of results file work/wuresults_05.dat
[10:24:58] - Error: Could not read unit 05 file. Removing from queue.
[10:24:58] EUE limit exceeded. Pausing 24 hours.
briar7
Hardware configuration: Athlon64 X2 5400+BE @ 3.1GHz
2Gb DDR2-800
HIS Radeon HD4850 @ 625/993
Post by briar7 »
Just wanted to report that I also got the same WU, also leading to 24 hour pause.
[06:24:01] - Preparing to get new work unit...
[06:24:01] + Attempting to get work packet
[06:24:01] - Will indicate memory of 4094 MB
[06:24:01] - Connecting to assignment server
[06:24:01] Connecting to http://assign-GPU.stanford.edu:8080/
[06:24:02] Posted data.
[06:24:02] Initial: 40AB; - Successful: assigned to (171.64.65.102).
[06:24:02] + News From Folding@Home: Welcome to Folding@Home
[06:24:02] Loaded queue successfully.
[06:24:02] Connecting to http://171.64.65.102:8080/
[06:24:02] Initial: 0000; - Receiving payload (expected size: 69074)
[06:24:02] Conversation time very short, giving reduced weight in bandwidth avg
[06:24:02] - Downloaded at ~134 kB/s
[06:24:02] - Averaged speed for that direction ~155 kB/s
[06:24:02] + Received work.
[06:24:02] Trying to send all finished work units
[06:24:02] + No unsent completed units remaining.
[06:24:02] + Closed connections
[06:24:02]
[06:24:02] + Processing work unit
[06:24:02] Core required: FahCore_11.exe
[06:24:02] Core found.
[06:24:02] Working on queue slot 04 [July 29 06:24:02 UTC]
[06:24:02] + Working ...
[06:24:02] - Calling '.\FahCore_11.exe -dir work/ -suffix 04 -priority 96 -nocpulock -checkpoint 15 -verbose -lifeline 5552 -version 623'
[06:24:02]
[06:24:02] *------------------------------*
[06:24:02] Folding@Home GPU Core - Beta
[06:24:02] Version 1.24 (Mon Feb 9 11:00:12 PST 2009)
[06:24:02]
[06:24:02] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[06:24:02] Build host: amoeba
[06:24:02] Board Type: AMD
[06:24:02] Core      :
[06:24:02] Preparing to commence simulation
[06:24:02] - Looking at optimizations...
[06:24:03] - Created dyn
[06:24:03] - Files status OK
[06:24:03] - Expanded 68562 -> 357580 (decompressed 521.5 percent)
[06:24:03] Called DecompressByteArray: compressed_data_size=68562 data_size=357580, decompressed_data_size=357580 diff=0
[06:24:03] - Digital signature verified
[06:24:03]
[06:24:03] Project: 5744 (Run 1, Clone 100, Gen 361)
[06:24:03]
[06:24:03] Assembly optimizations on if available.
[06:24:03] Entering M.D.
[06:24:09] Tpr hash work/wudata_04.tpr:  1477839935 1092303722 3511353941 2322473075 2461123317
[06:24:09] Working on Protein
[06:24:09] Client config found, loading data.
[06:24:09] Starting GUI Server
[06:24:14] mdrun_gpu returned
[06:24:14] Nonzero force sum on GPU
[06:24:14]
[06:24:14] Folding@home Core Shutdown: UNSTABLE_MACHINE
[06:24:17] CoreStatus = 7A (122)
[06:24:17] Sending work to server
[06:24:17] Project: 5744 (Run 1, Clone 100, Gen 361)
[06:24:17] - Read packet limit of 540015616... Set to 524286976.
[06:24:17] - Error: Could not get length of results file work/wuresults_04.dat
[06:24:17] - Error: Could not read unit 04 file. Removing from queue.
[06:24:17] Trying to send all finished work units
[06:24:17] + No unsent completed units remaining.
[06:24:17] - Preparing to get new work unit...
[06:24:17] + Attempting to get work packet
[06:24:17] - Will indicate memory of 4094 MB
[06:24:17] - Connecting to assignment server
[06:24:17] Connecting to http://assign-GPU.stanford.edu:8080/
[06:24:17] Posted data.
[06:24:17] Initial: 40AB; - Successful: assigned to (171.64.65.102).
[06:24:17] + News From Folding@Home: Welcome to Folding@Home
[06:24:17] Loaded queue successfully.
[06:24:17] Connecting to http://171.64.65.102:8080/
[06:24:17] Initial: 0000; - Receiving payload (expected size: 69074)
[06:24:18] - Downloaded at ~67 kB/s
[06:24:18] - Averaged speed for that direction ~137 kB/s
[06:24:18] + Received work.
[06:24:18] Trying to send all finished work units
[06:24:18] + No unsent completed units remaining.
[06:24:18] + Closed connections
[06:24:23]
[06:24:23] + Processing work unit
[06:24:23] Core required: FahCore_11.exe
[06:24:23] Core found.
[06:24:23] Working on queue slot 05 [July 29 06:24:23 UTC]
[06:24:23] + Working ...
[06:24:23] - Calling '.\FahCore_11.exe -dir work/ -suffix 05 -priority 96 -nocpulock -checkpoint 15 -verbose -lifeline 5552 -version 623'
[06:24:23]
[06:24:23] *------------------------------*
[06:24:23] Folding@Home GPU Core - Beta
[06:24:23] Version 1.24 (Mon Feb 9 11:00:12 PST 2009)
[06:24:23]
[06:24:23] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[06:24:23] Build host: amoeba
[06:24:23] Board Type: AMD
[06:24:23] Core      :
[06:24:23] Preparing to commence simulation
[06:24:23] - Looking at optimizations...
[06:24:23] - Created dyn
[06:24:23] - Files status OK
[06:24:23] - Expanded 68562 -> 357580 (decompressed 521.5 percent)
[06:24:23] Called DecompressByteArray: compressed_data_size=68562 data_size=357580, decompressed_data_size=357580 diff=0
[06:24:23] - Digital signature verified
[06:24:23]
[06:24:23] Project: 5744 (Run 1, Clone 100, Gen 361)
[06:24:23]
[06:24:23] Assembly optimizations on if available.
[06:24:23] Entering M.D.
[06:24:29] Tpr hash work/wudata_05.tpr:  1477839935 1092303722 3511353941 2322473075 2461123317
[06:24:29] Working on Protein
[06:24:29] Client config found, loading data.
[06:24:29] Starting GUI Server
[06:24:34] mdrun_gpu returned
[06:24:34] Nonzero force sum on GPU
[06:24:34]
[06:24:34] Folding@home Core Shutdown: UNSTABLE_MACHINE
[06:24:37] CoreStatus = 7A (122)
[06:24:37] Sending work to server
[06:24:37] Project: 5744 (Run 1, Clone 100, Gen 361)
[06:24:37] - Read packet limit of 540015616... Set to 524286976.
[06:24:37] - Error: Could not get length of results file work/wuresults_05.dat
[06:24:37] - Error: Could not read unit 05 file. Removing from queue.
[06:24:37] Trying to send all finished work units
[06:24:37] + No unsent completed units remaining.
[06:24:37] - Preparing to get new work unit...
[06:24:37] + Attempting to get work packet
[06:24:37] - Will indicate memory of 4094 MB
[06:24:37] - Connecting to assignment server
[06:24:37] Connecting to http://assign-GPU.stanford.edu:8080/
[06:24:38] Posted data.
[06:24:38] Initial: 40AB; - Successful: assigned to (171.64.65.102).
[06:24:38] + News From Folding@Home: Welcome to Folding@Home
[06:24:38] Loaded queue successfully.
[06:24:38] Connecting to http://171.64.65.102:8080/
[06:24:38] Initial: 0000; - Receiving payload (expected size: 69074)
[06:24:39] - Downloaded at ~67 kB/s
[06:24:39] - Averaged speed for that direction ~123 kB/s
[06:24:39] + Received work.
[06:24:39] Trying to send all finished work units
[06:24:39] + No unsent completed units remaining.
[06:24:39] + Closed connections
[06:24:44]
[06:24:44] + Processing work unit
[06:24:44] Core required: FahCore_11.exe
[06:24:44] Core found.
[06:24:44] Working on queue slot 06 [July 29 06:24:44 UTC]
[06:24:44] + Working ...
[06:24:44] - Calling '.\FahCore_11.exe -dir work/ -suffix 06 -priority 96 -nocpulock -checkpoint 15 -verbose -lifeline 5552 -version 623'
[06:24:44]
[06:24:44] *------------------------------*
[06:24:44] Folding@Home GPU Core - Beta
[06:24:44] Version 1.24 (Mon Feb 9 11:00:12 PST 2009)
[06:24:44]
[06:24:44] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[06:24:44] Build host: amoeba
[06:24:44] Board Type: AMD
[06:24:44] Core      :
[06:24:44] Preparing to commence simulation
[06:24:44] - Looking at optimizations...
[06:24:44] - Created dyn
[06:24:44] - Files status OK
[06:24:44] - Expanded 68562 -> 357580 (decompressed 521.5 percent)
[06:24:44] Called DecompressByteArray: compressed_data_size=68562 data_size=357580, decompressed_data_size=357580 diff=0
[06:24:44] - Digital signature verified
[06:24:44]
[06:24:44] Project: 5744 (Run 1, Clone 100, Gen 361)
[06:24:44]
[06:24:44] Assembly optimizations on if available.
[06:24:44] Entering M.D.
[06:24:50] Tpr hash work/wudata_06.tpr:  1477839935 1092303722 3511353941 2322473075 2461123317
[06:24:50] Working on Protein
[06:24:52] Client config found, loading data.
[06:24:52] Starting GUI Server
[06:25:01] mdrun_gpu returned
[06:25:01] Nonzero force sum on GPU
[06:25:01]
[06:25:01] Folding@home Core Shutdown: UNSTABLE_MACHINE
[06:25:06] CoreStatus = 7A (122)
[06:25:06] Sending work to server
[06:25:06] Project: 5744 (Run 1, Clone 100, Gen 361)
[06:25:06] - Read packet limit of 540015616... Set to 524286976.
[06:25:06] - Error: Could not get length of results file work/wuresults_06.dat
[06:25:06] - Error: Could not read unit 06 file. Removing from queue.
[06:25:06] Trying to send all finished work units
[06:25:06] + No unsent completed units remaining.
[06:25:06] - Preparing to get new work unit...
[06:25:06] + Attempting to get work packet
[06:25:06] - Will indicate memory of 4094 MB
[06:25:06] - Connecting to assignment server
[06:25:06] Connecting to http://assign-GPU.stanford.edu:8080/
[06:25:07] Posted data.
[06:25:07] Initial: 40AB; - Successful: assigned to (171.64.65.102).
[06:25:07] + News From Folding@Home: Welcome to Folding@Home
[06:25:07] Loaded queue successfully.
[06:25:07] Connecting to http://171.64.65.102:8080/
[06:25:07] Initial: 0000; - Receiving payload (expected size: 69074)
[06:25:07] Conversation time very short, giving reduced weight in bandwidth avg
[06:25:07] - Downloaded at ~134 kB/s
[06:25:07] - Averaged speed for that direction ~124 kB/s
[06:25:07] + Received work.
[06:25:07] Trying to send all finished work units
[06:25:07] + No unsent completed units remaining.
[06:25:07] + Closed connections
[06:25:12]
[06:25:12] + Processing work unit
[06:25:12] Core required: FahCore_11.exe
[06:25:12] Core found.
[06:25:12] Working on queue slot 07 [July 29 06:25:12 UTC]
[06:25:12] + Working ...
[06:25:12] - Calling '.\FahCore_11.exe -dir work/ -suffix 07 -priority 96 -nocpulock -checkpoint 15 -verbose -lifeline 5552 -version 623'
[06:25:12]
[06:25:12] *------------------------------*
[06:25:12] Folding@Home GPU Core - Beta
[06:25:12] Version 1.24 (Mon Feb 9 11:00:12 PST 2009)
[06:25:12]
[06:25:12] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[06:25:12] Build host: amoeba
[06:25:12] Board Type: AMD
[06:25:12] Core      :
[06:25:12] Preparing to commence simulation
[06:25:12] - Looking at optimizations...
[06:25:12] - Created dyn
[06:25:12] - Files status OK
[06:25:12] - Expanded 68562 -> 357580 (decompressed 521.5 percent)
[06:25:12] Called DecompressByteArray: compressed_data_size=68562 data_size=357580, decompressed_data_size=357580 diff=0
[06:25:12] - Digital signature verified
[06:25:12]
[06:25:12] Project: 5744 (Run 1, Clone 100, Gen 361)
[06:25:12]
[06:25:12] Assembly optimizations on if available.
[06:25:12] Entering M.D.
[06:25:18] Tpr hash work/wudata_07.tpr:  1477839935 1092303722 3511353941 2322473075 2461123317
[06:25:19] Working on Protein
[06:25:19] Client config found, loading data.
[06:25:19] Starting GUI Server
[06:25:23] mdrun_gpu returned
[06:25:23] Nonzero force sum on GPU
[06:25:23]
[06:25:23] Folding@home Core Shutdown: UNSTABLE_MACHINE
[06:25:27] CoreStatus = 7A (122)
[06:25:27] Sending work to server
[06:25:27] Project: 5744 (Run 1, Clone 100, Gen 361)
[06:25:27] - Read packet limit of 540015616... Set to 524286976.
[06:25:27] - Error: Could not get length of results file work/wuresults_07.dat
[06:25:27] - Error: Could not read unit 07 file. Removing from queue.
[06:25:27] Trying to send all finished work units
[06:25:27] + No unsent completed units remaining.
[06:25:27] - Preparing to get new work unit...
[06:25:27] + Attempting to get work packet
[06:25:27] - Will indicate memory of 4094 MB
[06:25:27] - Connecting to assignment server
[06:25:27] Connecting to http://assign-GPU.stanford.edu:8080/
[06:25:27] Posted data.
[06:25:27] Initial: 40AB; - Successful: assigned to (171.64.65.102).
[06:25:27] + News From Folding@Home: Welcome to Folding@Home
[06:25:27] Loaded queue successfully.
[06:25:27] Connecting to http://171.64.65.102:8080/
[06:25:27] Initial: 0000; - Receiving payload (expected size: 69074)
[06:25:28] - Downloaded at ~67 kB/s
[06:25:28] - Averaged speed for that direction ~113 kB/s
[06:25:28] + Received work.
[06:25:28] Trying to send all finished work units
[06:25:28] + No unsent completed units remaining.
[06:25:28] + Closed connections
[06:25:33]
[06:25:33] + Processing work unit
[06:25:33] Core required: FahCore_11.exe
[06:25:33] Core found.
[06:25:33] Working on queue slot 08 [July 29 06:25:33 UTC]
[06:25:33] + Working ...
[06:25:33] - Calling '.\FahCore_11.exe -dir work/ -suffix 08 -priority 96 -nocpulock -checkpoint 15 -verbose -lifeline 5552 -version 623'
[06:25:33]
[06:25:33] *------------------------------*
[06:25:33] Folding@Home GPU Core - Beta
[06:25:33] Version 1.24 (Mon Feb 9 11:00:12 PST 2009)
[06:25:33]
[06:25:33] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[06:25:33] Build host: amoeba
[06:25:33] Board Type: AMD
[06:25:33] Core      :
[06:25:33] Preparing to commence simulation
[06:25:33] - Looking at optimizations...
[06:25:33] - Created dyn
[06:25:33] - Files status OK
[06:25:33] - Expanded 68562 -> 357580 (decompressed 521.5 percent)
[06:25:33] Called DecompressByteArray: compressed_data_size=68562 data_size=357580, decompressed_data_size=357580 diff=0
[06:25:33] - Digital signature verified
[06:25:33]
[06:25:33] Project: 5744 (Run 1, Clone 100, Gen 361)
[06:25:33]
[06:25:33] Assembly optimizations on if available.
[06:25:33] Entering M.D.
[06:25:39] Tpr hash work/wudata_08.tpr:  1477839935 1092303722 3511353941 2322473075 2461123317
[06:25:39] Working on Protein
[06:25:39] Client config found, loading data.
[06:25:39] Starting GUI Server
[06:25:44] mdrun_gpu returned
[06:25:44] Nonzero force sum on GPU
[06:25:44]
[06:25:44] Folding@home Core Shutdown: UNSTABLE_MACHINE
[06:25:47] CoreStatus = 7A (122)
[06:25:47] Sending work to server
[06:25:47] Project: 5744 (Run 1, Clone 100, Gen 361)
[06:25:47] - Read packet limit of 540015616... Set to 524286976.
[06:25:47] - Error: Could not get length of results file work/wuresults_08.dat
[06:25:47] - Error: Could not read unit 08 file. Removing from queue.
[06:25:47] EUE limit exceeded. Pausing 24 hours.
Core i5-2500K stable @ 4.4GHz, Sapphire HD4870 @800/1000, 12GBPNY DDR3-1600, OCZ StealthXStream 500w, Win7 Pro X64
The WU (P5744,R1,C100,G361) has been reported as a bad WU.
