Project: 1797 (Run 7, Clone 94, Gen 6)
bretth603
Post by bretth603 »
I've received this Classic WU twice and it's crashed both times right at the end. I get the little Windows XP SP3 popup that says core A0 has encountered a problem. I don't know if it's my PC or a problem with the WU.
Start
[14:13:10] + Processing work unit
[14:13:10] Core required: FahCore_a0.exe
[14:13:10] Core found.
[14:13:10] Working on queue slot 03 [June 21 14:13:10 UTC]
[14:13:10] + Working ...
[14:13:10]
[14:13:10] *------------------------------*
[14:13:10] Folding@Home Gromacs 3.3 Core
[14:13:10] Version 1.93 (July 23, 2008)
[14:13:10]
[14:13:10] Preparing to commence simulation
[14:13:10] - Looking at optimizations...
[14:13:10] - Created dyn
[14:13:10] - Files status OK
[14:13:11] - Expanded 1130572 -> 5930189 (decompressed 524.5 percent)
[14:13:11] - Starting from initial work packet
[14:13:11]
[14:13:11] Project: 1797 (Run 7, Clone 94, Gen 6)
[14:13:11]
[14:13:11] Assembly optimizations on if available.
[14:13:11] Entering M.D.
[14:13:17] Rejecting checkpoint
[14:13:18] Protein: 41361
[14:13:18] Writing local files
[14:13:20] Extra SSE boost OK.
[14:13:21] Writing local files
[14:13:21] Completed 0 out of 500000 steps  (0 percent)
[14:49:05] Writing local files
[14:49:05] Completed 5000 out of 500000 steps  (1 percent)
[15:26:02] Writing local files
End
[00:35:20] Completed 490000 out of 500000 steps  (98 percent)
[01:10:48] Writing local files
[01:10:48] Completed 495000 out of 500000 steps  (99 percent)
[01:46:15] Writing local files
[01:46:15] Completed 500000 out of 500000 steps  (100 percent)
[01:46:15] Writing final coordinates.
[01:51:15] + Working...
[04:46:15] 3 hours since checkpoint written...
[04:46:15]
[04:46:15] Folding@home Core Shutdown: EARLY_UNIT_END
[04:46:18] CoreStatus = 72 (114)
[04:46:18] Sending work to server
[04:46:18] Project: 1797 (Run 7, Clone 94, Gen 6)
[04:46:18] - Read packet limit of 540015616... Set to 524286976.
[04:46:18] - Error: Could not get length of results file work/wuresults_03.dat
[04:46:18] - Error: Could not read unit 03 file. Removing from queue.
[04:46:18] - Preparing to get new work unit...
[04:46:18] + Attempting to get work packet
[04:46:18] - Connecting to assignment server
[04:46:18] - Successful: assigned to (171.64.65.62).
[04:46:18] + News From Folding@Home: Welcome to Folding@Home
[04:46:18] Loaded queue successfully.
[04:46:22] + Closed connections
[04:46:27]
Edit: I'm running a 2GHz Core Duo w/ 3.2G RAM. If someone else has completed this WU it might help to debug.
Re: Project: 1797 (Run 7, Clone 94, Gen 6)
I've reported this as a bad WU even though it looks like a problem with Core_a0
bretth603
Post by bretth603 »
Now that you mention it, you're right: it probably is a core_a0 problem or problem with core_a0 on my machine. The other WUs I've run recently were on other cores.
Thanks for the tip. Now, how to debug it.....I'll pay attention to that core from now on.
