171.67.108.20
Nobleatreides
171.67.108.20 Could not connect to Work Server
Post by Nobleatreides »
[23:56:22] + Attempting to get work packet
[23:56:22] - Connecting to assignment server
[23:56:23] - Successful: assigned to (171.67.108.20).
[23:56:23] + News From Folding@Home: Welcome to Folding@Home
[23:56:23] Loaded queue successfully.
[23:56:23] - Couldn't send HTTP request to server
[23:56:23] + Could not connect to Work Server
[23:56:23] - Attempt #8 to get work failed, and no other work to do.
Waiting before retry.
I just installed FAH v6.23, am i missing somethiong? do i need to port forward anything to get this to work?
Re: 171.67.108.20 Could not connect to Work Server
Welcome to the foldingforum.org community forum, Nobleatreides.
You should not need port forwarding, but you do need to make sure that you don't have a firewall that's blocking the FAH program from connecting to the internet.
I am able to open both http://171.67.108.20:8080/ and http://171.67.108.20/ in my browser and the server status page indicates that this server is functioning normally. The folding client acts like an alternative browser but many firewalls block it until you grant it an exception.
Pette Broad
Hardware configuration: CPU folding on only one machine a laptop
GPU Hardware..
3 x 460
1 X 260
4 X 250
+ 1 X 9800GT (3 days a week)
Post by Pette Broad »
Looking at the server itself it seems to be stuck at 10,000 available units, seen this before and its a sign that somethings wrong.
Tue Aug 4 08:00:11 PDT 2009 171.67.108.20 classic vsp11v gbowman accept Accepting 0.29 0 0 999 26812 8572 0 0 10000 10000 10000 - - - - 397 0 - - 1 - 171.67.108.26 0 1 - - - - - - - ; - - - - - - 0 gbowman 1 vsp11v
Tue Aug 4 08:15:10 PDT 2009 171.67.108.20 classic vsp11v gbowman accept Accepting 0.22 0 0 999 26812 8572 1 0 10000 10000 10000 - - - - 422 0 - - 1 - 171.67.108.26 0 1 - - - - - - - ; - - - - - - 0 gbowman 1 vsp11v
Tue Aug 4 08:30:10 PDT 2009 171.67.108.20 classic vsp11v gbowman accept Accepting 0.20 0 0 999 26812 8572 0 0 10000 10000 10000 - - - - 474 0 - - 1 - 171.67.108.26 0 1 - - - - - - - ; - - - - - - 0 gbowman 1 vsp11v
Tue Aug 4 08:45:10 PDT 2009 171.67.108.20 classic vsp11v gbowman accept Accepting 0.25 0 0 999 26812 8572 0 0 10000 10000 10000 - - - - 519 0 - - 1 - 171.67.108.26 0 1 - - - - - - - ; - - - - - - 0 gbowman 1 vsp11v
Has been like this from the top of the server status log!!
Pete
scruzerdude
Post by scruzerdude »
I just downloaded the console client (zip file) and am seeing "Couldn't send HTTP request to server". I can visit the IP address in Firefox and see a page with "OK". But the client repeatedly fails to connect.
Perhaps the server needs a reboot :roll:
I agree that the 10000 numbers look suspicious, but look at WUs RCV which clearly indicates that results are being uploaded to it. (The numbers appear to reset when the Stats are updated.)
I only see three projects that are being assigned by that server: 3770, and 4436-4437 and all three of those projects show a missing atom count on psummary so something isn't configured correctly but I'm not convinced we have enough information to figure out what's wrong or how serious it is.
codysluder
Post by codysluder »
That server has gone from STATUS=full to STATUS=accept so the problem has probably been fixed. In that status, we'll still be able to upload completed WUs but the assignment server won't be sending us there for new work. It still says there are 10000 WUs available, but as you said, that number is suspicious.
Rum@NoV
Hardware configuration: Orion (SMP):
CPU: Intel Core i7-2600
Memory: 8192 MBytes PC12800 DDR3 SDRAM
Graphics: Sapphire RADEON HD 5850, 1024 MB GDDR5 SDRAM
OS: Microsoft Windows 7 Home Premium (x64) Build 7601
Deepcore_II (SMP):
CPU: Intel Core 2 Quad Q9650
Memory: 4096 MBytes PC6400 DDR2-SDRAM
OS: Ubuntu Server 10.04
Nostromo (SMP+GPU):
CPU: Intel Core 2 Duo E8500
Graphics: EVGA e-GeForce 8800 GT, 512 MB GDDR3 SDRAM
Post by Rum@NoV »
I have some trouble with 2 clients:
[17:54:53] + Attempting to get work packet
[17:54:53] - Will indicate memory of 2047 MB
[17:54:53] - Connecting to assignment server
[17:54:53] Connecting to http://assign.stanford.edu:8080/
[17:54:54] Posted data.
[17:54:54] Initial: 43AB; - Successful: assigned to (171.67.108.20).
[17:54:54] + News From Folding@Home: Welcome to Folding@Home
[17:54:54] Loaded queue successfully.
[17:54:54] Connecting to http://171.67.108.20:8080/
[17:55:00] - Couldn't send HTTP request to server
[17:55:00] + Could not connect to Work Server
[17:55:00] - Attempt #7 to get work failed, and no other work to do.
No luck for the past 8 hours. Can somebody please check this server?
Pette Broad
GPU Hardware..
3 x 460
1 X 260
4 X 250
Your'e right, getting work is a matter of luck right now for classic units and I'm sure that's not good for the project!! There just isn't enough work to go around and its been like this for days. I've got machines on their 15th/16th attempt to get work, doesn't matter what flags I use the work is only being picked up randomly :(
Pete
v00d00
Hardware configuration: FX8320e (6 cores enabled) @ stock,
- 16GB DDR3,
- Zotac GTX 1050Ti @ Stock.
- Gigabyte GTX 970 @ Stock
Debian 9.
Ran Seti@Home prior to that.
Post by v00d00 »
This explains why im having major problems getting work at the minute.
Can someone PM Kasson or one of the other PG regulars and ask them to generate a couple thousand new workunits for us? Unless of course they've run out of science stuff for us to do (which as far as im aware is not the case ;) ).
For the linux users stuck in this loop, you can try (like i have) to scrounge windows units by running fah over wine, which has gotten me a couple of workunits.
tonic
Post by tonic »
10 clients on 3 different machines all getting this error now. We need some new WUs!
tonic
Post by tonic »
Still stuck. Can I force my clients to use a different server? Not sure why they are all using the .20 server that's obviously not working
FaaR
Post by FaaR »
Almost all my single-core CPU clients are now out of work (6/8, and 2 more will be done in 1-3 hours), and none of them can get new work.
At least one client has been out of work for over a full day now.
Please fix. My PCs are getting restless! :D
whynot
Post by whynot »
There's something I can't get:
{8766:27} [0:0]% time telnet 171.67.108.20 8080
Trying 171.67.108.20...
Connected to 171.67.108.20.
Escape character is '^]'.
telnet> quit
Connection closed.
telnet 171.67.108.20 8080  0.00s user 0.00s system 0% cpu 32.451 total
That beast supposed to say something (within 30sec), isn't it? According to serverstat page vsp11v is in accept; then nobody should be sent there, shouldn't her/him? I've tried all WSes from my logs -- some of them are smoking strange stuff too (should I look for server specific thread for each of them?).
PG? Admins? Mods? Anyone?
I'm counting for science.
Points just make me sick.
chrisretusn
Hardware configuration: AMD Athlon(tm) 64 X2 Dual Core Processor 4000+
AMD Athlon(tm) XP 2600+
Post by chrisretusn »
All of my clients have finally received new assignments. :)
Folding on Slackware Linux.
tjclifford
Post by tjclifford »
I'm getting this message too; but generally on my Linux box (Redhat fc6 - I'd be running a more updated version, but when
I tried to run Folding 5.04 on a higher version, it would not run, so I back-revved.
This is the most recent log entries (21:18 EST, 2009-10-25):
--- Opening Log file [October 26 01:07:22]
# Linux Console Edition #######################################################
Folding@Home Client Version 5.04beta
http://folding.stanford.edu
Launch directory: /home/tom/foldingathome
Executable: ./FAH504-Linux.exe
[01:07:22] - Ask before connecting: No
[01:07:22] - User name: tjclifford2 (Team 78002)
[01:07:22] - User ID: 1701BE9F58A44E17
[01:07:22] - Machine ID: 1
[01:07:22]
[01:07:23] Loaded queue successfully.
[01:07:23] + Benchmarking ...
[01:07:27] - Preparing to get new work unit...
[01:07:27] + Attempting to get work packet
[01:07:27] - Connecting to assignment server
[01:10:37] - Couldn't send HTTP request to server
[01:10:37] + Could not connect to Assignment Server
[01:10:37] - Successful: assigned to (171.67.108.13).
[01:10:37] + News From Folding@Home: Welcome to Folding@Home
[01:10:37] Loaded queue successfully.
[01:10:38] + Could not connect to Work Server
[01:10:38] - Error: Attempt #1 to get work failed, and no other work to do.
[01:10:52] + Attempting to get work packet
[01:10:52] - Connecting to assignment server
[01:14:01] - Couldn't send HTTP request to server
[01:14:01] + Could not connect to Assignment Server
[01:14:01] - Successful: assigned to (171.67.108.13).
[01:14:01] + News From Folding@Home: Welcome to Folding@Home
[01:14:02] Loaded queue successfully.
[01:14:02] + Could not connect to Work Server
[01:14:02] - Error: Attempt #2 to get work failed, and no other work to do.
[01:14:20] + Attempting to get work packet
[01:14:20] - Connecting to assignment server
[01:17:29] - Couldn't send HTTP request to server
[01:17:29] + Could not connect to Assignment Server
[01:17:30] - Successful: assigned to (171.67.108.13).
[01:17:30] + News From Folding@Home: Welcome to Folding@Home
[01:17:30] Loaded queue successfully.
[01:17:30] + Could not connect to Work Server
[01:17:30] - Error: Attempt #3 to get work failed, and no other work to do.
[01:17:52] + Attempting to get work packet
[01:17:52] - Connecting to assignment server
