Project: 3050 (Run 1, Clone 48, Gen 3) stops at 8%
Jmarks
Hardware configuration: A) Gigabyte GA-X48-DQ6 Motherboard, 2gig ocz PC6400 memory, 1 80gig hard drive sata II, 1 250gig sata II hard drive, 256 ATI READON X1300PRO video card and a Intel Q9450 CPU. Win XP running SMP.
B) Gigabyte GA-X48-DQ6 Motherboard, 4gig Adata PC6400 memory, 1 250gig sata II hard drive, SAPPHIRE Radeon HD 2600XT 256MB video card and a Intel Q9450 CPU. Win XP running SMP.
C) Intel P35 mother board, 4 gig g gyles PC6400 memory, 1 250gig sata II hard drive, 256 ATI READON X1300PRO video card and a Intel E66000 CPU. Win XP running SMP.
Post by Jmarks »
FYI On one of my pcs p3050 r1 c48 g3 stops at 8% . 4 times so far.
msg is
9] Warning: long 1-4 interactions
[15:16:49] Gromacs cannot continue further.
[15:16:49] Going to send back what have done.
[15:16:49] logfile size: 28641
[15:16:49] - Writing 29177 bytes of core data to disk...
[15:16:49] ... Done.
[15:16:50] - Failed to delete work/wudata_04.dyn
[15:16:50] - Failed to delete work/wudata_04.bed
[15:16:50] - Failed to delete work/wudata_04.chk
[15:16:50] Warning: check for stray files
How do I make the pc get a different wu?
Jmarks
Stop client and get different WU?
Post by Jmarks »
I left a message in the wu thread about wu 3050 which will not go passed 8%.
What I need to Know is how to clear the WU and start another?
I looked at wiki and It say to use -delete as a last resort. If someone could explain exactally what I need to do it will make my day.
Thanks Jon
Flathead74
Re: p3050 r1 c48 g3 stops at 8%
Post by Flathead74 »
Dear Jmarks, when posting "Issues with a specific WU",
please simply copy and paste the WU info from the Fahlog.
It is much easier to post that way, and it also make searches easier (possible).
Thank you.
To delete a WU, first stop the client.
Restart the client with the "-delete x" flag, where x = the position in the of the WU in the queue.
The WU to be deleted can be found in your Fahlog by looking for "Working on Unit xx", or "-suffix xx", as the client starts.
Re: Project: 3050 (Run 1, Clone 48, Gen 3) stops at 8%
The delete flag may not be supported in the SMP client yet.
Delete the Work folder, and the queue.dat file. (Only as a last resort, and also assuming all other completed WUs are uploaded, else you lose those too.)
I also combined the two threads.
Jmarks
Post by Jmarks »
I had to delete the work folder and queue.dat file. It load up a 2653 an all looks fine thanks.
Re: Stop client and get different WU?
It's not an issue since you've already deleted the WU, but for future reference, we've gotten some reports suggesting that if you get in this situation again, one thing to try is to let it run to 7% and then stop the client. Wait until all copies of FahCore_a1 have stopped, then restart. This MAY allow the WU to pass the error at 8%.
. . . and, no, I don't understand which WUs it works on or why it may work.
Jmarks wrote:I left a message in the wu thread about wu 3050 which will not go passed 8%.
Jmarks
Post by Jmarks »
My pcs are dedicated folders in my basement with no monitors. I only check them with fahmon a couple a times a day. That would not be easy for me.
