Project: 6012 (Run 0, Clone 395, Gen 142)
staypuft
Post by staypuft »
This WU did not get past 0% with repeated failures, see below. This was the second WU assigned to this particular machine. Prior to successful completion of the first WU the install.bat would not complete without a Windows error. Renaming the .exe back to "Folding@home-Win32-x86" solved this problem. The client was installed in 'C:\FAH'
At some point in this process I decided to uninstall and reinstall to 'C:\Program Files' directory and not rename the .exe, copied the queue.dat, unitinfo.txt and work folder to new directory. Reran install.bat without issues. Started client, it pulled a new WU. Up to that point the same WU was being restarted over and over even though it was EUE twice. So far it's back up and running.
System:
Windows XP Pro 32-bit
No Firewall
AVG with FAH directories and files flagged as no scan, no autoprotect
C2D E6600, 2GB RAM
Question:
How do the 7 restarts of this same WU affect the bonus calc?
                       Folding@Home Client Version 6.29
                          http://folding.stanford.edu
Launch directory: C:\FAH
Executable: Folding@home-Win32-x86
Arguments: -smp -verbosity 9 -advmethods
[16:22:33] - Ask before connecting: No
[16:22:33] - User name: staypuft (Team 111065)
[16:22:33] - User ID:
[16:22:33] - Machine ID: 16
[16:22:33]
[16:22:33] Work directory not found. Creating...
[16:22:33] Could not open work queue, generating new queue...
[16:22:33] - Preparing to get new work unit...
[16:22:33] Cleaning up work directory
[16:22:33] + Attempting to get work packet
[16:22:33] Passkey found
[16:22:33] - Autosending finished units... [May 11 16:22:33 UTC]
[16:22:33] Trying to send all finished work units
[16:22:33] - Will indicate memory of 2046 MB
[16:22:33] + No unsent completed units remaining.
[16:22:33] - Autosend completed
[16:22:33] - Detect CPU. Vendor: GenuineIntel, Family: 6, Model: 15, Stepping: 6
[16:22:33] - Connecting to assignment server
[16:22:33] Connecting to http://assign.stanford.edu:8080/
[16:22:34] - Couldn't send HTTP request to server
[16:22:34] + Could not connect to Assignment Server
[16:22:34] Connecting to http://assign2.stanford.edu:80/
[16:22:35] Posted data.
[16:22:35] Initial: 0000; + No appropriate work server was available; will try again in a bit.
[16:22:35] + Couldn't get work instructions.
[16:22:35] - Attempt #1  to get work failed, and no other work to do.
Waiting before retry.
... <6 failed attempts>
[16:28:48] + Attempting to get work packet
[16:28:48] Passkey found
[16:28:48] - Will indicate memory of 2046 MB
[16:28:48] - Connecting to assignment server
[16:28:48] Connecting to http://assign.stanford.edu:8080/
[16:28:49] Posted data.
[16:28:49] Initial: 40AB; - Successful: assigned to (171.64.65.54).
[16:28:49] + News From Folding@Home: Welcome to Folding@Home
[16:28:49] Loaded queue successfully.
[16:28:49] Connecting to http://171.64.65.54:8080/
[16:28:50] Posted data.
[16:28:50] Initial: 0000; - Receiving payload (expected size: 1766105)
[16:29:01] - Downloaded at ~156 kB/s
[16:29:01] - Averaged speed for that direction ~156 kB/s
[16:29:01] + Received work.
[16:29:01] + Closed connections
[16:29:01]
[16:29:01] + Processing work unit
[16:29:01] Core required: FahCore_a3.exe
[16:29:01] Core not found.
[16:29:01] - Core is not present or corrupted.
[16:29:01] - Attempting to download new core...
[16:29:01] + Downloading new core: FahCore_a3.exe
[16:29:01] Downloading core (/~pande/Win32/x86/Core_a3.fah from www.stanford.edu)
[16:29:02] Initial: AFDE; + 10240 bytes downloaded
[16:29:15] Initial: 498B; + 2340489 bytes downloaded
[16:29:15] Verifying core Core_a3.fah...
[16:29:15] Signature is VALID
[16:29:15]
[16:29:15] Trying to unzip core FahCore_a3.exe
[16:29:17] Decompressed FahCore_a3.exe (8087552 bytes) successfully
[16:29:22] + Core successfully engaged
[16:29:27]
[16:29:27] + Processing work unit
[16:29:27] Core required: FahCore_a3.exe
[16:29:27] Core found.
[16:29:27] Working on queue slot 01 [May 11 16:29:27 UTC]
[16:29:27] + Working ...
[16:29:27] - Calling '.\FahCore_a3.exe -dir work/ -nice 19 -suffix 01 -np 2 -checkpoint 15 -verbose -lifeline 3676 -version 629'
[16:29:27]
[16:29:27] *------------------------------*
[16:29:27] Folding@Home Gromacs SMP Core
[16:29:27] Version 2.17 (Mar 12, 2010)
[16:29:27]
[16:29:27] Preparing to commence simulation
[16:29:27] - Looking at optimizations...
[16:29:27] - Created dyn
[16:29:27] - Files status OK
[16:29:27] - Expanded 1765593 -> 2250761 (decompressed 127.4 percent)
[16:29:27] Called DecompressByteArray: compressed_data_size=1765593 data_size=2250761, decompressed_data_size=2250761 diff=0
[16:29:27] - Digital signature verified
[16:29:27]
[16:29:27] Project: 6052 (Run 0, Clone 20, Gen 18)
[16:29:27]
[16:29:27] Assembly optimizations on if available.
[16:29:27] Entering M.D.
[16:29:34] Completed 0 out of 500000 steps  (0%)
[16:43:46] Completed 5000 out of 500000 steps  (1%)
[16:59:01] Completed 10000 out of 500000 steps  (2%)
[17:14:40] Completed 15000 out of 500000 steps  (3%)
[17:29:40] Completed 20000 out of 500000 steps  (4%)
[17:43:41] Completed 25000 out of 500000 steps  (5%)
[17:57:38] Completed 30000 out of 500000 steps  (6%)
[18:11:32] Completed 35000 out of 500000 steps  (7%)
[18:25:25] Completed 40000 out of 500000 steps  (8%)
[18:39:18] Completed 45000 out of 500000 steps  (9%)
[18:53:11] Completed 50000 out of 500000 steps  (10%)
[19:07:01] Completed 55000 out of 500000 steps  (11%)
[19:20:52] Completed 60000 out of 500000 steps  (12%)
[19:34:44] Completed 65000 out of 500000 steps  (13%)
[19:48:36] Completed 70000 out of 500000 steps  (14%)
[20:02:27] Completed 75000 out of 500000 steps  (15%)
[20:16:20] Completed 80000 out of 500000 steps  (16%)
[20:30:24] Completed 85000 out of 500000 steps  (17%)
[20:45:02] Completed 90000 out of 500000 steps  (18%)
[20:59:56] Completed 95000 out of 500000 steps  (19%)
[21:15:19] Completed 100000 out of 500000 steps  (20%)
[21:30:48] Completed 105000 out of 500000 steps  (21%)
[21:45:14] Completed 110000 out of 500000 steps  (22%)
[21:59:00] Completed 115000 out of 500000 steps  (23%)
[22:12:48] Completed 120000 out of 500000 steps  (24%)
[22:22:33] - Autosending finished units... [May 11 22:22:33 UTC]
[22:22:33] Trying to send all finished work units
[22:22:33] + No unsent completed units remaining.
[22:22:33] - Autosend completed
[22:26:34] Completed 125000 out of 500000 steps  (25%)
[22:40:20] Completed 130000 out of 500000 steps  (26%)
[22:54:07] Completed 135000 out of 500000 steps  (27%)
[23:07:54] Completed 140000 out of 500000 steps  (28%)
[23:21:41] Completed 145000 out of 500000 steps  (29%)
[23:35:40] Completed 150000 out of 500000 steps  (30%)
[23:49:27] Completed 155000 out of 500000 steps  (31%)
[00:03:13] Completed 160000 out of 500000 steps  (32%)
[00:17:01] Completed 165000 out of 500000 steps  (33%)
[00:30:49] Completed 170000 out of 500000 steps  (34%)
[00:44:35] Completed 175000 out of 500000 steps  (35%)
[00:58:22] Completed 180000 out of 500000 steps  (36%)
[01:12:07] Completed 185000 out of 500000 steps  (37%)
[01:25:54] Completed 190000 out of 500000 steps  (38%)
[01:39:41] Completed 195000 out of 500000 steps  (39%)
[01:53:27] Completed 200000 out of 500000 steps  (40%)
[02:07:14] Completed 205000 out of 500000 steps  (41%)
[02:21:02] Completed 210000 out of 500000 steps  (42%)
[02:34:51] Completed 215000 out of 500000 steps  (43%)
[02:48:38] Completed 220000 out of 500000 steps  (44%)
[03:02:25] Completed 225000 out of 500000 steps  (45%)
[03:16:13] Completed 230000 out of 500000 steps  (46%)
[03:30:00] Completed 235000 out of 500000 steps  (47%)
[03:43:47] Completed 240000 out of 500000 steps  (48%)
[03:57:36] Completed 245000 out of 500000 steps  (49%)
[04:11:23] Completed 250000 out of 500000 steps  (50%)
[04:22:33] - Autosending finished units... [May 12 04:22:33 UTC]
[04:22:33] Trying to send all finished work units
[04:22:33] + No unsent completed units remaining.
[04:22:33] - Autosend completed
[04:25:12] Completed 255000 out of 500000 steps  (51%)
[04:38:59] Completed 260000 out of 500000 steps  (52%)
[04:52:46] Completed 265000 out of 500000 steps  (53%)
[05:06:34] Completed 270000 out of 500000 steps  (54%)
[05:20:23] Completed 275000 out of 500000 steps  (55%)
[05:34:11] Completed 280000 out of 500000 steps  (56%)
[05:48:00] Completed 285000 out of 500000 steps  (57%)
[06:01:48] Completed 290000 out of 500000 steps  (58%)
[06:15:36] Completed 295000 out of 500000 steps  (59%)
[06:29:24] Completed 300000 out of 500000 steps  (60%)
[06:43:11] Completed 305000 out of 500000 steps  (61%)
[06:56:58] Completed 310000 out of 500000 steps  (62%)
[07:10:44] Completed 315000 out of 500000 steps  (63%)
[07:24:33] Completed 320000 out of 500000 steps  (64%)
[07:38:20] Completed 325000 out of 500000 steps  (65%)
[07:52:07] Completed 330000 out of 500000 steps  (66%)
[08:05:53] Completed 335000 out of 500000 steps  (67%)
[08:19:40] Completed 340000 out of 500000 steps  (68%)
[08:33:37] Completed 345000 out of 500000 steps  (69%)
[08:47:24] Completed 350000 out of 500000 steps  (70%)
[09:01:12] Completed 355000 out of 500000 steps  (71%)
[09:15:00] Completed 360000 out of 500000 steps  (72%)
[09:28:48] Completed 365000 out of 500000 steps  (73%)
[09:42:35] Completed 370000 out of 500000 steps  (74%)
[09:56:21] Completed 375000 out of 500000 steps  (75%)
[10:10:09] Completed 380000 out of 500000 steps  (76%)
[10:22:34] - Autosending finished units... [May 12 10:22:34 UTC]
[10:22:34] Trying to send all finished work units
[10:22:34] + No unsent completed units remaining.
[10:22:34] - Autosend completed
[10:23:58] Completed 385000 out of 500000 steps  (77%)
[10:37:47] Completed 390000 out of 500000 steps  (78%)
[10:51:35] Completed 395000 out of 500000 steps  (79%)
[11:05:23] Completed 400000 out of 500000 steps  (80%)
[11:19:12] Completed 405000 out of 500000 steps  (81%)
[11:33:01] Completed 410000 out of 500000 steps  (82%)
[11:46:51] Completed 415000 out of 500000 steps  (83%)
[12:00:45] Completed 420000 out of 500000 steps  (84%)
[12:15:27] Completed 425000 out of 500000 steps  (85%)
[12:30:20] Completed 430000 out of 500000 steps  (86%)
[12:45:06] Completed 435000 out of 500000 steps  (87%)
[12:59:12] Completed 440000 out of 500000 steps  (88%)
[13:13:36] Completed 445000 out of 500000 steps  (89%)
[13:27:56] Completed 450000 out of 500000 steps  (90%)
[13:42:12] Completed 455000 out of 500000 steps  (91%)
[13:56:17] Completed 460000 out of 500000 steps  (92%)
[14:11:15] Completed 465000 out of 500000 steps  (93%)
[14:26:20] Completed 470000 out of 500000 steps  (94%)
[14:40:34] Completed 475000 out of 500000 steps  (95%)
[14:54:42] Completed 480000 out of 500000 steps  (96%)
[15:09:30] Completed 485000 out of 500000 steps  (97%)
[15:24:59] Completed 490000 out of 500000 steps  (98%)
[15:39:06] Completed 495000 out of 500000 steps  (99%)
[15:53:43] Completed 500000 out of 500000 steps  (100%)
[15:53:44] DynamicWrapper: Finished Work Unit: sleep=10000
[15:53:54]
[15:53:54] Finished Work Unit:
[15:53:54] - Reading up to 3698496 from "work/wudata_01.trr": Read 3698496
[15:53:54] trr file hash check passed.
[15:53:54] edr file hash check passed.
[15:53:54] logfile size: 59746
[15:53:54] Leaving Run
[15:53:57] - Writing 3793394 bytes of core data to disk...
[15:54:02]   ... Done.
[15:54:04] - Shutting down core
[15:54:04]
[15:54:04] Folding@home Core Shutdown: FINISHED_UNIT
[15:54:06] CoreStatus = 64 (100)
[15:54:06] Unit 1 finished with 84 percent of time to deadline remaining.
[15:54:06] Updated performance fraction: 0.837375
[15:54:06] Sending work to server
[15:54:06] Project: 6052 (Run 0, Clone 20, Gen 18)
[15:54:06] + Attempting to send results [May 12 15:54:06 UTC]
[15:54:06] - Reading file work/wuresults_01.dat from core
[15:54:06]   (Read 3793394 bytes from disk)
[15:54:06] Connecting to http://171.64.65.54:8080/
[15:54:20] Posted data.
[15:54:21] Initial: 0000; - Uploaded at ~247 kB/s
[15:54:21] - Averaged speed for that direction ~247 kB/s
[15:54:21] + Results successfully sent
[15:54:21] Thank you for your contribution to Folding@Home.
[15:54:21] + Starting local stats count at 1
[15:54:25] Trying to send all finished work units
[15:54:25] + No unsent completed units remaining.
[15:54:25] - Preparing to get new work unit...
[15:54:25] Cleaning up work directory
[15:54:25] + Attempting to get work packet
[15:54:25] Passkey found
[15:54:25] - Will indicate memory of 2046 MB
[15:54:25] - Connecting to assignment server
[15:54:25] Connecting to http://assign.stanford.edu:8080/
[15:54:26] Posted data.
[15:54:26] Initial: ED82; - Successful: assigned to (130.237.232.140).
[15:54:26] + News From Folding@Home: Welcome to Folding@Home
[15:54:26] Loaded queue successfully.
[15:54:26] Connecting to http://130.237.232.140:8080/
[15:54:27] Posted data.
[15:54:27] Initial: 0000; - Receiving payload (expected size: 1797411)
[15:54:46] - Downloaded at ~92 kB/s
[15:54:46] - Averaged speed for that direction ~124 kB/s
[15:54:46] + Received work.
[15:54:46] Trying to send all finished work units
[15:54:46] + No unsent completed units remaining.
[15:54:46] + Closed connections
[15:54:46]
[15:54:46] + Processing work unit
[15:54:46] Core required: FahCore_a3.exe
[15:54:46] Core found.
[15:54:46] Working on queue slot 02 [May 12 15:54:46 UTC]
[15:54:46] + Working ...
[15:54:46] - Calling '.\FahCore_a3.exe -dir work/ -nice 19 -suffix 02 -np 2 -checkpoint 15 -verbose -lifeline 3676 -version 629'
[15:54:46]
[15:54:46] *------------------------------*
[15:54:46] Folding@Home Gromacs SMP Core
[15:54:46] Version 2.17 (Mar 12, 2010)
[15:54:46]
[15:54:46] Preparing to commence simulation
[15:54:46] - Looking at optimizations...
[15:54:46] - Created dyn
[15:54:46] - Files status OK
[15:54:47] - Expanded 1796899 -> 2078149 (decompressed 115.6 percent)
[15:54:47] Called DecompressByteArray: compressed_data_size=1796899 data_size=2078149, decompressed_data_size=2078149 diff=0
[15:54:47] - Digital signature verified
[15:54:47]
[15:54:47] Project: 6012 (Run 0, Clone 395, Gen 142)
[15:54:47]
[15:54:47] Assembly optimizations on if available.
[15:54:47] Entering M.D.
[15:54:53] Completed 0 out of 500000 steps  (0%)
[15:55:03] CoreStatus = C0000029 (-1073741783)
[15:55:03] Client-core communications error: ERROR 0xc0000029
[15:55:03] Deleting current work unit & continuing...
[15:55:15] Trying to send all finished work units
[15:55:15] + No unsent completed units remaining.
[15:55:15] - Preparing to get new work unit...
[15:55:15] Cleaning up work directory
[15:55:15] + Attempting to get work packet
[15:55:15] Passkey found
[15:55:15] - Will indicate memory of 2046 MB
[15:55:15] - Connecting to assignment server
[15:55:15] Connecting to http://assign.stanford.edu:8080/
[15:55:15] Posted data.
[15:55:15] Initial: ED82; - Successful: assigned to (130.237.232.140).
[15:55:15] + News From Folding@Home: Welcome to Folding@Home
[15:55:15] Loaded queue successfully.
[15:55:15] Connecting to http://130.237.232.140:8080/
[15:55:16] Posted data.
[15:55:16] Initial: 0000; - Receiving payload (expected size: 1797411)
[15:55:23] - Downloaded at ~250 kB/s
[15:55:23] - Averaged speed for that direction ~166 kB/s
[15:55:23] + Received work.
[15:55:23] + Closed connections
[15:55:28]
[15:55:28] + Processing work unit
[15:55:28] Core required: FahCore_a3.exe
[15:55:28] Core found.
[15:55:28] Working on queue slot 03 [May 12 15:55:28 UTC]
[15:55:28] + Working ...
[15:55:28] - Calling '.\FahCore_a3.exe -dir work/ -nice 19 -suffix 03 -np 2 -checkpoint 15 -verbose -lifeline 3676 -version 629'
[15:55:28]
[15:55:28] *------------------------------*
[15:55:28] Folding@Home Gromacs SMP Core
[15:55:28] Version 2.17 (Mar 12, 2010)
[15:55:28]
[15:55:28] Preparing to commence simulation
[15:55:28] - Looking at optimizations...
[15:55:28] - Created dyn
[15:55:28] - Files status OK
[15:55:29] - Expanded 1796899 -> 2078149 (decompressed 115.6 percent)
[15:55:29] Called DecompressByteArray: compressed_data_size=1796899 data_size=2078149, decompressed_data_size=2078149 diff=0
[15:55:29] - Digital signature verified
[15:55:29]
[15:55:29] Project: 6012 (Run 0, Clone 395, Gen 142)
[15:55:29]
[15:55:29] Assembly optimizations on if available.
[15:55:29] Entering M.D.
[15:55:35] Completed 0 out of 500000 steps  (0%)
...<Windows error thrown and client frozen>
[15:56:02] Killing all core threads
[15:56:02] Could not get process id information.  Please kill core process manually
Folding@Home Client Shutdown at user request.
[15:56:02] ***** Got a SIGTERM signal (2)
Folding@Home Client Shutdown.
...<restarted client>
--- Opening Log file [May 12 15:59:36 UTC]
[15:59:36] - Ask before connecting: No
[15:59:36] - User name: staypuft (Team 111065)
[15:59:36] - User ID:
[15:59:36] - Machine ID: 16
[15:59:36]
[15:59:36] Loaded queue successfully.
[15:59:36]
[15:59:36] - Autosending finished units... [May 12 15:59:36 UTC]
[15:59:36] + Processing work unit
[15:59:36] Trying to send all finished work units
[15:59:36] Core required: FahCore_a3.exe
[15:59:36] + No unsent completed units remaining.
[15:59:36] - Autosend completed
[15:59:36] Core found.
[15:59:36] Working on queue slot 03 [May 12 15:59:36 UTC]
[15:59:36] + Working ...
[15:59:36] - Calling '.\FahCore_a3.exe -dir work/ -nice 19 -suffix 03 -np 2 -checkpoint 15 -verbose -lifeline 5912 -version 629'
[15:59:37]
[15:59:37] *------------------------------*
[15:59:37] Folding@Home Gromacs SMP Core
[15:59:37] Version 2.17 (Mar 12, 2010)
[15:59:37]
[15:59:37] Preparing to commence simulation
[15:59:37] - Ensuring status. Please wait.
[15:59:46] - Looking at optimizations...
[15:59:46] - Working with standard loops on this execution.
[15:59:46] - Previous termination of core was improper.
[15:59:46] - Files status OK
[15:59:47] - Expanded 1796899 -> 2078149 (decompressed 115.6 percent)
[15:59:47] Called DecompressByteArray: compressed_data_size=1796899 data_size=2078149, decompressed_data_size=2078149 diff=0
[15:59:47] - Digital signature verified
[15:59:47]
[15:59:47] Project: 6012 (Run 0, Clone 395, Gen 142)
[15:59:47]
[15:59:47] Entering M.D.
[15:59:53] Completed 0 out of 500000 steps  (0%)
[16:00:13] CoreStatus = C0000029 (-1073741783)
[16:00:13] Client-core communications error: ERROR 0xc0000029
[16:00:13] Deleting current work unit & continuing...
[16:00:25] Trying to send all finished work units
[16:00:25] + No unsent completed units remaining.
[16:00:25] - Preparing to get new work unit...
[16:00:25] Cleaning up work directory
[16:00:25] + Attempting to get work packet
[16:00:25] Passkey found
[16:00:25] - Will indicate memory of 2046 MB
[16:00:25] - Detect CPU. Vendor: GenuineIntel, Family: 6, Model: 15, Stepping: 6
[16:00:25] - Connecting to assignment server
[16:00:25] Connecting to http://assign.stanford.edu:8080/
[16:00:25] Posted data.
[16:00:25] Initial: ED82; - Successful: assigned to (130.237.232.140).
[16:00:25] + News From Folding@Home: Welcome to Folding@Home
[16:00:25] Loaded queue successfully.
[16:00:25] Connecting to http://130.237.232.140:8080/
[16:00:26] Posted data.
[16:00:26] Initial: 0000; - Receiving payload (expected size: 1797411)
[16:00:39] - Downloaded at ~135 kB/s
[16:00:39] - Averaged speed for that direction ~158 kB/s
[16:00:39] + Received work.
[16:00:39] + Closed connections
[16:00:44]
[16:00:44] + Processing work unit
[16:00:44] Core required: FahCore_a3.exe
[16:00:44] Core found.
[16:00:44] Working on queue slot 04 [May 12 16:00:44 UTC]
[16:00:44] + Working ...
[16:00:44] - Calling '.\FahCore_a3.exe -dir work/ -nice 19 -suffix 04 -np 2 -checkpoint 15 -verbose -lifeline 5912 -version 629'
[16:00:44]
[16:00:44] *------------------------------*
[16:00:44] Folding@Home Gromacs SMP Core
[16:00:44] Version 2.17 (Mar 12, 2010)
[16:00:44]
[16:00:44] Preparing to commence simulation
[16:00:44] - Looking at optimizations...
[16:00:44] - Created dyn
[16:00:44] - Files status OK
[16:00:45] - Expanded 1796899 -> 2078149 (decompressed 115.6 percent)
[16:00:45] Called DecompressByteArray: compressed_data_size=1796899 data_size=2078149, decompressed_data_size=2078149 diff=0
[16:00:45] - Digital signature verified
[16:00:45]
[16:00:45] Project: 6012 (Run 0, Clone 395, Gen 142)
[16:00:45]
[16:00:45] Assembly optimizations on if available.
[16:00:45] Entering M.D.
[16:00:51] Completed 0 out of 500000 steps  (0%)
...<Windows error thrown>
[16:00:51] Caught exception!
[16:00:51] mdrun returned 255
[16:00:51] Going to send back what have done -- stepsTotalG=500000
[16:00:51] Work fraction=0.0000 steps=500000.
[16:00:55] logfile size=11765 infoLength=11765 edr=0 trr=25
[16:00:55] logfile size: 11765 info=11765 bed=0 hdr=25
[16:00:55] - Writing 12303 bytes of core data to disk...
[16:00:55]   ... Done.
[16:00:56]
[16:00:56] Folding@home Core Shutdown: EARLY_UNIT_END
[16:00:58] CoreStatus = 72 (114)
[16:00:58] Sending work to server
[16:00:58] Project: 6012 (Run 0, Clone 395, Gen 142)
[16:00:58] + Attempting to send results [May 12 16:00:58 UTC]
[16:00:58] - Reading file work/wuresults_04.dat from core
[16:00:58]   (Read 12303 bytes from disk)
[16:00:58] Connecting to http://130.237.232.140:8080/
[16:00:59] Posted data.
[16:00:59] Initial: 0000; - Uploaded at ~13 kB/s
[16:00:59] - Averaged speed for that direction ~130 kB/s
[16:00:59] + Results successfully sent
[16:00:59] Thank you for your contribution to Folding@Home.
[16:01:03] Trying to send all finished work units
[16:01:03] + No unsent completed units remaining.
[16:01:03] - Preparing to get new work unit...
[16:01:03] Cleaning up work directory
[16:01:03] + Attempting to get work packet
[16:01:03] Passkey found
[16:01:03] - Will indicate memory of 2046 MB
[16:01:03] - Connecting to assignment server
[16:01:03] Connecting to http://assign.stanford.edu:8080/
[16:01:04] Posted data.
[16:01:04] Initial: ED82; - Successful: assigned to (130.237.232.140).
[16:01:04] + News From Folding@Home: Welcome to Folding@Home
[16:01:04] Loaded queue successfully.
[16:01:04] Connecting to http://130.237.232.140:8080/
[16:01:05] Posted data.
[16:01:05] Initial: 0000; - Receiving payload (expected size: 1797411)
[16:01:13] - Downloaded at ~219 kB/s
[16:01:44] - Averaged speed for that direction ~170 kB/s
[16:01:44] + Received work.
[16:01:44] Trying to send all finished work units
[16:01:44] + No unsent completed units remaining.
[16:01:44] + Closed connections
[16:01:49]
[16:01:49] + Processing work unit
[16:01:49] Core required: FahCore_a3.exe
[16:01:49] Core found.
[16:01:49] Working on queue slot 05 [May 12 16:01:49 UTC]
[16:01:49] + Working ...
[16:01:49] - Calling '.\FahCore_a3.exe -dir work/ -nice 19 -suffix 05 -np 2 -checkpoint 15 -verbose -lifeline 5912 -version 629'
[16:01:49]
[16:01:49] *------------------------------*
[16:01:49] Folding@Home Gromacs SMP Core
[16:01:49] Version 2.17 (Mar 12, 2010)
[16:01:49]
[16:01:49] Preparing to commence simulation
[16:01:49] - Looking at optimizations...
[16:01:49] - Created dyn
[16:01:49] - Files status OK
[16:01:49] - Expanded 1796899 -> 2078149 (decompressed 115.6 percent)
[16:01:49] Called DecompressByteArray: compressed_data_size=1796899 data_size=2078149, decompressed_data_size=2078149 diff=0
[16:01:49] - Digital signature verified
[16:01:49]
[16:01:49] Project: 6012 (Run 0, Clone 395, Gen 142)
[16:01:49]
[16:01:49] Assembly optimizations on if available.
[16:01:49] Entering M.D.
[16:01:56] Completed 0 out of 500000 steps  (0%)
[16:01:56] Caught exception!
[16:01:56] mdrun returned 255
[16:01:56] Going to send back what have done -- stepsTotalG=500000
[16:01:56] Work fraction=0.0000 steps=500000.
[16:02:00] logfile size=11765 infoLength=11765 edr=0 trr=25
[16:02:00] logfile size: 11765 info=11765 bed=0 hdr=25
[16:02:00] - Writing 12303 bytes of core data to disk...
[16:02:00]   ... Done.
[16:02:00]
[16:02:00] Folding@home Core Shutdown: EARLY_UNIT_END
[16:02:03] CoreStatus = 72 (114)
[16:02:03] Sending work to server
[16:02:03] Project: 6012 (Run 0, Clone 395, Gen 142)
[16:02:03] + Attempting to send results [May 12 16:02:03 UTC]
[16:02:03] - Reading file work/wuresults_05.dat from core
[16:02:03]   (Read 12303 bytes from disk)
[16:02:03] Connecting to http://130.237.232.140:8080/
[16:02:04] Posted data.
[16:02:04] Initial: 0000; - Uploaded at ~13 kB/s
[16:02:04] - Averaged speed for that direction ~91 kB/s
[16:02:04] + Results successfully sent
[16:02:04] Thank you for your contribution to Folding@Home.
[16:02:08] Trying to send all finished work units
[16:02:08] + No unsent completed units remaining.
[16:02:08] - Preparing to get new work unit...
[16:02:08] Cleaning up work directory
[16:02:08] + Attempting to get work packet
[16:02:08] Passkey found
[16:02:08] - Will indicate memory of 2046 MB
[16:02:08] - Connecting to assignment server
[16:02:08] Connecting to http://assign.stanford.edu:8080/
[16:02:08] Posted data.
[16:02:08] Initial: ED82; - Successful: assigned to (130.237.232.140).
[16:02:08] + News From Folding@Home: Welcome to Folding@Home
[16:02:09] Loaded queue successfully.
[16:02:09] Connecting to http://130.237.232.140:8080/
[16:02:09] Posted data.
[16:02:09] Initial: 0000; - Receiving payload (expected size: 1797411)
[16:02:18] - Downloaded at ~195 kB/s
[16:02:20] - Averaged speed for that direction ~175 kB/s
[16:02:20] + Received work.
[16:02:20] Trying to send all finished work units
[16:02:20] + No unsent completed units remaining.
[16:02:20] + Closed connections
[16:02:25]
[16:02:27] + Processing work unit
[16:02:27] Core required: FahCore_a3.exe
[16:02:27] Core found.
[16:02:27] Working on queue slot 06 [May 12 16:02:27 UTC]
[16:02:27] + Working ...
[16:02:27] - Calling '.\FahCore_a3.exe -dir work/ -nice 19 -suffix 06 -np 2 -checkpoint 15 -verbose -lifeline 5912 -version 629'
[16:02:27]
[16:02:27] *------------------------------*
[16:02:27] Folding@Home Gromacs SMP Core
[16:02:27] Version 2.17 (Mar 12, 2010)
[16:02:27]
[16:02:27] Preparing to commence simulation
[16:02:27] - Looking at optimizations...
[16:02:27] - Created dyn
[16:02:27] - Files status OK
[16:02:28] - Expanded 1796899 -> 2078149 (decompressed 115.6 percent)
[16:02:28] Called DecompressByteArray: compressed_data_size=1796899 data_size=2078149, decompressed_data_size=2078149 diff=0
[16:02:28] - Digital signature verified
[16:02:28]
[16:02:28] Project: 6012 (Run 0, Clone 395, Gen 142)
[16:02:28]
[16:02:28] Assembly optimizations on if available.
[16:02:28] Entering M.D.
[16:02:34] Completed 0 out of 500000 steps  (0%)
[16:02:37] Killing all core threads
[16:02:37] Could not get process id information.  Please kill core process manually
[16:02:38] ***** Got a SIGTERM signal (2)
[16:02:38] Killing all core threads
[16:02:38] Could not get process id information.  Please kill core process manually
--- Opening Log file [May 12 17:24:06 UTC]
[17:24:06] - Ask before connecting: No
[17:24:06] - User name: staypuft (Team 111065)
[17:24:06] - User ID:
[17:24:06] - Machine ID: 16
[17:24:06]
[17:24:07] Loaded queue successfully.
[17:24:07]
[17:24:07] + Processing work unit
[17:24:07] Core required: FahCore_a3.exe
[17:24:07] - Autosending finished units... [May 12 17:24:07 UTC]
[17:24:07] Trying to send all finished work units
[17:24:07] Core found.
[17:24:07] + No unsent completed units remaining.
[17:24:07] - Autosend completed
[17:24:07] Working on queue slot 06 [May 12 17:24:07 UTC]
[17:24:07] + Working ...
[17:24:07] - Calling '.\FahCore_a3.exe -dir work/ -nice 19 -suffix 06 -np 2 -checkpoint 15 -verbose -lifeline 3272 -version 629'
[17:24:07]
[17:24:07] *------------------------------*
[17:24:07] Folding@Home Gromacs SMP Core
[17:24:07] Version 2.17 (Mar 12, 2010)
[17:24:07]
[17:24:07] Preparing to commence simulation
[17:24:07] - Ensuring status. Please wait.
[17:24:17] - Looking at optimizations...
[17:24:17] - Working with standard loops on this execution.
[17:24:17] - Previous termination of core was improper.
[17:24:17] - Files status OK
[17:24:18] - Expanded 1796899 -> 2078149 (decompressed 115.6 percent)
[17:24:18] Called DecompressByteArray: compressed_data_size=1796899 data_size=2078149, decompressed_data_size=2078149 diff=0
[17:24:18] - Digital signature verified
[17:24:18]
[17:24:18] Project: 6012 (Run 0, Clone 395, Gen 142)
[17:24:18]
[17:24:19] Entering M.D.
[17:24:31] Completed 0 out of 500000 steps  (0%)
[17:24:48] CoreStatus = C0000029 (-1073741783)
[17:24:48] Client-core communications error: ERROR 0xc0000029
[17:24:48] Deleting current work unit & continuing...
[17:24:51] Killing all core threads
[17:24:51] Could not get process id information.  Please kill core process manually
[17:24:51] ***** Got a SIGTERM signal (2)
...<renamed client to fah6.exe>
--- Opening Log file [May 12 17:25:29 UTC]
Executable: fah6
[17:25:29] - Ask before connecting: No
[17:25:29] - User name: staypuft (Team 111065)
[17:25:29] - User ID:
[17:25:29] - Machine ID: 16
[17:25:29]
[17:25:29] Loaded queue successfully.
[17:25:29]
[17:25:29] + Processing work unit
[17:25:29] - Autosending finished units... [May 12 17:25:29 UTC]
[17:25:29] Trying to send all finished work units
[17:25:29] Core required: FahCore_a3.exe
[17:25:29] + No unsent completed units remaining.
[17:25:29] - Autosend completed
[17:25:29] Core found.
[17:25:29] Working on queue slot 06 [May 12 17:25:29 UTC]
[17:25:29] + Working ...
[17:25:29] - Calling '.\FahCore_a3.exe -dir work/ -nice 19 -suffix 06 -np 2 -checkpoint 15 -verbose -lifeline 2364 -version 629'
[17:25:29]
[17:25:29] *------------------------------*
[17:25:29] Folding@Home Gromacs SMP Core
[17:25:29] Version 2.17 (Mar 12, 2010)
[17:25:29]
[17:25:29] Preparing to commence simulation
[17:25:29] - Looking at optimizations...
[17:25:29] - Files status OK
[17:25:30] - Expanded 1796899 -> 2078149 (decompressed 115.6 percent)
[17:25:30] Called DecompressByteArray: compressed_data_size=1796899 data_size=2078149, decompressed_data_size=2078149 diff=0
[17:25:30] - Digital signature verified
[17:25:30]
[17:25:30] Project: 6012 (Run 0, Clone 395, Gen 142)
[17:25:30]
[17:25:31] Assembly optimizations on if available.
[17:25:31] Entering M.D.
[17:25:38] Completed 0 out of 500000 steps  (0%)
[17:25:38] Caught exception!
[17:25:38] mdrun returned 255
[17:25:38] Going to send back what have done -- stepsTotalG=500000
[17:25:38] Work fraction=0.0000 steps=500000.
[17:25:42] logfile size=11765 infoLength=11765 edr=0 trr=25
[17:25:42] logfile size: 11765 info=11765 bed=0 hdr=25
[17:25:42] - Writing 12303 bytes of core data to disk...
[17:25:45]   ... Done.
[17:25:46]
[17:25:46] Folding@home Core Shutdown: EARLY_UNIT_END
[17:25:50] CoreStatus = 72 (114)
[17:25:50] Sending work to server
[17:25:50] Project: 6012 (Run 0, Clone 395, Gen 142)
[17:25:50] + Attempting to send results [May 12 17:25:50 UTC]
[17:25:50] - Reading file work/wuresults_06.dat from core
[17:25:50]   (Read 12303 bytes from disk)
[17:25:50] Connecting to http://130.237.232.140:8080/
[17:25:51] Posted data.
[17:25:51] Initial: 0000; - Uploaded at ~13 kB/s
[17:25:51] - Averaged speed for that direction ~71 kB/s
[17:25:51] + Results successfully sent
[17:25:51] Thank you for your contribution to Folding@Home.
[17:25:55] Trying to send all finished work units
[17:25:55] + No unsent completed units remaining.
[17:25:55] - Preparing to get new work unit...
[17:25:55] Cleaning up work directory
[17:25:55] + Attempting to get work packet
[17:25:55] Passkey found
[17:25:55] - Will indicate memory of 2046 MB
[17:25:55] - Detect CPU. Vendor: GenuineIntel, Family: 6, Model: 15, Stepping: 6
[17:25:55] - Connecting to assignment server
[17:25:55] Connecting to http://assign.stanford.edu:8080/
[17:25:56] Posted data.
[17:25:56] Initial: ED82; - Successful: assigned to (130.237.232.140).
[17:25:56] + News From Folding@Home: Welcome to Folding@Home
[17:25:56] Loaded queue successfully.
[17:25:56] Connecting to http://130.237.232.140:8080/
[17:25:57] Posted data.
[17:25:57] Initial: 0000; - Receiving payload (expected size: 1797411)
[17:26:09] - Downloaded at ~146 kB/s
[17:26:09] - Averaged speed for that direction ~169 kB/s
[17:26:09] + Received work.
[17:26:09] Trying to send all finished work units
[17:26:09] + No unsent completed units remaining.
[17:26:09] + Closed connections
[17:26:14]
[17:26:14] + Processing work unit
[17:26:14] Core required: FahCore_a3.exe
[17:26:14] Core found.
[17:26:14] Working on queue slot 07 [May 12 17:26:14 UTC]
[17:26:14] + Working ...
[17:26:14] - Calling '.\FahCore_a3.exe -dir work/ -nice 19 -suffix 07 -np 2 -checkpoint 15 -verbose -lifeline 2364 -version 629'
[17:26:14]
[17:26:14] *------------------------------*
[17:26:14] Folding@Home Gromacs SMP Core
[17:26:14] Version 2.17 (Mar 12, 2010)
[17:26:14]
[17:26:14] Preparing to commence simulation
[17:26:14] - Looking at optimizations...
[17:26:14] - Created dyn
[17:26:14] - Files status OK
[17:26:15] - Expanded 1796899 -> 2078149 (decompressed 115.6 percent)
[17:26:15] Called DecompressByteArray: compressed_data_size=1796899 data_size=2078149, decompressed_data_size=2078149 diff=0
[17:26:15] - Digital signature verified
[17:26:15]
[17:26:15] Project: 6012 (Run 0, Clone 395, Gen 142)
[17:26:15]
[17:26:15] Assembly optimizations on if available.
[17:26:15] Entering M.D.
[17:26:21] Completed 0 out of 500000 steps  (0%)
[17:26:24] Killing all core threads
[17:26:24] Could not get process id information.  Please kill core process manually
[17:26:24] ***** Got a SIGTERM signal (2)
...<deleted FahCore_A3.exe>
--- Opening Log file [May 12 17:30:47 UTC]
Executable: fah6
[17:30:47] - Ask before connecting: No
[17:30:47] - User name: staypuft (Team 111065)
[17:30:47] - User ID:
[17:30:47] - Machine ID: 16
[17:30:47]
[17:30:47] Loaded queue successfully.
[17:30:47]
[17:30:47] - Autosending finished units... [May 12 17:30:47 UTC]
[17:30:47] + Processing work unit
[17:30:47] Trying to send all finished work units
[17:30:47] Core required: FahCore_a3.exe
[17:30:47] + No unsent completed units remaining.
[17:30:47] - Autosend completed
[17:30:47] Core not found.
[17:30:47] - Core is not present or corrupted.
[17:30:47] - Attempting to download new core...
[17:30:47] + Downloading new core: FahCore_a3.exe
[17:30:47] Downloading core (/~pande/Win32/x86/Core_a3.fah from www.stanford.edu)
[17:30:47] Initial: AFDE; + 10240 bytes downloaded
[17:30:48] Initial: 498B; + 2340489 bytes downloaded
[17:30:48] Verifying core Core_a3.fah...
[17:30:48] Signature is VALID
[17:30:48]
[17:30:48] Trying to unzip core FahCore_a3.exe
[17:30:49] Decompressed FahCore_a3.exe (8087552 bytes) successfully
[17:30:54] + Core successfully engaged
[17:30:59]
[17:31:09] + Processing work unit
[17:31:09] Core required: FahCore_a3.exe
[17:31:09] Core found.
[17:31:09] Working on queue slot 07 [May 12 17:31:09 UTC]
[17:31:09] + Working ...
[17:31:09] - Calling '.\FahCore_a3.exe -dir work/ -nice 19 -suffix 07 -np 2 -checkpoint 15 -verbose -lifeline 3744 -version 629'
[17:31:09]
[17:31:09] *------------------------------*
[17:31:09] Folding@Home Gromacs SMP Core
[17:31:09] Version 2.17 (Mar 12, 2010)
[17:31:09]
[17:31:09] Preparing to commence simulation
[17:31:09] - Ensuring status. Please wait.
[17:31:19] - Looking at optimizations...
[17:31:24] - Working with standard loops on this execution.
[17:31:24] - Previous termination of core was improper.
[17:31:24] - Files status OK
[17:31:24] - Expanded 1796899 -> 2078149 (decompressed 115.6 percent)
[17:31:24] Called DecompressByteArray: compressed_data_size=1796899 data_size=2078149, decompressed_data_size=2078149 diff=0
[17:31:24] - Digital signature verified
[17:31:24]
[17:31:24] Project: 6012 (Run 0, Clone 395, Gen 142)
[17:31:24]
[17:31:24] Entering M.D.
[17:31:26] Completed 0 out of 500000 steps  (0%)
[17:34:12] CoreStatus = C0000029 (-1073741783)
[17:34:12] Client-core communications error: ERROR 0xc0000029
[17:34:12] Deleting current work unit & continuing...
[17:34:24] Trying to send all finished work units
[17:34:24] + No unsent completed units remaining.
[17:34:24] - Preparing to get new work unit...
[17:34:24] Cleaning up work directory
[17:34:24] + Attempting to get work packet
[17:34:24] Passkey found
[17:34:24] - Will indicate memory of 2046 MB
[17:34:24] - Detect CPU. Vendor: GenuineIntel, Family: 6, Model: 15, Stepping: 6
[17:34:24] - Connecting to assignment server
[17:34:24] Connecting to http://assign.stanford.edu:8080/
[17:34:24] Posted data.
[17:34:24] Initial: ED82; - Successful: assigned to (130.237.232.140).
[17:34:24] + News From Folding@Home: Welcome to Folding@Home
[17:34:24] Loaded queue successfully.
[17:34:24] Connecting to http://130.237.232.140:8080/
[17:34:25] Killing all core threads
[17:34:25] Could not get process id information.  Please kill core process manually
[17:34:25] ***** Got a SIGTERM signal (2)
...<reinstalled client to Program Files directory, copied queue.dat and work folder and unitinfo.txt>
--- Opening Log file [May 12 18:04:15 UTC]
Launch directory: C:\Program Files\FAH
[18:04:15] - Ask before connecting: No
[18:04:15] - User name: staypuft (Team 111065)
[18:04:15] - User ID:
[18:04:15] - Machine ID: 16
[18:04:15]
[18:04:16] Loaded queue successfully.
[18:04:16] - Preparing to get new work unit...
[18:04:16] - Autosending finished units... [May 12 18:04:16 UTC]
[18:04:16] Cleaning up work directory
[18:04:16] Trying to send all finished work units
[18:04:16] + No unsent completed units remaining.
[18:04:16] + Attempting to get work packet
[18:04:16] - Autosend completed
[18:04:16] Passkey found
[18:04:16] - Will indicate memory of 2046 MB
[18:04:16] - Detect CPU. Vendor: GenuineIntel, Family: 6, Model: 15, Stepping: 6
[18:04:16] - Connecting to assignment server
[18:04:16] Connecting to http://assign.stanford.edu:8080/
[18:04:16] Posted data.
[18:04:16] Initial: 40AB; - Successful: assigned to (171.64.65.54).
[18:04:16] + News From Folding@Home: Welcome to Folding@Home
[18:04:16] Connecting to http://171.64.65.54:8080/
[18:04:17] Posted data.
[18:04:17] Initial: 0000; - Receiving payload (expected size: 1767614)
[18:04:23] - Downloaded at ~287 kB/s
[18:04:23] - Averaged speed for that direction ~193 kB/s
[18:04:23] + Received work.
[18:04:23] + Closed connections
[18:04:23]
[18:04:23] + Processing work unit
[18:04:23] Core required: FahCore_a3.exe
[18:04:23] Core not found.
[18:04:23] - Core is not present or corrupted.
[18:04:23] - Attempting to download new core...
[18:04:23] + Downloading new core: FahCore_a3.exe
[18:04:23] Downloading core (/~pande/Win32/x86/Core_a3.fah from www.stanford.edu)
[18:04:24] Initial: AFDE; + 10240 bytes downloaded
[18:04:26] Initial: 498B; + 2340489 bytes downloaded
[18:04:26] Verifying core Core_a3.fah...
[18:04:26] Signature is VALID
[18:04:26]
[18:04:26] Trying to unzip core FahCore_a3.exe
[18:04:27] Decompressed FahCore_a3.exe (8087552 bytes) successfully
[18:04:32] + Core successfully engaged
[18:04:37]
[18:04:37] + Processing work unit
[18:04:37] Core required: FahCore_a3.exe
[18:04:37] Core found.
[18:04:37] Working on queue slot 08 [May 12 18:04:37 UTC]
[18:04:37] + Working ...
[18:04:37] - Calling '.\FahCore_a3.exe -dir work/ -nice 19 -suffix 08 -np 2 -checkpoint 15 -verbose -lifeline 2772 -version 629'
[18:04:38]
[18:04:38] *------------------------------*
[18:04:38] Folding@Home Gromacs SMP Core
[18:04:38] Version 2.17 (Mar 12, 2010)
[18:04:38]
[18:04:38] Preparing to commence simulation
[18:04:38] - Looking at optimizations...
[18:04:38] - Created dyn
[18:04:38] - Files status OK
[18:04:38] - Expanded 1767102 -> 2253729 (decompressed 127.5 percent)
[18:04:38] Called DecompressByteArray: compressed_data_size=1767102 data_size=2253729, decompressed_data_size=2253729 diff=0
[18:04:38] - Digital signature verified
[18:04:38]
[18:04:38] Project: 6053 (Run 0, Clone 42, Gen 26)
[18:04:38]
[18:04:38] Assembly optimizations on if available.
[18:04:38] Entering M.D.
[18:04:46] Completed 0 out of 500000 steps  (0%)
[18:18:38] Completed 5000 out of 500000 steps  (1%)
[18:32:27] Completed 10000 out of 500000 steps  (2%)
[18:46:14] Completed 15000 out of 500000 steps  (3%)
[19:00:34] Completed 20000 out of 500000 steps  (4%)
[19:16:08] Completed 25000 out of 500000 steps  (5%)
[19:30:35] Completed 30000 out of 500000 steps  (6%)
[19:45:08] Completed 35000 out of 500000 steps  (7%)
Re: Project: 6012 (Run 0, Clone 395, Gen 142)
This is a bad WU and I've reported it.
I'm not quite sure how the 80% rule is being applied. You did have a lot of restarts, but your log shows several different scenarios.
In some cases, (error C0000029) the client deleted the WU and it was reassigned. 3x
In some cases, an EUE report was generated (CoreStatus = 72) and results were uploaded. 3x
In some cases, you had to kill the client and there was nothing to upload. 3x
The Mod db shows three of those errors (error 72)
staypuft
Post by staypuft »
Thanks for the update Bruce. If there is anything I should do differently next time please let me know.
The only thing you CAN do is to report it here, just as you have done.
staypuft
Post by staypuft »
OK, will do. Thx again
