171.67.108.22
Michael_McCord,_M.D.
171.67.108.22
Post by Michael_McCord,_M.D. »
Same issue as the thread beneath this one exactly...171.67.108.31.
Proud to still be on Page One World!
Team MPC- in relentless pursuit of the cure.
DrSpalding
Hardware configuration: Dell Studio 425 MTS-Core i7-920 c0 stock
evga SLI 3x o/c Core i7-920 d0 @ 3.9GHz + nVidia GTX275
Dell 5150 + nVidia 9800GT
Re: 171.67.108.22
Post by DrSpalding »
I have a Win SMP 6.29 console client running -bigadv and the server 171.67.108.22 is marked as up and running but is not assigning a WU from 6:44 PDT today when it uploaded a 2684 WU. My machine has been trying for 3+ hours now to get a WU. I am considering running -advmethods instead to get some work to do.
Not a real doctor, I just play one on the 'net!
kasson
Pande Group Member
Re: 171.67.108.22
Post by kasson »
The server is out of windows-capable jobs right now.
DrSpalding
Re: 171.67.108.22
Thanks for the update, kasson. Are there any non -bigadv A3 units available via -smp -advmethods?
Re: 171.67.108.22
I will be completing my bigadv in ~14hrs. I have read that if there aren't any bigadv WUs, the Server will assign -advmethods WUs. Has that been implemented yet?
DrSpalding
Re: 171.67.108.22
PantherX wrote:I will be completing my bigadv in ~14hrs. I have read that if there aren't any bigadv WUs, the Server will assign -advmethods WUs. Has that been implemented yet?
I thought that it should have moved off of the bigadv server too, but it has been my experience that once the assignment server assigns your machine to a particular WU server, it is pretty sticky. It may just take longer than I have patience for though.
I switched to -advmethods and picked up a WU immediately. I'll let it run and check back periodically to see if -bigadv has been repopulated with WUs to distribute.
kasson
Pande Group Member
Re: 171.67.108.22
Post by kasson »
There are plenty of A3 -advanced methods work units. The situation with Server .22 is a little more complicated right now because we have a primary supply of 2684's and then some work units that are more client-restricted (e.g. a few leftover A2 work units). This makes it harder for the AS to correctly account for the # of available work units. The spec is that it's supposed to count the number of unrestricted work units, but evidently something's going wrong there.
Edit by Mod:
Changed ".22" above to "Server .22" to avoid the misunderstanding discussed in the next two posts.
filu
Re: 171.67.108.22
Post by filu »
So, although the core (v.22) has not been tested and is written by the same algorithm as for Linux. That is easier and faster but is it better? Good luck.
i7-2600K@4.8 Asus P8P67 EVO 2x2GB GTX480
i7-920@4.0 GA-EX58-UD5 3x2GB 2xGTX560Ti
2x Xeon 5620 6x 2GB
2x Xeon 5645 6x 2GB
Re: 171.67.108.22
filu wrote:So, although the core (v.22) has not been tested and is written by the same algorithm as for Linux. That is easier and faster but is it better? Good luck.
I think that Dr. Kasson was referring to Server 171.67.108.22 when he stated .22
More info about FahCore_a3 v2.22: (http://en.fah-addict.net/news/news-0-25 ... -linux.php) and (http://en.fah-addict.net/news/news-0-25 ... indows.php)
hrsetrdr
Re: 171.67.108.22
Post by hrsetrdr »
kasson wrote:The server is out of windows-capable jobs right now.
Ha, looks like my timing is impeccable- I just tore down two Debian installs and switched to Windows to capture some bigadv WUs....Image
Folding rig:Supermicro X9DRD-7LN4F-JBOD | (2) Xeon E5-2670 | 128GB DDR3 ECC Registered
Install Folding@Home on Linux without Python dependancy issues
Re: 171.67.108.22
Well, Kasson already knows about it, and he wants it fixed as much as you do.
DrSpalding
Re: 171.67.108.22
Quick update as of 16:00 PDT.
Still no Windows -bigadv WUs to be had. Restarted again back to -advmethods and will check again tomorrow.
hrsetrdr
Re: 171.67.108.22
Post by hrsetrdr »
Bruce,
I'm not a complainer, but I just feel better after a good cry. :lol: I've already gone to "Plan B"(actually "Plan C") as there's bigger WUs to fry. ;-)
Re: 171.67.108.22
My first attempt was unsuccessful but on the second attempt, I was assigned a bigadv. Looks that everything is fixed
DrSpalding
Re: 171.67.108.22
I switched over to -bigadv again and it is finishing up a 6702 WU now. I'll know in ~8 hours if I can get going on -bigadv again.
