Project: 5734 (Run 2, Clone 12, Gen 772)
Stewart1
Post by Stewart1 »
Board is an ATI 3850
[15:45:48] Project: 5734 (Run 2, Clone 12, Gen 772)
[15:45:48]
[15:45:48] Assembly optimizations on if available.
[15:45:48] Entering M.D.
[15:45:54] Tpr hash work/wudata_02.tpr:  3852432253 2977017888 1022542029 1655236903 2687166597
[15:45:54] Working on Protein
[15:45:54] Client config found, loading data.
[15:45:54] Starting GUI Server
[15:46:01] mdrun_gpu returned
[15:46:01] NANs detected on GPU
[15:46:01]
[15:46:01] Folding@home Core Shutdown: UNSTABLE_MACHINE
[15:46:04] CoreStatus = 7A (122)
[15:46:04] Sending work to server
[15:46:04] Project: 5734 (Run 2, Clone 12, Gen 772)
[15:46:04] - Read packet limit of 540015616... Set to 524286976.
[15:46:04] - Error: Could not get length of results file work/wuresults_02.dat
[15:46:04] - Error: Could not read unit 02 file. Removing from queue.
[15:46:04] - Preparing to get new work unit...
[15:46:04] + Attempting to get work packet
[15:46:04] - Connecting to assignment server
[15:46:10] - Successful: assigned to (171.64.65.102).
[15:46:10] + News From Folding@Home: Welcome to Folding@Home
[15:46:10] Loaded queue successfully.
[15:46:23] + Closed connections
[15:46:28]
[15:46:28] + Processing work unit
[15:46:28] Core required: FahCore_11.exe
[15:46:28] Core found.
[15:46:28] Working on queue slot 03 [June 28 15:46:28 UTC]
[15:46:28] + Working ...
[15:46:28]
[15:46:28] *------------------------------*
[15:46:28] Folding@Home GPU Core - Beta
[15:46:28] Version 1.24 (Mon Feb 9 11:00:12 PST 2009)
[15:46:28]
[15:46:28] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[15:46:28] Build host: amoeba
[15:46:28] Board Type: AMD
[15:46:28] Core      :
[15:46:28] Preparing to commence simulation
[15:46:28] - Looking at optimizations...
[15:46:28] - Created dyn
[15:46:28] - Files status OK
[15:46:28] - Expanded 63430 -> 492188 (decompressed 775.9 percent)
[15:46:28] Called DecompressByteArray: compressed_data_size=63430 data_size=492188, decompressed_data_size=492188 diff=0
[15:46:28] - Digital signature verified
[15:46:28]
[15:46:28] Project: 5734 (Run 2, Clone 12, Gen 772)
[15:46:28]
[15:46:28] Assembly optimizations on if available.
[15:46:28] Entering M.D.
[15:46:34] Tpr hash work/wudata_03.tpr:  3852432253 2977017888 1022542029 1655236903 2687166597
[15:46:35] Working on Protein
[15:46:35] Client config found, loading data.
[15:46:35] Starting GUI Server
[15:46:41] mdrun_gpu returned
[15:46:41] NANs detected on GPU
[15:46:41]
[15:46:41] Folding@home Core Shutdown: UNSTABLE_MACHINE
[15:46:44] CoreStatus = 7A (122)
[15:46:44] Sending work to server
[15:46:44] Project: 5734 (Run 2, Clone 12, Gen 772)
[15:46:44] - Read packet limit of 540015616... Set to 524286976.
[15:46:44] - Error: Could not get length of results file work/wuresults_03.dat
[15:46:44] - Error: Could not read unit 03 file. Removing from queue.
[15:46:44] - Preparing to get new work unit...
[15:46:44] + Attempting to get work packet
[15:46:44] - Connecting to assignment server
[15:46:50] - Successful: assigned to (171.64.65.102).
[15:46:50] + News From Folding@Home: Welcome to Folding@Home
[15:46:51] Loaded queue successfully.
[15:47:04] + Closed connections
[15:47:09]
[15:47:09] + Processing work unit
[15:47:09] Core required: FahCore_11.exe
[15:47:09] Core found.
[15:47:09] Working on queue slot 04 [June 28 15:47:09 UTC]
[15:47:09] + Working ...
[15:47:10]
[15:47:10] *------------------------------*
[15:47:10] Folding@Home GPU Core - Beta
[15:47:10] Version 1.24 (Mon Feb 9 11:00:12 PST 2009)
[15:47:10]
[15:47:10] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[15:47:10] Build host: amoeba
[15:47:10] Board Type: AMD
[15:47:10] Core      :
[15:47:10] Preparing to commence simulation
[15:47:10] - Looking at optimizations...
[15:47:10] - Created dyn
[15:47:10] - Files status OK
[15:47:10] - Expanded 63430 -> 492188 (decompressed 775.9 percent)
[15:47:10] Called DecompressByteArray: compressed_data_size=63430 data_size=492188, decompressed_data_size=492188 diff=0
[15:47:10] - Digital signature verified
[15:47:10]
[15:47:10] Project: 5734 (Run 2, Clone 12, Gen 772)
[15:47:10]
[15:47:10] Assembly optimizations on if available.
[15:47:10] Entering M.D.
[15:47:16] Tpr hash work/wudata_04.tpr:  3852432253 2977017888 1022542029 1655236903 2687166597
[15:47:16] Working on Protein
[15:47:16] Client config found, loading data.
[15:47:16] Starting GUI Server
[15:47:23] mdrun_gpu returned
[15:47:23] NANs detected on GPU
[15:47:23]
[15:47:23] Folding@home Core Shutdown: UNSTABLE_MACHINE
[15:47:26] CoreStatus = 7A (122)
[15:47:26] Sending work to server
[15:47:26] Project: 5734 (Run 2, Clone 12, Gen 772)
[15:47:26] - Read packet limit of 540015616... Set to 524286976.
[15:47:26] - Error: Could not get length of results file work/wuresults_04.dat
[15:47:26] - Error: Could not read unit 04 file. Removing from queue.
[15:47:26] - Preparing to get new work unit...
[15:47:26] + Attempting to get work packet
[15:47:26] - Connecting to assignment server
[15:47:33] - Successful: assigned to (171.64.65.102).
[15:47:33] + News From Folding@Home: Welcome to Folding@Home
[15:47:33] Loaded queue successfully.
[15:47:42] + Closed connections
[15:47:47]
[15:47:47] + Processing work unit
[15:47:47] Core required: FahCore_11.exe
[15:47:47] Core found.
[15:47:47] Working on queue slot 05 [June 28 15:47:47 UTC]
[15:47:47] + Working ...
[15:47:47]
[15:47:47] *------------------------------*
[15:47:47] Folding@Home GPU Core - Beta
[15:47:47] Version 1.24 (Mon Feb 9 11:00:12 PST 2009)
[15:47:47]
[15:47:47] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[15:47:47] Build host: amoeba
[15:47:47] Board Type: AMD
[15:47:47] Core      :
[15:47:47] Preparing to commence simulation
[15:47:47] - Looking at optimizations...
[15:47:47] - Created dyn
[15:47:47] - Files status OK
[15:47:47] - Expanded 63430 -> 492188 (decompressed 775.9 percent)
[15:47:47] Called DecompressByteArray: compressed_data_size=63430 data_size=492188, decompressed_data_size=492188 diff=0
[15:47:47] - Digital signature verified
[15:47:47]
[15:47:47] Project: 5734 (Run 2, Clone 12, Gen 772)
[15:47:47]
[15:47:47] Assembly optimizations on if available.
[15:47:47] Entering M.D.
[15:47:53] Tpr hash work/wudata_05.tpr:  3852432253 2977017888 1022542029 1655236903 2687166597
[15:47:53] Working on Protein
[15:47:53] Client config found, loading data.
[15:47:53] Starting GUI Server
[15:48:00] mdrun_gpu returned
[15:48:00] NANs detected on GPU
[15:48:00]
[15:48:00] Folding@home Core Shutdown: UNSTABLE_MACHINE
[15:48:03] CoreStatus = 7A (122)
[15:48:03] Sending work to server
[15:48:03] Project: 5734 (Run 2, Clone 12, Gen 772)
[15:48:03] - Read packet limit of 540015616... Set to 524286976.
[15:48:03] - Error: Could not get length of results file work/wuresults_05.dat
[15:48:03] - Error: Could not read unit 05 file. Removing from queue.
[15:48:03] - Preparing to get new work unit...
[15:48:03] + Attempting to get work packet
[15:48:03] - Connecting to assignment server
[15:48:06] - Successful: assigned to (171.64.65.102).
[15:48:06] + News From Folding@Home: Welcome to Folding@Home
[15:48:06] Loaded queue successfully.
[15:48:13] + Closed connections
[15:48:18]
[15:48:18] + Processing work unit
[15:48:18] Core required: FahCore_11.exe
[15:48:18] Core found.
[15:48:18] Working on queue slot 06 [June 28 15:48:18 UTC]
[15:48:18] + Working ...
[15:48:18]
[15:48:18] *------------------------------*
[15:48:18] Folding@Home GPU Core - Beta
[15:48:18] Version 1.24 (Mon Feb 9 11:00:12 PST 2009)
[15:48:18]
[15:48:18] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[15:48:18] Build host: amoeba
[15:48:18] Board Type: AMD
[15:48:18] Core      :
[15:48:18] Preparing to commence simulation
[15:48:18] - Looking at optimizations...
[15:48:18] - Created dyn
[15:48:18] - Files status OK
[15:48:18] - Expanded 63430 -> 492188 (decompressed 775.9 percent)
[15:48:18] Called DecompressByteArray: compressed_data_size=63430 data_size=492188, decompressed_data_size=492188 diff=0
[15:48:18] - Digital signature verified
[15:48:18]
[15:48:18] Project: 5734 (Run 2, Clone 12, Gen 772)
[15:48:18]
[15:48:18] Assembly optimizations on if available.
[15:48:18] Entering M.D.
[15:48:24] Tpr hash work/wudata_06.tpr:  3852432253 2977017888 1022542029 1655236903 2687166597
[15:48:24] Working on Protein
[15:48:24] Client config found, loading data.
[15:48:24] Starting GUI Server
[15:48:31] mdrun_gpu returned
[15:48:31] NANs detected on GPU
[15:48:31]
[15:48:31] Folding@home Core Shutdown: UNSTABLE_MACHINE
[15:48:34] CoreStatus = 7A (122)
[15:48:34] Sending work to server
[15:48:34] Project: 5734 (Run 2, Clone 12, Gen 772)
[15:48:34] - Read packet limit of 540015616... Set to 524286976.
[15:48:34] - Error: Could not get length of results file work/wuresults_06.dat
[15:48:34] - Error: Could not read unit 06 file. Removing from queue.
[15:48:34] EUE limit exceeded. Pausing 24 hours.
mathwhiz
Re: Project: 5734 (Run 2, Clone 12, Gen 772)
Post by mathwhiz »
I have received this one over 10 times with the same immediate NANs result. All other work units I receive process just fine.
I've put this bad WU out of it's misery.
mathwhiz
Post by mathwhiz »
Thanks bruce!
