Project: 5747 (Run 1, Clone 15, Gen 1285)
Mactin
Post by Mactin »
Could Project: 5747 (Run 1, Clone 15, Gen 1285) be a bad WU ?
I had the same problem 11 times in a row, after a couple of restarts, I had to trash the client and change the Machine ID to get something else.
--- Opening Log file [June 26 12:04:31 UTC]
                          http://folding.stanford.edu
Launch directory: C:\Program Files (x86)\folding\m3 GPU
Executable: C:\Program Files (x86)\folding\m3 GPU\Folding@home-Win32-GPU.exe
Arguments: -local -gpu 0 -verbosity 9 -forcegpu ati_r700 -config
[12:04:31] - Ask before connecting: No
[12:04:31] - User name: Martin_i7-980x_HD5870 (Team 96377)
[12:04:31] - User ID: 6C6A12517E046D46
[12:04:31] - Machine ID: 3
[12:04:31]
[12:04:31] Configuring Folding@Home...
[12:04:34] - Ask before connecting: No
[12:04:34] - User name: Martin_i7-980x_HD5870 (Team 96377)
[12:04:34] - User ID: 6C6A12517E046D46
[12:04:34] - Machine ID: 3
[12:04:34]
[12:04:34] Loaded queue successfully.
[12:04:34] - Preparing to get new work unit...
[12:04:34] - Autosending finished units... [June 26 12:04:34 UTC]
[12:04:34] + Attempting to get work packet
[12:04:34] Trying to send all finished work units
[12:04:34] - Will indicate memory of 1024 MB
[12:04:34] + No unsent completed units remaining.
[12:04:34] - Detect CPU.[12:04:34] - Autosend completed
 Vendor: GenuineIntel, Family: 6, Model: 12, Stepping: 2
[12:04:34] - Connecting to assignment server
[12:04:34] Connecting to http://assign-GPU.stanford.edu:8080/
[12:04:35] Posted data.
[12:04:35] Initial: 40AB; - Successful: assigned to (171.64.65.102).
[12:04:35] + News From Folding@Home: Welcome to Folding@Home
[12:04:35] Loaded queue successfully.
[12:04:35] Connecting to http://171.64.65.102:8080/
[12:04:35] Initial: 0000; - Receiving payload (expected size: 69080)
[12:04:36] - Downloaded at ~67 kB/s
[12:04:36] - Averaged speed for that direction ~82 kB/s
[12:04:36] + Received work.
[12:04:36] + Closed connections
[12:04:36]
[12:04:36] + Processing work unit
[12:04:36] Core required: FahCore_11.exe
[12:04:36] Core found.
[12:04:36] Working on queue slot 09 [June 26 12:04:36 UTC]
[12:04:36] + Working ...
[12:04:36] - Calling '.\FahCore_11.exe -dir work/ -suffix 09 -checkpoint 10 -verbose -lifeline 2592 -version 623'
[12:04:36]
[12:04:36] *------------------------------*
[12:04:36] Folding@Home GPU Core - Beta
[12:04:36] Version 1.24 (Mon Feb 9 11:00:12 PST 2009)
[12:04:36]
[12:04:36] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[12:04:36] Build host: amoeba
[12:04:36] Board Type: AMD
[12:04:36] Core      :
[12:04:36] Preparing to commence simulation
[12:04:36] - Looking at optimizations...
[12:04:36] - Created dyn
[12:04:36] - Files status OK
[12:04:36] - Expanded 68568 -> 357580 (decompressed 521.4 percent)
[12:04:36] Called DecompressByteArray: compressed_data_size=68568 data_size=357580, decompressed_data_size=357580 diff=0
[12:04:36] - Digital signature verified
[12:04:36]
[12:04:36] Project: 5747 (Run 1, Clone 15, Gen 1285)
[12:04:36]
[12:04:36] Assembly optimizations on if available.
[12:04:36] Entering M.D.
[12:04:42] Tpr hash work/wudata_09.tpr:  1712642377 2730102086 3674622148 1453241572 717641734
[12:04:42] Working on Protein
[12:04:43] Client config found, loading data.
[12:04:43] Starting GUI Server
[12:04:46] mdrun_gpu returned
[12:04:46] SHAKE violations on GPU
[12:04:46]
[12:04:46] Folding@home Core Shutdown: UNSTABLE_MACHINE
[12:04:49] CoreStatus = 7A (122)
[12:04:49] Sending work to server
[12:04:49] Project: 5747 (Run 1, Clone 15, Gen 1285)
[12:04:49] - Read packet limit of 540015616... Set to 524286976.
[12:04:49] - Error: Could not get length of results file work/wuresults_09.dat
[12:04:49] - Error: Could not read unit 09 file. Removing from queue.
[12:04:49] Trying to send all finished work units
[12:04:49] + No unsent completed units remaining.
[12:04:49] - Preparing to get new work unit...
[12:04:49] + Attempting to get work packet
[12:04:49] - Will indicate memory of 1024 MB
[12:04:49] - Connecting to assignment server
[12:04:49] Connecting to http://assign-GPU.stanford.edu:8080/
[12:04:49] Posted data.
[12:04:49] Initial: 40AB; - Successful: assigned to (171.64.65.102).
[12:04:49] + News From Folding@Home: Welcome to Folding@Home
[12:04:49] Loaded queue successfully.
[12:04:49] Connecting to http://171.64.65.102:8080/
[12:04:49] Initial: 0000; - Receiving payload (expected size: 69080)
[12:04:50] - Downloaded at ~67 kB/s
[12:04:50] - Averaged speed for that direction ~79 kB/s
[12:04:50] + Received work.
[12:04:50] Trying to send all finished work units
[12:04:50] + No unsent completed units remaining.
[12:04:50] + Closed connections
[12:04:55]
[12:04:55] + Processing work unit
[12:04:55] Core required: FahCore_11.exe
[12:04:55] Core found.
[12:04:55] Working on queue slot 00 [June 26 12:04:55 UTC]
[12:04:55] + Working ...
[12:04:55] - Calling '.\FahCore_11.exe -dir work/ -suffix 00 -checkpoint 10 -verbose -lifeline 2592 -version 623'
[12:04:55]
[12:04:55] *------------------------------*
[12:04:55] Folding@Home GPU Core - Beta
[12:04:55] Version 1.24 (Mon Feb 9 11:00:12 PST 2009)
[12:04:55]
[12:04:55] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[12:04:55] Build host: amoeba
[12:04:55] Board Type: AMD
[12:04:55] Core      :
[12:04:55] Preparing to commence simulation
[12:04:55] - Looking at optimizations...
[12:04:55] - Created dyn
[12:04:55] - Files status OK
[12:04:55] - Expanded 68568 -> 357580 (decompressed 521.4 percent)
[12:04:55] Called DecompressByteArray: compressed_data_size=68568 data_size=357580, decompressed_data_size=357580 diff=0
[12:04:55] - Digital signature verified
[12:04:55]
[12:04:55] Project: 5747 (Run 1, Clone 15, Gen 1285)
[12:04:55]
[12:04:55] Assembly optimizations on if available.
[12:04:55] Entering M.D.
[12:05:01] Tpr hash work/wudata_00.tpr:  1712642377 2730102086 3674622148 1453241572 717641734
[12:05:01] Working on Protein
[12:05:02] Client config found, loading data.
[12:05:02] Starting GUI Server
[12:05:05] mdrun_gpu returned
[12:05:05] SHAKE violations on GPU
[12:05:05]
[12:05:05] Folding@home Core Shutdown: UNSTABLE_MACHINE
[12:05:08] CoreStatus = 7A (122)
[12:05:08] Sending work to server
[12:05:08] Project: 5747 (Run 1, Clone 15, Gen 1285)
[12:05:08] - Read packet limit of 540015616... Set to 524286976.
[12:05:08] - Error: Could not get length of results file work/wuresults_00.dat
[12:05:08] - Error: Could not read unit 00 file. Removing from queue.
[12:05:08] Trying to send all finished work units
[12:05:08] + No unsent completed units remaining.
[12:05:08] - Preparing to get new work unit...
[12:05:08] + Attempting to get work packet
[12:05:08] - Will indicate memory of 1024 MB
[12:05:08] - Connecting to assignment server
[12:05:08] Connecting to http://assign-GPU.stanford.edu:8080/
[12:05:08] Posted data.
[12:05:08] Initial: 40AB; - Successful: assigned to (171.64.65.102).
[12:05:08] + News From Folding@Home: Welcome to Folding@Home
[12:05:08] Loaded queue successfully.
[12:05:08] Connecting to http://171.64.65.102:8080/
[12:05:09] Posted data.
[12:05:09] Initial: 0000; - Receiving payload (expected size: 69080)
[12:05:09] Conversation time very short, giving reduced weight in bandwidth avg
[12:05:09] - Downloaded at ~134 kB/s
[12:05:09] - Averaged speed for that direction ~85 kB/s
[12:05:09] + Received work.
[12:05:09] Trying to send all finished work units
[12:05:09] + No unsent completed units remaining.
[12:05:09] + Closed connections
[12:05:14]
[12:05:14] + Processing work unit
[12:05:14] Core required: FahCore_11.exe
[12:05:14] Core found.
[12:05:14] Working on queue slot 01 [June 26 12:05:14 UTC]
[12:05:14] + Working ...
[12:05:14] - Calling '.\FahCore_11.exe -dir work/ -suffix 01 -checkpoint 10 -verbose -lifeline 2592 -version 623'
[12:05:15]
[12:05:15] *------------------------------*
[12:05:15] Folding@Home GPU Core - Beta
[12:05:15] Version 1.24 (Mon Feb 9 11:00:12 PST 2009)
[12:05:15]
[12:05:15] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[12:05:15] Build host: amoeba
[12:05:15] Board Type: AMD
[12:05:15] Core      :
[12:05:15] Preparing to commence simulation
[12:05:15] - Looking at optimizations...
[12:05:15] - Created dyn
[12:05:15] - Files status OK
[12:05:15] - Expanded 68568 -> 357580 (decompressed 521.4 percent)
[12:05:15] Called DecompressByteArray: compressed_data_size=68568 data_size=357580, decompressed_data_size=357580 diff=0
[12:05:15] - Digital signature verified
[12:05:15]
[12:05:15] Project: 5747 (Run 1, Clone 15, Gen 1285)
[12:05:15]
[12:05:15] Assembly optimizations on if available.
[12:05:15] Entering M.D.
[12:05:21] Tpr hash work/wudata_01.tpr:  1712642377 2730102086 3674622148 1453241572 717641734
[12:05:21] Working on Protein
[12:05:22] Client config found, loading data.
[12:05:22] Starting GUI Server
[12:05:24] mdrun_gpu returned
[12:05:24] SHAKE violations on GPU
[12:05:24]
[12:05:24] Folding@home Core Shutdown: UNSTABLE_MACHINE
[12:05:25] ***** Got a SIGTERM signal (2)
[12:05:25] Killing all core threads
Folding@Home Client Shutdown.
--- Opening Log file [June 26 12:06:53 UTC]
[12:06:53] - Ask before connecting: No
[12:06:53] - User name: Martin_i7-980x_HD5870 (Team 96377)
[12:06:53] - User ID: 6C6A12517E046D46
[12:06:53] - Machine ID: 3
[12:06:53]
[12:06:53] Configuring Folding@Home...
[12:07:21] - Ask before connecting: No
[12:07:21] - User name: Martin_i7-980x_HD5870 (Team 96377)
[12:07:21] - User ID: 6C6A12517E046D46
[12:07:21] - Machine ID: 4
[12:07:21]
[12:07:21] Work directory not found. Creating...
[12:07:21] Could not open work queue, generating new queue...
[12:07:21] - Preparing to get new work unit...
[12:07:21] - Autosending finished units... [June 26 12:07:21 UTC]
[12:07:21] + Attempting to get work packet
[12:07:21] Trying to send all finished work units
[12:07:21] - Will indicate memory of 1024 MB
[12:07:21] + No unsent completed units remaining.
[12:07:21] - Detect CPU.[12:07:21] - Autosend completed
[12:07:21] - Connecting to assignment server
[12:07:21] Connecting to http://assign-GPU.stanford.edu:8080/
[12:07:21] Posted data.
[12:07:21] Initial: 40AB; - Successful: assigned to (171.64.65.102).
[12:07:21] + News From Folding@Home: Welcome to Folding@Home
[12:07:21] Loaded queue successfully.
[12:07:21] Connecting to http://171.64.65.102:8080/
[12:07:22] Posted data.
[12:07:22] Initial: 0000; - Receiving payload (expected size: 99054)
[12:07:23] - Downloaded at ~96 kB/s
[12:07:23] - Averaged speed for that direction ~96 kB/s
[12:07:23] + Received work.
[12:07:23] + Closed connections
[12:07:23]
[12:07:23] + Processing work unit
[12:07:23] Core required: FahCore_11.exe
[12:07:23] Core found.
[12:07:23] Working on queue slot 01 [June 26 12:07:23 UTC]
[12:07:23] + Working ...
[12:07:23] - Calling '.\FahCore_11.exe -dir work/ -suffix 01 -checkpoint 10 -verbose -lifeline 4672 -version 623'
[12:07:23]
[12:07:23] *------------------------------*
[12:07:23] Folding@Home GPU Core - Beta
[12:07:23] Version 1.24 (Mon Feb 9 11:00:12 PST 2009)
[12:07:23]
[12:07:23] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[12:07:23] Build host: amoeba
[12:07:23] Board Type: AMD
[12:07:23] Core      :
[12:07:23] Preparing to commence simulation
[12:07:23] - Looking at optimizations...
[12:07:23] - Created dyn
[12:07:23] - Files status OK
[12:07:23] - Expanded 98542 -> 492188 (decompressed 499.4 percent)
[12:07:23] Called DecompressByteArray: compressed_data_size=98542 data_size=492188, decompressed_data_size=492188 diff=0
[12:07:23] - Digital signature verified
[12:07:23]
[12:07:23] Project: 5733 (Run 3, Clone 34, Gen 887)
[12:07:23]
[12:07:23] Assembly optimizations on if available.
[12:07:23] Entering M.D.
[12:07:29] Tpr hash work/wudata_01.tpr:  591933565 3093903435 2523330360 2032437391 2496865669
[12:07:29] Working on Protein
[12:07:30] Client config found, loading data.
[12:07:30] Starting GUI Server
[12:09:09] Completed 1%
Re: Project: 5747 (Run 1, Clone 15, Gen 1285)
I've reported this as a bad WU.
