HELP!!!
genithebest
HELP!!!
Post by genithebest »
I have had F@h downloaded on my pc for almost one whole year and i seem to get no points and i do not know what the problem is can somone check it for me please
Username=genithebest
team num=143016
:x :x :x :x
P5-133XL
Machine #2:
Machine 3:
Re: HELP!!!
Post by P5-133XL »
First what client(s) are you using? Perhaps show the logs.
parkut
Re: HELP!!!
Post by parkut »
First, you should confirm you are actually contributing work. When FAH is running, you can see your CPU processor utilization at 100%
Then, if it is actually doing something, look for a file called FAHlog.txt
within that file, there are many lines of text, most importantly, ones that look like this
[10:56:14] + Results successfully sent
[10:56:14] Thank you for your contribution to Folding@Home.
[10:56:14] + Number of Units Completed: 981
This means work is being done, uploaded and accepted.
Lets start there, OK?
kiore
Re: HELP!!!
Post by kiore »
Here you are:
http://fah-web.stanford.edu/cgi-bin/mai ... enithebest
Date of last work unit 2009-08-07 12:01:17
Total score 0
Overall rank (if points are combined) 1410457 of 1410457
Active clients (within 50 days) 0
Active clients (within 7 days) 0
Nothing running at present are you sure you have it switched on?
Tell us more about what you downloaded and what you think you are running.
genithebest
Re: HELP!!!
its been like 10 mins and it says cpu working (0/125)
genithebest
Re: HELP!!!
How do point get saved anyway because mine seems to save nothin ...
kiore
Re: HELP!!!
Post by kiore »
genithebest wrote:its been like 10 mins and it says cpu working (0/125)
OK I suspect you have a project 26XX which is quite big and will seem slow.
OK let's guess you have a systray cpu in windows so there should be a little coloured ball thing on your taskbar.
Right click on it got to status then logfile here you will see a FAHlog.txt thingee cut and paste that and post it between the code thing, look up. It will look like this:
[15:38:53] - Ask before connecting: No
[15:38:53] - User name: kiore (Team 182116)
[15:38:53] - User ID:xxxxxxxx
[15:38:53] - Machine ID: 9
[15:38:53]
[15:38:53] Loaded queue successfully.
[15:38:53] Initialization complete
[15:38:53]
[15:38:53] + Processing work unit
[15:38:53] Core required: FahCore_a0.exe
[15:38:53] Core found.
[15:38:53] - Autosending finished units... [May 14 15:38:53 UTC]
[15:38:53] Trying to send all finished work units
[15:38:53] + No unsent completed units remaining.
[15:38:53] - Autosend completed
[15:38:53] Working on queue slot 07 [May 14 15:38:53 UTC]
[15:38:53] + Working ...
[15:38:53] - Calling '.\FahCore_a0.exe -dir work/ -suffix 07 -checkpoint 15 -verbose -lifeline 4040 -version 623'
[15:38:53]
[15:38:53] *------------------------------*
[15:38:53] Folding@Home Gromacs 3.3 Core
[15:38:53] Version 1.93 (July 23, 2008)
[15:38:53]
[15:38:53] Preparing to commence simulation
[15:38:53] - Looking at optimizations...
[15:38:53] - Files status OK
[15:38:54] - Expanded 1119041 -> 5947613 (decompressed 531.4 percent)
[15:38:54]
[15:38:54] Project: 1796 (Run 13, Clone 146, Gen 2)
[15:38:54]
[15:38:54] Assembly optimizations on if available.
[15:38:54] Entering M.D.
[15:39:00] FAH Init
[15:39:00] Checkpoint file:
[15:39:05] (Starting from checkpoint)
[15:39:05] Read checkpoint
[15:39:05] Protein: 41330
[15:39:05] Writing local files
[15:39:06] Completed 150000 out of 500000 steps  (30 percent)
[15:39:06] Extra SSE boost OK.
[15:54:06] Timered checkpoint triggered.
[16:02:03] Writing local files
[16:02:03] Completed 155000 out of 500000 steps  (31 percent)
[16:17:03] Timered checkpoint triggered.
[16:24:52] Writing local files
[16:24:52] Completed 160000 out of 500000 steps  (32 percent)
[16:39:51] Timered checkpoint triggered.
[16:47:28] Writing local files
[16:47:28] Completed 165000 out of 500000 steps  (33 percent)
[17:02:27] Timered checkpoint triggered.
[17:10:10] Writing local files
[17:10:10] Completed 170000 out of 500000 steps  (34 percent)
[17:25:10] Timered checkpoint triggered.
[17:33:17] Writing local files
[17:33:17] Completed 175000 out of 500000 steps  (35 percent)
[17:48:16] Timered checkpoint triggered.
[17:56:38] Writing local files
[17:56:38] Completed 180000 out of 500000 steps  (36 percent)
[18:11:38] Timered checkpoint triggered.
[18:20:00] Writing local files
[18:20:00] Completed 185000 out of 500000 steps  (37 percent)
[18:34:59] Timered checkpoint triggered.
genithebest
Re: HELP!!!
Here it is
--- Opening Log file [May 15 20:02:12 UTC]
# Windows CPU Systray Edition #################################################
http://folding.stanford.edu
Launch directory: C:\Users\Argen\AppData\Roaming\Folding@home-x86
[20:02:54] - Ask before connecting: No
[20:02:54] - User name: genithebest (Team 143016)
[20:02:54] - User ID not found locally
[20:02:54] + Requesting User ID from server
[20:02:55] - Machine ID: 1
[20:02:55]
[20:02:55] Work directory not found. Creating...
[20:02:55] Could not open work queue, generating new queue...
[20:02:55] Initialization complete
[20:02:55] - Preparing to get new work unit...
[20:02:55] + Attempting to get work packet
[20:02:55] - Connecting to assignment server
[20:02:56] - Successful: assigned to (171.64.65.65).
[20:02:56] + News From Folding@Home: Welcome to Folding@Home
[20:02:56] Loaded queue successfully.
[20:03:27] + Closed connections
[20:03:27]
[20:03:27] + Processing work unit
[20:03:27] Core required: FahCore_78.exe
[20:03:27] Core not found.
[20:03:27] - Core is not present or corrupted.
[20:03:27] - Attempting to download new core...
[20:03:27] + Downloading new core: FahCore_78.exe
[20:03:28] + 10240 bytes downloaded
[20:03:29] + 20480 bytes downloaded
[20:03:29] + 30720 bytes downloaded
[20:03:29] + 40960 bytes downloaded
[20:03:29] + 51200 bytes downloaded
[20:03:29] + 61440 bytes downloaded
[20:03:29] + 71680 bytes downloaded
[20:03:29] + 81920 bytes downloaded
[20:03:29] + 92160 bytes downloaded
[20:03:29] + 102400 bytes downloaded
[20:03:29] + 112640 bytes downloaded
[20:03:29] + 122880 bytes downloaded
[20:03:29] + 133120 bytes downloaded
[20:03:29] + 143360 bytes downloaded
[20:03:30] + 153600 bytes downloaded
[20:03:30] + 163840 bytes downloaded
[20:03:30] + 174080 bytes downloaded
[20:03:30] + 184320 bytes downloaded
[20:03:30] + 194560 bytes downloaded
[20:03:30] + 204800 bytes downloaded
[20:03:30] + 215040 bytes downloaded
[20:03:30] + 225280 bytes downloaded
[20:03:30] + 235520 bytes downloaded
[20:03:30] + 245760 bytes downloaded
[20:03:30] + 256000 bytes downloaded
[20:03:30] + 266240 bytes downloaded
[20:03:30] + 276480 bytes downloaded
[20:03:30] + 286720 bytes downloaded
[20:03:30] + 296960 bytes downloaded
[20:03:30] + 307200 bytes downloaded
[20:03:30] + 317440 bytes downloaded
[20:03:30] + 327680 bytes downloaded
[20:03:30] + 337920 bytes downloaded
[20:03:30] + 348160 bytes downloaded
[20:03:30] + 358400 bytes downloaded
[20:03:30] + 368640 bytes downloaded
[20:03:30] + 378880 bytes downloaded
[20:03:30] + 389120 bytes downloaded
[20:03:30] + 399360 bytes downloaded
[20:03:30] + 409600 bytes downloaded
[20:03:30] + 419840 bytes downloaded
[20:03:30] + 430080 bytes downloaded
[20:03:31] + 440320 bytes downloaded
[20:03:31] + 450560 bytes downloaded
[20:03:31] + 460800 bytes downloaded
[20:03:31] + 471040 bytes downloaded
[20:03:31] + 481280 bytes downloaded
[20:03:31] + 491520 bytes downloaded
[20:03:31] + 501760 bytes downloaded
[20:03:31] + 512000 bytes downloaded
[20:03:31] + 522240 bytes downloaded
[20:03:31] + 532480 bytes downloaded
[20:03:31] + 542720 bytes downloaded
[20:03:31] + 552960 bytes downloaded
[20:03:31] + 563200 bytes downloaded
[20:03:31] + 573440 bytes downloaded
[20:03:31] + 583680 bytes downloaded
[20:03:31] + 593920 bytes downloaded
[20:03:31] + 604160 bytes downloaded
[20:03:31] + 614400 bytes downloaded
[20:03:31] + 624640 bytes downloaded
[20:03:31] + 634880 bytes downloaded
[20:03:31] + 645120 bytes downloaded
[20:03:31] + 655360 bytes downloaded
[20:03:31] + 665600 bytes downloaded
[20:03:31] + 675840 bytes downloaded
[20:03:31] + 686080 bytes downloaded
[20:03:31] + 696320 bytes downloaded
[20:03:31] + 706560 bytes downloaded
[20:03:31] + 716800 bytes downloaded
[20:03:31] + 727040 bytes downloaded
[20:03:31] + 737280 bytes downloaded
[20:03:31] + 747520 bytes downloaded
[20:03:31] + 757760 bytes downloaded
[20:03:31] + 768000 bytes downloaded
[20:03:31] + 778240 bytes downloaded
[20:03:31] + 788480 bytes downloaded
[20:03:31] + 798720 bytes downloaded
[20:03:31] + 808960 bytes downloaded
[20:03:31] + 819200 bytes downloaded
[20:03:31] + 825633 bytes downloaded
[20:03:31] Verifying core Core_78.fah...
[20:03:31] Signature is VALID
[20:03:31]
[20:03:31] Trying to unzip core FahCore_78.exe
[20:03:32] Decompressed FahCore_78.exe (2338816 bytes) successfully
[20:03:37] + Core successfully engaged
[20:03:42]
[20:03:42] + Processing work unit
[20:03:42] Core required: FahCore_78.exe
[20:03:42] Core found.
[20:03:42] Working on queue slot 01 [May 15 20:03:42 UTC]
[20:03:42] + Working ...
[20:03:42]
[20:03:42] *------------------------------*
[20:03:42] Folding@Home Gromacs Core
[20:03:42] Version 1.90 (March 8, 2006)
[20:03:42]
[20:03:42] Preparing to commence simulation
[20:03:42] - Looking at optimizations...
[20:03:42] - Created dyn
[20:03:42] - Files status OK
[20:03:53] Opening http://fah-web.stanford.edu/cgi-bin/mai ... ithebest...
[20:04:19] Opening C:\Users\Argen\AppData\Roaming\Folding@home-x86\MyFolding.html...
[20:04:58] - Expanded 9243334 -> 47924691 (decompressed 53.8 percent)
[20:04:59] - Starting from initial work packet
[20:04:59]
[20:04:59] Project: 2613 (Run 46, Clone 9, Gen 123)
[20:04:59]
[20:05:04] Assembly optimizations on if available.
[20:05:04] Entering M.D.
[20:05:16] Protein: p2613_TETHERED VESICLES
[20:05:16]
[20:05:16] Writing local files
[20:09:24] Extra SSE boost OK.
[20:09:44] Writing local files
[20:09:50] Completed 0 out of 125000 steps (0%)
[20:20:41] CoreStatus = 62 (98)
[20:20:41] + Restarting core (settings changed)
[20:20:41]
[20:20:41] + Processing work unit
[20:20:41] Core required: FahCore_78.exe
[20:20:41] Core found.
[20:20:41] Working on queue slot 01 [May 15 20:20:41 UTC]
[20:20:41] + Working ...
[20:20:42]
[20:20:42] *------------------------------*
[20:20:42] Folding@Home Gromacs Core
[20:20:42] Version 1.90 (March 8, 2006)
[20:20:42]
[20:20:42] Preparing to commence simulation
[20:20:42] - Ensuring status. Please wait.
[20:21:00] - Looking at optimizations...
[20:21:00] - Not checking prior termination.
[20:22:34] - Expanded 9243334 -> 47924691 (decompressed 53.8 percent)
[20:22:36]
[20:22:36] Project: 2613 (Run 46, Clone 9, Gen 123)
[20:22:36]
[20:22:42] Assembly optimizations on if available.
[20:22:42] Entering M.D.
[20:24:35] (Starting from checkpoint)
[20:24:39] Protein: p2613_TETHERED VESICLES
[20:24:40]
[20:24:41] Writing local files
[20:26:23] Extra SSE boost OK.
[20:26:25] Writing local files
[20:26:27] Completed 0 out of 125000 steps (0%)
kiore
Re: HELP!!!
Post by kiore »
OK working on project 2613 worth 755 points so quite big, but should score a bonus points score. My laptop @ 1.8GHz is doing one of these and it is taking 46min per frame giving 235ppd.
What did you change in your log?
genithebest
Re: HELP!!!
kiore wrote:OK working on project 2613 worth 755 points so quite big, but should score a bonus points score. My laptop @ 1.8GHz is doing one of these and it is taking 46min per frame giving 235ppd.
No i havent changed nothing but it may be my slow pc, how long would it take ur pc to to this ?
kiore
Re: HELP!!!
Post by kiore »
It takes just over 3 days on my old laptop, this will vary considerably on the speed of your CPU and how long you run it for.
If you want advice on maximising your system or anything else, have a look around the forum, plenty of info and help here 8-)
patonb
Re: HELP!!!
Post by patonb »
you won't get points til you return the work unit.
codysluder
Re: HELP!!!
Post by codysluder »
From the log that you posted, it does seem clear that you're probably right about having a slow PC. It's probably useful to know what type of hardware you have and how many hours per week that you actually run the folding client. Points are only awarded for work that is completed before the deadline and searching for the messages mentioned by parkut apparently turned up nothing. You might also look in FAHlog-Prev.txt since it often contains older data than what you posted.
