Project: 10039 (Run 1201, Clone 0, Gen 0)
Datsun 1600
Post by Datsun 1600 »
After 3 months of not a problem, I came home after a week away to find this mess. What are you people doing?
Why is this WU doing the same frame twice?
Oh and the WU is deleted.
[01:54:44] + Attempting to send results [May 11 01:54:44 UTC]
[01:55:53] + Results successfully sent
[01:55:53] Thank you for your contribution to Folding@Home.
[01:55:53] + Number of Units Completed: 130
[01:55:57] - Preparing to get new work unit...
[01:55:57] Cleaning up work directory
[01:55:57] + Attempting to get work packet
[01:55:57] Passkey found
[01:55:57] - Connecting to assignment server
[01:56:05] - Successful: assigned to (129.74.85.15).
[01:56:05] + News From Folding@Home: Welcome to Folding@Home
[01:56:06] Loaded queue successfully.
[01:56:12] + Closed connections
[01:56:12]
[01:56:12] + Processing work unit
[01:56:12] Work type b4 not eligible for variable processors
[01:56:12] Core required: FahCore_b4.exe
[01:56:12] Core not found.
[01:56:12] - Core is not present or corrupted.
[01:56:12] - Attempting to download new core...
[01:56:12] + Downloading new core: FahCore_b4.exe
[01:56:16] + 10240 bytes downloaded
snip
[01:56:35] + 5169901 bytes downloaded
[01:56:35] Verifying core Core_b4.fah...
[01:56:35] Signature is VALID
[01:56:35]
[01:56:35] Trying to unzip core FahCore_b4.exe
[01:56:37] Decompressed FahCore_b4.exe (16564224 bytes) successfully
[01:56:42] + Core successfully engaged
[01:56:47]
[01:56:47] + Processing work unit
[01:56:47] Work type b4 not eligible for variable processors
[01:56:47] Core required: FahCore_b4.exe
[01:56:47] Core found.
[01:56:47] Working on queue slot 01 [May 11 01:56:47 UTC]
[01:56:47] + Working ...
[01:56:50] *********************** Log Started 11/May/2010 01:56:50 ***********************
[01:56:50] ************************** ProtoMol Folding@Home Core **************************
[01:56:50]   Version: 23
[01:56:50]      Type: 180
[01:56:50]      Core: ProtoMol
[01:56:50]   Website: http://folding.stanford.edu/
[01:56:50] Copyright: (c) 2009 Stanford University
[01:56:50]    Author: Joseph Coffland <joseph@cauldrondevelopment.com>
[01:56:50]      Args: -dir work/ -suffix 01 -checkpoint 15 -lifeline 2776 -version 629
[01:56:50] ************************************ Build *************************************
[01:56:50]      Date: Mar 22 2010
[01:56:50]      Time: 16:55:15
[01:56:50]  Revision: 1789
[01:56:50]  Compiler: Intel(R) C++ MSVC 1500 mode 1110
[01:56:50]   Options: /TP /nologo /EHsc /wd4297 /wd4103 /wd1786 /arch:IA32 /Ox
[01:56:50]            /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qrestrict /MT
[01:56:50]   Defines: _CRT_SECURE_NO_WARNINGS NDEBUG HAVE_GEEKINFO BOOST_ALL_NO_LIB
[01:56:50]            XML_STATIC HAVE_EXPAT HAVE_OPENSSL HAVE_LIBFAH HAVE_SIMTK_LAPACK
[01:56:50]  Platform: Windows XP
[01:56:50]      Bits: 32
[01:56:50]      Mode: Release
[01:56:50] ************************************ System ************************************
[01:56:50]        OS: Microsoft Windows 7 Professional
[01:56:50]       CPU: Intel(R) Core(TM) i3 CPU 540 @ 3.07GHz
[01:56:50]    CPU ID: GenuineIntel Family 6 Model 37 Stepping 2
[01:56:50]      CPUs: 16 Logical, 1 Physical
[01:56:50]    Memory: 3.87 GB
[01:56:50]   Threads: Windows
[01:56:50] ********************************************************************************
[01:56:50] Project: 10039 (Run 1201, Clone 0, Gen 0)
[01:56:50] Reading tar file par_all27_prot_lipid.inp
[01:56:50] Reading tar file scpismQuartic.inp
[01:56:50] Reading tar file ww.pdb
[01:56:50] Reading tar file ww.psf
[01:56:50] Reading tar file protomol.conf
[01:56:50] Reading tar file core.xml
[01:56:50] Digital signatures verified
[01:56:50] Completed 0 out of 499375 steps (0%)
[01:59:24] Completed 5000 out of 499375 steps (1%)
snip
[09:55:31] Completed 499300 out of 499375 steps (99%)
[09:55:37] Saving result file logfile_01.txt
[09:55:37] Saving result file checkpt
[09:55:37] Saving result file checkpt.crc
[09:55:37] Saving result file log.txt
[09:55:40] Saving result file protomol.conf
[09:55:40] Saving result file ww.31.pos
[09:55:40] Saving result file ww.31.vel
[09:55:40] Saving result file ww.dcd
[09:55:41] Folding@home Core Shutdown: FINISHED_UNIT
[09:55:44] CoreStatus = 62 (98)
[09:55:44] + Restarting core (settings changed)
[09:55:44]
[09:55:44] + Processing work unit
[09:55:44] Work type b4 not eligible for variable processors
[09:55:44] Core required: FahCore_b4.exe
[09:55:44] Core found.
[09:55:44] Working on queue slot 01 [May 11 09:55:44 UTC]
[09:55:44] + Working ...
[09:55:47] *********************** Log Started 11/May/2010 09:55:47 ***********************
[09:55:47] ************************** ProtoMol Folding@Home Core **************************
[09:55:47]   Version: 23
[09:55:47]      Type: 180
[09:55:47]      Core: ProtoMol
[09:55:47]   Website: http://folding.stanford.edu/
[09:55:47] Copyright: (c) 2009 Stanford University
[09:55:47]    Author: Joseph Coffland <joseph@cauldrondevelopment.com>
[09:55:47]      Args: -dir work/ -suffix 01 -checkpoint 15 -notermcheck -lifeline 2776
[09:55:47]            -version 629
[09:55:47] ************************************ Build *************************************
[09:55:47]      Date: Mar 22 2010
[09:55:47]      Time: 16:55:15
[09:55:47]  Revision: 1789
[09:55:47]  Compiler: Intel(R) C++ MSVC 1500 mode 1110
[09:55:47]   Options: /TP /nologo /EHsc /wd4297 /wd4103 /wd1786 /arch:IA32 /Ox
[09:55:47]            /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qrestrict /MT
[09:55:47]   Defines: _CRT_SECURE_NO_WARNINGS NDEBUG HAVE_GEEKINFO BOOST_ALL_NO_LIB
[09:55:47]            XML_STATIC HAVE_EXPAT HAVE_OPENSSL HAVE_LIBFAH HAVE_SIMTK_LAPACK
[09:55:47]  Platform: Windows XP
[09:55:47]      Bits: 32
[09:55:47]      Mode: Release
[09:55:47] ************************************ System ************************************
[09:55:47]        OS: Microsoft Windows 7 Professional
[09:55:47]       CPU: Intel(R) Core(TM) i3 CPU 540 @ 3.07GHz
[09:55:47]    CPU ID: GenuineIntel Family 6 Model 37 Stepping 2
[09:55:47]      CPUs: 16 Logical, 1 Physical
[09:55:47]    Memory: 3.87 GB
[09:55:47]   Threads: Windows
[09:55:47] ********************************************************************************
[09:55:47] Project: 10039 (Run 1201, Clone 0, Gen 0)
[09:55:47] Reading tar file par_all27_prot_lipid.inp
[09:55:47] Reading tar file scpismQuartic.inp
[09:55:47] Reading tar file ww.pdb
[09:55:47] Reading tar file ww.psf
[09:55:47] Reading tar file protomol.conf
[09:55:47] Reading tar file core.xml
[09:55:47] Digital signatures verified
[09:55:48] Completed 0 out of 499375 steps (0%)
[09:58:23] Completed 5000 out of 499375 steps (1%)
[10:00:58] Completed 10000 out of 499375 steps (2%)
[10:35:52] Completed 65000 out of 499375 steps (13%)
[10:39:59] Completed 70000 out of 499375 steps (14%)
[10:44:10] Completed 74900 out of 499375 steps (14%) Doubling up
[10:48:25] Completed 79900 out of 499375 steps (16%)
[12:52:47] Completed 204800 out of 499375 steps (41%)
[12:58:19] Completed 209800 out of 499375 steps (42%) Doubling up
[13:04:00] Completed 214700 out of 499375 steps (42%)
[13:09:42] Completed 219700 out of 499375 steps (43%)
[15:39:46] Completed 349600 out of 499375 steps (70%)
[15:45:26] Completed 354600 out of 499375 steps (71%)
[15:50:55] Completed 359500 out of 499375 steps (71%) Doubling up
[15:56:43] Completed 364500 out of 499375 steps (72%)
[17:00:14] Completed 419500 out of 499375 steps (84%)
[17:06:08] Completed 424500 out of 499375 steps (85%)
[17:11:49] Completed 429400 out of 499375 steps (85%) Doubling up
[17:17:45] Completed 434400 out of 499375 steps (86%)
[18:20:57] Completed 489400 out of 499375 steps (98%)
[18:26:27] Completed 494400 out of 499375 steps (99%)
[18:31:59] Completed 499300 out of 499375 steps (99%) Doubling up
[18:32:04] Saving result file logfile_01.txt
[18:32:04] Saving result file checkpt
[18:32:04] Saving result file checkpt.crc
[18:32:04] Saving result file log.txt
[18:32:07] Saving result file protomol.conf
[18:32:07] Saving result file ww.34.pos
[18:32:07] Saving result file ww.34.vel
[18:32:07] Saving result file ww.dcd
[18:32:08] Folding@home Core Shutdown: FINISHED_UNIT
[18:32:12] CoreStatus = 62 (98)
[18:32:12] + Restarting core (settings changed)
[18:32:12]
[18:32:12] + Processing work unit
[18:32:12] Work type b4 not eligible for variable processors
[18:32:12] Core required: FahCore_b4.exe
[18:32:12] Core found.
[18:32:12] Working on queue slot 01 [May 11 18:32:12 UTC]
[18:32:12] + Working ...
[18:32:15] *********************** Log Started 11/May/2010 18:32:15 ***********************
[18:32:15] ************************** ProtoMol Folding@Home Core **************************
[18:32:15]   Version: 23
[18:32:15]      Type: 180
[18:32:15]      Core: ProtoMol
[18:32:15]   Website: http://folding.stanford.edu/
[18:32:15] Copyright: (c) 2009 Stanford University
[18:32:15]    Author: Joseph Coffland <joseph@cauldrondevelopment.com>
[18:32:15]      Args: -dir work/ -suffix 01 -checkpoint 15 -notermcheck -lifeline 2776
[18:32:15]            -version 629
[18:32:15] ************************************ Build *************************************
[18:32:15]      Date: Mar 22 2010
[18:32:15]      Time: 16:55:15
[18:32:15]  Revision: 1789
[18:32:15]  Compiler: Intel(R) C++ MSVC 1500 mode 1110
[18:32:15]   Options: /TP /nologo /EHsc /wd4297 /wd4103 /wd1786 /arch:IA32 /Ox
[18:32:15]            /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qrestrict /MT
[18:32:15]   Defines: _CRT_SECURE_NO_WARNINGS NDEBUG HAVE_GEEKINFO BOOST_ALL_NO_LIB
[18:32:15]            XML_STATIC HAVE_EXPAT HAVE_OPENSSL HAVE_LIBFAH HAVE_SIMTK_LAPACK
[18:32:15]  Platform: Windows XP
[18:32:15]      Bits: 32
[18:32:15]      Mode: Release
[18:32:15] ************************************ System ************************************
[18:32:15]        OS: Microsoft Windows 7 Professional
[18:32:15]       CPU: Intel(R) Core(TM) i3 CPU 540 @ 3.07GHz
[18:32:15]    CPU ID: GenuineIntel Family 6 Model 37 Stepping 2
[18:32:15]      CPUs: 16 Logical, 1 Physical
[18:32:15]    Memory: 3.87 GB
[18:32:15]   Threads: Windows
[18:32:15] ********************************************************************************
[18:32:15] Project: 10039 (Run 1201, Clone 0, Gen 0)
[18:32:15] Reading tar file par_all27_prot_lipid.inp
[18:32:15] Reading tar file scpismQuartic.inp
[18:32:15] Reading tar file ww.pdb
[18:32:15] Reading tar file ww.psf
[18:32:15] Reading tar file protomol.conf
[18:32:15] Reading tar file core.xml
[18:32:15] Digital signatures verified
[18:32:15] Completed 0 out of 499375 steps (0%)
[18:34:48] Completed 5000 out of 499375 steps (1%)
[18:37:26] Completed 10000 out of 499375 steps (2%)
[19:12:50] Completed 65000 out of 499375 steps (13%)
[19:16:23] Completed 70000 out of 499375 steps (14%)
[19:19:56] Completed 74900 out of 499375 steps (14%) Doubling up
[19:23:51] Completed 79900 out of 499375 steps (16%)
[21:17:57] Completed 204800 out of 499375 steps (41%)
[21:23:11] Completed 209800 out of 499375 steps (42%)
[21:28:15] Completed 214700 out of 499375 steps (42%) Doubling up
[21:31:26] ERROR: ProtoMol ERROR: ABORT
[21:31:26] Saving result file logfile_01.txt
[21:31:26] Saving result file checkpt
[21:31:26] Saving result file checkpt.crc
[21:31:26] Saving result file log.txt
[21:31:27] Saving result file protomol.conf
[21:31:27] Saving result file ww.10.pos
[21:31:27] Saving result file ww.10.vel
[21:31:27] Saving result file ww.dcd
[21:31:28] Folding@home Core Shutdown: BAD_WORK_UNIT
[21:31:30] CoreStatus = 62 (98)
[21:31:30] + Restarting core (settings changed)
[21:31:30]
[21:31:30] + Processing work unit
[21:31:30] Work type b4 not eligible for variable processors
[21:31:30] Core required: FahCore_b4.exe
[21:31:30] Core found.
[21:31:30] Working on queue slot 01 [May 11 21:31:30 UTC]
[21:31:30] + Working ...
[21:31:33] *********************** Log Started 11/May/2010 21:31:33 ***********************
[21:31:33] ************************** ProtoMol Folding@Home Core **************************
[21:31:33]   Version: 23
[21:31:33]      Type: 180
[21:31:33]      Core: ProtoMol
[21:31:33]   Website: http://folding.stanford.edu/
[21:31:33] Copyright: (c) 2009 Stanford University
[21:31:33]    Author: Joseph Coffland <joseph@cauldrondevelopment.com>
[21:31:33]      Args: -dir work/ -suffix 01 -checkpoint 15 -notermcheck -lifeline 2776
[21:31:33]            -version 629
[21:31:33] ************************************ Build *************************************
[21:31:33]      Date: Mar 22 2010
[21:31:33]      Time: 16:55:15
[21:31:33]  Revision: 1789
[21:31:33]  Compiler: Intel(R) C++ MSVC 1500 mode 1110
[21:31:33]   Options: /TP /nologo /EHsc /wd4297 /wd4103 /wd1786 /arch:IA32 /Ox
[21:31:33]            /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qrestrict /MT
[21:31:33]   Defines: _CRT_SECURE_NO_WARNINGS NDEBUG HAVE_GEEKINFO BOOST_ALL_NO_LIB
[21:31:33]            XML_STATIC HAVE_EXPAT HAVE_OPENSSL HAVE_LIBFAH HAVE_SIMTK_LAPACK
[21:31:33]  Platform: Windows XP
[21:31:33]      Bits: 32
[21:31:33]      Mode: Release
[21:31:33] ************************************ System ************************************
[21:31:33]        OS: Microsoft Windows 7 Professional
[21:31:33]       CPU: Intel(R) Core(TM) i3 CPU 540 @ 3.07GHz
[21:31:33]    CPU ID: GenuineIntel Family 6 Model 37 Stepping 2
[21:31:33]      CPUs: 16 Logical, 1 Physical
[21:31:33]    Memory: 3.87 GB
[21:31:33]   Threads: Windows
[21:31:33] ********************************************************************************
[21:31:33] Project: 10039 (Run 1201, Clone 0, Gen 0)
[21:31:33] Reading tar file par_all27_prot_lipid.inp
[21:31:33] Reading tar file scpismQuartic.inp
[21:31:33] Reading tar file ww.pdb
[21:31:33] Reading tar file ww.psf
[21:31:33] Reading tar file protomol.conf
[21:31:33] Reading tar file core.xml
[21:31:33] Digital signatures verified
[21:31:34] Completed 0 out of 499375 steps (0%)
[21:34:07] Completed 5000 out of 499375 steps (1%)
[21:36:40] Completed 10000 out of 499375 steps (2%)
[22:11:47] Completed 65000 out of 499375 steps (13%)
[22:15:53] Completed 70000 out of 499375 steps (14%)
[22:20:07] Completed 74900 out of 499375 steps (14%)
[22:24:22] Completed 79900 out of 499375 steps (16%)
[23:15:52] Completed 134900 out of 499375 steps (27%)
[23:20:43] Completed 139900 out of 499375 steps (28%)
[23:25:21] Completed 144800 out of 499375 steps (28%) Doubling up
[23:30:15] Completed 149800 out of 499375 steps (29%)
[00:26:32] Completed 204800 out of 499375 steps (41%)
[00:31:28] Completed 209800 out of 499375 steps (42%) Doubling up
[00:36:25] Completed 214700 out of 499375 steps (42%)
[00:41:22] Completed 219700 out of 499375 steps (43%)
[02:52:45] Completed 349600 out of 499375 steps (70%)
[02:58:14] Completed 354600 out of 499375 steps (71%) Doubling up
[03:03:47] Completed 359500 out of 499375 steps (71%)
[03:09:27] Completed 364500 out of 499375 steps (72%)
[05:24:53] Completed 489400 out of 499375 steps (98%)
[05:30:28] Completed 494400 out of 499375 steps (99%)
[05:35:54] Completed 499300 out of 499375 steps (99%) Doubling up
[05:35:58] Saving result file logfile_01.txt
[05:35:58] Saving result file checkpt
[05:35:58] Saving result file checkpt.crc
[05:35:58] Saving result file log.txt
[05:36:02] Saving result file protomol.conf
[05:36:02] Saving result file ww.32.pos
[05:36:02] Saving result file ww.32.vel
[05:36:02] Saving result file ww.dcd
[05:36:03] Folding@home Core Shutdown: FINISHED_UNIT
[05:36:06] CoreStatus = 62 (98)
[05:36:06] + Restarting core (settings changed)
[05:36:06]
[05:36:06] + Processing work unit
[05:36:06] Work type b4 not eligible for variable processors
[05:36:06] Core required: FahCore_b4.exe
[05:36:06] Core found.
[05:36:06] Working on queue slot 01 [May 12 05:36:06 UTC]
[05:36:06] + Working ...
[05:36:09] *********************** Log Started 12/May/2010 05:36:09 ***********************
[05:36:09] ************************** ProtoMol Folding@Home Core **************************
[05:36:09]   Version: 23
[05:36:09]      Type: 180
[05:36:09]      Core: ProtoMol
[05:36:09]   Website: http://folding.stanford.edu/
[05:36:09] Copyright: (c) 2009 Stanford University
[05:36:09]    Author: Joseph Coffland <joseph@cauldrondevelopment.com>
[05:36:09]      Args: -dir work/ -suffix 01 -checkpoint 15 -notermcheck -lifeline 2776
[05:36:09]            -version 629
[05:36:09] ************************************ Build *************************************
[05:36:09]      Date: Mar 22 2010
[05:36:09]      Time: 16:55:15
[05:36:09]  Revision: 1789
[05:36:09]  Compiler: Intel(R) C++ MSVC 1500 mode 1110
[05:36:09]   Options: /TP /nologo /EHsc /wd4297 /wd4103 /wd1786 /arch:IA32 /Ox
[05:36:09]            /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qrestrict /MT
[05:36:09]   Defines: _CRT_SECURE_NO_WARNINGS NDEBUG HAVE_GEEKINFO BOOST_ALL_NO_LIB
[05:36:09]            XML_STATIC HAVE_EXPAT HAVE_OPENSSL HAVE_LIBFAH HAVE_SIMTK_LAPACK
[05:36:09]  Platform: Windows XP
[05:36:09]      Bits: 32
[05:36:09]      Mode: Release
[05:36:09] ************************************ System ************************************
[05:36:09]        OS: Microsoft Windows 7 Professional
[05:36:09]       CPU: Intel(R) Core(TM) i3 CPU 540 @ 3.07GHz
[05:36:09]    CPU ID: GenuineIntel Family 6 Model 37 Stepping 2
[05:36:09]      CPUs: 16 Logical, 1 Physical
[05:36:09]    Memory: 3.87 GB
[05:36:09]   Threads: Windows
[05:36:09] ********************************************************************************
[05:36:09] Project: 10039 (Run 1201, Clone 0, Gen 0)
[05:36:09] Reading tar file par_all27_prot_lipid.inp
[05:36:09] Reading tar file scpismQuartic.inp
[05:36:09] Reading tar file ww.pdb
[05:36:09] Reading tar file ww.psf
[05:36:09] Reading tar file protomol.conf
[05:36:09] Reading tar file core.xml
[05:36:09] Digital signatures verified
[05:36:10] Completed 0 out of 499375 steps (0%)
[05:38:45] Completed 5000 out of 499375 steps (1%)
[06:13:20] Completed 65000 out of 499375 steps (13%)
[06:16:35] Completed 70000 out of 499375 steps (14%)
[06:19:46] Completed 74900 out of 499375 steps (14%) Doubling up
[06:23:09] Completed 79900 out of 499375 steps (16%)
[07:08:52] Completed 134900 out of 499375 steps (27%)
[07:13:36] Completed 139900 out of 499375 steps (28%)
[07:18:22] Completed 144800 out of 499375 steps (28%)
[07:23:16] Completed 149800 out of 499375 steps (29%)
[08:16:44] Completed 204800 out of 499375 steps (41%)
[08:21:40] Completed 209800 out of 499375 steps (42%)
[08:26:35] Completed 214700 out of 499375 steps (42%) Doubling up
[08:31:37] Completed 219700 out of 499375 steps (43%)
[09:32:26] Completed 279700 out of 499375 steps (56%)
[09:37:36] Completed 284700 out of 499375 steps (57%)
[09:42:31] Completed 289600 out of 499375 steps (57%) Doubling up
[09:47:34] Completed 294600 out of 499375 steps (58%)
[10:46:33] Completed 349600 out of 499375 steps (70%)
[10:52:11] Completed 354600 out of 499375 steps (71%)
[10:57:36] Completed 359500 out of 499375 steps (71%)
[11:03:05] Completed 364500 out of 499375 steps (72%)
[13:28:34] Completed 489400 out of 499375 steps (98%)
[13:34:27] Completed 494400 out of 499375 steps (99%)
[13:40:00] Completed 499300 out of 499375 steps (99%) Doubling up
[13:40:06] Saving result file logfile_01.txt
[13:40:06] Saving result file checkpt
[13:40:06] Saving result file checkpt.crc
[13:40:06] Saving result file log.txt
[13:40:09] Saving result file protomol.conf
[13:40:09] Saving result file ww.32.pos
[13:40:09] Saving result file ww.32.vel
[13:40:09] Saving result file ww.dcd
[13:40:10] Folding@home Core Shutdown: FINISHED_UNIT
[13:40:14] CoreStatus = 62 (98)
[13:40:14] + Restarting core (settings changed)
[13:40:14]
[13:40:14] + Processing work unit
[13:40:14] Work type b4 not eligible for variable processors
[13:40:14] Core required: FahCore_b4.exe
[13:40:14] Core found.
[13:40:14] Working on queue slot 01 [May 12 13:40:14 UTC]
[13:40:14] + Working ...
[13:40:17] *********************** Log Started 12/May/2010 13:40:17 ***********************
[13:40:17] ************************** ProtoMol Folding@Home Core **************************
[13:40:17]   Version: 23
[13:40:17]      Type: 180
[13:40:17]      Core: ProtoMol
[13:40:17]   Website: http://folding.stanford.edu/
[13:40:17] Copyright: (c) 2009 Stanford University
[13:40:17]    Author: Joseph Coffland <joseph@cauldrondevelopment.com>
[13:40:17]      Args: -dir work/ -suffix 01 -checkpoint 15 -notermcheck -lifeline 2776
[13:40:17]            -version 629
[13:40:17] ************************************ Build *************************************
[13:40:17]      Date: Mar 22 2010
[13:40:17]      Time: 16:55:15
[13:40:17]  Revision: 1789
[13:40:17]  Compiler: Intel(R) C++ MSVC 1500 mode 1110
[13:40:17]   Options: /TP /nologo /EHsc /wd4297 /wd4103 /wd1786 /arch:IA32 /Ox
[13:40:17]            /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qrestrict /MT
[13:40:17]   Defines: _CRT_SECURE_NO_WARNINGS NDEBUG HAVE_GEEKINFO BOOST_ALL_NO_LIB
[13:40:17]            XML_STATIC HAVE_EXPAT HAVE_OPENSSL HAVE_LIBFAH HAVE_SIMTK_LAPACK
[13:40:17]  Platform: Windows XP
[13:40:17]      Bits: 32
[13:40:17]      Mode: Release
[13:40:17] ************************************ System ************************************
[13:40:17]        OS: Microsoft Windows 7 Professional
[13:40:17]       CPU: Intel(R) Core(TM) i3 CPU 540 @ 3.07GHz
[13:40:17]    CPU ID: GenuineIntel Family 6 Model 37 Stepping 2
[13:40:17]      CPUs: 16 Logical, 1 Physical
[13:40:17]    Memory: 3.87 GB
[13:40:17]   Threads: Windows
[13:40:17] ********************************************************************************
[13:40:17] Project: 10039 (Run 1201, Clone 0, Gen 0)
[13:40:17] Reading tar file par_all27_prot_lipid.inp
[13:40:17] Reading tar file scpismQuartic.inp
[13:40:17] Reading tar file ww.pdb
[13:40:17] Reading tar file ww.psf
[13:40:17] Reading tar file protomol.conf
[13:40:17] Reading tar file core.xml
[13:40:17] Digital signatures verified
[13:40:17] Completed 0 out of 499375 steps (0%)
[13:42:51] Completed 5000 out of 499375 steps (1%)
[21:15:49] Completed 489400 out of 499375 steps (98%)
[21:20:58] Completed 494400 out of 499375 steps (99%)
[21:26:03] Completed 499300 out of 499375 steps (99%)
[21:26:07] Saving result file logfile_01.txt
[21:26:07] Saving result file checkpt
[21:26:07] Saving result file checkpt.crc
[21:26:07] Saving result file log.txt
[21:26:10] Saving result file protomol.conf
[21:26:10] Saving result file ww.30.pos
[21:26:10] Saving result file ww.30.vel
[21:26:10] Saving result file ww.dcd
[21:26:11] Folding@home Core Shutdown: FINISHED_UNIT
[21:26:15] CoreStatus = 62 (98)
[21:26:15] + Restarting core (settings changed)
[21:26:15]
[21:26:15] + Processing work unit
[21:26:15] Work type b4 not eligible for variable processors
[21:26:15] Core required: FahCore_b4.exe
[21:26:15] Core found.
[21:26:15] Working on queue slot 01 [May 12 21:26:15 UTC]
[21:26:15] + Working ...
[21:26:18] *********************** Log Started 12/May/2010 21:26:18 ***********************
[21:26:18] ************************** ProtoMol Folding@Home Core **************************
[21:26:18]   Version: 23
[21:26:18]      Type: 180
[21:26:18]      Core: ProtoMol
[21:26:18]   Website: http://folding.stanford.edu/
[21:26:18] Copyright: (c) 2009 Stanford University
[21:26:18]    Author: Joseph Coffland <joseph@cauldrondevelopment.com>
[21:26:18]      Args: -dir work/ -suffix 01 -checkpoint 15 -notermcheck -lifeline 2776
[21:26:18]            -version 629
[21:26:18] ************************************ Build *************************************
[21:26:18]      Date: Mar 22 2010
[21:26:18]      Time: 16:55:15
[21:26:18]  Revision: 1789
[21:26:18]  Compiler: Intel(R) C++ MSVC 1500 mode 1110
[21:26:18]   Options: /TP /nologo /EHsc /wd4297 /wd4103 /wd1786 /arch:IA32 /Ox
[21:26:18]            /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qrestrict /MT
[21:26:18]   Defines: _CRT_SECURE_NO_WARNINGS NDEBUG HAVE_GEEKINFO BOOST_ALL_NO_LIB
[21:26:18]            XML_STATIC HAVE_EXPAT HAVE_OPENSSL HAVE_LIBFAH HAVE_SIMTK_LAPACK
[21:26:18]  Platform: Windows XP
[21:26:18]      Bits: 32
[21:26:18]      Mode: Release
[21:26:18] ************************************ System ************************************
[21:26:18]        OS: Microsoft Windows 7 Professional
[21:26:18]       CPU: Intel(R) Core(TM) i3 CPU 540 @ 3.07GHz
[21:26:18]    CPU ID: GenuineIntel Family 6 Model 37 Stepping 2
[21:26:18]      CPUs: 16 Logical, 1 Physical
[21:26:18]    Memory: 3.87 GB
[21:26:18]   Threads: Windows
[21:26:18] ********************************************************************************
[21:26:18] Project: 10039 (Run 1201, Clone 0, Gen 0)
[21:26:18] Reading tar file par_all27_prot_lipid.inp
[21:26:18] Reading tar file scpismQuartic.inp
[21:26:18] Reading tar file ww.pdb
[21:26:18] Reading tar file ww.psf
[21:26:18] Reading tar file protomol.conf
[21:26:18] Reading tar file core.xml
[21:26:18] Digital signatures verified
[21:26:18] Completed 0 out of 499375 steps (0%)
[21:28:52] Completed 5000 out of 499375 steps (1%)
[21:31:28] Completed 10000 out of 499375 steps (2%)
[21:34:05] Completed 15000 out of 499375 steps (3%)
[21:36:49] Completed 20000 out of 499375 steps (4%)
[21:39:32] Completed 25000 out of 499375 steps (5%)
[21:42:28] Completed 30000 out of 499375 steps (6%)
[21:45:27] Completed 35000 out of 499375 steps (7%)
[21:48:24] Completed 40000 out of 499375 steps (8%)
[21:51:35] Completed 45000 out of 499375 steps (9%)
[21:54:55] Completed 50000 out of 499375 steps (10%)
[21:58:23] Completed 55000 out of 499375 steps (11%)
[22:02:01] Completed 60000 out of 499375 steps (12%)
[22:05:33] Completed 65000 out of 499375 steps (13%)
[22:09:11] Completed 70000 out of 499375 steps (14%)
[22:13:09] Completed 74900 out of 499375 steps (14%)
[22:17:33] Completed 79900 out of 499375 steps (16%)
[22:22:17] Completed 84900 out of 499375 steps (17%)
[22:27:09] Completed 89900 out of 499375 steps (18%)
[22:32:14] Completed 94900 out of 499375 steps (19%)
[22:37:25] Completed 99900 out of 499375 steps (20%)
[22:42:36] Completed 104900 out of 499375 steps (21%)
[22:47:35] Completed 109900 out of 499375 steps (22%)
[22:52:30] Completed 114900 out of 499375 steps (23%)
[22:57:36] Completed 119900 out of 499375 steps (24%)
[23:02:42] Completed 124900 out of 499375 steps (25%)
[23:07:52] Completed 129900 out of 499375 steps (26%)
[23:12:30] Completed 134900 out of 499375 steps (27%)
[23:17:02] Completed 139900 out of 499375 steps (28%)
[23:21:37] Completed 144800 out of 499375 steps (28%)
[23:26:34] Completed 149800 out of 499375 steps (29%)
[23:31:38] Completed 154800 out of 499375 steps (30%)
[23:37:06] Completed 159800 out of 499375 steps (32%)
[23:42:33] Completed 164800 out of 499375 steps (33%)
[23:47:37] Completed 169800 out of 499375 steps (34%)
[23:52:42] Completed 174800 out of 499375 steps (35%)
[23:57:48] Completed 179800 out of 499375 steps (36%)
[00:03:21] Completed 184800 out of 499375 steps (37%)
[00:08:47] Completed 189800 out of 499375 steps (38%)
[00:14:22] Completed 194800 out of 499375 steps (39%)
[00:20:03] Completed 199800 out of 499375 steps (40%)
[00:25:35] Completed 204800 out of 499375 steps (41%)
[00:31:17] Completed 209800 out of 499375 steps (42%)
[00:36:39] Completed 214700 out of 499375 steps (42%)
[00:42:15] Completed 219700 out of 499375 steps (43%)
[00:47:46] Completed 224700 out of 499375 steps (44%)
[00:53:17] Completed 229700 out of 499375 steps (45%)
[00:58:54] Completed 234700 out of 499375 steps (46%)
[01:04:27] Completed 239700 out of 499375 steps (48%)
[01:10:08] Completed 244700 out of 499375 steps (49%)
[01:15:33] Completed 249700 out of 499375 steps (50%)
[01:21:05] Completed 254700 out of 499375 steps (51%)
[01:26:29] Completed 259700 out of 499375 steps (52%)
[01:31:51] Completed 264700 out of 499375 steps (53%)
[01:37:30] Completed 269700 out of 499375 steps (54%)
[01:42:52] Completed 274700 out of 499375 steps (55%)
[01:48:17] Completed 279700 out of 499375 steps (56%)
[01:53:38] Completed 284700 out of 499375 steps (57%)
[01:59:08] Completed 289600 out of 499375 steps (57%)
[02:04:48] Completed 294600 out of 499375 steps (58%)
[02:10:15] Completed 299600 out of 499375 steps (59%)
[02:15:42] Completed 304600 out of 499375 steps (60%)
[02:21:23] Completed 309600 out of 499375 steps (61%)
[02:27:03] Completed 314600 out of 499375 steps (62%)
[02:32:29] Completed 319600 out of 499375 steps (64%)
[02:38:01] Completed 324600 out of 499375 steps (65%)
[02:43:05] Completed 329600 out of 499375 steps (66%)
[02:48:14] Completed 334600 out of 499375 steps (67%)
[02:53:36] Completed 339600 out of 499375 steps (68%)
[02:59:03] Completed 344600 out of 499375 steps (69%)
[03:04:31] Completed 349600 out of 499375 steps (70%)
[03:10:10] Completed 354600 out of 499375 steps (71%)
[03:15:38] Completed 359500 out of 499375 steps (71%)
[03:21:35] Completed 364500 out of 499375 steps (72%)
[03:27:12] Completed 369500 out of 499375 steps (73%)
[03:32:43] Completed 374500 out of 499375 steps (74%)
[03:38:30] Completed 379500 out of 499375 steps (75%)
[03:43:53] Completed 384500 out of 499375 steps (76%)
[03:49:30] Completed 389500 out of 499375 steps (77%)
[03:55:27] Completed 394500 out of 499375 steps (78%)
[04:01:14] Completed 399500 out of 499375 steps (80%)
[04:07:18] Completed 404500 out of 499375 steps (81%)
[04:13:10] Completed 409500 out of 499375 steps (82%)
[04:18:53] Completed 414500 out of 499375 steps (83%)
[04:24:52] Completed 419500 out of 499375 steps (84%)
[04:30:31] Completed 424500 out of 499375 steps (85%)
[04:36:01] Completed 429400 out of 499375 steps (85%)
[04:41:50] Completed 434400 out of 499375 steps (86%)
[04:47:31] Completed 439400 out of 499375 steps (87%)
[04:53:18] Completed 444400 out of 499375 steps (88%)
[04:59:07] Completed 449400 out of 499375 steps (89%)
[05:04:59] Completed 454400 out of 499375 steps (90%)
[05:11:01] Completed 459400 out of 499375 steps (91%)
[05:16:48] Completed 464400 out of 499375 steps (92%)
[05:22:27] Completed 469400 out of 499375 steps (93%)
[05:28:13] Completed 474400 out of 499375 steps (94%)
[05:33:48] Completed 479400 out of 499375 steps (96%)
[05:39:40] Completed 484400 out of 499375 steps (97%)
[05:45:16] Completed 489400 out of 499375 steps (98%)
[05:50:55] Completed 494400 out of 499375 steps (99%)
[05:56:20] Completed 499300 out of 499375 steps (99%)
[05:56:26] Saving result file logfile_01.txt
[05:56:26] Saving result file checkpt
[05:56:26] Saving result file checkpt.crc
[05:56:26] Saving result file log.txt
[05:56:29] Saving result file protomol.conf
[05:56:29] Saving result file ww.33.pos
[05:56:29] Saving result file ww.33.vel
[05:56:29] Saving result file ww.dcd
[05:56:30] Folding@home Core Shutdown: FINISHED_UNIT
[05:56:34] CoreStatus = 62 (98)
[05:56:34] + Restarting core (settings changed)
[05:56:34]
[05:56:34] + Processing work unit
[05:56:34] Work type b4 not eligible for variable processors
[05:56:34] Core required: FahCore_b4.exe
[05:56:34] Core found.
[05:56:34] Working on queue slot 01 [May 13 05:56:34 UTC]
[05:56:34] + Working ...
[05:56:37] *********************** Log Started 13/May/2010 05:56:37 ***********************
[05:56:37] ************************** ProtoMol Folding@Home Core **************************
[05:56:37]   Version: 23
[05:56:37]      Type: 180
[05:56:37]      Core: ProtoMol
[05:56:37]   Website: http://folding.stanford.edu/
[05:56:37] Copyright: (c) 2009 Stanford University
[05:56:37]    Author: Joseph Coffland <joseph@cauldrondevelopment.com>
[05:56:37]      Args: -dir work/ -suffix 01 -checkpoint 15 -notermcheck -lifeline 2776
[05:56:37]            -version 629
[05:56:37] ************************************ Build *************************************
[05:56:37]      Date: Mar 22 2010
[05:56:37]      Time: 16:55:15
[05:56:37]  Revision: 1789
[05:56:37]  Compiler: Intel(R) C++ MSVC 1500 mode 1110
[05:56:37]   Options: /TP /nologo /EHsc /wd4297 /wd4103 /wd1786 /arch:IA32 /Ox
[05:56:37]            /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qrestrict /MT
[05:56:37]   Defines: _CRT_SECURE_NO_WARNINGS NDEBUG HAVE_GEEKINFO BOOST_ALL_NO_LIB
[05:56:37]            XML_STATIC HAVE_EXPAT HAVE_OPENSSL HAVE_LIBFAH HAVE_SIMTK_LAPACK
[05:56:37]  Platform: Windows XP
[05:56:37]      Bits: 32
[05:56:37]      Mode: Release
[05:56:37] ************************************ System ************************************
[05:56:37]        OS: Microsoft Windows 7 Professional
[05:56:37]       CPU: Intel(R) Core(TM) i3 CPU 540 @ 3.07GHz
[05:56:37]    CPU ID: GenuineIntel Family 6 Model 37 Stepping 2
[05:56:37]      CPUs: 16 Logical, 1 Physical
[05:56:37]    Memory: 3.87 GB
[05:56:37]   Threads: Windows
[05:56:37] ********************************************************************************
[05:56:37] Project: 10039 (Run 1201, Clone 0, Gen 0)
[05:56:37] Reading tar file par_all27_prot_lipid.inp
[05:56:37] Reading tar file scpismQuartic.inp
[05:56:37] Reading tar file ww.pdb
[05:56:37] Reading tar file ww.psf
[05:56:37] Reading tar file protomol.conf
[05:56:37] Reading tar file core.xml
[05:56:37] Digital signatures verified
[05:56:38] Completed 0 out of 499375 steps (0%)
[05:59:12] Completed 5000 out of 499375 steps (1%)
[06:01:47] Completed 10000 out of 499375 steps (2%)
[06:04:25] Completed 15000 out of 499375 steps (3%)
[06:07:08] Completed 20000 out of 499375 steps (4%)
[06:09:57] Completed 25000 out of 499375 steps (5%)
[06:12:51] Completed 30000 out of 499375 steps (6%)
[06:15:56] Completed 35000 out of 499375 steps (7%)
[06:18:57] Completed 40000 out of 499375 steps (8%)
[06:22:07] Completed 45000 out of 499375 steps (9%)
[06:25:23] Completed 50000 out of 499375 steps (10%)
[06:28:43] Completed 55000 out of 499375 steps (11%)
[06:32:18] Completed 60000 out of 499375 steps (12%)
[06:35:44] Completed 65000 out of 499375 steps (13%)
[06:39:12] Completed 70000 out of 499375 steps (14%)
[06:42:32] Completed 74900 out of 499375 steps (14%)
[06:46:01] Completed 79900 out of 499375 steps (16%)
[06:49:37] Completed 84900 out of 499375 steps (17%)
[06:53:38] Completed 89900 out of 499375 steps (18%)
[06:58:07] Completed 94900 out of 499375 steps (19%)
[07:02:39] Completed 99900 out of 499375 steps (20%)
[07:07:10] Completed 104900 out of 499375 steps (21%)
[07:11:44] Completed 109900 out of 499375 steps (22%)
[07:16:34] Completed 114900 out of 499375 steps (23%)
[07:21:26] Completed 119900 out of 499375 steps (24%)
[07:26:20] Completed 124900 out of 499375 steps (25%)
[07:31:27] Completed 129900 out of 499375 steps (26%)
[07:36:38] Completed 134900 out of 499375 steps (27%)
[07:42:03] Completed 139900 out of 499375 steps (28%)
[07:47:13] Completed 144800 out of 499375 steps (28%)
[07:52:53] Completed 149800 out of 499375 steps (29%)
[07:58:27] Completed 154800 out of 499375 steps (30%)
[08:03:59] Completed 159800 out of 499375 steps (32%)
[08:09:31] Completed 164800 out of 499375 steps (33%)
[08:14:57] Completed 169800 out of 499375 steps (34%)
[08:20:24] Completed 174800 out of 499375 steps (35%)
[08:25:51] Completed 179800 out of 499375 steps (36%)
[08:31:09] Completed 184800 out of 499375 steps (37%)
[08:36:37] Completed 189800 out of 499375 steps (38%)
[08:41:47] Completed 194800 out of 499375 steps (39%)
[08:47:11] Completed 199800 out of 499375 steps (40%)
[08:52:52] Completed 204800 out of 499375 steps (41%)
[08:58:37] Completed 209800 out of 499375 steps (42%)
[09:04:23] Completed 214700 out of 499375 steps (42%)
[09:09:56] Completed 219700 out of 499375 steps (43%)
[09:15:35] Completed 224700 out of 499375 steps (44%)
[09:21:07] Completed 229700 out of 499375 steps (45%)
[09:26:44] Completed 234700 out of 499375 steps (46%)
[09:32:17] Completed 239700 out of 499375 steps (48%)
[09:37:46] Completed 244700 out of 499375 steps (49%)
[09:43:20] Completed 249700 out of 499375 steps (50%)
[09:49:01] Completed 254700 out of 499375 steps (51%)
[09:54:49] Completed 259700 out of 499375 steps (52%)
[10:00:31] Completed 264700 out of 499375 steps (53%)
[10:06:08] Completed 269700 out of 499375 steps (54%)
[10:12:13] Completed 274700 out of 499375 steps (55%)
[10:18:14] Completed 279700 out of 499375 steps (56%)
[10:24:02] Completed 284700 out of 499375 steps (57%)
[10:29:26] Completed 289600 out of 499375 steps (57%)
[10:35:00] Completed 294600 out of 499375 steps (58%)
[10:40:50] Completed 299600 out of 499375 steps (59%)
[10:46:47] Completed 304600 out of 499375 steps (60%)
[10:52:27] Completed 309600 out of 499375 steps (61%)
[10:58:16] Completed 314600 out of 499375 steps (62%)
[11:03:54] Completed 319600 out of 499375 steps (64%)
[11:09:39] Completed 324600 out of 499375 steps (65%)
[11:15:13] Completed 329600 out of 499375 steps (66%)
[11:20:53] Completed 334600 out of 499375 steps (67%)
[11:26:37] Completed 339600 out of 499375 steps (68%)
[11:32:07] Completed 344600 out of 499375 steps (69%)
[11:37:32] Completed 349600 out of 499375 steps (70%)
[11:42:56] Completed 354600 out of 499375 steps (71%)
[11:48:17] Completed 359500 out of 499375 steps (71%)
[11:53:52] Completed 364500 out of 499375 steps (72%)
[11:59:25] Completed 369500 out of 499375 steps (73%)
[12:05:06] Completed 374500 out of 499375 steps (74%)
[12:10:45] Completed 379500 out of 499375 steps (75%)
[12:16:10] Completed 384500 out of 499375 steps (76%)
[12:21:45] Completed 389500 out of 499375 steps (77%)
[12:27:16] Completed 394500 out of 499375 steps (78%)
[12:32:42] Completed 399500 out of 499375 steps (80%)
[12:38:21] Completed 404500 out of 499375 steps (81%)
[12:44:04] Completed 409500 out of 499375 steps (82%)
[12:49:50] Completed 414500 out of 499375 steps (83%)
[12:55:29] Completed 419500 out of 499375 steps (84%)
[13:01:07] Completed 424500 out of 499375 steps (85%)
[13:06:43] Completed 429400 out of 499375 steps (85%)
[13:12:35] Completed 434400 out of 499375 steps (86%)
[13:18:16] Completed 439400 out of 499375 steps (87%)
[13:24:04] Completed 444400 out of 499375 steps (88%)
[13:29:45] Completed 449400 out of 499375 steps (89%)
[13:35:39] Completed 454400 out of 499375 steps (90%)
[13:41:19] Completed 459400 out of 499375 steps (91%)
[13:47:11] Completed 464400 out of 499375 steps (92%)
[13:52:36] Completed 469400 out of 499375 steps (93%)
[13:58:07] Completed 474400 out of 499375 steps (94%)
[14:03:37] Completed 479400 out of 499375 steps (96%)
[14:09:20] Completed 484400 out of 499375 steps (97%)
[14:14:53] Completed 489400 out of 499375 steps (98%)
[14:20:20] Completed 494400 out of 499375 steps (99%)
[14:25:48] Completed 499300 out of 499375 steps (99%)
[14:25:52] Saving result file logfile_01.txt
[14:25:52] Saving result file checkpt
[14:25:52] Saving result file checkpt.crc
[14:25:52] Saving result file log.txt
[14:25:56] Saving result file protomol.conf
[14:25:56] Saving result file ww.33.pos
[14:25:56] Saving result file ww.33.vel
[14:25:56] Saving result file ww.dcd
[14:25:57] Folding@home Core Shutdown: FINISHED_UNIT
[14:25:59] CoreStatus = 62 (98)
[14:25:59] + Restarting core (settings changed)
[14:25:59]
[14:25:59] + Processing work unit
[14:25:59] Work type b4 not eligible for variable processors
[14:25:59] Core required: FahCore_b4.exe
[14:25:59] Core found.
[14:25:59] Working on queue slot 01 [May 13 14:25:59 UTC]
[14:25:59] + Working ...
[14:26:02] *********************** Log Started 13/May/2010 14:26:02 ***********************
[14:26:02] ************************** ProtoMol Folding@Home Core **************************
[14:26:02]   Version: 23
[14:26:02]      Type: 180
[14:26:02]      Core: ProtoMol
[14:26:02]   Website: http://folding.stanford.edu/
[14:26:02] Copyright: (c) 2009 Stanford University
[14:26:02]    Author: Joseph Coffland <joseph@cauldrondevelopment.com>
[14:26:02]      Args: -dir work/ -suffix 01 -checkpoint 15 -notermcheck -lifeline 2776
[14:26:02]            -version 629
[14:26:02] ************************************ Build *************************************
[14:26:02]      Date: Mar 22 2010
[14:26:02]      Time: 16:55:15
[14:26:02]  Revision: 1789
[14:26:02]  Compiler: Intel(R) C++ MSVC 1500 mode 1110
[14:26:02]   Options: /TP /nologo /EHsc /wd4297 /wd4103 /wd1786 /arch:IA32 /Ox
[14:26:02]            /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qrestrict /MT
[14:26:02]   Defines: _CRT_SECURE_NO_WARNINGS NDEBUG HAVE_GEEKINFO BOOST_ALL_NO_LIB
[14:26:02]            XML_STATIC HAVE_EXPAT HAVE_OPENSSL HAVE_LIBFAH HAVE_SIMTK_LAPACK
[14:26:02]  Platform: Windows XP
[14:26:02]      Bits: 32
[14:26:02]      Mode: Release
[14:26:02] ************************************ System ************************************
[14:26:02]        OS: Microsoft Windows 7 Professional
[14:26:02]       CPU: Intel(R) Core(TM) i3 CPU 540 @ 3.07GHz
[14:26:02]    CPU ID: GenuineIntel Family 6 Model 37 Stepping 2
[14:26:02]      CPUs: 16 Logical, 1 Physical
[14:26:02]    Memory: 3.87 GB
[14:26:02]   Threads: Windows
[14:26:02] ********************************************************************************
[14:26:02] Project: 10039 (Run 1201, Clone 0, Gen 0)
[14:26:02] Reading tar file par_all27_prot_lipid.inp
[14:26:02] Reading tar file scpismQuartic.inp
[14:26:02] Reading tar file ww.pdb
[14:26:02] Reading tar file ww.psf
[14:26:02] Reading tar file protomol.conf
[14:26:02] Reading tar file core.xml
[14:26:02] Digital signatures verified
[14:26:03] Completed 0 out of 499375 steps (0%)
[14:28:36] Completed 5000 out of 499375 steps (1%)
[14:31:13] Completed 10000 out of 499375 steps (2%)
[14:33:49] Completed 15000 out of 499375 steps (3%)
[14:36:30] Completed 20000 out of 499375 steps (4%)
[14:39:13] Completed 25000 out of 499375 steps (5%)
[14:42:15] Completed 30000 out of 499375 steps (6%)
[14:45:19] Completed 35000 out of 499375 steps (7%)
[14:48:18] Completed 40000 out of 499375 steps (8%)
[14:51:19] Completed 45000 out of 499375 steps (9%)
[14:54:34] Completed 50000 out of 499375 steps (10%)
[14:58:00] Completed 55000 out of 499375 steps (11%)
[15:01:38] Completed 60000 out of 499375 steps (12%)
[15:05:23] Completed 65000 out of 499375 steps (13%)
[15:09:12] Completed 70000 out of 499375 steps (14%)
[15:12:49] Completed 74900 out of 499375 steps (14%)
[15:16:34] Completed 79900 out of 499375 steps (16%)
[15:20:40] Completed 84900 out of 499375 steps (17%)
[15:25:20] Completed 89900 out of 499375 steps (18%)
[15:30:10] Completed 94900 out of 499375 steps (19%)
[15:34:54] Completed 99900 out of 499375 steps (20%)
[15:39:40] Completed 104900 out of 499375 steps (21%)
[15:44:36] Completed 109900 out of 499375 steps (22%)
[15:49:23] Completed 114900 out of 499375 steps (23%)
[15:54:14] Completed 119900 out of 499375 steps (24%)
[15:59:17] Completed 124900 out of 499375 steps (25%)
[16:04:20] Completed 129900 out of 499375 steps (26%)
[16:09:14] Completed 134900 out of 499375 steps (27%)
[16:14:26] Completed 139900 out of 499375 steps (28%)
[16:19:42] Completed 144800 out of 499375 steps (28%)
[16:24:51] Completed 149800 out of 499375 steps (29%)
[16:30:09] Completed 154800 out of 499375 steps (30%)
[16:35:34] Completed 159800 out of 499375 steps (32%)
[16:40:54] Completed 164800 out of 499375 steps (33%)
[16:46:02] Completed 169800 out of 499375 steps (34%)
[16:51:09] Completed 174800 out of 499375 steps (35%)
[16:56:18] Completed 179800 out of 499375 steps (36%)
[17:01:34] Completed 184800 out of 499375 steps (37%)
[17:06:33] Completed 189800 out of 499375 steps (38%)
[17:11:45] Completed 194800 out of 499375 steps (39%)
[17:16:46] Completed 199800 out of 499375 steps (40%)
[17:22:09] Completed 204800 out of 499375 steps (41%)
[17:27:13] Completed 209800 out of 499375 steps (42%)
[17:32:27] Completed 214700 out of 499375 steps (42%)
[17:37:29] Completed 219700 out of 499375 steps (43%)
[17:42:28] Completed 224700 out of 499375 steps (44%)
[17:47:39] Completed 229700 out of 499375 steps (45%)
[17:52:47] Completed 234700 out of 499375 steps (46%)
[17:57:58] Completed 239700 out of 499375 steps (48%)
[18:03:07] Completed 244700 out of 499375 steps (49%)
[18:08:19] Completed 249700 out of 499375 steps (50%)
[18:13:39] Completed 254700 out of 499375 steps (51%)
[18:18:53] Completed 259700 out of 499375 steps (52%)
[18:24:09] Completed 264700 out of 499375 steps (53%)
[18:29:34] Completed 269700 out of 499375 steps (54%)
[18:35:03] Completed 274700 out of 499375 steps (55%)
[18:40:30] Completed 279700 out of 499375 steps (56%)
[18:45:47] Completed 284700 out of 499375 steps (57%)
[18:50:41] Completed 289600 out of 499375 steps (57%)
[18:55:59] Completed 294600 out of 499375 steps (58%)
[19:01:23] Completed 299600 out of 499375 steps (59%)
[19:06:58] Completed 304600 out of 499375 steps (60%)
[19:12:10] Completed 309600 out of 499375 steps (61%)
[19:17:21] Completed 314600 out of 499375 steps (62%)
[19:22:31] Completed 319600 out of 499375 steps (64%)
[19:27:57] Completed 324600 out of 499375 steps (65%)
[19:33:17] Completed 329600 out of 499375 steps (66%)
[19:38:49] Completed 334600 out of 499375 steps (67%)
[19:44:07] Completed 339600 out of 499375 steps (68%)
[19:49:37] Completed 344600 out of 499375 steps (69%)
[19:55:14] Completed 349600 out of 499375 steps (70%)
[20:01:02] Completed 354600 out of 499375 steps (71%)
[20:06:22] Completed 359500 out of 499375 steps (71%)
[20:11:53] Completed 364500 out of 499375 steps (72%)
[20:17:24] Completed 369500 out of 499375 steps (73%)
[20:23:02] Completed 374500 out of 499375 steps (74%)
[20:28:45] Completed 379500 out of 499375 steps (75%)
[20:34:21] Completed 384500 out of 499375 steps (76%)
[20:40:00] Completed 389500 out of 499375 steps (77%)
[20:45:34] Completed 394500 out of 499375 steps (78%)
[20:51:07] Completed 399500 out of 499375 steps (80%)
[20:56:29] Completed 404500 out of 499375 steps (81%)
[21:02:10] Completed 409500 out of 499375 steps (82%)
[21:07:59] Completed 414500 out of 499375 steps (83%)
[21:13:24] Completed 419500 out of 499375 steps (84%)
[21:18:49] Completed 424500 out of 499375 steps (85%)
[21:24:07] Completed 429400 out of 499375 steps (85%)
[21:29:32] Completed 434400 out of 499375 steps (86%)
[21:35:17] Completed 439400 out of 499375 steps (87%)
[21:40:37] Completed 444400 out of 499375 steps (88%)
[21:45:55] Completed 449400 out of 499375 steps (89%)
[21:51:33] Completed 454400 out of 499375 steps (90%)
[21:57:11] Completed 459400 out of 499375 steps (91%)
[22:02:30] Completed 464400 out of 499375 steps (92%)
[22:08:06] Completed 469400 out of 499375 steps (93%)
[22:13:44] Completed 474400 out of 499375 steps (94%)
[22:19:13] Completed 479400 out of 499375 steps (96%)
[22:25:12] Completed 484400 out of 499375 steps (97%)
[22:31:02] Completed 489400 out of 499375 steps (98%)
[22:36:39] Completed 494400 out of 499375 steps (99%)
[22:42:25] Completed 499300 out of 499375 steps (99%)
[22:42:31] Saving result file logfile_01.txt
[22:42:31] Saving result file checkpt
[22:42:31] Saving result file checkpt.crc
[22:42:31] Saving result file log.txt
[22:42:34] Saving result file protomol.conf
[22:42:34] Saving result file ww.32.pos
[22:42:34] Saving result file ww.32.vel
[22:42:34] Saving result file ww.dcd
[22:42:35] Folding@home Core Shutdown: FINISHED_UNIT
[22:42:38] CoreStatus = 62 (98)
[22:42:38] + Restarting core (settings changed)
[22:42:38]
[22:42:38] + Processing work unit
[22:42:38] Work type b4 not eligible for variable processors
[22:42:38] Core required: FahCore_b4.exe
[22:42:38] Core found.
[22:42:38] Working on queue slot 01 [May 13 22:42:38 UTC]
[22:42:38] + Working ...
[22:42:41] *********************** Log Started 13/May/2010 22:42:40 ***********************
[22:42:41] ************************** ProtoMol Folding@Home Core **************************
[22:42:41]   Version: 23
[22:42:41]      Type: 180
[22:42:41]      Core: ProtoMol
[22:42:41]   Website: http://folding.stanford.edu/
[22:42:41] Copyright: (c) 2009 Stanford University
[22:42:41]    Author: Joseph Coffland <joseph@cauldrondevelopment.com>
[22:42:41]      Args: -dir work/ -suffix 01 -checkpoint 15 -notermcheck -lifeline 2776
[22:42:41]            -version 629
[22:42:41] ************************************ Build *************************************
[22:42:41]      Date: Mar 22 2010
[22:42:41]      Time: 16:55:15
[22:42:41]  Revision: 1789
[22:42:41]  Compiler: Intel(R) C++ MSVC 1500 mode 1110
[22:42:41]   Options: /TP /nologo /EHsc /wd4297 /wd4103 /wd1786 /arch:IA32 /Ox
[22:42:41]            /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qrestrict /MT
[22:42:41]   Defines: _CRT_SECURE_NO_WARNINGS NDEBUG HAVE_GEEKINFO BOOST_ALL_NO_LIB
[22:42:41]            XML_STATIC HAVE_EXPAT HAVE_OPENSSL HAVE_LIBFAH HAVE_SIMTK_LAPACK
[22:42:41]  Platform: Windows XP
[22:42:41]      Bits: 32
[22:42:41]      Mode: Release
[22:42:41] ************************************ System ************************************
[22:42:41]        OS: Microsoft Windows 7 Professional
[22:42:41]       CPU: Intel(R) Core(TM) i3 CPU 540 @ 3.07GHz
[22:42:41]    CPU ID: GenuineIntel Family 6 Model 37 Stepping 2
[22:42:41]      CPUs: 16 Logical, 1 Physical
[22:42:41]    Memory: 3.87 GB
[22:42:41]   Threads: Windows
[22:42:41] ********************************************************************************
[22:42:41] Project: 10039 (Run 1201, Clone 0, Gen 0)
[22:42:41] Reading tar file par_all27_prot_lipid.inp
[22:42:41] Reading tar file scpismQuartic.inp
[22:42:41] Reading tar file ww.pdb
[22:42:41] Reading tar file ww.psf
[22:42:41] Reading tar file protomol.conf
[22:42:41] Reading tar file core.xml
[22:42:41] Digital signatures verified
[22:42:41] Completed 0 out of 499375 steps (0%)
[22:45:16] Completed 5000 out of 499375 steps (1%)
[22:47:52] Completed 10000 out of 499375 steps (2%)
[22:50:30] Completed 15000 out of 499375 steps (3%)
[22:53:16] Completed 20000 out of 499375 steps (4%)
[22:56:02] Completed 25000 out of 499375 steps (5%)
[22:58:51] Completed 30000 out of 499375 steps (6%)
[23:01:41] Completed 35000 out of 499375 steps (7%)
[23:04:32] Completed 40000 out of 499375 steps (8%)
[23:07:30] Completed 45000 out of 499375 steps (9%)
[23:10:47] Completed 50000 out of 499375 steps (10%)
[23:13:58] Completed 55000 out of 499375 steps (11%)
[23:17:18] Completed 60000 out of 499375 steps (12%)
[23:20:26] Completed 65000 out of 499375 steps (13%)
[23:23:33] Completed 70000 out of 499375 steps (14%)
[23:26:38] Completed 74900 out of 499375 steps (14%)
[23:30:00] Completed 79900 out of 499375 steps (16%)
[23:33:43] Completed 84900 out of 499375 steps (17%)
[23:37:34] Completed 89900 out of 499375 steps (18%)
[23:41:54] Completed 94900 out of 499375 steps (19%)
[23:46:12] Completed 99900 out of 499375 steps (20%)
[23:50:33] Completed 104900 out of 499375 steps (21%)
[23:54:56] Completed 109900 out of 499375 steps (22%)
[23:59:10] Completed 114900 out of 499375 steps (23%)
[00:03:30] Completed 119900 out of 499375 steps (24%)
[00:08:16] Completed 124900 out of 499375 steps (25%)
[00:12:54] Completed 129900 out of 499375 steps (26%)
[00:17:21] Completed 134900 out of 499375 steps (27%)
[00:22:04] Completed 139900 out of 499375 steps (28%)
[00:27:06] Completed 144800 out of 499375 steps (28%)
[00:32:17] Completed 149800 out of 499375 steps (29%)
[00:37:28] Completed 154800 out of 499375 steps (30%)
[00:42:57] Completed 159800 out of 499375 steps (32%)
[00:48:30] Completed 164800 out of 499375 steps (33%)
[00:54:02] Completed 169800 out of 499375 steps (34%)
[00:59:28] Completed 174800 out of 499375 steps (35%)
[01:04:38] Completed 179800 out of 499375 steps (36%)
[01:09:46] Completed 184800 out of 499375 steps (37%)
[01:15:05] Completed 189800 out of 499375 steps (38%)
[01:19:52] Completed 194800 out of 499375 steps (39%)
[01:25:02] Completed 199800 out of 499375 steps (40%)
[01:30:24] Completed 204800 out of 499375 steps (41%)
[01:35:31] Completed 209800 out of 499375 steps (42%)
[01:40:53] Completed 214700 out of 499375 steps (42%)
[01:46:07] Completed 219700 out of 499375 steps (43%)
[01:51:12] Completed 224700 out of 499375 steps (44%)
[01:56:34] Completed 229700 out of 499375 steps (45%)
[02:02:10] Completed 234700 out of 499375 steps (46%)
[02:07:19] Completed 239700 out of 499375 steps (48%)
[02:12:30] Completed 244700 out of 499375 steps (49%)
[02:17:28] Completed 249700 out of 499375 steps (50%)
[02:17:38] ERROR: ProtoMol ERROR: ABORT
[02:17:38] Saving result file logfile_01.txt
[02:17:38] Saving result file checkpt
[02:17:38] Saving result file checkpt.crc
[02:17:38] Saving result file log.txt
[02:17:39] Saving result file protomol.conf
[02:17:39] Saving result file ww.13.pos
[02:17:39] Saving result file ww.13.vel
[02:17:39] Saving result file ww.dcd
[02:17:40] Folding@home Core Shutdown: BAD_WORK_UNIT
[02:17:43] CoreStatus = 62 (98)
[02:17:43] + Restarting core (settings changed)
[02:17:43]
[02:17:43] + Processing work unit
[02:17:43] Work type b4 not eligible for variable processors
[02:17:43] Core required: FahCore_b4.exe
[02:17:43] Core found.
[02:17:43] Working on queue slot 01 [May 14 02:17:43 UTC]
[02:17:43] + Working ...
[02:17:46] *********************** Log Started 14/May/2010 02:17:46 ***********************
[02:17:46] ************************** ProtoMol Folding@Home Core **************************
[02:17:46]   Version: 23
[02:17:46]      Type: 180
[02:17:46]      Core: ProtoMol
[02:17:46]   Website: http://folding.stanford.edu/
[02:17:46] Copyright: (c) 2009 Stanford University
[02:17:46]    Author: Joseph Coffland <joseph@cauldrondevelopment.com>
[02:17:46]      Args: -dir work/ -suffix 01 -checkpoint 15 -notermcheck -lifeline 2776
[02:17:46]            -version 629
[02:17:46] ************************************ Build *************************************
[02:17:46]      Date: Mar 22 2010
[02:17:46]      Time: 16:55:15
[02:17:46]  Revision: 1789
[02:17:46]  Compiler: Intel(R) C++ MSVC 1500 mode 1110
[02:17:46]   Options: /TP /nologo /EHsc /wd4297 /wd4103 /wd1786 /arch:IA32 /Ox
[02:17:46]            /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qrestrict /MT
[02:17:46]   Defines: _CRT_SECURE_NO_WARNINGS NDEBUG HAVE_GEEKINFO BOOST_ALL_NO_LIB
[02:17:46]            XML_STATIC HAVE_EXPAT HAVE_OPENSSL HAVE_LIBFAH HAVE_SIMTK_LAPACK
[02:17:46]  Platform: Windows XP
[02:17:46]      Bits: 32
[02:17:46]      Mode: Release
[02:17:46] ************************************ System ************************************
[02:17:46]        OS: Microsoft Windows 7 Professional
[02:17:46]       CPU: Intel(R) Core(TM) i3 CPU 540 @ 3.07GHz
[02:17:46]    CPU ID: GenuineIntel Family 6 Model 37 Stepping 2
[02:17:46]      CPUs: 16 Logical, 1 Physical
[02:17:46]    Memory: 3.87 GB
[02:17:46]   Threads: Windows
[02:17:46] ********************************************************************************
[02:17:46] Project: 10039 (Run 1201, Clone 0, Gen 0)
[02:17:46] Reading tar file par_all27_prot_lipid.inp
[02:17:46] Reading tar file scpismQuartic.inp
[02:17:46] Reading tar file ww.pdb
[02:17:46] Reading tar file ww.psf
[02:17:46] Reading tar file protomol.conf
[02:17:46] Reading tar file core.xml
[02:17:46] Digital signatures verified
[02:17:47] Completed 0 out of 499375 steps (0%)
[02:20:20] Completed 5000 out of 499375 steps (1%)
[02:22:56] Completed 10000 out of 499375 steps (2%)
[02:25:33] Completed 15000 out of 499375 steps (3%)
[02:28:17] Completed 20000 out of 499375 steps (4%)
[02:31:07] Completed 25000 out of 499375 steps (5%)
[02:34:04] Completed 30000 out of 499375 steps (6%)
[02:37:00] Completed 35000 out of 499375 steps (7%)
[02:40:05] Completed 40000 out of 499375 steps (8%)
[02:43:12] Completed 45000 out of 499375 steps (9%)
[02:46:22] Completed 50000 out of 499375 steps (10%)
[02:49:38] Completed 55000 out of 499375 steps (11%)
[02:53:06] Completed 60000 out of 499375 steps (12%)
[02:56:38] Completed 65000 out of 499375 steps (13%)
[03:00:14] Completed 70000 out of 499375 steps (14%)
[03:03:47] Completed 74900 out of 499375 steps (14%)
[03:07:31] Completed 79900 out of 499375 steps (16%)
[03:11:30] Completed 84900 out of 499375 steps (17%)
[03:15:35] Completed 89900 out of 499375 steps (18%)
[03:19:51] Completed 94900 out of 499375 steps (19%)
[03:24:27] Completed 99900 out of 499375 steps (20%)
[03:28:45] Completed 104900 out of 499375 steps (21%)
[03:33:24] Completed 109900 out of 499375 steps (22%)
[03:37:55] Completed 114900 out of 499375 steps (23%)
[03:42:25] Completed 119900 out of 499375 steps (24%)
[03:47:03] Completed 124900 out of 499375 steps (25%)
[03:51:32] Completed 129900 out of 499375 steps (26%)
[03:56:10] Completed 134900 out of 499375 steps (27%)
[04:00:54] Completed 139900 out of 499375 steps (28%)
[04:05:51] Completed 144800 out of 499375 steps (28%)
[04:11:10] Completed 149800 out of 499375 steps (29%)
[04:17:06] Completed 154800 out of 499375 steps (30%)
[04:23:00] Completed 159800 out of 499375 steps (32%)
[04:28:54] Completed 164800 out of 499375 steps (33%)
[04:34:32] Completed 169800 out of 499375 steps (34%)
[04:40:19] Completed 174800 out of 499375 steps (35%)
[04:45:47] Completed 179800 out of 499375 steps (36%)
[04:51:05] Completed 184800 out of 499375 steps (37%)
[04:56:34] Completed 189800 out of 499375 steps (38%)
[05:02:17] Completed 194800 out of 499375 steps (39%)
[05:07:45] Completed 199800 out of 499375 steps (40%)
[05:13:26] Completed 204800 out of 499375 steps (41%)
[05:19:00] Completed 209800 out of 499375 steps (42%)
Re: Project: 10039 (Run 1201, Clone 0, Gen 0)
It looks like a bad WU ... there's only one entry in the stats DB, and it's an error ...
I'll mark it as bad ... you should take you chance, stop the client, delete /work, queue.dat and fahcore_b4.exe. It will force an upgrade of the core to v24 and you might be able to get a new WU ...
codysluder
Post by codysluder »
Datsun 1600 wrote:Why is this WU doing the same frame twice?
It's not doing the same frame twice.
Divide 70000 steps by 499375 steps. What percent is that? Now divide 74900 by 499375. What percent is that? Now divide 79900 by 499375. What percent is that?
(See Bruce's answer here: viewtopic.php?f=47&t=14568&p=143256#p143256)
