Project: 5784 (Run 5, Clone 97, Gen 189)
Not really sure if it is my fault as I was installing the available windows update and by the time I came back, I noticed an EUE @ 7%. The Client had already started to process another WU [Project: 5783 (Run 8, Clone 85, Gen 152)] and had reached 58%. First EUE with the GPU Client. Here is the Log:
[18:16:19] + Attempting to get work packet
[18:16:19] - Will indicate memory of 4091 MB
[18:16:19] - Connecting to assignment server
[18:16:19] Connecting to http://assign-GPU.stanford.edu:8080/
[18:16:21] Posted data.
[18:16:21] Initial: 43AB; - Successful: assigned to (171.67.108.21).
[18:16:21] + News From Folding@Home: Welcome to Folding@Home
[18:16:21] Loaded queue successfully.
[18:16:21] Connecting to http://171.67.108.21:8080/
[18:16:22] Posted data.
[18:16:22] Initial: 0000; - Receiving payload (expected size: 65172)
[18:16:23] - Downloaded at ~63 kB/s
[18:16:23] - Averaged speed for that direction ~32 kB/s
[18:16:23] + Received work.
[18:16:23] Trying to send all finished work units
[18:16:23] + No unsent completed units remaining.
[18:16:23] + Closed connections
[18:16:23]
[18:16:23] + Processing work unit
[18:16:23] Core required: FahCore_11.exe
[18:16:23] Core found.
[18:16:23] Working on queue slot 02 [June 22 18:16:23 UTC]
[18:16:23] + Working ...
[18:16:23] - Calling '.\FahCore_11.exe -dir work/ -suffix 02 -priority 96 -nocpulock -checkpoint 15 -verbose -lifeline 3604 -version 623'
[18:16:24]
[18:16:24] *------------------------------*
[18:16:24] Folding@Home GPU Core
[18:16:24] Version 1.31 (Tue Sep 15 10:57:42 PDT 2009)
[18:16:24]
[18:16:24] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[18:16:24] Build host: amoeba
[18:16:24] Board Type: Nvidia
[18:16:24] Core      :
[18:16:24] Preparing to commence simulation
[18:16:24] - Looking at optimizations...
[18:16:24] DeleteFrameFiles: successfully deleted file=work/wudata_02.ckp
[18:16:24] - Created dyn
[18:16:24] - Files status OK
[18:16:24] - Expanded 64660 -> 341507 (decompressed 528.1 percent)
[18:16:24] Called DecompressByteArray: compressed_data_size=64660 data_size=341507, decompressed_data_size=341507 diff=0
[18:16:24] - Digital signature verified
[18:16:24]
[18:16:24] Project: 5784 (Run 5, Clone 97, Gen 189)
[18:16:24]
[18:16:24] Assembly optimizations on if available.
[18:16:24] Entering M.D.
[18:16:24] Tpr hash work/wudata_02.tpr:  3540156433 3572595282 1356233194 2447601219 2495561595
[18:16:24]
[18:16:24] Calling fah_main args: 14 usage=100
[18:16:24]
[18:16:24] Working on Gromacs Runs One Microsecond At Cannonball Speeds
[18:16:24] Client config found, loading data.
[18:16:24] Starting GUI Server
[18:16:24] Completed 1%
[18:16:24] Completed 2%
[18:16:24] Completed 3%
[18:16:24] Completed 4%
[18:16:24] Completed 5%
[18:16:24] Completed 6%
[18:16:24] Completed 7%
[18:16:40]    3572595282
[18:16:40]    2   1356233194   1356233194
[18:16:40]    3   2447601219   2447601219
[18:16:40]    4   2495561595   2495561595
[18:16:40] fcCheckPointResume: file hashes same.
[18:16:40] fcCheckPointResume: state restored.
[18:16:40] Run: exception thrown during GuardedRun
[18:16:40] Run: exception thrown in GuardedRun -- Gromacs cannot continue further.
[18:16:40] Going to send back what have done -- stepsTotalG=20000000
[18:16:40] Work fraction=0.0000 steps=20000000.
[18:16:44] logfile size=12069 infoLength=12069 edr=0 trr=23
[18:16:44] + Opened results file
[18:16:44] - Writing 12605 bytes of core data to disk...
[18:16:44] Done: 12093 -> 4199 (compressed to 34.7 percent)
[18:16:44]   ... Done.
[18:16:44] DeleteFrameFiles: file=work/wudata_02.ckp not deleted! error code=-1
[18:16:44]
[18:16:44] Folding@home Core Shutdown: EARLY_UNIT_END
[18:16:48] CoreStatus = 72 (114)
[18:16:48] Sending work to server
[18:16:48] Project: 5784 (Run 5, Clone 97, Gen 189)
[18:16:48] - Read packet limit of 540015616... Set to 524286976.
[18:16:48] + Attempting to send results [June 22 18:16:48 UTC]
[18:16:48] - Reading file work/wuresults_02.dat from core
[18:16:48]   (Read 4711 bytes from disk)
[18:16:48] Connecting to http://171.67.108.21:8080/
[18:16:49] Posted data.
[18:16:49] Initial: 0000; - Uploaded at ~5 kB/s
[18:16:49] - Averaged speed for that direction ~8 kB/s
[18:16:49] + Results successfully sent
[18:16:49] Thank you for your contribution to Folding@Home.
[18:16:53] Trying to send all finished work units
[18:16:53] + No unsent completed units remaining.
Re: Project: 5784 (Run 5, Clone 97, Gen 189)
Someone else has been able to complete this WU ...
