Project: 2684 (Run 3, Clone 17, Gen 0)
DocJonz
Post by DocJonz »
Produced fatal error, which stated; 1 particles communicated to PME node 5 are more than 2/3rds the cut off out of the domian decomposition cell ....
Machine is Ubuntu64 9.04, i7 980X, 6GB RAM - never had a failed WU to date on this machine - bar this one of course! (Couldn't find the CoreStatus 8B (139) on the FahWiki ....)
[09:23:06] Signature is VALID
[09:23:06]
[09:23:06] Trying to unzip core FahCore_a3.exe
[09:23:06] Decompressed FahCore_a3.exe (4375728 bytes) successfully
[09:23:06] + Core successfully engaged
[09:23:11]
[09:23:11] + Processing work unit
[09:23:11] Core required: FahCore_a3.exe
[09:23:11] Core found.
[09:23:11] Working on queue slot 03 [May 27 09:23:11 UTC]
[09:23:11] + Working ...
[09:23:11] - Calling './FahCore_a3.exe -dir work/ -nice 19 -suffix 03 -np 12 -checkpoint 10 -forceasm -verbose -lifeline 12919 -version 629'
[09:23:11]
[09:23:11] *------------------------------*
[09:23:11] Folding@Home Gromacs SMP Core
[09:23:11] Version 2.21 (May 10, 2010)
[09:23:11]
[09:23:11] Preparing to commence simulation
[09:23:11] - Assembly optimizations manually forced on.
[09:23:11] - Not checking prior termination.
[09:23:13] - Expanded 20082537 -> 30791309 (decompressed 153.3 percent)
[09:23:13] Called DecompressByteArray: compressed_data_size=20082537 data_size=30791309, decompressed_data_size=30791309 diff=0
[09:23:13] - Digital signature verified
[09:23:13]
[09:23:13] Project: 2684 (Run 3, Clone 17, Gen 0)
[09:23:13]
[09:23:13] Assembly optimizations on if available.
[09:23:13] Entering M.D.
[09:23:26] Completed 0 out of 250000 steps  (0%)
[09:23:29] CoreStatus = 8B (139)
[09:23:29] Client-core communications error: ERROR 0x8b
[09:23:29] Deleting current work unit & continuing...
[09:23:41] Trying to send all finished work units
[09:23:41] + No unsent completed units remaining.
[09:23:41] - Preparing to get new work unit...
[09:23:41] Cleaning up work directory
[09:23:43] + Attempting to get work packet
[09:23:43] Passkey found
[09:23:43] - Will indicate memory of 5500 MB
[09:23:43] - Connecting to assignment server
[09:23:43] Connecting to http://assign.stanford.edu:8080/
[09:23:44] Posted data.
[09:23:44] Initial: 43AB; - Successful: assigned to (171.67.108.22).
[09:23:44] + News From Folding@Home: Welcome to Folding@Home
[09:23:44] Loaded queue successfully.
[09:23:44] Connecting to http://171.67.108.22:8080/
[09:23:52] Posted data.
[09:23:52] Initial: 0000; - Receiving payload (expected size: 20083049)
[09:24:29] - Downloaded at ~530 kB/s
[09:24:29] - Averaged speed for that direction ~459 kB/s
[09:24:29] + Received work.
[09:24:29] + Closed connections
[09:24:34]
[09:24:34] + Processing work unit
[09:24:34] Core required: FahCore_a3.exe
[09:24:34] Core found.
[09:24:34] Working on queue slot 04 [May 27 09:24:34 UTC]
[09:24:34] + Working ...
[09:24:34] - Calling './FahCore_a3.exe -dir work/ -nice 19 -suffix 04 -np 12 -checkpoint 10 -forceasm -verbose -lifeline 12919 -version 629'
[09:24:34]
[09:24:34] *------------------------------*
[09:24:34] Folding@Home Gromacs SMP Core
[09:24:34] Version 2.21 (May 10, 2010)
[09:24:34]
[09:24:34] Preparing to commence simulation
[09:24:34] - Assembly optimizations manually forced on.
[09:24:34] - Not checking prior termination.
[09:24:36] - Expanded 20082537 -> 30791309 (decompressed 153.3 percent)
[09:24:36] Called DecompressByteArray: compressed_data_size=20082537 data_size=30791309, decompressed_data_size=30791309 diff=0
[09:24:36] - Digital signature verified
[09:24:36]
[09:24:36] Project: 2684 (Run 3, Clone 17, Gen 0)
[09:24:36]
[09:24:36] Assembly optimizations on if available.
[09:24:36] Entering M.D.
[09:24:49] Completed 0 out of 250000 steps  (0%)
[09:27:35] mdrun returned 255
[09:27:35] Going to send back what have done -- stepsTotalG=250000
[09:27:35] Work fraction=0.0000 steps=250000.
[09:27:39] logfile size=12744 infoLength=12744 edr=25 trr=1
[09:27:39] logfile size: 12744 info=12744 bed=25 hdr=1
[09:27:39] - Writing 13282 bytes of core data to disk...
[09:27:40]   ... Done.
[09:27:42]
[09:27:42] Folding@home Core Shutdown: UNSTABLE_MACHINE
[09:27:42] CoreStatus = 7A (122)
[09:27:42] Sending work to server
[09:27:42] Project: 2684 (Run 3, Clone 17, Gen 0)
[09:27:42] + Attempting to send results [May 27 09:27:42 UTC]
[09:27:42] - Reading file work/wuresults_04.dat from core
[09:27:42]   (Read 13282 bytes from disk)
[09:27:42] Connecting to http://171.67.108.22:8080/
[09:27:43] Posted data.
[09:27:44] Initial: 0000; - Uploaded at ~6 kB/s
[09:27:44] - Averaged speed for that direction ~24 kB/s
[09:27:44] + Results successfully sent
[09:27:44] Thank you for your contribution to Folding@Home.
[09:27:44] Trying to send all finished work units
[09:27:44] + No unsent completed units remaining.
[09:27:44] - Preparing to get new work unit...
[09:27:44] Cleaning up work directory
[09:27:45] + Attempting to get work packet
[09:27:45] Passkey found
[09:27:45] - Will indicate memory of 5500 MB
[09:27:45] - Connecting to assignment server
[09:27:45] Connecting to http://assign.stanford.edu:8080/
[09:27:46] Posted data.
[09:27:46] Initial: 43AB; - Successful: assigned to (171.67.108.22).
[09:27:46] + News From Folding@Home: Welcome to Folding@Home
[09:27:46] Loaded queue successfully.
[09:27:46] Connecting to http://171.67.108.22:8080/
[09:27:55] Posted data.
[09:27:55] Initial: 0000; - Receiving payload (expected size: 20083049)
[09:28:30] - Downloaded at ~560 kB/s
[09:28:30] - Averaged speed for that direction ~479 kB/s
[09:28:30] + Received work.
[09:28:30] Trying to send all finished work units
[09:28:30] + No unsent completed units remaining.
[09:28:30] + Closed connections
[09:28:35]
[09:28:35] + Processing work unit
[09:28:35] Core required: FahCore_a3.exe
[09:28:35] Core found.
[09:28:35] Working on queue slot 05 [May 27 09:28:35 UTC]
[09:28:35] + Working ...
[09:28:35] - Calling './FahCore_a3.exe -dir work/ -nice 19 -suffix 05 -np 12 -checkpoint 10 -forceasm -verbose -lifeline 12919 -version 629'
[09:28:35]
[09:28:35] *------------------------------*
[09:28:35] Folding@Home Gromacs SMP Core
[09:28:35] Version 2.21 (May 10, 2010)
[09:28:35]
[09:28:35] Preparing to commence simulation
[09:28:35] - Assembly optimizations manually forced on.
[09:28:35] - Not checking prior termination.
[09:28:36] - Expanded 20082537 -> 30791309 (decompressed 153.3 percent)
[09:28:36] Called DecompressByteArray: compressed_data_size=20082537 data_size=30791309, decompressed_data_size=30791309 diff=0
[09:28:37] - Digital signature verified
[09:28:37]
[09:28:37] Project: 2684 (Run 3, Clone 17, Gen 0)
[09:28:37]
[09:28:37] Assembly optimizations on if available.
[09:28:37] Entering M.D.
[09:28:49] Completed 0 out of 250000 steps  (0%)
[09:31:39] mdrun returned 255
[09:31:39] Going to send back what have done -- stepsTotalG=250000
[09:31:39] Work fraction=0.0000 steps=250000.
[09:31:43] logfile size=12744 infoLength=12744 edr=25 trr=1
[09:31:43] logfile size: 12744 info=12744 bed=25 hdr=1
[09:31:43] - Writing 13282 bytes of core data to disk...
[09:31:44]   ... Done.
[09:31:46]
[09:31:46] Folding@home Core Shutdown: UNSTABLE_MACHINE
[09:31:47] CoreStatus = 7A (122)
[09:31:47] Sending work to server
[09:31:47] Project: 2684 (Run 3, Clone 17, Gen 0)
[09:31:47] + Attempting to send results [May 27 09:31:47 UTC]
[09:31:47] - Reading file work/wuresults_05.dat from core
[09:31:47]   (Read 13282 bytes from disk)
[09:31:47] Connecting to http://171.67.108.22:8080/
[09:31:48] Posted data.
[09:31:48] Initial: 0000; - Uploaded at ~6 kB/s
[09:31:49] - Averaged speed for that direction ~21 kB/s
[09:31:49] + Results successfully sent
[09:31:49] Thank you for your contribution to Folding@Home.
[09:31:49] Trying to send all finished work units
[09:31:49] + No unsent completed units remaining.
[09:31:49] - Preparing to get new work unit...
[09:31:49] Cleaning up work directory
[09:31:50] + Attempting to get work packet
[09:31:50] Passkey found
[09:31:50] - Will indicate memory of 5500 MB
[09:31:50] - Connecting to assignment server
[09:31:50] Connecting to http://assign.stanford.edu:8080/
[09:31:52] Posted data.
[09:31:52] Initial: 43AB; - Successful: assigned to (171.67.108.22).
[09:31:52] + News From Folding@Home: Welcome to Folding@Home
[09:31:52] Loaded queue successfully.
[09:31:52] Connecting to http://171.67.108.22:8080/
[09:32:00] Posted data.
[09:32:00] Initial: 0000; - Receiving payload (expected size: 20083049)
[09:32:39] - Downloaded at ~502 kB/s
[09:32:39] - Averaged speed for that direction ~484 kB/s
[09:32:39] + Received work.
[09:32:39] Trying to send all finished work units
[09:32:39] + No unsent completed units remaining.
[09:32:39] + Closed connections
[09:32:44]
[09:32:44] + Processing work unit
[09:32:44] Core required: FahCore_a3.exe
[09:32:44] Core found.
[09:32:44] Working on queue slot 06 [May 27 09:32:44 UTC]
[09:32:44] + Working ...
[09:32:44] - Calling './FahCore_a3.exe -dir work/ -nice 19 -suffix 06 -np 12 -checkpoint 10 -forceasm -verbose -lifeline 12919 -version 629'
[09:32:44]
[09:32:44] *------------------------------*
[09:32:44] Folding@Home Gromacs SMP Core
[09:32:44] Version 2.21 (May 10, 2010)
[09:32:44]
[09:32:44] Preparing to commence simulation
[09:32:44] - Assembly optimizations manually forced on.
[09:32:44] - Not checking prior termination.
[09:32:46] - Expanded 20082537 -> 30791309 (decompressed 153.3 percent)
[09:32:46] Called DecompressByteArray: compressed_data_size=20082537 data_size=30791309, decompressed_data_size=30791309 diff=0
[09:32:46] - Digital signature verified
[09:32:46]
[09:32:46] Project: 2684 (Run 3, Clone 17, Gen 0)
[09:32:46]
[09:32:46] Assembly optimizations on if available.
[09:32:46] Entering M.D.
[09:32:59] Completed 0 out of 250000 steps  (0%)
[09:33:01] mdrun returned 255
[09:33:01] Going to send back what have done -- stepsTotalG=250000
[09:33:01] Work fraction=0.0000 steps=250000.
[09:33:05] logfile size=12877 infoLength=12877 edr=25 trr=1
[09:33:05] logfile size: 12877 info=12877 bed=25 hdr=1
[09:33:05] - Writing 13415 bytes of core data to disk...
[09:33:06]   ... Done.
[09:33:08]
[09:33:08] Folding@home Core Shutdown: EARLY_UNIT_END
[09:33:08] CoreStatus = 72 (114)
[09:33:08] Sending work to server
[09:33:08] Project: 2684 (Run 3, Clone 17, Gen 0)
[09:33:08] + Attempting to send results [May 27 09:33:08 UTC]
Re: Project: 2683 (Run 3, Clone 17, Gen 0)
Marked as a bad WU.
