Project: 6076 (Run 0, Clone 18, Gen 28) - No Bonus - Why ?
Mactin
Post by Mactin »
My first FredNotFred WU, Project: 6076 (Run 0, Clone 18, Gen 28), got no Bonus.
It looks I was credited 481 points for it.
Why ?
Now I'm crunching thru a -bigadv WU, Project: 2683 (Run 5, Clone 6, Gen 72), will it get a Bonus ?
Re: Project: 6076 (Run 0, Clone 18, Gen 28) - No Bonus - Why ?
Are you using a passkey? Have you completed 10 a2/a3 WUs using that passkey & UserName with at least an 80% success rate?
Bonus points are awarded at the time the WU is credited, so if you didn't get a bonus, don't expect it to show up later.
Mactin
Post by Mactin »
Yes, yes and yes.
I have complete successfully dozens..
A couple of hours latter, I got a bonus with p6054-0-155-9 with the same username and passkey.
If I had no passkey would I be issued a -bigadv ?
I don't believe that the passkey is used to restrict assignments so without a passkey, you can be issued -bigadv but you wouldn't get a bonus.
Did your passkey change? Was the WU assigned while the Assignment Server was having its recent problems?
kasson
Pande Group Member
Post by kasson »
For that particular WU, no passkey was provided by your client upon assign. Your other returns around that time did have a passkey and were given the bonus. The client needs to provide the passkey at the time of assign as well as WU return.
Mactin
Post by Mactin »
Ok, thank you, it explain what appened.
Sinse this was my first WU with FredNotFred, it was assigned by the generic Username provided by FredNotFred.
I reconfigured and restarted without killing the WU, I taugh this was the ethical thing to do.
It returned with My username and passkey.
Not dumping the WU, penalized my points, but science won in the end. That's life ! No regrets.
