Project: 10040 (Run 924, Clone 0, Gen 6)
wan.ardiles
Post by wan.ardiles »
[00:49:54] - Machine ID: 1
[00:49:54]
[00:49:54] Loaded queue successfully.
[00:49:54] Initialization complete
[00:49:54]
[00:49:54] + Processing work unit
[00:49:54] Core required: FahCore_b4.exe
[00:49:54] Core found.
[00:49:54] Working on queue slot 07 [June 9 00:49:54 UTC]
[00:49:54] + Working ...
[00:50:01] *********************** Log Started 09/Jun/2010 00:50:01 ***********************
[00:50:01] ************************** ProtoMol Folding@Home Core **************************
[00:50:01]   Version: 25
[00:50:01]      Type: 180
[00:50:01]      Core: ProtoMol
[00:50:01]   Website: http://folding.stanford.edu/
[00:50:01] Copyright: (c) 2009 Stanford University
[00:50:01]    Author: Joseph Coffland <joseph@cauldrondevelopment.com>
[00:50:01]      Args: -dir work/ -suffix 07 -priority 96 -nocpulock -checkpoint 30
[00:50:01]            -lifeline 2656 -version 623
[00:50:01] ************************************ Build *************************************
[00:50:01]      Date: May 18 2010
[00:50:01]      Time: 23:43:52
[00:50:01]  Revision: 1819
[00:50:01]  Compiler: Intel(R) C++ MSVC 1500 mode 1110
[00:50:01]   Options: /TP /nologo /EHsc /wd4297 /wd4103 /wd1786 /arch:IA32 /Ox
[00:50:01]            /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qrestrict /MT
[00:50:01]   Defines: _CRT_SECURE_NO_WARNINGS NDEBUG HAVE_GEEKINFO BOOST_ALL_NO_LIB
[00:50:01]            XML_STATIC HAVE_EXPAT HAVE_OPENSSL HAVE_LIBFAH HAVE_SIMTK_LAPACK
[00:50:01]  Platform: Windows XP
[00:50:01]      Bits: 32
[00:50:01]      Mode: Release
[00:50:01] ************************************ System ************************************
[00:50:01]        OS: Microsoft Windows XP Professional
[00:50:01]       CPU: Intel(R) Pentium(R) 4 CPU 3.00GHz
[00:50:01]    CPU ID: GenuineIntel Family 15 Model 4 Stepping 1
[00:50:01]      CPUs: 2 Logical, 1 Physical
[00:50:01]    Memory: 1023 MB
[00:50:01]   Threads: Windows
[00:50:01] ********************************************************************************
[00:50:01] Project: 10040 (Run 924, Clone 0, Gen 6)
[00:50:01] Unit: 0x000000090001329c4be590b20000039f
[00:50:01] User: 0x00000000000000000000000000000000
[00:50:01] Machine: 1
[00:50:01] Digital signatures verified
[00:50:09] Completed 975300 out of 2000000 steps (48%)
[00:54:36] Completed 980000 out of 2000000 steps (49%)
[01:14:41] Completed 1000000 out of 2000000 steps (50%)
[01:14:58] ERROR: ProtoMol ERROR: Corrupt DCD file. Size is 255804, should be >= 262356.
[01:14:58] Saving result file logfile_07.txt
[01:14:58] Saving result file checkpt
[01:14:58] Saving result file checkpt.crc
[01:14:58] Saving result file log.txt
[01:14:58] Saving result file protomol.conf
[01:14:58] Saving result file ww.dcd
[01:14:58] Saving result file ww_exteq_nowater1.540.pos
[01:14:58] Saving result file ww_exteq_nowater1.540.vel
[01:14:58] WARNING: While cleaning up: 0: Failed to remove directory '07': boost::filesystem::remove: The process cannot access the file because it is being used by another process: "07\ww.dcd"
[01:14:58] Folding@home Core Shutdown: BAD_WORK_UNIT
[01:15:01] CoreStatus = 72 (114)
[01:15:01] Sending work to server
[01:15:01] Project: 10040 (Run 924, Clone 0, Gen 6)
[01:15:01] + Attempting to send results [June 9 01:15:01 UTC]
[01:15:18] + Results successfully sent
[01:15:18] Thank you for your contribution to Folding@Home.
[01:15:24] - Preparing to get new work unit...
[01:15:24] + Attempting to get work packet
[01:15:24] - Connecting to assignment server
[01:15:26] - Successful: assigned to (129.74.85.15).
[01:15:26] + News From Folding@Home: Welcome to Folding@Home
[01:15:26] Loaded queue successfully.
[01:15:31] + Closed connections
After the bad WU, the machine is running Project: 10030 (Run 6, Clone 0, Gen 16). Hope it will working fine :)
Re: Project: 10040 (Run 924, Clone 0, Gen 6)
I had a Mod mark it as bad.
Someone else has been able to complete it successfully ...
Then why is that WU still getting sent out?
That's the 1 million $ question :mrgreen:
wan.ardiles
May I know if I get any points, even with partial completion?
codysluder
Post by codysluder »
That error shows you had a corrupt checkpoint. Was there anything unusual about the previous run where you completed the first part of the WU? (That information may be in FAHlog-Prev.txt).
wan.ardiles
--- Opening Log file [June 5 00:32:57 UTC]
# Windows CPU Systray Edition #################################################
Launch directory: C:\Documents and Settings\root\Application Data\Folding@home-x86
[00:32:57] - Ask before connecting: No
[00:32:57] - User name: wan.ardiles@gmail.com (Team 2999)
[00:32:57] - User ID: 51CA9AE53E28XXXX
[00:32:57] - Machine ID: 1
[00:32:57]
[00:32:57] Loaded queue successfully.
[00:32:57] Initialization complete
[00:32:57]
[00:32:57] + Processing work unit
[00:32:57] Core required: FahCore_b4.exe
[00:32:57] Core found.
[00:32:57] Working on queue slot 06 [June 5 00:32:57 UTC]
[00:32:57] + Working ...
[00:33:02] *********************** Log Started 05/Jun/2010 00:33:01 ***********************
[00:33:02] ************************** ProtoMol Folding@Home Core **************************
[00:33:02]   Version: 25
[00:33:02]      Type: 180
[00:33:02]      Core: ProtoMol
[00:33:02]   Website: http://folding.stanford.edu/
[00:33:02] Copyright: (c) 2009 Stanford University
[00:33:02]    Author: Joseph Coffland <joseph@cauldrondevelopment.com>
[00:33:02]      Args: -dir work/ -suffix 06 -priority 96 -nocpulock -checkpoint 30
[00:33:02]            -lifeline 3168 -version 623
[00:33:02] ************************************ Build *************************************
[00:33:02]      Date: May 18 2010
[00:33:02]      Time: 23:43:52
[00:33:02]  Revision: 1819
[00:33:02]  Compiler: Intel(R) C++ MSVC 1500 mode 1110
[00:33:02]   Options: /TP /nologo /EHsc /wd4297 /wd4103 /wd1786 /arch:IA32 /Ox
[00:33:02]            /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qrestrict /MT
[00:33:02]   Defines: _CRT_SECURE_NO_WARNINGS NDEBUG HAVE_GEEKINFO BOOST_ALL_NO_LIB
[00:33:02]            XML_STATIC HAVE_EXPAT HAVE_OPENSSL HAVE_LIBFAH HAVE_SIMTK_LAPACK
[00:33:02]  Platform: Windows XP
[00:33:02]      Bits: 32
[00:33:02]      Mode: Release
[00:33:02] ************************************ System ************************************
[00:33:02]        OS: Microsoft Windows XP Professional
[00:33:02]       CPU: Intel(R) Pentium(R) 4 CPU 3.00GHz
[00:33:02]    CPU ID: GenuineIntel Family 15 Model 4 Stepping 1
[00:33:02]      CPUs: 2 Logical, 1 Physical
[00:33:02]    Memory: 1023 MB
[00:33:02]   Threads: Windows
[00:33:02] ********************************************************************************
[00:33:02] Project: 10033 (Run 531, Clone 0, Gen 2)
[00:33:02] Unit: 0x000000040001329c4bd49dfa00013ca6
[00:33:02] User: 0x00000000000000000000000000000000
[00:33:02] Machine: 1
[00:33:02] Digital signatures verified
[00:33:06] Completed 152000 out of 499375 steps (30%)
[00:40:37] Completed 154800 out of 499375 steps (30%)
[00:52:09] Completed 159800 out of 499375 steps (32%)
[01:03:36] Completed 164800 out of 499375 steps (33%)
[01:14:46] Completed 169800 out of 499375 steps (34%)
[01:26:28] Completed 174800 out of 499375 steps (35%)
[01:38:04] Completed 179800 out of 499375 steps (36%)
[01:50:23] Completed 184800 out of 499375 steps (37%)
[02:03:01] Completed 189800 out of 499375 steps (38%)
[02:15:29] Completed 194800 out of 499375 steps (39%)
[02:28:30] Completed 199800 out of 499375 steps (40%)
[02:41:32] Completed 204800 out of 499375 steps (41%)
[02:53:46] Completed 209800 out of 499375 steps (42%)
[03:05:20] Completed 214700 out of 499375 steps (42%)
[03:19:16] Completed 219700 out of 499375 steps (43%)
[03:33:25] Completed 224700 out of 499375 steps (44%)
[03:48:26] Completed 229700 out of 499375 steps (45%)
[04:02:31] Completed 234700 out of 499375 steps (46%)
[04:16:46] Completed 239700 out of 499375 steps (48%)
[04:31:23] Completed 244700 out of 499375 steps (49%)
[04:46:11] Completed 249700 out of 499375 steps (50%)
[05:00:41] Completed 254700 out of 499375 steps (51%)
[05:16:21] Completed 259700 out of 499375 steps (52%)
Folding@Home Client Shutdown.
--- Opening Log file [June 5 05:50:17 UTC]
[05:50:17] - Ask before connecting: No
[05:50:17] - User name: wan.ardiles@gmail.com (Team 2999)
[05:50:17] - User ID: 51CA9AE53E28XXXX
[05:50:17] - Machine ID: 1
[05:50:17]
[05:50:17] Loaded queue successfully.
[05:50:17] Initialization complete
[05:50:17]
[05:50:17] + Processing work unit
[05:50:17] Core required: FahCore_b4.exe
[05:50:17] Core found.
[05:50:17] Working on queue slot 06 [June 5 05:50:17 UTC]
[05:50:17] + Working ...
[05:50:25] *********************** Log Started 05/Jun/2010 05:50:25 ***********************
[05:50:25] ************************** ProtoMol Folding@Home Core **************************
[05:50:25]   Version: 25
[05:50:25]      Type: 180
[05:50:25]      Core: ProtoMol
[05:50:25]   Website: http://folding.stanford.edu/
[05:50:25] Copyright: (c) 2009 Stanford University
[05:50:25]    Author: Joseph Coffland <joseph@cauldrondevelopment.com>
[05:50:25]      Args: -dir work/ -suffix 06 -priority 96 -nocpulock -checkpoint 30
[05:50:25]            -lifeline 1472 -version 623
[05:50:25] ************************************ Build *************************************
[05:50:25]      Date: May 18 2010
[05:50:25]      Time: 23:43:52
[05:50:25]  Revision: 1819
[05:50:25]  Compiler: Intel(R) C++ MSVC 1500 mode 1110
[05:50:25]   Options: /TP /nologo /EHsc /wd4297 /wd4103 /wd1786 /arch:IA32 /Ox
[05:50:25]            /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qrestrict /MT
[05:50:25]   Defines: _CRT_SECURE_NO_WARNINGS NDEBUG HAVE_GEEKINFO BOOST_ALL_NO_LIB
[05:50:25]            XML_STATIC HAVE_EXPAT HAVE_OPENSSL HAVE_LIBFAH HAVE_SIMTK_LAPACK
[05:50:25]  Platform: Windows XP
[05:50:25]      Bits: 32
[05:50:25]      Mode: Release
[05:50:25] ************************************ System ************************************
[05:50:25]        OS: Microsoft Windows XP Professional
[05:50:25]       CPU: Intel(R) Pentium(R) 4 CPU 3.00GHz
[05:50:25]    CPU ID: GenuineIntel Family 15 Model 4 Stepping 1
[05:50:25]      CPUs: 2 Logical, 1 Physical
[05:50:25]    Memory: 1023 MB
[05:50:25]   Threads: Windows
[05:50:25] ********************************************************************************
[05:50:25] Project: 10033 (Run 531, Clone 0, Gen 2)
[05:50:25] Unit: 0x000000040001329c4bd49dfa00013ca6
[05:50:25] User: 0x00000000000000000000000000000000
[05:50:25] Machine: 1
[05:50:25] Digital signatures verified
[05:50:35] Completed 255900 out of 499375 steps (51%)
[06:00:08] Completed 259700 out of 499375 steps (52%)
[06:12:28] Completed 264700 out of 499375 steps (53%)
[06:24:18] Completed 269700 out of 499375 steps (54%)
[06:36:13] Completed 274700 out of 499375 steps (55%)
[06:48:24] Completed 279700 out of 499375 steps (56%)
[07:00:39] Completed 284700 out of 499375 steps (57%)
[07:12:40] Completed 289600 out of 499375 steps (57%)
[07:25:27] Completed 294600 out of 499375 steps (58%)
[07:38:09] Completed 299600 out of 499375 steps (59%)
[07:49:45] Completed 304600 out of 499375 steps (60%)
[08:01:37] Completed 309600 out of 499375 steps (61%)
[08:13:50] Completed 314600 out of 499375 steps (62%)
[08:26:36] Completed 319600 out of 499375 steps (64%)
[08:39:32] Completed 324600 out of 499375 steps (65%)
[08:52:09] Completed 329600 out of 499375 steps (66%)
[09:05:17] Completed 334600 out of 499375 steps (67%)
[09:18:39] Completed 339600 out of 499375 steps (68%)
[09:31:41] Completed 344600 out of 499375 steps (69%)
[09:44:33] Completed 349600 out of 499375 steps (70%)
[09:57:22] Completed 354600 out of 499375 steps (71%)
[10:10:08] Completed 359500 out of 499375 steps (71%)
[10:22:57] Completed 364500 out of 499375 steps (72%)
[10:36:10] Completed 369500 out of 499375 steps (73%)
[10:48:56] Completed 374500 out of 499375 steps (74%)
[11:02:00] Completed 379500 out of 499375 steps (75%)
[11:14:50] Completed 384500 out of 499375 steps (76%)
[11:28:37] Completed 389500 out of 499375 steps (77%)
--- Opening Log file [June 6 07:48:23 UTC]
[07:48:23] - Ask before connecting: No
[07:48:23] - User name: wan.ardiles@gmail.com (Team 2999)
[07:48:23] - User ID: 51CA9AE53E28XXXX
[07:48:23] - Machine ID: 1
[07:48:23]
[07:48:23] Loaded queue successfully.
[07:48:23] Initialization complete
[07:48:23]
[07:48:23] + Processing work unit
[07:48:23] Core required: FahCore_b4.exe
[07:48:23] Core found.
[07:48:23] Working on queue slot 06 [June 6 07:48:23 UTC]
[07:48:23] + Working ...
[07:48:32] *********************** Log Started 06/Jun/2010 07:48:31 ***********************
[07:48:32] ************************** ProtoMol Folding@Home Core **************************
[07:48:32]   Version: 25
[07:48:32]      Type: 180
[07:48:32]      Core: ProtoMol
[07:48:32]   Website: http://folding.stanford.edu/
[07:48:32] Copyright: (c) 2009 Stanford University
[07:48:32]    Author: Joseph Coffland <joseph@cauldrondevelopment.com>
[07:48:32]      Args: -dir work/ -suffix 06 -priority 96 -nocpulock -checkpoint 30
[07:48:32]            -lifeline 3488 -version 623
[07:48:32] ************************************ Build *************************************
[07:48:32]      Date: May 18 2010
[07:48:32]      Time: 23:43:52
[07:48:32]  Revision: 1819
[07:48:32]  Compiler: Intel(R) C++ MSVC 1500 mode 1110
[07:48:32]   Options: /TP /nologo /EHsc /wd4297 /wd4103 /wd1786 /arch:IA32 /Ox
[07:48:32]            /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qrestrict /MT
[07:48:32]   Defines: _CRT_SECURE_NO_WARNINGS NDEBUG HAVE_GEEKINFO BOOST_ALL_NO_LIB
[07:48:32]            XML_STATIC HAVE_EXPAT HAVE_OPENSSL HAVE_LIBFAH HAVE_SIMTK_LAPACK
[07:48:32]  Platform: Windows XP
[07:48:32]      Bits: 32
[07:48:32]      Mode: Release
[07:48:32] ************************************ System ************************************
[07:48:32]        OS: Microsoft Windows XP Professional
[07:48:32]       CPU: Intel(R) Pentium(R) 4 CPU 3.00GHz
[07:48:32]    CPU ID: GenuineIntel Family 15 Model 4 Stepping 1
[07:48:32]      CPUs: 2 Logical, 1 Physical
[07:48:32]    Memory: 1023 MB
[07:48:32]   Threads: Windows
[07:48:32] ********************************************************************************
[07:48:32] Project: 10033 (Run 531, Clone 0, Gen 2)
[07:48:32] Unit: 0x000000040001329c4bd49dfa00013ca6
[07:48:32] User: 0x00000000000000000000000000000000
[07:48:32] Machine: 1
[07:48:32] Digital signatures verified
[07:48:41] Completed 387000 out of 499375 steps (77%)
[07:55:23] Completed 389500 out of 499375 steps (77%)
[08:09:01] Completed 394500 out of 499375 steps (78%)
[08:22:39] Completed 399500 out of 499375 steps (80%)
[08:36:26] Completed 404500 out of 499375 steps (81%)
[08:49:16] Completed 409500 out of 499375 steps (82%)
[09:02:20] Completed 414500 out of 499375 steps (83%)
[09:15:54] Completed 419500 out of 499375 steps (84%)
[09:30:52] Completed 424500 out of 499375 steps (85%)
[09:45:09] Completed 429400 out of 499375 steps (85%)
--- Opening Log file [June 7 00:46:29 UTC]
[00:46:29] - Ask before connecting: No
[00:46:29] - User name: wan.ardiles@gmail.com (Team 2999)
[00:46:29] - User ID: 51CA9AE53E28XXXX
[00:46:29] - Machine ID: 1
[00:46:29]
[00:46:29] Loaded queue successfully.
[00:46:29] Initialization complete
[00:46:29]
[00:46:29] + Processing work unit
[00:46:29] Core required: FahCore_b4.exe
[00:46:29] Core found.
[00:46:29] Working on queue slot 06 [June 7 00:46:29 UTC]
[00:46:29] + Working ...
[00:47:01] *********************** Log Started 07/Jun/2010 00:47:01 ***********************
[00:47:02] ************************** ProtoMol Folding@Home Core **************************
[00:47:02]   Version: 25
[00:47:02]      Type: 180
[00:47:02]      Core: ProtoMol
[00:47:02]   Website: http://folding.stanford.edu/
[00:47:02] Copyright: (c) 2009 Stanford University
[00:47:02]    Author: Joseph Coffland <joseph@cauldrondevelopment.com>
[00:47:02]      Args: -dir work/ -suffix 06 -priority 96 -nocpulock -checkpoint 30
[00:47:02]            -lifeline 1916 -version 623
[00:47:02] ************************************ Build *************************************
[00:47:02]      Date: May 18 2010
[00:47:02]      Time: 23:43:52
[00:47:02]  Revision: 1819
[00:47:02]  Compiler: Intel(R) C++ MSVC 1500 mode 1110
[00:47:02]   Options: /TP /nologo /EHsc /wd4297 /wd4103 /wd1786 /arch:IA32 /Ox
[00:47:02]            /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qrestrict /MT
[00:47:02]   Defines: _CRT_SECURE_NO_WARNINGS NDEBUG HAVE_GEEKINFO BOOST_ALL_NO_LIB
[00:47:02]            XML_STATIC HAVE_EXPAT HAVE_OPENSSL HAVE_LIBFAH HAVE_SIMTK_LAPACK
[00:47:02]  Platform: Windows XP
[00:47:02]      Bits: 32
[00:47:02]      Mode: Release
[00:47:02] ************************************ System ************************************
[00:47:02]        OS: Microsoft Windows XP Professional
[00:47:02]       CPU: Intel(R) Pentium(R) 4 CPU 3.00GHz
[00:47:02]    CPU ID: GenuineIntel Family 15 Model 4 Stepping 1
[00:47:02]      CPUs: 2 Logical, 1 Physical
[00:47:02]    Memory: 1023 MB
[00:47:02]   Threads: Windows
[00:47:02] ********************************************************************************
[00:47:02] Project: 10033 (Run 531, Clone 0, Gen 2)
[00:47:02] Unit: 0x000000040001329c4bd49dfa00013ca6
[00:47:02] User: 0x00000000000000000000000000000000
[00:47:02] Machine: 1
[00:47:02] Digital signatures verified
[00:47:23] Completed 420500 out of 499375 steps (84%)
[00:59:19] Completed 424500 out of 499375 steps (85%)
[01:13:03] Completed 429400 out of 499375 steps (85%)
[01:26:06] Completed 434400 out of 499375 steps (86%)
[01:39:42] Completed 439400 out of 499375 steps (87%)
[01:52:31] Completed 444400 out of 499375 steps (88%)
[02:05:39] Completed 449400 out of 499375 steps (89%)
[02:17:38] Completed 454400 out of 499375 steps (90%)
[02:32:58] Completed 459400 out of 499375 steps (91%)
[02:46:56] Completed 464400 out of 499375 steps (92%)
[03:01:35] Completed 469400 out of 499375 steps (93%)
[03:13:35] Completed 474400 out of 499375 steps (94%)
[03:26:52] Completed 479400 out of 499375 steps (96%)
[03:40:00] Completed 484400 out of 499375 steps (97%)
[03:54:50] Completed 489400 out of 499375 steps (98%)
[04:10:42] Completed 494400 out of 499375 steps (99%)
[04:25:37] Completed 499300 out of 499375 steps (99%)
[04:25:50] Saving result file logfile_06.txt
[04:25:50] Saving result file checkpt
[04:25:50] Saving result file checkpt.crc
[04:25:50] Saving result file log.txt
[04:26:01] Saving result file protomol.conf
[04:26:01] Saving result file ww.99.pos
[04:26:01] Saving result file ww.99.vel
[04:26:01] Saving result file ww.dcd
[04:26:05] Folding@home Core Shutdown: FINISHED_UNIT
[04:26:08] CoreStatus = 64 (100)
[04:26:08] Sending work to server
[04:26:08] Project: 10033 (Run 531, Clone 0, Gen 2)
[04:26:08] + Attempting to send results [June 7 04:26:08 UTC]
[04:32:26] + Results successfully sent
[04:32:26] Thank you for your contribution to Folding@Home.
[04:32:26] + Number of Units Completed: 33
[04:32:34] - Preparing to get new work unit...
[04:32:34] + Attempting to get work packet
[04:32:34] - Connecting to assignment server
[04:32:35] - Successful: assigned to (129.74.85.15).
[04:32:35] + News From Folding@Home: Welcome to Folding@Home
[04:32:35] Loaded queue successfully.
[04:32:39] + Closed connections
[04:32:39]
[04:32:39] + Processing work unit
[04:32:39] Core required: FahCore_b4.exe
[04:32:39] Core found.
[04:32:39] Working on queue slot 07 [June 7 04:32:39 UTC]
[04:32:39] + Working ...
[04:32:41] *********************** Log Started 07/Jun/2010 04:32:41 ***********************
[04:32:41] ************************** ProtoMol Folding@Home Core **************************
[04:32:41]   Version: 25
[04:32:41]      Type: 180
[04:32:41]      Core: ProtoMol
[04:32:41]   Website: http://folding.stanford.edu/
[04:32:41] Copyright: (c) 2009 Stanford University
[04:32:41]    Author: Joseph Coffland <joseph@cauldrondevelopment.com>
[04:32:41]      Args: -dir work/ -suffix 07 -priority 96 -nocpulock -checkpoint 30
[04:32:41]            -lifeline 1916 -version 623
[04:32:41] ************************************ Build *************************************
[04:32:41]      Date: May 18 2010
[04:32:41]      Time: 23:43:52
[04:32:41]  Revision: 1819
[04:32:41]  Compiler: Intel(R) C++ MSVC 1500 mode 1110
[04:32:41]   Options: /TP /nologo /EHsc /wd4297 /wd4103 /wd1786 /arch:IA32 /Ox
[04:32:41]            /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qrestrict /MT
[04:32:41]   Defines: _CRT_SECURE_NO_WARNINGS NDEBUG HAVE_GEEKINFO BOOST_ALL_NO_LIB
[04:32:41]            XML_STATIC HAVE_EXPAT HAVE_OPENSSL HAVE_LIBFAH HAVE_SIMTK_LAPACK
[04:32:41]  Platform: Windows XP
[04:32:41]      Bits: 32
[04:32:41]      Mode: Release
[04:32:41] ************************************ System ************************************
[04:32:41]        OS: Microsoft Windows XP Professional
[04:32:41]       CPU: Intel(R) Pentium(R) 4 CPU 3.00GHz
[04:32:41]    CPU ID: GenuineIntel Family 15 Model 4 Stepping 1
[04:32:41]      CPUs: 2 Logical, 1 Physical
[04:32:41]    Memory: 1023 MB
[04:32:41]   Threads: Windows
[04:32:41] ********************************************************************************
[04:32:41] Project: 10040 (Run 924, Clone 0, Gen 6)
[04:32:41] Unit: 0x000000090001329c4be590b20000039f
[04:32:41] User: 0x00000000000000000000000000000000
[04:32:41] Machine: 1
[04:32:41] Reading tar file par_all27_prot_lipid.inp
[04:32:41] Reading tar file scpismQuartic.inp
[04:32:41] Reading tar file ww_exteq_nowater1.pdb
[04:32:41] Reading tar file ww_exteq_nowater1.psf
[04:32:41] Reading tar file checkpt
[04:32:41] Reading tar file ww_exteq_nowater1.506.pos
[04:32:42] Reading tar file ww_exteq_nowater1.506.vel
[04:32:42] Reading tar file protomol.conf
[04:32:42] Reading tar file core.xml
[04:32:42] Digital signatures verified
[04:32:42] Completed 0 out of 2000000 steps (0%)
[04:55:44] Completed 20000 out of 2000000 steps (1%)
[05:18:58] Completed 40000 out of 2000000 steps (2%)
[05:42:07] Completed 60000 out of 2000000 steps (3%)
[06:02:35] Completed 80000 out of 2000000 steps (4%)
[06:22:53] Completed 100000 out of 2000000 steps (5%)
[06:43:10] Completed 120000 out of 2000000 steps (6%)
[06:46:29] + Working...
[07:04:10] Completed 140000 out of 2000000 steps (7%)
[07:24:52] Completed 160000 out of 2000000 steps (8%)
[07:47:35] Completed 180000 out of 2000000 steps (9%)
[08:09:42] Completed 200000 out of 2000000 steps (10%)
[08:30:48] Completed 220000 out of 2000000 steps (11%)
[08:52:28] Completed 240000 out of 2000000 steps (12%)
[09:15:20] Completed 260000 out of 2000000 steps (13%)
[09:38:09] Completed 280000 out of 2000000 steps (14%)
[10:00:00] Completed 300000 out of 2000000 steps (15%)
[10:20:12] Completed 320000 out of 2000000 steps (16%)
[10:41:22] Completed 340000 out of 2000000 steps (17%)
[11:02:09] Completed 360000 out of 2000000 steps (18%)
[11:22:59] Completed 380000 out of 2000000 steps (19%)
[11:43:36] Completed 400000 out of 2000000 steps (20%)
[12:05:27] Completed 420000 out of 2000000 steps (21%)
--- Opening Log file [June 8 00:46:04 UTC]
[00:46:04] - Ask before connecting: No
[00:46:04] - User name: wan.ardiles@gmail.com (Team 2999)
[00:46:04] - User ID: 51CA9AE53E28XXXX
[00:46:04] - Machine ID: 1
[00:46:04]
[00:46:04] Loaded queue successfully.
[00:46:04] Initialization complete
[00:46:04]
[00:46:04] + Processing work unit
[00:46:04] Core required: FahCore_b4.exe
[00:46:04] Core found.
[00:46:04] Working on queue slot 07 [June 8 00:46:04 UTC]
[00:46:04] + Working ...
[00:46:08] *********************** Log Started 08/Jun/2010 00:46:08 ***********************
[00:46:08] ************************** ProtoMol Folding@Home Core **************************
[00:46:08]   Version: 25
[00:46:08]      Type: 180
[00:46:08]      Core: ProtoMol
[00:46:08]   Website: http://folding.stanford.edu/
[00:46:08] Copyright: (c) 2009 Stanford University
[00:46:08]    Author: Joseph Coffland <joseph@cauldrondevelopment.com>
[00:46:08]      Args: -dir work/ -suffix 07 -priority 96 -nocpulock -checkpoint 30
[00:46:08]            -lifeline 3100 -version 623
[00:46:08] ************************************ Build *************************************
[00:46:08]      Date: May 18 2010
[00:46:08]      Time: 23:43:52
[00:46:08]  Revision: 1819
[00:46:08]  Compiler: Intel(R) C++ MSVC 1500 mode 1110
[00:46:08]   Options: /TP /nologo /EHsc /wd4297 /wd4103 /wd1786 /arch:IA32 /Ox
[00:46:08]            /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qrestrict /MT
[00:46:08]   Defines: _CRT_SECURE_NO_WARNINGS NDEBUG HAVE_GEEKINFO BOOST_ALL_NO_LIB
[00:46:08]            XML_STATIC HAVE_EXPAT HAVE_OPENSSL HAVE_LIBFAH HAVE_SIMTK_LAPACK
[00:46:08]  Platform: Windows XP
[00:46:08]      Bits: 32
[00:46:08]      Mode: Release
[00:46:08] ************************************ System ************************************
[00:46:08]        OS: Microsoft Windows XP Professional
[00:46:08]       CPU: Intel(R) Pentium(R) 4 CPU 3.00GHz
[00:46:08]    CPU ID: GenuineIntel Family 15 Model 4 Stepping 1
[00:46:08]      CPUs: 2 Logical, 1 Physical
[00:46:08]    Memory: 1023 MB
[00:46:08]   Threads: Windows
[00:46:08] ********************************************************************************
[00:46:08] Project: 10040 (Run 924, Clone 0, Gen 6)
[00:46:08] Unit: 0x000000090001329c4be590b20000039f
[00:46:08] User: 0x00000000000000000000000000000000
[00:46:08] Machine: 1
[00:46:08] Digital signatures verified
[00:46:09] Completed 418100 out of 2000000 steps (20%)
[00:47:55] Completed 420000 out of 2000000 steps (21%)
[01:07:39] Completed 440000 out of 2000000 steps (22%)
[01:30:32] Completed 460000 out of 2000000 steps (23%)
[01:52:13] Completed 480000 out of 2000000 steps (24%)
[02:14:58] Completed 500000 out of 2000000 steps (25%)
[02:34:29] Completed 520000 out of 2000000 steps (26%)
[02:54:09] Completed 540000 out of 2000000 steps (27%)
[03:14:22] Completed 560000 out of 2000000 steps (28%)
[03:35:11] Completed 580000 out of 2000000 steps (29%)
[03:56:01] Completed 600000 out of 2000000 steps (30%)
[04:17:08] Completed 620000 out of 2000000 steps (31%)
[04:35:48] Completed 640000 out of 2000000 steps (32%)
[04:54:37] Completed 660000 out of 2000000 steps (33%)
[05:13:26] Completed 680000 out of 2000000 steps (34%)
[05:32:58] Completed 700000 out of 2000000 steps (35%)
[05:52:01] Completed 720000 out of 2000000 steps (36%)
[06:11:41] Completed 740000 out of 2000000 steps (37%)
[06:32:02] Completed 760000 out of 2000000 steps (38%)
[06:46:04] + Working...
[06:54:11] Completed 780000 out of 2000000 steps (39%)
[07:14:52] Completed 800000 out of 2000000 steps (40%)
[07:35:02] Completed 820000 out of 2000000 steps (41%)
[07:56:21] Completed 840000 out of 2000000 steps (42%)
[08:17:10] Completed 860000 out of 2000000 steps (43%)
[08:38:38] Completed 880000 out of 2000000 steps (44%)
[08:59:21] Completed 900000 out of 2000000 steps (45%)
[09:20:17] Completed 920000 out of 2000000 steps (46%)
[09:41:39] Completed 940000 out of 2000000 steps (47%)
[10:01:47] Completed 960000 out of 2000000 steps (48%)
[10:21:40] Completed 980000 out of 2000000 steps (49%)
--- Opening Log file [June 9 00:49:54 UTC]
[00:49:54] - Ask before connecting: No
[00:49:54] - User name: wan.ardiles@gmail.com (Team 2999)
[00:49:54] - User ID: 51CA9AE53E28XXXX
[00:49:54]
[00:49:54]
[00:50:01]      Bits: 32
[01:15:36]
[01:15:36] + Processing work unit
[01:15:36] Core required: FahCore_b4.exe
[01:15:36] Core found.
[01:15:36] Working on queue slot 08 [June 9 01:15:36 UTC]
[01:15:36] + Working ...
[01:15:38] *********************** Log Started 09/Jun/2010 01:15:38 ***********************
[01:15:38] ************************** ProtoMol Folding@Home Core **************************
[01:15:38]   Version: 25
[01:15:38]      Type: 180
[01:15:38]      Core: ProtoMol
[01:15:38]   Website: http://folding.stanford.edu/
[01:15:38] Copyright: (c) 2009 Stanford University
[01:15:38]    Author: Joseph Coffland <joseph@cauldrondevelopment.com>
[01:15:38]      Args: -dir work/ -suffix 08 -priority 96 -nocpulock -checkpoint 30
[01:15:38]            -lifeline 2656 -version 623
[01:15:38] ************************************ Build *************************************
[01:15:38]      Date: May 18 2010
[01:15:38]      Time: 23:43:52
[01:15:38]  Revision: 1819
[01:15:38]  Compiler: Intel(R) C++ MSVC 1500 mode 1110
[01:15:38]   Options: /TP /nologo /EHsc /wd4297 /wd4103 /wd1786 /arch:IA32 /Ox
[01:15:38]            /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qrestrict /MT
[01:15:38]   Defines: _CRT_SECURE_NO_WARNINGS NDEBUG HAVE_GEEKINFO BOOST_ALL_NO_LIB
[01:15:38]            XML_STATIC HAVE_EXPAT HAVE_OPENSSL HAVE_LIBFAH HAVE_SIMTK_LAPACK
[01:15:38]  Platform: Windows XP
[01:15:38]      Bits: 32
[01:15:38]      Mode: Release
[01:15:38] ************************************ System ************************************
[01:15:38]        OS: Microsoft Windows XP Professional
[01:15:38]       CPU: Intel(R) Pentium(R) 4 CPU 3.00GHz
[01:15:38]    CPU ID: GenuineIntel Family 15 Model 4 Stepping 1
[01:15:38]      CPUs: 2 Logical, 1 Physical
[01:15:38]    Memory: 1023 MB
[01:15:38]   Threads: Windows
[01:15:38] ********************************************************************************
[01:15:38] Project: 10030 (Run 6, Clone 0, Gen 16)
[01:15:38] Unit: 0x0000001b0001329c4bd49c650000c35f
[01:15:38] User: 0x00000000000000000000000000000000
[01:15:38] Machine: 1
[01:15:38] Reading tar file par_all27_prot_lipid.inp
[01:15:38] Reading tar file scpismQuartic.inp
[01:15:38] Reading tar file ww.pdb
[01:15:38] Reading tar file ww.psf
[01:15:38] Reading tar file checkpt
[01:15:38] Reading tar file ww.1377.pos
[01:15:38] Reading tar file ww.1377.vel
[01:15:38] Reading tar file protomol.conf
[01:15:38] Reading tar file core.xml
[01:15:38] Digital signatures verified
[01:15:39] Completed 0 out of 499375 steps (0%)
[01:28:11] Completed 5000 out of 499375 steps (1%)
[01:41:24] Completed 10000 out of 499375 steps (2%)
[01:53:49] Completed 15000 out of 499375 steps (3%)
[02:06:23] Completed 20000 out of 499375 steps (4%)
[02:18:03] Completed 25000 out of 499375 steps (5%)
[02:29:22] Completed 30000 out of 499375 steps (6%)
[02:41:22] Completed 35000 out of 499375 steps (7%)
[02:53:26] Completed 40000 out of 499375 steps (8%)
[03:05:49] Completed 45000 out of 499375 steps (9%)
[03:18:27] Completed 50000 out of 499375 steps (10%)
[03:31:08] Completed 55000 out of 499375 steps (11%)
[03:44:21] Completed 60000 out of 499375 steps (12%)
[03:57:32] Completed 65000 out of 499375 steps (13%)
wan.ardiles
I didn't see anything unusual, except for the BAD_WORK_UNIT :) Only this is the 1st time my machine encountered this 'directory 07' error.
