Project 2684
DocJonz
Project 2684
Post by DocJonz »
I've got two nominally identical -bigadv machines - Core i7 980X (Corsair H50 cooled), 6GB Corsair Dominator (with airflow fan), Ubuntu64 9.04 (everything running at stock speeds) - and over the last day or so, both have been having wierd issues with Projects 2684 .... :?:
Farm1:
[18:00:53] Completed 250000 out of 250000 steps  (100%)
[18:01:01] DynamicWrapper: Finished Work Unit: sleep=10000
[18:01:11]
[18:01:11] Finished Work Unit:
[18:01:11] - Reading up to 52544928 from "work/wudata_03.trr": Read 52544928
[18:01:12] trr file hash check passed.
[18:01:12] - Reading up to 46181596 from "work/wudata_03.xtc": Read 46181596
[18:01:12] xtc file hash check passed.
[18:01:12] edr file hash check passed.
[18:01:12] logfile size: 215066
[18:01:12] Leaving Run
[18:01:15] - Writing 99106506 bytes of core data to disk...
[18:01:19]   ... Done.
[18:01:33] - Shutting down core
[18:01:33]
[18:01:33] Folding@home Core Shutdown: FINISHED_UNIT
[18:04:36] CoreStatus = 64 (100)
[18:04:36] Unit 3 finished with 68 percent of time to deadline remaining.
[18:04:36] Updated performance fraction: 0.691173
[18:04:36] Sending work to server
[18:04:36] Project: 2683 (Run 11, Clone 12, Gen 55)
[18:04:36] + Attempting to send results [June 7 18:04:36 UTC]
[18:04:36] - Reading file work/wuresults_03.dat from core
[18:04:36]   (Read 99106506 bytes from disk)
[18:04:36] Connecting to http://171.67.108.22:8080/
[19:06:19] Posted data.
[19:06:19] Initial: 0000; - Uploaded at ~23 kB/s
[19:12:16] - Averaged speed for that direction ~25 kB/s
[19:12:16] + Results successfully sent
[19:12:16] Thank you for your contribution to Folding@Home.
[19:12:16] + Number of Units Completed: 3
[19:12:20] - Warning: Could not delete all work unit files (3): Core file absent
[19:12:20] Trying to send all finished work units
[19:12:20] + No unsent completed units remaining.
[19:12:20] - Preparing to get new work unit...
[19:12:20] Cleaning up work directory
[19:12:20] + Attempting to get work packet
[19:12:20] Passkey found
[19:12:20] - Will indicate memory of 5550 MB
[19:12:20] - Connecting to assignment server
[19:12:20] Connecting to http://assign.stanford.edu:8080/
[19:12:21] Posted data.
[19:12:21] Initial: 43AB; - Successful: assigned to (171.67.108.22).
[19:12:21] + News From Folding@Home: Welcome to Folding@Home
[19:12:22] Loaded queue successfully.
[19:12:22] Connecting to http://171.67.108.22:8080/
[19:12:33] Posted data.
[19:12:33] Initial: 0000; - Receiving payload (expected size: 24828362)
[19:16:49] - Downloaded at ~94 kB/s
[19:16:49] - Averaged speed for that direction ~447 kB/s
[19:16:49] + Received work.
[19:16:49] Trying to send all finished work units
[19:16:49] + No unsent completed units remaining.
[19:16:49] + Closed connections
[19:16:49]
[19:16:49] + Processing work unit
[19:16:49] Core required: FahCore_a3.exe
[19:16:49] Core not found.
[19:16:49] - Core is not present or corrupted.
[19:16:49] - Attempting to download new core...
[19:16:49] + Downloading new core: FahCore_a3.exe
[19:16:49] Downloading core (/~pande/Linux/AMD64/Core_a3.fah from www.stanford.edu)
[19:16:50] Initial: AFDE; + 10240 bytes downloaded
[19:16:51] Initial: 300D; + 20480 bytes downloaded
[19:16:58] Initial: 6A84; + 1832960 bytes downloaded
[19:16:58] Initial: 3C5C; + 1843200 bytes downloaded
[19:16:58] Initial: 0000; + 1843342 bytes downloaded
[19:16:58] Verifying core Core_a3.fah...
[19:16:58] Signature is VALID
[19:16:58]
[19:16:58] Trying to unzip core FahCore_a3.exe
[19:16:58] Decompressed FahCore_a3.exe (4375728 bytes) successfully
[19:16:58] + Core successfully engaged
[19:17:03]
[19:17:03] + Processing work unit
[19:17:03] Core required: FahCore_a3.exe
[19:17:03] Core found.
[19:17:03] Working on queue slot 04 [June 7 19:17:03 UTC]
[19:17:03] + Working ...
[19:17:03] - Calling './FahCore_a3.exe -dir work/ -nice 19 -suffix 04 -np 12 -checkpoint 10 -forceasm -verbose -lifeline 3949 -version 629'
[19:17:03]
[19:17:03] *------------------------------*
[19:17:03] Folding@Home Gromacs SMP Core
[19:17:03] Version 2.21 (May 10, 2010)
[19:17:03]
[19:17:03] Preparing to commence simulation
[19:17:03] - Ensuring status. Please wait.
[19:17:13] - Assembly optimizations manually forced on.
[19:17:13] - Not checking prior termination.
[19:17:15] - Expanded 24827850 -> 30791309 (decompressed 124.0 percent)
[19:17:15] Called DecompressByteArray: compressed_data_size=24827850 data_size=30791309, decompressed_data_size=30791309 diff=0
[19:17:15] - Digital signature verified
[19:17:15]
[19:17:15] Project: 2684 (Run 6, Clone 15, Gen 2)
[19:17:15]
[19:17:15] Assembly optimizations on if available.
[19:17:15] Entering M.D.
[19:17:25] Completed 0 out of 250000 steps  (0%)
[19:54:41] Completed 2500 out of 250000 steps  (1%)
[20:24:10] - Autosending finished units... [June 7 20:24:10 UTC]
[20:24:10] Trying to send all finished work units
[20:24:10] + No unsent completed units remaining.
[20:24:10] - Autosend completed
[20:31:53] Completed 5000 out of 250000 steps  (2%)
[21:09:20] Completed 7500 out of 250000 steps  (3%)
[21:46:49] Completed 10000 out of 250000 steps  (4%)
[22:24:14] Completed 12500 out of 250000 steps  (5%)
[23:01:39] Completed 15000 out of 250000 steps  (6%)
[23:38:59] Completed 17500 out of 250000 steps  (7%)
[00:16:30] Completed 20000 out of 250000 steps  (8%)
[00:53:58] Completed 22500 out of 250000 steps  (9%)
[01:31:28] Completed 25000 out of 250000 steps  (10%)
[02:09:00] Completed 27500 out of 250000 steps  (11%)
[02:24:10] - Autosending finished units... [June 8 02:24:10 UTC]
[02:24:10] Trying to send all finished work units
[02:24:10] + No unsent completed units remaining.
[02:24:10] - Autosend completed
[02:46:26] Completed 30000 out of 250000 steps  (12%)
[02:50:07] CoreStatus = 8B (139)
[02:50:07] Client-core communications error: ERROR 0x8b
[02:50:07] Deleting current work unit & continuing...
[02:50:21] Trying to send all finished work units
[02:50:21] + No unsent completed units remaining.
[02:50:21] - Preparing to get new work unit...
[02:50:21] Cleaning up work directory
[02:50:21] + Attempting to get work packet
[02:50:21] Passkey found
[02:50:21] - Will indicate memory of 5550 MB
[02:50:21] - Connecting to assignment server
[02:50:21] Connecting to http://assign.stanford.edu:8080/
[02:50:22] Posted data.
[02:50:22] Initial: 43AB; - Successful: assigned to (171.67.108.22).
[02:50:22] + News From Folding@Home: Welcome to Folding@Home
[02:50:22] Loaded queue successfully.
[02:50:22] Connecting to http://171.67.108.22:8080/
[02:50:31] Posted data.
[02:50:31] Initial: 0000; - Receiving payload (expected size: 24828362)
[02:51:14] - Downloaded at ~563 kB/s
[02:51:14] - Averaged speed for that direction ~470 kB/s
[02:51:14] + Received work.
[02:51:14] + Closed connections
[02:51:19]
[02:51:19] + Processing work unit
[02:51:19] Core required: FahCore_a3.exe
[02:51:19] Core found.
[02:51:19] Working on queue slot 05 [June 8 02:51:19 UTC]
[02:51:19] + Working ...
[02:51:19] - Calling './FahCore_a3.exe -dir work/ -nice 19 -suffix 05 -np 12 -checkpoint 10 -forceasm -verbose -lifeline 3949 -version 629'
[02:51:19]
[02:51:19] *------------------------------*
[02:51:19] Folding@Home Gromacs SMP Core
[02:51:19] Version 2.21 (May 10, 2010)
[02:51:19]
[02:51:19] Preparing to commence simulation
[02:51:19] - Assembly optimizations manually forced on.
[02:51:19] - Not checking prior termination.
[02:51:21] - Expanded 24827850 -> 30791309 (decompressed 124.0 percent)
[02:51:21] Called DecompressByteArray: compressed_data_size=24827850 data_size=30791309, decompressed_data_size=30791309 diff=0
[02:51:21] - Digital signature verified
[02:51:21]
[02:51:21] Project: 2684 (Run 6, Clone 15, Gen 2)
[02:51:21]
[02:51:21] Assembly optimizations on if available.
[02:51:21] Entering M.D.
[02:51:32] Completed 0 out of 250000 steps  (0%)
[02:51:35] mdrun returned 255
[02:51:35] Going to send back what have done -- stepsTotalG=250000
[02:51:35] Work fraction=499970.9062 steps=250000.
[02:51:39] logfile size=12570 infoLength=12570 edr=25 trr=1
[02:51:39] logfile size: 12570 info=12570 bed=25 hdr=1
[02:51:39] - Writing 13108 bytes of core data to disk...
[02:51:40]   ... Done.
[02:51:42]
[02:51:42] Folding@home Core Shutdown: EARLY_UNIT_END
[02:51:43] CoreStatus = 72 (114)
[02:51:43] Sending work to server
[02:51:43] Project: 2684 (Run 6, Clone 15, Gen 2)
[02:51:43] + Attempting to send results [June 8 02:51:43 UTC]
[02:51:43] - Reading file work/wuresults_05.dat from core
[02:51:43]   (Read 13108 bytes from disk)
[02:51:43] Connecting to http://171.67.108.22:8080/
[02:51:44] Posted data.
[02:51:44] Initial: 0000; - Uploaded at ~6 kB/s
[02:51:45] - Averaged speed for that direction ~21 kB/s
[02:51:45] + Results successfully sent
[02:51:45] Thank you for your contribution to Folding@Home.
[02:51:45] Trying to send all finished work units
[02:51:45] + No unsent completed units remaining.
[02:51:45] - Preparing to get new work unit...
[02:51:45] Cleaning up work directory
[02:51:45] + Attempting to get work packet
[02:51:45] Passkey found
[02:51:45] - Will indicate memory of 5550 MB
[02:51:45] - Connecting to assignment server
[02:51:45] Connecting to http://assign.stanford.edu:8080/
[02:51:46] Posted data.
[02:51:46] Initial: 43AB; - Successful: assigned to (171.67.108.22).
[02:51:46] + News From Folding@Home: Welcome to Folding@Home
[02:51:46] Loaded queue successfully.
[02:51:46] Connecting to http://171.67.108.22:8080/
[02:51:58] Posted data.
[02:51:58] Initial: 0000; - Receiving payload (expected size: 24828362)
[02:52:41] - Downloaded at ~563 kB/s
[02:52:41] - Averaged speed for that direction ~489 kB/s
[02:52:41] + Received work.
[02:52:41] Trying to send all finished work units
[02:52:41] + No unsent completed units remaining.
[02:52:41] + Closed connections
[02:52:46]
[02:52:46] + Processing work unit
[02:52:46] Core required: FahCore_a3.exe
[02:52:46] Core found.
[02:52:46] Working on queue slot 06 [June 8 02:52:46 UTC]
[02:52:46] + Working ...
[02:52:46] - Calling './FahCore_a3.exe -dir work/ -nice 19 -suffix 06 -np 12 -checkpoint 10 -forceasm -verbose -lifeline 3949 -version 629'
[02:52:46]
[02:52:46] *------------------------------*
[02:52:46] Folding@Home Gromacs SMP Core
[02:52:46] Version 2.21 (May 10, 2010)
[02:52:46]
[02:52:46] Preparing to commence simulation
[02:52:46] - Assembly optimizations manually forced on.
[02:52:46] - Not checking prior termination.
[02:52:48] - Expanded 24827850 -> 30791309 (decompressed 124.0 percent)
[02:52:48] Called DecompressByteArray: compressed_data_size=24827850 data_size=30791309, decompressed_data_size=30791309 diff=0
[02:52:48] - Digital signature verified
[02:52:48]
[02:52:48] Project: 2684 (Run 6, Clone 15, Gen 2)
[02:52:48]
[02:52:48] Assembly optimizations on if available.
[02:52:48] Entering M.D.
[02:52:59] Completed 0 out of 250000 steps  (0%)
[02:53:01] mdrun returned 255
[02:53:01] Going to send back what have done -- stepsTotalG=250000
[02:53:01] Work fraction=8589934592.0000 steps=250000.
[02:53:05] logfile size=12570 infoLength=12570 edr=25 trr=1
[02:53:05] logfile size: 12570 info=12570 bed=25 hdr=1
[02:53:05] - Writing 13108 bytes of core data to disk...
[02:53:06]   ... Done.
[02:53:08]
[02:53:08] Folding@home Core Shutdown: UNSTABLE_MACHINE
[02:53:08] CoreStatus = 7A (122)
[02:53:08] Sending work to server
[02:53:08] Project: 2684 (Run 6, Clone 15, Gen 2)
[02:53:08] + Attempting to send results [June 8 02:53:08 UTC]
[02:53:08] - Reading file work/wuresults_06.dat from core
[02:53:08]   (Read 13108 bytes from disk)
[02:53:08] Connecting to http://171.67.108.22:8080/
[02:53:09] Posted data.
[02:53:09] Initial: 0000; - Uploaded at ~6 kB/s
[02:53:10] - Averaged speed for that direction ~18 kB/s
[02:53:10] + Results successfully sent
[02:53:10] Thank you for your contribution to Folding@Home.
[02:53:10] Trying to send all finished work units
[02:53:10] + No unsent completed units remaining.
[02:53:10] - Preparing to get new work unit...
[02:53:10] Cleaning up work directory
[02:53:10] + Attempting to get work packet
[02:53:10] Passkey found
[02:53:10] - Will indicate memory of 5550 MB
[02:53:10] - Connecting to assignment server
[02:53:10] Connecting to http://assign.stanford.edu:8080/
[02:53:12] Posted data.
[02:53:12] Initial: 43AB; - Successful: assigned to (171.67.108.22).
[02:53:12] + News From Folding@Home: Welcome to Folding@Home
[02:53:12] Loaded queue successfully.
[02:53:12] Connecting to http://171.67.108.22:8080/
[02:53:21] Posted data.
[02:53:21] Initial: 0000; - Receiving payload (expected size: 24828362)
[02:54:03] - Downloaded at ~577 kB/s
[02:54:03] - Averaged speed for that direction ~506 kB/s
[02:54:03] + Received work.
[02:54:03] Trying to send all finished work units
[02:54:03] + No unsent completed units remaining.
[02:54:03] + Closed connections
[02:54:08]
[02:54:08] + Processing work unit
[02:54:08] Core required: FahCore_a3.exe
[02:54:08] Core found.
[02:54:08] Working on queue slot 07 [June 8 02:54:08 UTC]
[02:54:08] + Working ...
[02:54:08] - Calling './FahCore_a3.exe -dir work/ -nice 19 -suffix 07 -np 12 -checkpoint 10 -forceasm -verbose -lifeline 3949 -version 629'
[02:54:08]
[02:54:08] *------------------------------*
[02:54:08] Folding@Home Gromacs SMP Core
[02:54:08] Version 2.21 (May 10, 2010)
[02:54:08]
[02:54:08] Preparing to commence simulation
[02:54:08] - Assembly optimizations manually forced on.
[02:54:08] - Not checking prior termination.
[02:54:10] - Expanded 24827850 -> 30791309 (decompressed 124.0 percent)
[02:54:10] Called DecompressByteArray: compressed_data_size=24827850 data_size=30791309, decompressed_data_size=30791309 diff=0
[02:54:10] - Digital signature verified
[02:54:10]
[02:54:10] Project: 2684 (Run 6, Clone 15, Gen 2)
[02:54:10]
[02:54:10] Assembly optimizations on if available.
[02:54:10] Entering M.D.
[02:54:21] Completed 0 out of 250000 steps  (0%)
[02:54:24] mdrun returned 255
[02:54:24] Going to send back what have done -- stepsTotalG=250000
[02:54:24] Work fraction=499970.9062 steps=250000.
[02:54:28] logfile size=12570 infoLength=12570 edr=25 trr=1
[02:54:28] logfile size: 12570 info=12570 bed=25 hdr=1
[02:54:28] - Writing 13108 bytes of core data to disk...
[02:54:29]   ... Done.
[02:54:32]
[02:54:32] Folding@home Core Shutdown: EARLY_UNIT_END
[02:54:32] CoreStatus = 72 (114)
[02:54:32] Sending work to server
[02:54:32] Project: 2684 (Run 6, Clone 15, Gen 2)
[02:54:32] + Attempting to send results [June 8 02:54:32 UTC]
[02:54:32] - Reading file work/wuresults_07.dat from core
[02:54:32]   (Read 13108 bytes from disk)
[02:54:32] Connecting to http://171.67.108.22:8080/
[02:54:33] Posted data.
[02:54:33] Initial: 0000; - Uploaded at ~6 kB/s
[02:54:34] - Averaged speed for that direction ~15 kB/s
[02:54:34] + Results successfully sent
[02:54:34] Thank you for your contribution to Folding@Home.
[02:54:34] Trying to send all finished work units
[02:54:34] + No unsent completed units remaining.
[02:54:34] - Preparing to get new work unit...
[02:54:34] Cleaning up work directory
[02:54:34] + Attempting to get work packet
[02:54:34] Passkey found
[02:54:34] - Will indicate memory of 5550 MB
[02:54:34] - Connecting to assignment server
[02:54:34] Connecting to http://assign.stanford.edu:8080/
[02:54:35] Posted data.
[02:54:35] Initial: 43AB; - Successful: assigned to (171.67.108.22).
[02:54:35] + News From Folding@Home: Welcome to Folding@Home
[02:54:35] Loaded queue successfully.
[02:54:35] Connecting to http://171.67.108.22:8080/
[02:54:47] Posted data.
[02:54:47] Initial: 0000; - Receiving payload (expected size: 24828362)
[02:55:30] - Downloaded at ~563 kB/s
[02:55:30] - Averaged speed for that direction ~518 kB/s
[02:55:30] + Received work.
[02:55:30] Trying to send all finished work units
[02:55:30] + No unsent completed units remaining.
[02:55:30] + Closed connections
[02:55:35]
[02:55:35] + Processing work unit
[02:55:35] Core required: FahCore_a3.exe
[02:55:35] Core found.
[02:55:35] Working on queue slot 08 [June 8 02:55:35 UTC]
[02:55:35] + Working ...
[02:55:35] - Calling './FahCore_a3.exe -dir work/ -nice 19 -suffix 08 -np 12 -checkpoint 10 -forceasm -verbose -lifeline 3949 -version 629'
[02:55:35]
[02:55:35] *------------------------------*
[02:55:35] Folding@Home Gromacs SMP Core
[02:55:35] Version 2.21 (May 10, 2010)
[02:55:35]
[02:55:35] Preparing to commence simulation
[02:55:35] - Assembly optimizations manually forced on.
[02:55:35] - Not checking prior termination.
[02:55:37] - Expanded 24827850 -> 30791309 (decompressed 124.0 percent)
[02:55:37] Called DecompressByteArray: compressed_data_size=24827850 data_size=30791309, decompressed_data_size=30791309 diff=0
[02:55:37] - Digital signature verified
[02:55:37]
[02:55:37] Project: 2684 (Run 6, Clone 15, Gen 2)
[02:55:37]
[02:55:37] Assembly optimizations on if available.
[02:55:37] Entering M.D.
[02:55:48] Completed 0 out of 250000 steps  (0%)
[02:55:51] mdrun returned 255
[02:55:51] Going to send back what have done -- stepsTotalG=250000
[02:55:51] Work fraction=249992.7344 steps=250000.
[02:55:55] logfile size=12570 infoLength=12570 edr=25 trr=1
[02:55:55] logfile size: 12570 info=12570 bed=25 hdr=1
[02:55:55] - Writing 13108 bytes of core data to disk...
[02:55:56]   ... Done.
[02:55:59]
[02:55:59] Folding@home Core Shutdown: UNSTABLE_MACHINE
[02:55:59] CoreStatus = 7A (122)
[02:55:59] Sending work to server
[02:55:59] Project: 2684 (Run 6, Clone 15, Gen 2)
[02:55:59] + Attempting to send results [June 8 02:55:59 UTC]
[02:55:59] - Reading file work/wuresults_08.dat from core
[02:55:59]   (Read 13108 bytes from disk)
[02:55:59] Connecting to http://171.67.108.22:8080/
[02:56:00] Posted data.
[02:56:01] Initial: 0000; - Uploaded at ~6 kB/s
[02:56:01] - Averaged speed for that direction ~14 kB/s
[02:56:01] + Results successfully sent
[02:56:01] Thank you for your contribution to Folding@Home.
[02:56:01] Trying to send all finished work units
[02:56:01] + No unsent completed units remaining.
[02:56:01] - Preparing to get new work unit...
[02:56:01] Cleaning up work directory
[02:56:01] + Attempting to get work packet
[02:56:01] Passkey found
[02:56:01] - Will indicate memory of 5550 MB
[02:56:01] - Connecting to assignment server
[02:56:01] Connecting to http://assign.stanford.edu:8080/
[02:56:02] Posted data.
[02:56:02] Initial: 43AB; - Successful: assigned to (171.67.108.22).
[02:56:02] + News From Folding@Home: Welcome to Folding@Home
[02:56:02] Loaded queue successfully.
[02:56:02] Connecting to http://171.67.108.22:8080/
[02:56:14] Posted data.
[02:56:14] Initial: 0000; - Receiving payload (expected size: 24828362)
[02:56:56] - Downloaded at ~577 kB/s
[02:56:56] - Averaged speed for that direction ~530 kB/s
[02:56:56] + Received work.
[02:56:56] Trying to send all finished work units
[02:56:56] + No unsent completed units remaining.
[02:56:56] + Closed connections
[02:57:01]
[02:57:01] + Processing work unit
[02:57:01] Core required: FahCore_a3.exe
[02:57:01] Core found.
[02:57:01] Working on queue slot 09 [June 8 02:57:01 UTC]
[02:57:01] + Working ...
[02:57:01] - Calling './FahCore_a3.exe -dir work/ -nice 19 -suffix 09 -np 12 -checkpoint 10 -forceasm -verbose -lifeline 3949 -version 629'
[02:57:01]
[02:57:01] *------------------------------*
[02:57:01] Folding@Home Gromacs SMP Core
[02:57:01] Version 2.21 (May 10, 2010)
[02:57:01]
[02:57:01] Preparing to commence simulation
[02:57:01] - Assembly optimizations manually forced on.
[02:57:01] - Not checking prior termination.
[02:57:03] - Expanded 24827850 -> 30791309 (decompressed 124.0 percent)
[02:57:03] Called DecompressByteArray: compressed_data_size=24827850 data_size=30791309, decompressed_data_size=30791309 diff=0
[02:57:03] - Digital signature verified
[02:57:03]
[02:57:03] Project: 2684 (Run 6, Clone 15, Gen 2)
[02:57:03]
[02:57:03] Assembly optimizations on if available.
[02:57:03] Entering M.D.
[02:57:14] Completed 0 out of 250000 steps  (0%)
[02:57:16] mdrun returned 255
[02:57:16] Going to send back what have done -- stepsTotalG=250000
[02:57:16] Work fraction=8589934592.0000 steps=250000.
[02:57:20] logfile size=12570 infoLength=12570 edr=25 trr=1
[02:57:20] logfile size: 12570 info=12570 bed=25 hdr=1
[02:57:20] - Writing 13108 bytes of core data to disk...
[02:57:21]   ... Done.
[02:57:24]
[02:57:24] Folding@home Core Shutdown: UNSTABLE_MACHINE
[02:57:25] CoreStatus = 7A (122)
[02:57:25] Sending work to server
[02:57:25] Project: 2684 (Run 6, Clone 15, Gen 2)
[02:57:25] + Attempting to send results [June 8 02:57:25 UTC]
[02:57:25] - Reading file work/wuresults_09.dat from core
[02:57:25]   (Read 13108 bytes from disk)
[02:57:25] Connecting to http://171.67.108.22:8080/
[02:57:25] Posted data.
[02:57:25] Initial: 0000; - Uploaded at ~13 kB/s
[02:57:26] - Averaged speed for that direction ~14 kB/s
[02:57:26] + Results successfully sent
[02:57:26] Thank you for your contribution to Folding@Home.
[02:57:26] Trying to send all finished work units
[02:57:26] + No unsent completed units remaining.
[02:57:26] - Preparing to get new work unit...
[02:57:26] Cleaning up work directory
[02:57:26] + Attempting to get work packet
[02:57:26] Passkey found
[02:57:26] - Will indicate memory of 5550 MB
[02:57:26] - Connecting to assignment server
[02:57:26] Connecting to http://assign.stanford.edu:8080/
[02:57:28] Posted data.
[02:57:28] Initial: 43AB; - Successful: assigned to (171.67.108.22).
[02:57:28] + News From Folding@Home: Welcome to Folding@Home
[02:57:28] Loaded queue successfully.
[02:57:28] Connecting to http://171.67.108.22:8080/
[02:57:39] Posted data.
[02:57:39] Initial: 0000; - Receiving payload (expected size: 24828362)
[02:58:22] - Downloaded at ~563 kB/s
[02:58:22] - Averaged speed for that direction ~536 kB/s
[02:58:22] + Received work.
[02:58:22] Trying to send all finished work units
[02:58:22] + No unsent completed units remaining.
[02:58:22] + Closed connections
[02:58:27]
[02:58:27] + Processing work unit
[02:58:27] Core required: FahCore_a3.exe
[02:58:27] Core found.
[02:58:27] Working on queue slot 00 [June 8 02:58:27 UTC]
[02:58:27] + Working ...
[02:58:27] - Calling './FahCore_a3.exe -dir work/ -nice 19 -suffix 00 -np 12 -checkpoint 10 -forceasm -verbose -lifeline 3949 -version 629'
[02:58:27]
[02:58:27] *------------------------------*
[02:58:27] Folding@Home Gromacs SMP Core
[02:58:27] Version 2.21 (May 10, 2010)
[02:58:27]
[02:58:27] Preparing to commence simulation
[02:58:27] - Assembly optimizations manually forced on.
[02:58:27] - Not checking prior termination.
[02:58:29] - Expanded 24827850 -> 30791309 (decompressed 124.0 percent)
[02:58:29] Called DecompressByteArray: compressed_data_size=24827850 data_size=30791309, decompressed_data_size=30791309 diff=0
[02:58:29] - Digital signature verified
[02:58:29]
[02:58:29] Project: 2684 (Run 6, Clone 15, Gen 2)
[02:58:29]
[02:58:29] Assembly optimizations on if available.
[02:58:29] Entering M.D.
[02:58:41] Completed 0 out of 250000 steps  (0%)
[03:08:26] CoreStatus = 8B (139)
[03:08:26] Client-core communications error: ERROR 0x8b
[03:08:26] Deleting current work unit & continuing...
[03:08:39] Trying to send all finished work units
[03:08:39] + No unsent completed units remaining.
[03:08:39] - Preparing to get new work unit...
[03:08:39] Cleaning up work directory
[03:08:41] + Attempting to get work packet
[03:08:41] Passkey found
[03:08:41] - Will indicate memory of 5550 MB
[03:08:41] - Connecting to assignment server
[03:08:41] Connecting to http://assign.stanford.edu:8080/
[03:08:41] Posted data.
[03:08:41] Initial: 43AB; - Successful: assigned to (171.67.108.22).
[03:08:41] + News From Folding@Home: Welcome to Folding@Home
[03:08:42] Loaded queue successfully.
[03:08:42] Connecting to http://171.67.108.22:8080/
[03:08:42] Posted data.
[03:08:42] Initial: 0000; - Error: Bad packet type from server, expected work assignment
[03:08:43] - Attempt #1  to get work failed, and no other work to do.
Waiting before retry.
[03:08:52] + Attempting to get work packet
[03:08:52] Passkey found
[03:08:52] - Will indicate memory of 5550 MB
[03:08:52] - Connecting to assignment server
[03:08:52] Connecting to http://assign.stanford.edu:8080/
[03:08:53] Posted data.
[03:08:53] Initial: 43AB; - Successful: assigned to (171.67.108.22).
[03:08:53] + News From Folding@Home: Welcome to Folding@Home
[03:08:53] Loaded queue successfully.
[03:08:53] Connecting to http://171.67.108.22:8080/
[03:09:05] Posted data.
[03:09:05] Initial: 0000; - Receiving payload (expected size: 24828362)
[03:09:47] - Downloaded at ~577 kB/s
[03:09:47] - Averaged speed for that direction ~544 kB/s
[03:09:47] + Received work.
[03:09:47] + Closed connections
[03:09:52]
[03:09:52] + Processing work unit
[03:09:52] Core required: FahCore_a3.exe
[03:09:52] Core found.
[03:09:52] Working on queue slot 01 [June 8 03:09:52 UTC]
[03:09:52] + Working ...
[03:09:52] - Calling './FahCore_a3.exe -dir work/ -nice 19 -suffix 01 -np 12 -checkpoint 10 -forceasm -verbose -lifeline 3949 -version 629'
[03:09:52]
[03:09:52] *------------------------------*
[03:09:52] Folding@Home Gromacs SMP Core
[03:09:52] Version 2.21 (May 10, 2010)
[03:09:52]
[03:09:52] Preparing to commence simulation
[03:09:52] - Assembly optimizations manually forced on.
[03:09:52] - Not checking prior termination.
[03:09:54] - Expanded 24827850 -> 30791309 (decompressed 124.0 percent)
[03:09:54] Called DecompressByteArray: compressed_data_size=24827850 data_size=30791309, decompressed_data_size=30791309 diff=0
[03:09:54] - Digital signature verified
[03:09:54]
[03:09:54] Project: 2684 (Run 6, Clone 15, Gen 2)
[03:09:54]
[03:09:54] Assembly optimizations on if available.
[03:09:54] Entering M.D.
[03:10:05] Completed 0 out of 250000 steps  (0%)
[03:10:08] mdrun returned 255
[03:10:08] Going to send back what have done -- stepsTotalG=250000
[03:10:08] Work fraction=249992.7344 steps=250000.
[03:10:12] logfile size=12570 infoLength=12570 edr=25 trr=1
[03:10:12] logfile size: 12570 info=12570 bed=25 hdr=1
[03:10:12] - Writing 13108 bytes of core data to disk...
[03:10:13]   ... Done.
[03:10:16]
[03:10:16] Folding@home Core Shutdown: UNSTABLE_MACHINE
[03:10:16] CoreStatus = 7A (122)
[03:10:16] Sending work to server
[03:10:16] Project: 2684 (Run 6, Clone 15, Gen 2)
[03:10:16] + Attempting to send results [June 8 03:10:16 UTC]
[03:10:16] - Reading file work/wuresults_01.dat from core
[03:10:16]   (Read 13108 bytes from disk)
[03:10:16] Connecting to http://171.67.108.22:8080/
[03:10:17] Posted data.
[03:10:17] Initial: 0000; - Uploaded at ~6 kB/s
[03:10:18] - Averaged speed for that direction ~12 kB/s
[03:10:18] + Results successfully sent
[03:10:18] Thank you for your contribution to Folding@Home.
[03:10:18] Trying to send all finished work units
[03:10:18] + No unsent completed units remaining.
[03:10:18] - Preparing to get new work unit...
[03:10:18] Cleaning up work directory
[03:10:19] + Attempting to get work packet
[03:10:19] Passkey found
[03:10:19] - Will indicate memory of 5550 MB
[03:10:19] - Connecting to assignment server
[03:10:19] Connecting to http://assign.stanford.edu:8080/
[03:10:20] Posted data.
[03:10:20] Initial: 43AB; - Successful: assigned to (171.67.108.22).
[03:10:20] + News From Folding@Home: Welcome to Folding@Home
[03:10:20] Loaded queue successfully.
[03:10:20] Connecting to http://171.67.108.22:8080/
[03:10:32] Posted data.
[03:10:32] Initial: 0000; - Receiving payload (expected size: 24828362)
[03:11:14] - Downloaded at ~577 kB/s
[03:11:14] - Averaged speed for that direction ~551 kB/s
[03:11:14] + Received work.
[03:11:14] Trying to send all finished work units
[03:11:14] + No unsent completed units remaining.
[03:11:14] + Closed connections
[03:11:19]
[03:11:19] + Processing work unit
[03:11:19] Core required: FahCore_a3.exe
[03:11:19] Core found.
[03:11:19] Working on queue slot 02 [June 8 03:11:19 UTC]
[03:11:19] + Working ...
[03:11:19] - Calling './FahCore_a3.exe -dir work/ -nice 19 -suffix 02 -np 12 -checkpoint 10 -forceasm -verbose -lifeline 3949 -version 629'
[03:11:20]
[03:11:20] *------------------------------*
[03:11:20] Folding@Home Gromacs SMP Core
[03:11:20] Version 2.21 (May 10, 2010)
[03:11:20]
[03:11:20] Preparing to commence simulation
[03:11:20] - Assembly optimizations manually forced on.
[03:11:20] - Not checking prior termination.
[03:11:22] - Expanded 24827850 -> 30791309 (decompressed 124.0 percent)
[03:11:22] Called DecompressByteArray: compressed_data_size=24827850 data_size=30791309, decompressed_data_size=30791309 diff=0
[03:11:22] - Digital signature verified
[03:11:22]
[03:11:22] Project: 2684 (Run 6, Clone 15, Gen 2)
[03:11:22]
[03:11:22] Assembly optimizations on if available.
[03:11:22] Entering M.D.
[03:11:33] Completed 0 out of 250000 steps  (0%)
[03:48:52] Completed 2500 out of 250000 steps  (1%)
[04:26:08] Completed 5000 out of 250000 steps  (2%)
[05:03:27] Completed 7500 out of 250000 steps  (3%)
[05:40:45] Completed 10000 out of 250000 steps  (4%)
DocJonz
Re: Project 2684
Post by DocJonz »
Results from the second machine ....
Farm2:
# Linux SMP Console Edition ###################################################
                       Folding@Home Client Version 6.29
                          http://folding.stanford.edu
Launch directory: /home/williams/Folding@Home/LinuxSMP
Executable: ./fah6
Arguments: -forceasm -smp -bigadv -verbosity 9
[12:32:37] - Ask before connecting: No
[12:32:37] - User name: DocJonz (Team 35947)
[12:32:37] - User ID: 26B860ED5E0FB698
[12:32:37] - Machine ID: 2
[12:32:37]
[12:32:37] Work directory not found. Creating...
[12:32:37] Could not open work queue, generating new queue...
[12:32:37] - Preparing to get new work unit...
[12:32:37] - Autosending finished units... [June 6 12:32:37 UTC]
[12:32:37] Cleaning up work directory
[12:32:37] Trying to send all finished work units
[12:32:37] + No unsent completed units remaining.
[12:32:37] - Autosend completed
[12:32:37] + Attempting to get work packet
[12:32:37] Passkey found
[12:32:37] - Will indicate memory of 5550 MB
[12:32:37] - Connecting to assignment server
[12:32:37] Connecting to http://assign.stanford.edu:8080/
[12:32:38] Posted data.
[12:32:38] Initial: 43AB; - Successful: assigned to (171.67.108.22).
[12:32:38] + News From Folding@Home: Welcome to Folding@Home
[12:32:38] Loaded queue successfully.
[12:32:38] Connecting to http://171.67.108.22:8080/
[12:32:49] Posted data.
[12:32:49] Initial: 0000; - Receiving payload (expected size: 24837374)
[12:33:32] - Downloaded at ~564 kB/s
[12:33:32] - Averaged speed for that direction ~564 kB/s
[12:33:32] + Received work.
[12:33:32] + Closed connections
[12:33:32]
[12:33:32] + Processing work unit
[12:33:32] Core required: FahCore_a3.exe
[12:33:32] Core found.
[12:33:32] Working on queue slot 01 [June 6 12:33:32 UTC]
[12:33:32] + Working ...
[12:33:32] - Calling './FahCore_a3.exe -dir work/ -nice 19 -suffix 01 -np 12 -checkpoint 10 -forceasm -verbose -lifeline 26742 -version 629'
[12:33:32]
[12:33:32] *------------------------------*
[12:33:32] Folding@Home Gromacs SMP Core
[12:33:32] Version 2.21 (May 10, 2010)
[12:33:32]
[12:33:32] Preparing to commence simulation
[12:33:32] - Assembly optimizations manually forced on.
[12:33:32] - Not checking prior termination.
[12:33:34] - Expanded 24836862 -> 30791309 (decompressed 123.9 percent)
[12:33:34] Called DecompressByteArray: compressed_data_size=24836862 data_size=30791309, decompressed_data_size=30791309 diff=0
[12:33:34] - Digital signature verified
[12:33:34]
[12:33:34] Project: 2684 (Run 6, Clone 19, Gen 1)
[12:33:34]
[12:33:34] Assembly optimizations on if available.
[12:33:34] Entering M.D.
[12:33:45] Completed 0 out of 250000 steps  (0%)
[12:33:47] mdrun returned 255
[12:33:47] Going to send back what have done -- stepsTotalG=250000
[12:33:47] Work fraction=4294967296.0000 steps=250000.
[12:33:51] logfile size=12570 infoLength=12570 edr=25 trr=1
[12:33:51] logfile size: 12570 info=12570 bed=25 hdr=1
[12:33:51] - Writing 13108 bytes of core data to disk...
[12:33:53]   ... Done.
[12:33:55]
[12:33:55] Folding@home Core Shutdown: UNSTABLE_MACHINE
[12:33:55] CoreStatus = 7A (122)
[12:33:55] Sending work to server
[12:33:55] Project: 2684 (Run 6, Clone 19, Gen 1)
[12:33:55] + Attempting to send results [June 6 12:33:55 UTC]
[12:33:55] - Reading file work/wuresults_01.dat from core
[12:33:55]   (Read 13108 bytes from disk)
[12:33:55] Connecting to http://171.67.108.22:8080/
[12:33:56] Posted data.
[12:33:57] Initial: 0000; - Uploaded at ~6 kB/s
[12:33:57] - Averaged speed for that direction ~6 kB/s
[12:33:57] + Results successfully sent
[12:33:57] Thank you for your contribution to Folding@Home.
[12:33:57] Trying to send all finished work units
[12:33:57] + No unsent completed units remaining.
[12:33:57] - Preparing to get new work unit...
[12:33:57] Cleaning up work directory
[12:33:57] + Attempting to get work packet
[12:33:57] Passkey found
[12:33:57] - Will indicate memory of 5550 MB
[12:33:57] - Connecting to assignment server
[12:33:57] Connecting to http://assign.stanford.edu:8080/
[12:33:59] Posted data.
[12:33:59] Initial: 43AB; - Successful: assigned to (171.67.108.22).
[12:33:59] + News From Folding@Home: Welcome to Folding@Home
[12:33:59] Loaded queue successfully.
[12:33:59] Connecting to http://171.67.108.22:8080/
[12:34:11] Posted data.
[12:34:11] Initial: 0000; - Receiving payload (expected size: 24839626)
[12:34:54] - Downloaded at ~564 kB/s
[12:34:54] - Averaged speed for that direction ~564 kB/s
[12:34:54] + Received work.
[12:34:54] Trying to send all finished work units
[12:34:54] + No unsent completed units remaining.
[12:34:54] + Closed connections
[12:34:59]
[12:34:59] + Processing work unit
[12:34:59] Core required: FahCore_a3.exe
[12:34:59] Core found.
[12:34:59] Working on queue slot 02 [June 6 12:34:59 UTC]
[12:34:59] + Working ...
[12:34:59] - Calling './FahCore_a3.exe -dir work/ -nice 19 -suffix 02 -np 12 -checkpoint 10 -forceasm -verbose -lifeline 26742 -version 629'
[12:34:59]
[12:34:59] *------------------------------*
[12:34:59] Folding@Home Gromacs SMP Core
[12:34:59] Version 2.21 (May 10, 2010)
[12:34:59]
[12:34:59] Preparing to commence simulation
[12:34:59] - Assembly optimizations manually forced on.
[12:34:59] - Not checking prior termination.
[12:35:01] - Expanded 24839114 -> 30791309 (decompressed 123.9 percent)
[12:35:01] Called DecompressByteArray: compressed_data_size=24839114 data_size=30791309, decompressed_data_size=30791309 diff=0
[12:35:01] - Digital signature verified
[12:35:01]
[12:35:01] Project: 2684 (Run 0, Clone 6, Gen 4)
[12:35:01]
[12:35:01] Assembly optimizations on if available.
[12:35:01] Entering M.D.
[12:35:13] Completed 0 out of 250000 steps  (0%)
[13:12:34] Completed 2500 out of 250000 steps  (1%)
[13:49:51] Completed 5000 out of 250000 steps  (2%)
[14:27:07] Completed 7500 out of 250000 steps  (3%)
[15:04:24] Completed 10000 out of 250000 steps  (4%)
[15:41:45] Completed 12500 out of 250000 steps  (5%)
[16:18:54] Completed 15000 out of 250000 steps  (6%)
[16:56:12] Completed 17500 out of 250000 steps  (7%)
[17:33:23] Completed 20000 out of 250000 steps  (8%)
[18:10:35] Completed 22500 out of 250000 steps  (9%)
[18:32:37] - Autosending finished units... [June 6 18:32:37 UTC]
[18:32:37] Trying to send all finished work units
[18:32:37] + No unsent completed units remaining.
[18:32:37] - Autosend completed
[18:47:51] Completed 25000 out of 250000 steps  (10%)
[19:25:07] Completed 27500 out of 250000 steps  (11%)
[20:02:17] Completed 30000 out of 250000 steps  (12%)
[20:39:33] Completed 32500 out of 250000 steps  (13%)
[21:16:41] Completed 35000 out of 250000 steps  (14%)
[21:54:01] Completed 37500 out of 250000 steps  (15%)
[22:31:14] Completed 40000 out of 250000 steps  (16%)
[23:08:35] Completed 42500 out of 250000 steps  (17%)
[23:45:38] Completed 45000 out of 250000 steps  (18%)
[00:22:48] Completed 47500 out of 250000 steps  (19%)
[00:32:37] - Autosending finished units... [June 7 00:32:37 UTC]
[00:32:37] Trying to send all finished work units
[00:32:37] + No unsent completed units remaining.
[00:32:37] - Autosend completed
[01:00:01] Completed 50000 out of 250000 steps  (20%)
[01:37:16] Completed 52500 out of 250000 steps  (21%)
[02:14:21] Completed 55000 out of 250000 steps  (22%)
[02:51:27] Completed 57500 out of 250000 steps  (23%)
[03:28:41] Completed 60000 out of 250000 steps  (24%)
[04:05:55] Completed 62500 out of 250000 steps  (25%)
[04:42:59] Completed 65000 out of 250000 steps  (26%)
[05:19:58] Completed 67500 out of 250000 steps  (27%)
[05:57:06] Completed 70000 out of 250000 steps  (28%)
[06:32:37] - Autosending finished units... [June 7 06:32:37 UTC]
[06:32:37] Trying to send all finished work units
[06:32:37] + No unsent completed units remaining.
[06:32:37] - Autosend completed
[06:34:19] Completed 72500 out of 250000 steps  (29%)
[07:11:33] Completed 75000 out of 250000 steps  (30%)
[07:29:03] CoreStatus = 8B (139)
[07:29:03] Client-core communications error: ERROR 0x8b
[07:29:03] Deleting current work unit & continuing...
[07:29:16] Trying to send all finished work units
[07:29:16] + No unsent completed units remaining.
[07:29:16] - Preparing to get new work unit...
[07:29:16] Cleaning up work directory
[07:29:16] + Attempting to get work packet
[07:29:16] Passkey found
[07:29:16] - Will indicate memory of 5550 MB
[07:29:16] - Connecting to assignment server
[07:29:16] Connecting to http://assign.stanford.edu:8080/
[07:29:17] Posted data.
[07:29:17] Initial: 43AB; - Successful: assigned to (171.67.108.22).
[07:29:17] + News From Folding@Home: Welcome to Folding@Home
[07:29:17] Loaded queue successfully.
[07:29:17] Connecting to http://171.67.108.22:8080/
[07:29:30] Posted data.
[07:29:30] Initial: 0000; - Receiving payload (expected size: 24839626)
[07:30:13] - Downloaded at ~564 kB/s
[07:30:13] - Averaged speed for that direction ~564 kB/s
[07:30:13] + Received work.
[07:30:13] + Closed connections
[07:30:18]
[07:30:18] + Processing work unit
[07:30:18] Core required: FahCore_a3.exe
[07:30:18] Core found.
[07:30:18] Working on queue slot 03 [June 7 07:30:18 UTC]
[07:30:18] + Working ...
[07:30:18] - Calling './FahCore_a3.exe -dir work/ -nice 19 -suffix 03 -np 12 -checkpoint 10 -forceasm -verbose -lifeline 26742 -version 629'
[07:30:18]
[07:30:18] *------------------------------*
[07:30:18] Folding@Home Gromacs SMP Core
[07:30:18] Version 2.21 (May 10, 2010)
[07:30:18]
[07:30:18] Preparing to commence simulation
[07:30:18] - Assembly optimizations manually forced on.
[07:30:18] - Not checking prior termination.
[07:30:20] - Expanded 24839114 -> 30791309 (decompressed 123.9 percent)
[07:30:20] Called DecompressByteArray: compressed_data_size=24839114 data_size=30791309, decompressed_data_size=30791309 diff=0
[07:30:20] - Digital signature verified
[07:30:20]
[07:30:20] Project: 2684 (Run 0, Clone 6, Gen 4)
[07:30:20]
[07:30:20] Assembly optimizations on if available.
[07:30:20] Entering M.D.
[07:30:31] Completed 0 out of 250000 steps  (0%)
[08:07:48] Completed 2500 out of 250000 steps  (1%)
[08:45:09] Completed 5000 out of 250000 steps  (2%)
[09:22:34] Completed 7500 out of 250000 steps  (3%)
[09:59:44] Completed 10000 out of 250000 steps  (4%)
[10:36:57] Completed 12500 out of 250000 steps  (5%)
[11:14:10] Completed 15000 out of 250000 steps  (6%)
[11:51:33] Completed 17500 out of 250000 steps  (7%)
[12:28:49] Completed 20000 out of 250000 steps  (8%)
[12:32:37] - Autosending finished units... [June 7 12:32:37 UTC]
[13:06:05] Completed 22500 out of 250000 steps  (9%)
[13:43:25] Completed 25000 out of 250000 steps  (10%)
[14:20:41] Completed 27500 out of 250000 steps  (11%)
[14:57:56] Completed 30000 out of 250000 steps  (12%)
[15:35:08] Completed 32500 out of 250000 steps  (13%)
[16:12:20] Completed 35000 out of 250000 steps  (14%)
[16:49:28] Completed 37500 out of 250000 steps  (15%)
[17:26:40] Completed 40000 out of 250000 steps  (16%)
[18:03:51] Completed 42500 out of 250000 steps  (17%)
[18:32:37] - Autosending finished units... [June 7 18:32:37 UTC]
[18:41:10] Completed 45000 out of 250000 steps  (18%)
[19:18:28] Completed 47500 out of 250000 steps  (19%)
[19:55:34] Completed 50000 out of 250000 steps  (20%)
[20:32:56] Completed 52500 out of 250000 steps  (21%)
[21:10:04] Completed 55000 out of 250000 steps  (22%)
[21:47:22] Completed 57500 out of 250000 steps  (23%)
[22:24:36] Completed 60000 out of 250000 steps  (24%)
[22:56:06] CoreStatus = 8B (139)
[22:56:06] Client-core communications error: ERROR 0x8b
[22:56:06] Deleting current work unit & continuing...
[22:56:20] Trying to send all finished work units
[22:56:20] + No unsent completed units remaining.
[22:56:20] - Preparing to get new work unit...
[22:56:20] Cleaning up work directory
[22:56:20] + Attempting to get work packet
[22:56:20] Passkey found
[22:56:20] - Will indicate memory of 5550 MB
[22:56:20] - Connecting to assignment server
[22:56:20] Connecting to http://assign.stanford.edu:8080/
[22:56:21] Posted data.
[22:56:21] Initial: 43AB; - Successful: assigned to (171.67.108.22).
[22:56:21] + News From Folding@Home: Welcome to Folding@Home
[22:56:21] Loaded queue successfully.
[22:56:21] Connecting to http://171.67.108.22:8080/
[22:56:33] Posted data.
[22:56:33] Initial: 0000; - Receiving payload (expected size: 24839626)
[22:57:15] - Downloaded at ~577 kB/s
[22:57:15] - Averaged speed for that direction ~567 kB/s
[22:57:15] + Received work.
[22:57:16] + Closed connections
[22:57:21]
[22:57:21] + Processing work unit
[22:57:21] Core required: FahCore_a3.exe
[22:57:21] Core found.
[22:57:21] Working on queue slot 04 [June 7 22:57:21 UTC]
[22:57:21] + Working ...
[22:57:21] - Calling './FahCore_a3.exe -dir work/ -nice 19 -suffix 04 -np 12 -checkpoint 10 -forceasm -verbose -lifeline 26742 -version 629'
[22:57:21]
[22:57:21] *------------------------------*
[22:57:21] Folding@Home Gromacs SMP Core
[22:57:21] Version 2.21 (May 10, 2010)
[22:57:21]
[22:57:21] Preparing to commence simulation
[22:57:21] - Assembly optimizations manually forced on.
[22:57:21] - Not checking prior termination.
[22:57:23] - Expanded 24839114 -> 30791309 (decompressed 123.9 percent)
[22:57:23] Called DecompressByteArray: compressed_data_size=24839114 data_size=30791309, decompressed_data_size=30791309 diff=0
[22:57:23] - Digital signature verified
[22:57:23]
[22:57:23] Project: 2684 (Run 0, Clone 6, Gen 4)
[22:57:23]
[22:57:23] Assembly optimizations on if available.
[22:57:23] Entering M.D.
[22:57:34] Completed 0 out of 250000 steps  (0%)
[23:00:30] mdrun returned 255
[23:00:30] Going to send back what have done -- stepsTotalG=250000
[23:00:30] Work fraction=5263.1562 steps=250000.
[23:00:34] logfile size=12572 infoLength=12572 edr=25 trr=1
[23:00:34] logfile size: 12572 info=12572 bed=25 hdr=1
[23:00:34] - Writing 13110 bytes of core data to disk...
[23:00:35]   ... Done.
[23:00:37]
[23:00:37] Folding@home Core Shutdown: EARLY_UNIT_END
[23:00:37] CoreStatus = 72 (114)
[23:00:37] Sending work to server
[23:00:37] Project: 2684 (Run 0, Clone 6, Gen 4)
[23:00:37] + Attempting to send results [June 7 23:00:37 UTC]
[23:00:37] - Reading file work/wuresults_04.dat from core
[23:00:37]   (Read 13110 bytes from disk)
[23:00:37] Connecting to http://171.67.108.22:8080/
[23:00:39] Posted data.
[23:00:39] Initial: 0000; - Uploaded at ~6 kB/s
[23:00:39] - Averaged speed for that direction ~6 kB/s
[23:00:39] + Results successfully sent
[23:00:39] Thank you for your contribution to Folding@Home.
[23:00:39] Trying to send all finished work units
[23:00:39] + No unsent completed units remaining.
[23:00:39] - Preparing to get new work unit...
[23:00:39] Cleaning up work directory
[23:00:39] + Attempting to get work packet
[23:00:39] Passkey found
[23:00:39] - Will indicate memory of 5550 MB
[23:00:39] - Connecting to assignment server
[23:00:39] Connecting to http://assign.stanford.edu:8080/
[23:00:40] Posted data.
[23:00:40] Initial: 43AB; - Successful: assigned to (171.67.108.22).
[23:00:40] + News From Folding@Home: Welcome to Folding@Home
[23:00:41] Loaded queue successfully.
[23:00:41] Connecting to http://171.67.108.22:8080/
[23:00:52] Posted data.
[23:00:52] Initial: 0000; - Receiving payload (expected size: 24839626)
[23:01:37] - Downloaded at ~539 kB/s
[23:01:37] - Averaged speed for that direction ~561 kB/s
[23:01:37] + Received work.
[23:01:37] Trying to send all finished work units
[23:01:37] + No unsent completed units remaining.
[23:01:37] + Closed connections
[23:01:42]
[23:01:42] + Processing work unit
[23:01:42] Core required: FahCore_a3.exe
[23:01:42] Core found.
[23:01:42] Working on queue slot 05 [June 7 23:01:42 UTC]
[23:01:42] + Working ...
[23:01:42] - Calling './FahCore_a3.exe -dir work/ -nice 19 -suffix 05 -np 12 -checkpoint 10 -forceasm -verbose -lifeline 26742 -version 629'
[23:01:42]
[23:01:42] *------------------------------*
[23:01:42] Folding@Home Gromacs SMP Core
[23:01:42] Version 2.21 (May 10, 2010)
[23:01:42]
[23:01:42] Preparing to commence simulation
[23:01:42] - Assembly optimizations manually forced on.
[23:01:42] - Not checking prior termination.
[23:01:44] - Expanded 24839114 -> 30791309 (decompressed 123.9 percent)
[23:01:44] Called DecompressByteArray: compressed_data_size=24839114 data_size=30791309, decompressed_data_size=30791309 diff=0
[23:01:44] - Digital signature verified
[23:01:44]
[23:01:44] Project: 2684 (Run 0, Clone 6, Gen 4)
[23:01:44]
[23:01:44] Assembly optimizations on if available.
[23:01:44] Entering M.D.
[23:01:55] Completed 0 out of 250000 steps  (0%)
[23:01:57] mdrun returned 255
[23:01:57] Going to send back what have done -- stepsTotalG=250000
[23:01:57] Work fraction=17179869184.0000 steps=250000.
[23:02:01] logfile size=12572 infoLength=12572 edr=25 trr=1
[23:02:01] logfile size: 12572 info=12572 bed=25 hdr=1
[23:02:01] - Writing 13110 bytes of core data to disk...
[23:02:02]   ... Done.
[23:02:05]
[23:02:05] Folding@home Core Shutdown: UNSTABLE_MACHINE
[23:02:05] CoreStatus = 7A (122)
[23:02:05] Sending work to server
[23:02:05] Project: 2684 (Run 0, Clone 6, Gen 4)
[23:02:05] + Attempting to send results [June 7 23:02:05 UTC]
[23:02:05] - Reading file work/wuresults_05.dat from core
[23:02:05]   (Read 13110 bytes from disk)
[23:02:05] Connecting to http://171.67.108.22:8080/
[23:02:06] Posted data.
[23:02:06] Initial: 0000; - Uploaded at ~6 kB/s
[23:02:07] - Averaged speed for that direction ~6 kB/s
[23:02:07] + Results successfully sent
[23:02:07] Thank you for your contribution to Folding@Home.
[23:02:07] Trying to send all finished work units
[23:02:07] + No unsent completed units remaining.
[23:02:07] - Preparing to get new work unit...
[23:02:07] Cleaning up work directory
[23:02:07] + Attempting to get work packet
[23:02:07] Passkey found
[23:02:07] - Will indicate memory of 5550 MB
[23:02:07] - Connecting to assignment server
[23:02:07] Connecting to http://assign.stanford.edu:8080/
[23:02:08] Posted data.
[23:02:08] Initial: 43AB; - Successful: assigned to (171.67.108.22).
[23:02:08] + News From Folding@Home: Welcome to Folding@Home
[23:02:08] Loaded queue successfully.
[23:02:08] Connecting to http://171.67.108.22:8080/
[23:02:17] Posted data.
[23:02:17] Initial: 0000; - Receiving payload (expected size: 24839626)
[23:03:01] - Downloaded at ~551 kB/s
[23:03:01] - Averaged speed for that direction ~559 kB/s
[23:03:01] + Received work.
[23:03:01] Trying to send all finished work units
[23:03:01] + No unsent completed units remaining.
[23:03:01] + Closed connections
[23:03:06]
[23:03:06] + Processing work unit
[23:03:06] Core required: FahCore_a3.exe
[23:03:06] Core found.
[23:03:06] Working on queue slot 06 [June 7 23:03:06 UTC]
[23:03:06] + Working ...
[23:03:06] - Calling './FahCore_a3.exe -dir work/ -nice 19 -suffix 06 -np 12 -checkpoint 10 -forceasm -verbose -lifeline 26742 -version 629'
[23:03:07]
[23:03:07] *------------------------------*
[23:03:07] Folding@Home Gromacs SMP Core
[23:03:07] Version 2.21 (May 10, 2010)
[23:03:07]
[23:03:07] Preparing to commence simulation
[23:03:07] - Assembly optimizations manually forced on.
[23:03:07] - Not checking prior termination.
[23:03:09] - Expanded 24839114 -> 30791309 (decompressed 123.9 percent)
[23:03:09] Called DecompressByteArray: compressed_data_size=24839114 data_size=30791309, decompressed_data_size=30791309 diff=0
[23:03:09] - Digital signature verified
[23:03:09]
[23:03:09] Project: 2684 (Run 0, Clone 6, Gen 4)
[23:03:09]
[23:03:09] Assembly optimizations on if available.
[23:03:09] Entering M.D.
[23:03:20] Completed 0 out of 250000 steps  (0%)
[23:06:25] mdrun returned 255
[23:06:25] Going to send back what have done -- stepsTotalG=250000
[23:06:25] Work fraction=4878.0474 steps=250000.
[23:06:29] logfile size=12572 infoLength=12572 edr=25 trr=1
[23:06:29] logfile size: 12572 info=12572 bed=25 hdr=1
[23:06:29] - Writing 13110 bytes of core data to disk...
[23:06:30]   ... Done.
[23:06:33]
[23:06:33] Folding@home Core Shutdown: EARLY_UNIT_END
[23:06:33] CoreStatus = 72 (114)
[23:06:33] Sending work to server
[23:06:33] Project: 2684 (Run 0, Clone 6, Gen 4)
[23:06:33] + Attempting to send results [June 7 23:06:33 UTC]
[23:06:33] - Reading file work/wuresults_06.dat from core
[23:06:33]   (Read 13110 bytes from disk)
[23:06:33] Connecting to http://171.67.108.22:8080/
[23:06:34] Posted data.
[23:06:34] Initial: 0000; - Uploaded at ~13 kB/s
[23:06:34] - Averaged speed for that direction ~8 kB/s
[23:06:34] + Results successfully sent
[23:06:34] Thank you for your contribution to Folding@Home.
[23:06:34] Trying to send all finished work units
[23:06:34] + No unsent completed units remaining.
[23:06:34] - Preparing to get new work unit...
[23:06:34] Cleaning up work directory
[23:06:34] + Attempting to get work packet
[23:06:34] Passkey found
[23:06:34] - Will indicate memory of 5550 MB
[23:06:34] - Connecting to assignment server
[23:06:34] Connecting to http://assign.stanford.edu:8080/
[23:06:35] Posted data.
[23:06:35] Initial: 43AB; - Successful: assigned to (171.67.108.22).
[23:06:35] + News From Folding@Home: Welcome to Folding@Home
[23:06:36] Loaded queue successfully.
[23:06:36] Connecting to http://171.67.108.22:8080/
[23:06:44] Posted data.
[23:06:44] Initial: 0000; - Receiving payload (expected size: 24839626)
[23:07:29] - Downloaded at ~539 kB/s
[23:07:29] - Averaged speed for that direction ~555 kB/s
[23:07:29] + Received work.
[23:07:29] Trying to send all finished work units
[23:07:29] + No unsent completed units remaining.
[23:07:29] + Closed connections
[23:07:34]
[23:07:34] + Processing work unit
[23:07:34] Core required: FahCore_a3.exe
[23:07:34] Core found.
[23:07:34] Working on queue slot 07 [June 7 23:07:34 UTC]
[23:07:34] + Working ...
[23:07:34] - Calling './FahCore_a3.exe -dir work/ -nice 19 -suffix 07 -np 12 -checkpoint 10 -forceasm -verbose -lifeline 26742 -version 629'
[23:07:34]
[23:07:34] *------------------------------*
[23:07:34] Folding@Home Gromacs SMP Core
[23:07:34] Version 2.21 (May 10, 2010)
[23:07:34]
[23:07:34] Preparing to commence simulation
[23:07:34] - Assembly optimizations manually forced on.
[23:07:34] - Not checking prior termination.
[23:07:36] - Expanded 24839114 -> 30791309 (decompressed 123.9 percent)
[23:07:36] Called DecompressByteArray: compressed_data_size=24839114 data_size=30791309, decompressed_data_size=30791309 diff=0
[23:07:36] - Digital signature verified
[23:07:36]
[23:07:36] Project: 2684 (Run 0, Clone 6, Gen 4)
[23:07:36]
[23:07:36] Assembly optimizations on if available.
[23:07:36] Entering M.D.
[23:07:48] Completed 0 out of 250000 steps  (0%)
[23:10:40] mdrun returned 255
[23:10:40] Going to send back what have done -- stepsTotalG=250000
[23:10:40] Work fraction=5263.1562 steps=250000.
[23:10:44] logfile size=12572 infoLength=12572 edr=25 trr=1
[23:10:44] logfile size: 12572 info=12572 bed=25 hdr=1
[23:10:44] - Writing 13110 bytes of core data to disk...
[23:10:45]   ... Done.
[23:10:47]
[23:10:47] Folding@home Core Shutdown: EARLY_UNIT_END
[23:10:47] CoreStatus = 72 (114)
[23:10:47] Sending work to server
[23:10:47] Project: 2684 (Run 0, Clone 6, Gen 4)
[23:10:47] + Attempting to send results [June 7 23:10:47 UTC]
[23:10:47] - Reading file work/wuresults_07.dat from core
[23:10:47]   (Read 13110 bytes from disk)
[23:10:47] Connecting to http://171.67.108.22:8080/
[23:10:48] Posted data.
[23:10:49] Initial: 0000; - Uploaded at ~6 kB/s
[23:10:49] - Averaged speed for that direction ~8 kB/s
[23:10:49] + Results successfully sent
[23:10:49] Thank you for your contribution to Folding@Home.
[23:10:49] Trying to send all finished work units
[23:10:49] + No unsent completed units remaining.
[23:10:49] - Preparing to get new work unit...
[23:10:49] Cleaning up work directory
[23:10:49] + Attempting to get work packet
[23:10:49] Passkey found
[23:10:49] - Will indicate memory of 5550 MB
[23:10:49] - Connecting to assignment server
[23:10:49] Connecting to http://assign.stanford.edu:8080/
[23:10:50] Posted data.
[23:10:50] Initial: 43AB; - Successful: assigned to (171.67.108.22).
[23:10:50] + News From Folding@Home: Welcome to Folding@Home
[23:10:51] Loaded queue successfully.
[23:10:51] Connecting to http://171.67.108.22:8080/
[23:10:59] Posted data.
[23:10:59] Initial: 0000; - Receiving payload (expected size: 24839626)
[23:11:46] - Downloaded at ~516 kB/s
[23:11:46] - Averaged speed for that direction ~547 kB/s
[23:11:46] + Received work.
[23:11:46] Trying to send all finished work units
[23:11:46] + No unsent completed units remaining.
[23:11:46] + Closed connections
[23:11:51]
[23:11:51] + Processing work unit
[23:11:51] Core required: FahCore_a3.exe
[23:11:51] Core found.
[23:11:51] Working on queue slot 08 [June 7 23:11:51 UTC]
[23:11:51] + Working ...
[23:11:51] - Calling './FahCore_a3.exe -dir work/ -nice 19 -suffix 08 -np 12 -checkpoint 10 -forceasm -verbose -lifeline 26742 -version 629'
[23:11:51]
[23:11:51] *------------------------------*
[23:11:51] Folding@Home Gromacs SMP Core
[23:11:51] Version 2.21 (May 10, 2010)
[23:11:51]
[23:11:51] Preparing to commence simulation
[23:11:51] - Assembly optimizations manually forced on.
[23:11:51] - Not checking prior termination.
[23:11:53] - Expanded 24839114 -> 30791309 (decompressed 123.9 percent)
[23:11:53] Called DecompressByteArray: compressed_data_size=24839114 data_size=30791309, decompressed_data_size=30791309 diff=0
[23:11:53] - Digital signature verified
[23:11:53]
[23:11:53] Project: 2684 (Run 0, Clone 6, Gen 4)
[23:11:53]
[23:11:53] Assembly optimizations on if available.
[23:11:53] Entering M.D.
[23:12:04] Completed 0 out of 250000 steps  (0%)
[23:12:07] mdrun returned 255
[23:12:07] Going to send back what have done -- stepsTotalG=250000
[23:12:07] Work fraction=999941.8125 steps=250000.
[23:12:11] logfile size=12572 infoLength=12572 edr=25 trr=1
[23:12:11] logfile size: 12572 info=12572 bed=25 hdr=1
[23:12:11] - Writing 13110 bytes of core data to disk...
[23:12:12]   ... Done.
[23:12:14]
[23:12:14] Folding@home Core Shutdown: EARLY_UNIT_END
[23:12:14] CoreStatus = 72 (114)
[23:12:14] Sending work to server
[23:12:14] Project: 2684 (Run 0, Clone 6, Gen 4)
[23:12:14] + Attempting to send results [June 7 23:12:14 UTC]
[23:12:14] - Reading file work/wuresults_08.dat from core
[23:12:14]   (Read 13110 bytes from disk)
[23:12:14] Connecting to http://171.67.108.22:8080/
[23:12:15] Posted data.
[23:12:15] Initial: 0000; - Uploaded at ~6 kB/s
[23:12:16] - Averaged speed for that direction ~8 kB/s
[23:12:16] + Results successfully sent
[23:12:16] Thank you for your contribution to Folding@Home.
[23:12:16] Trying to send all finished work units
[23:12:16] + No unsent completed units remaining.
[23:12:16] - Preparing to get new work unit...
[23:12:16] Cleaning up work directory
[23:12:16] + Attempting to get work packet
[23:12:16] Passkey found
[23:12:16] - Will indicate memory of 5550 MB
[23:12:16] - Connecting to assignment server
[23:12:16] Connecting to http://assign.stanford.edu:8080/
[23:12:17] Posted data.
[23:12:17] Initial: 43AB; - Successful: assigned to (171.67.108.22).
[23:12:17] + News From Folding@Home: Welcome to Folding@Home
[23:12:18] Loaded queue successfully.
[23:12:18] Connecting to http://171.67.108.22:8080/
[23:12:26] Posted data.
[23:12:26] Initial: 0000; - Receiving payload (expected size: 24839626)
[23:13:11] - Downloaded at ~539 kB/s
[23:13:11] - Averaged speed for that direction ~545 kB/s
[23:13:11] + Received work.
[23:13:11] Trying to send all finished work units
[23:13:11] + No unsent completed units remaining.
[23:13:11] + Closed connections
[23:13:16]
[23:13:16] + Processing work unit
[23:13:16] Core required: FahCore_a3.exe
[23:13:16] Core found.
[23:13:16] Working on queue slot 09 [June 7 23:13:16 UTC]
[23:13:16] + Working ...
[23:13:16] - Calling './FahCore_a3.exe -dir work/ -nice 19 -suffix 09 -np 12 -checkpoint 10 -forceasm -verbose -lifeline 26742 -version 629'
[23:13:17]
[23:13:17] *------------------------------*
[23:13:17] Folding@Home Gromacs SMP Core
[23:13:17] Version 2.21 (May 10, 2010)
[23:13:17]
[23:13:17] Preparing to commence simulation
[23:13:17] - Assembly optimizations manually forced on.
[23:13:17] - Not checking prior termination.
[23:13:19] - Expanded 24839114 -> 30791309 (decompressed 123.9 percent)
[23:13:19] Called DecompressByteArray: compressed_data_size=24839114 data_size=30791309, decompressed_data_size=30791309 diff=0
[23:13:19] - Digital signature verified
[23:13:19]
[23:13:19] Project: 2684 (Run 0, Clone 6, Gen 4)
[23:13:19]
[23:13:19] Assembly optimizations on if available.
[23:13:19] Entering M.D.
[23:13:30] Completed 0 out of 250000 steps  (0%)
[23:13:32] CoreStatus = 8B (139)
[23:13:32] Client-core communications error: ERROR 0x8b
[23:13:32] Deleting current work unit & continuing...
[23:13:44] Trying to send all finished work units
[23:13:44] + No unsent completed units remaining.
[23:13:44] - Preparing to get new work unit...
[23:13:44] Cleaning up work directory
[23:13:44] + Attempting to get work packet
[23:13:44] Passkey found
[23:13:44] - Will indicate memory of 5550 MB
[23:13:44] - Connecting to assignment server
[23:13:44] Connecting to http://assign.stanford.edu:8080/
[23:13:45] Posted data.
[23:13:45] Initial: 43AB; - Successful: assigned to (171.67.108.22).
[23:13:45] + News From Folding@Home: Welcome to Folding@Home
[23:13:46] Loaded queue successfully.
[23:13:46] Connecting to http://171.67.108.22:8080/
[23:13:57] Posted data.
[23:13:57] Initial: 0000; - Receiving payload (expected size: 24839626)
[23:14:41] - Downloaded at ~551 kB/s
[23:14:41] - Averaged speed for that direction ~547 kB/s
[23:14:41] + Received work.
[23:14:41] + Closed connections
[23:14:46]
[23:14:46] + Processing work unit
[23:14:46] Core required: FahCore_a3.exe
[23:14:46] Core found.
[23:14:46] Working on queue slot 00 [June 7 23:14:46 UTC]
[23:14:46] + Working ...
[23:14:46] - Calling './FahCore_a3.exe -dir work/ -nice 19 -suffix 00 -np 12 -checkpoint 10 -forceasm -verbose -lifeline 26742 -version 629'
[23:14:46]
[23:14:46] *------------------------------*
[23:14:46] Folding@Home Gromacs SMP Core
[23:14:46] Version 2.21 (May 10, 2010)
[23:14:46]
[23:14:46] Preparing to commence simulation
[23:14:46] - Assembly optimizations manually forced on.
[23:14:46] - Not checking prior termination.
[23:14:48] - Expanded 24839114 -> 30791309 (decompressed 123.9 percent)
[23:14:48] Called DecompressByteArray: compressed_data_size=24839114 data_size=30791309, decompressed_data_size=30791309 diff=0
[23:14:48] - Digital signature verified
[23:14:48]
[23:14:48] Project: 2684 (Run 0, Clone 6, Gen 4)
[23:14:48]
[23:14:48] Assembly optimizations on if available.
[23:14:48] Entering M.D.
[23:15:00] Completed 0 out of 250000 steps  (0%)
[23:17:51] CoreStatus = 8B (139)
[23:17:51] Client-core communications error: ERROR 0x8b
[23:17:51] Deleting current work unit & continuing...
[23:18:03] Trying to send all finished work units
[23:18:03] + No unsent completed units remaining.
[23:18:03] - Preparing to get new work unit...
[23:18:03] Cleaning up work directory
[23:18:03] + Attempting to get work packet
[23:18:03] Passkey found
[23:18:03] - Will indicate memory of 5550 MB
[23:18:03] - Connecting to assignment server
[23:18:03] Connecting to http://assign.stanford.edu:8080/
[23:18:23] - Could not CosmHTTPOpen
[23:18:23] + Could not connect to Assignment Server
[23:18:23] Connecting to http://assign2.stanford.edu:80/
[23:18:23] + Could not connect to Assignment Server 2
[23:18:23] + Couldn't get work instructions.
[23:18:23] - Attempt #1  to get work failed, and no other work to do.
[23:18:29] + Attempting to get work packet
[23:18:29] Passkey found
[23:18:29] - Will indicate memory of 5550 MB
[23:18:29] - Connecting to assignment server
[23:18:29] Connecting to http://assign.stanford.edu:8080/
[23:18:29] - Could not CosmHTTPOpen
[23:18:29] + Could not connect to Assignment Server
[23:18:29] Connecting to http://assign2.stanford.edu:80/
[23:18:29] + Could not connect to Assignment Server 2
[23:18:29] + Couldn't get work instructions.
[23:18:29] - Attempt #2  to get work failed, and no other work to do.
[23:18:46] + Attempting to get work packet
[23:18:46] Passkey found
[23:18:46] - Will indicate memory of 5550 MB
[23:18:46] - Connecting to assignment server
[23:18:46] Connecting to http://assign.stanford.edu:8080/
[23:18:46] - Could not CosmHTTPOpen
[23:18:46] + Could not connect to Assignment Server
[23:18:46] Connecting to http://assign2.stanford.edu:80/
[23:18:46] + Could not connect to Assignment Server 2
[23:18:46] + Couldn't get work instructions.
[23:18:46] - Attempt #3  to get work failed, and no other work to do.
[23:19:20] + Attempting to get work packet
[23:19:20] Passkey found
[23:19:20] - Will indicate memory of 5550 MB
[23:19:20] - Connecting to assignment server
[23:19:20] Connecting to http://assign.stanford.edu:8080/
[23:19:20] - Could not CosmHTTPOpen
[23:19:20] + Could not connect to Assignment Server
[23:19:20] Connecting to http://assign2.stanford.edu:80/
[23:19:20] + Could not connect to Assignment Server 2
[23:19:20] + Couldn't get work instructions.
[23:19:20] - Attempt #4  to get work failed, and no other work to do.
[23:20:08] + Attempting to get work packet
[23:20:08] Passkey found
[23:20:08] - Will indicate memory of 5550 MB
[23:20:08] - Connecting to assignment server
[23:20:08] Connecting to http://assign.stanford.edu:8080/
[23:20:08] - Could not CosmHTTPOpen
[23:20:08] + Could not connect to Assignment Server
[23:20:08] Connecting to http://assign2.stanford.edu:80/
[23:20:08] + Could not connect to Assignment Server 2
[23:20:08] + Couldn't get work instructions.
[23:20:08] - Attempt #5  to get work failed, and no other work to do.
[23:21:29] + Attempting to get work packet
[23:21:29] Passkey found
[23:21:29] - Will indicate memory of 5550 MB
[23:21:29] - Connecting to assignment server
[23:21:29] Connecting to http://assign.stanford.edu:8080/
[23:21:29] - Could not CosmHTTPOpen
[23:21:29] + Could not connect to Assignment Server
[23:21:29] Connecting to http://assign2.stanford.edu:80/
[23:21:29] + Could not connect to Assignment Server 2
[23:21:29] + Couldn't get work instructions.
[23:21:29] - Attempt #6  to get work failed, and no other work to do.
[23:24:19] + Attempting to get work packet
[23:24:19] Passkey found
[23:24:19] - Will indicate memory of 5550 MB
[23:24:19] - Connecting to assignment server
[23:24:19] Connecting to http://assign.stanford.edu:8080/
[23:24:19] - Could not CosmHTTPOpen
[23:24:19] + Could not connect to Assignment Server
[23:24:19] Connecting to http://assign2.stanford.edu:80/
[23:24:19] + Could not connect to Assignment Server 2
[23:24:19] + Couldn't get work instructions.
[23:24:19] - Attempt #7  to get work failed, and no other work to do.
[23:29:53] + Attempting to get work packet
[23:29:53] Passkey found
[23:29:53] - Will indicate memory of 5550 MB
[23:29:53] - Connecting to assignment server
[23:29:53] Connecting to http://assign.stanford.edu:8080/
[23:29:55] Posted data.
[23:29:55] Initial: 43AB; - Successful: assigned to (171.67.108.22).
[23:29:55] + News From Folding@Home: Welcome to Folding@Home
[23:29:55] Loaded queue successfully.
[23:29:55] Connecting to http://171.67.108.22:8080/
[23:29:55] Initial: 0000; - Error: Bad packet type from server, expected work assignment
[23:29:56] - Attempt #8  to get work failed, and no other work to do.
[23:40:49] + Attempting to get work packet
[23:40:49] Passkey found
[23:40:49] - Will indicate memory of 5550 MB
[23:40:49] - Connecting to assignment server
[23:40:49] Connecting to http://assign.stanford.edu:8080/
[23:40:50] Posted data.
[23:40:50] Initial: 43AB; - Successful: assigned to (171.67.108.22).
[23:40:50] + News From Folding@Home: Welcome to Folding@Home
[23:40:50] Loaded queue successfully.
[23:40:50] Connecting to http://171.67.108.22:8080/
[23:41:01] Posted data.
[23:41:01] Initial: 0000; - Receiving payload (expected size: 24839626)
[23:41:44] - Downloaded at ~564 kB/s
[23:41:44] - Averaged speed for that direction ~550 kB/s
[23:41:44] + Received work.
[23:41:44] + Closed connections
[23:41:49]
[23:41:49] + Processing work unit
[23:41:49] Core required: FahCore_a3.exe
[23:41:49] Core found.
[23:41:49] Working on queue slot 01 [June 7 23:41:49 UTC]
[23:41:49] + Working ...
[23:41:49] - Calling './FahCore_a3.exe -dir work/ -nice 19 -suffix 01 -np 12 -checkpoint 10 -forceasm -verbose -lifeline 26742 -version 629'
[23:41:49]
[23:41:49] *------------------------------*
[23:41:49] Folding@Home Gromacs SMP Core
[23:41:49] Version 2.21 (May 10, 2010)
[23:41:49]
[23:41:49] Preparing to commence simulation
[23:41:49] - Assembly optimizations manually forced on.
[23:41:49] - Not checking prior termination.
[23:41:51] - Expanded 24839114 -> 30791309 (decompressed 123.9 percent)
[23:41:51] Called DecompressByteArray: compressed_data_size=24839114 data_size=30791309, decompressed_data_size=30791309 diff=0
[23:41:51] - Digital signature verified
[23:41:51]
[23:41:51] Project: 2684 (Run 0, Clone 6, Gen 4)
[23:41:51]
[23:41:51] Assembly optimizations on if available.
[23:41:51] Entering M.D.
[23:42:01] Completed 0 out of 250000 steps  (0%)
[00:19:14] Completed 2500 out of 250000 steps  (1%)
[00:32:37] - Autosending finished units... [June 8 00:32:37 UTC]
[00:56:28] Completed 5000 out of 250000 steps  (2%)
[01:33:46] Completed 7500 out of 250000 steps  (3%)
[02:10:58] Completed 10000 out of 250000 steps  (4%)
[02:48:07] Completed 12500 out of 250000 steps  (5%)
[03:25:19] Completed 15000 out of 250000 steps  (6%)
[04:02:29] Completed 17500 out of 250000 steps  (7%)
[04:39:41] Completed 20000 out of 250000 steps  (8%)
[05:16:50] Completed 22500 out of 250000 steps  (9%)
[05:54:03] Completed 25000 out of 250000 steps  (10%)
John_Weatherman
Re: Project 2684
Post by John_Weatherman »
Seems to be having a problem with the same WU 1st log Project: 2684 (Run 6, Clone 15, Gen 2) and 2nd log Project: 2684 (Run 0, Clone 6, Gen 4) downloaded again and again.
The CoreStatus = 8B (139) seems to be a Linux problem as it's appeared even on a Protomol single core WU.
Edit I'll re-phrase that, a problem that's Linux and/or hardware.
