P6040 CoreStatus = 8B
Oak37
Hardware configuration: Core2Duo e6420 - Ubuntu 8.04 SMP client
Post by Oak37 »
I picked up Project: 6040 (Run 0, Clone 129, Gen 31) which EUEd straight away with a CoreStatus = 8B (139). The client tried again and is currently folding the same unit with no errors so far. Has anyone else encountered this error?
[18:28:15] Trying to send all finished work units
[18:28:15] + No unsent completed units remaining.
[18:28:15] - Preparing to get new work unit...
[18:28:15] Cleaning up work directory
[18:28:15] + Attempting to get work packet
[18:28:15] Passkey found
[18:28:15] - Will indicate memory of 1988 MB
[18:28:15] - Connecting to assignment server
[18:28:15] Connecting to http://assign.stanford.edu:8080/
[18:28:22] Posted data.
[18:28:22] Initial: 40AB; - Successful: assigned to (171.64.65.54).
[18:28:22] + News From Folding@Home: Welcome to Folding@Home
[18:28:22] Loaded queue successfully.
[18:28:22] Connecting to http://171.64.65.54:8080/
[18:28:24] Posted data.
[18:28:24] Initial: 0000; - Receiving payload (expected size: 7879866)
[18:29:04] - Downloaded at ~192 kB/s
[18:29:04] - Averaged speed for that direction ~248 kB/s
[18:29:04] + Received work.
[18:29:04] Trying to send all finished work units
[18:29:04] + No unsent completed units remaining.
[18:29:04] + Closed connections
[18:29:04]
[18:29:04] + Processing work unit
[18:29:04] Core required: FahCore_a3.exe
[18:29:04] Core found.
[18:29:04] Working on queue slot 07 [May 21 18:29:04 UTC]
[18:29:04] + Working ...
[18:29:04] - Calling './FahCore_a3.exe -dir work/ -nice 19 -suffix 07 -np 4 -checkpoint 30 -forceasm -verbose -lifeline 6260 -version 629'
[18:29:04]
[18:29:04] *------------------------------*
[18:29:04] Folding@Home Gromacs SMP Core
[18:29:04] Version 2.21 (April 29, 2010)
[18:29:04]
[18:29:04] Preparing to commence simulation
[18:29:04] - Assembly optimizations manually forced on.
[18:29:04] - Not checking prior termination.
[18:29:05] - Expanded 7879354 -> 10126021 (decompressed 128.5 percent)
[18:29:05] Called DecompressByteArray: compressed_data_size=7879354 data_size=10126021, decompressed_data_size=10126021 diff=0
[18:29:05] - Digital signature verified
[18:29:05]
[18:29:05] Project: 6040 (Run 0, Clone 129, Gen 31)
[18:29:05]
[18:29:05] Assembly optimizations on if available.
[18:29:05] Entering M.D.
[18:29:13] Completed 0 out of 250000 steps  (0%)
[18:29:13] CoreStatus = 8B (139)
[18:29:13] Client-core communications error: ERROR 0x8b
[18:29:13] Deleting current work unit & continuing...
[18:29:24] Trying to send all finished work units
[18:29:24] + No unsent completed units remaining.
[18:29:24] - Preparing to get new work unit...
[18:29:24] Cleaning up work directory
[18:29:24] + Attempting to get work packet
[18:29:24] Passkey found
[18:29:24] - Will indicate memory of 1988 MB
[18:29:24] - Connecting to assignment server
[18:29:24] Connecting to http://assign.stanford.edu:8080/
[18:29:30] Posted data.
[18:29:30] Initial: 40AB; - Successful: assigned to (171.64.65.54).
[18:29:30] + News From Folding@Home: Welcome to Folding@Home
[18:29:30] Loaded queue successfully.
[18:29:30] Connecting to http://171.64.65.54:8080/
[18:29:33] Posted data.
[18:29:33] Initial: 0000; - Receiving payload (expected size: 7879866)
[18:30:22] - Downloaded at ~157 kB/s
[18:30:22] - Averaged speed for that direction ~230 kB/s
[18:30:22] + Received work.
[18:30:22] + Closed connections
[18:30:27]
[18:30:27] + Processing work unit
[18:30:27] Core required: FahCore_a3.exe
[18:30:27] Core found.
[18:30:27] Working on queue slot 08 [May 21 18:30:27 UTC]
[18:30:27] + Working ...
[18:30:27] - Calling './FahCore_a3.exe -dir work/ -nice 19 -suffix 08 -np 4 -checkpoint 30 -forceasm -verbose -lifeline 6260 -version 629'
[18:30:27]
[18:30:27] *------------------------------*
[18:30:27] Folding@Home Gromacs SMP Core
[18:30:27] Version 2.21 (April 29, 2010)
[18:30:27]
[18:30:27] Preparing to commence simulation
[18:30:27] - Assembly optimizations manually forced on.
[18:30:27] - Not checking prior termination.
[18:30:28] - Expanded 7879354 -> 10126021 (decompressed 128.5 percent)
[18:30:28] Called DecompressByteArray: compressed_data_size=7879354 data_size=10126021, decompressed_data_size=10126021 diff=0
[18:30:28] - Digital signature verified
[18:30:28]
[18:30:28] Project: 6040 (Run 0, Clone 129, Gen 31)
[18:30:28]
[18:30:28] Assembly optimizations on if available.
[18:30:28] Entering M.D.
[18:30:37] Completed 0 out of 250000 steps  (0%)
[18:56:11] Completed 2500 out of 250000 steps  (1%)
[19:21:13] Completed 5000 out of 250000 steps  (2%)
Re: P6040 CoreStatus = 8B
There have been other reports of CoreStatus = 8B (139) from the a3 core but I don't remember if a cause (or a cure) have been found. Google on that string and you'll find a lot of posts on this forum.
DocJonz
Hardware configuration: Folding with: 4x RTX 4070Ti, 1x RTX 4080 Super
Post by DocJonz »
I've had similar failures with the -bigadv a3 WU's (see below), but not on any other WU's - there's no mention of this on the FAHWIKI error codes - are we any the wiser on what causes these??
[06:36:25] Project: 2684 (Run 4, Clone 12, Gen 5)
[06:36:25]
[06:36:25] Assembly optimizations on if available.
[06:36:25] Entering M.D.
[06:36:36] Completed 0 out of 250000 steps  (0%)
[07:14:03] Completed 2500 out of 250000 steps  (1%)
[07:50:53] Completed 5000 out of 250000 steps  (2%)
[08:27:44] Completed 7500 out of 250000 steps  (3%)
[09:04:36] Completed 10000 out of 250000 steps  (4%)
[09:41:28] Completed 12500 out of 250000 steps  (5%)
[10:18:22] Completed 15000 out of 250000 steps  (6%)
[10:39:14] CoreStatus = 8B (139)
[10:39:14] Client-core communications error: ERROR 0x8b
[10:39:14] Deleting current work unit & continuing...
[10:50:11] - Preparing to get new work unit...
[10:50:11] Cleaning up work directory
[10:50:11] + Attempting to get work packet
[10:50:11] Passkey found
[10:50:11] - Connecting to assignment server
John_Weatherman
Post by John_Weatherman »
The CoreStatus = 8B (139) seems to be something of a Linux problem as it's appeared even on a Protomol single core WU.
