When loaded this unit almost immediately crashes the Core and XP detects a fatal error and wishes to transfer info to MS. On closing this message system deletes unit, reloads it amd crashes again, etc, etc. Have now killed it off and moved onto a 6014. Can someone check this unit or mark it as a faulty one?
This pc has run 6040's ok in the past.
Thanks
Shunter
[02:17:40] Project: 6040 (Run 0, Clone 79, Gen 16)
[02:17:40]
[02:17:40] Assembly optimizations on if available.
[02:17:40] Entering M.D.
[02:17:48] Completed 0 out of 250000 steps (0%)
[02:41:31] - Autosending finished units... [May 30 02:41:31 UTC]
[02:41:31] Trying to send all finished work units
[02:41:31] + No unsent completed units remaining.
[02:41:31] - Autosend completed
[08:41:31] - Autosending finished units... [May 30 08:41:31 UTC]
[08:41:31] Trying to send all finished work units
[08:41:31] + No unsent completed units remaining.
[08:41:31] - Autosend completed
[08:45:10] CoreStatus = C0000029 (-1073741783)
[08:45:10] Client-core communications error: ERROR 0xc0000029
[08:45:10] Deleting current work unit & continuing...
[08:45:24] Trying to send all finished work units
[08:45:24] + No unsent completed units remaining.
[08:45:24] - Preparing to get new work unit...
[08:45:24] Cleaning up work directory
[08:45:25] + Attempting to get work packet
[08:45:25] Passkey found
[08:45:25] - Will indicate memory of 2046 MB
[08:45:25] - Connecting to assignment server
[08:45:25] Connecting to http://assign.stanford.edu:8080/
[08:45:28] Posted data.
[08:45:28] Initial: 40AB; - Successful: assigned to (171.64.65.54).
[08:45:28] + News From Folding@Home: Welcome to Folding@Home
[08:45:28] Loaded queue successfully.
[08:45:28] Connecting to http://171.64.65.54:8080/
[08:45:31] Posted data.
[08:45:31] Initial: 0000; - Receiving payload (expected size: 7880879)
[08:48:10] - Downloaded at ~48 kB/s
[08:48:10] - Averaged speed for that direction ~77 kB/s
[08:48:10] + Received work.
[08:48:10] + Closed connections
[08:48:15]
[08:48:15] + Processing work unit
[08:48:15] Core required: FahCore_a3.exe
[08:48:15] Core found.
[08:48:15] Working on queue slot 02 [May 30 08:48:15 UTC]
[08:48:15] + Working ...
[08:48:15] - Calling '.\FahCore_a3.exe -dir work/ -nice 19 -suffix 02 -np 4 -checkpoint 15 -forceasm -verbose -lifeline 3300 -version 629'
[08:48:15]
[08:48:15] *------------------------------*
[08:48:15] Folding@Home Gromacs SMP Core
[08:48:15] Version 2.19 (Mar 12, 2010)
[08:48:15]
[08:48:15] Preparing to commence simulation
[08:48:15] - Assembly optimizations manually forced on.
[08:48:15] - Not checking prior termination.
[08:48:17] - Expanded 7880367 -> 10126021 (decompressed 128.4 percent)
[08:48:17] Called DecompressByteArray: compressed_data_size=7880367 data_size=10126021, decompressed_data_size=10126021 diff=0
[08:48:17] - Digital signature verified
[08:48:17]
[08:48:17] Project: 6040 (Run 0, Clone 79, Gen 16)
[08:48:17]
[08:48:17] Assembly optimizations on if available.
[08:48:17] Entering M.D.
[08:48:26] Completed 0 out of 250000 steps (0%)
[08:48:55] CoreStatus = C0000029 (-1073741783)
[08:48:55] Client-core communications error: ERROR 0xc0000029
[08:48:55] Deleting current work unit & continuing...
[08:48:57] Killing all core threads
[08:48:57] Killing 2 cores
[08:48:57] Killing core 0
[08:48:57] Killing core 1
Folding@Home Client Shutdown at user request.
6040 (Run 0, Clone 79, Gen 16) Failed To Run
Re: 6040 (Run 0, Clone 79, Gen 16) Failed To Run
Since other people had troubles with it, I marked the WU as bad ...
