[11:58:58] Project: 6062 (Run 0, Clone 32, Gen 14)
[11:58:58]
[11:58:58] Assembly optimizations on if available.
[11:58:58] Entering M.D.
[11:59:04] Completed 0 out of 500000 steps (0%)
[11:59:05] mdrun returned 255
[11:59:05] Going to send back what have done -- stepsTotalG=500000
[11:59:05] Work fraction=0.0000 steps=500000.
[11:59:21] Killing all core threads
[11:59:21] Killing 4 cores
[11:59:21] Killing core 0
[11:59:21] Killing core 1
[11:59:21] Killing core 2
[11:59:21] Killing core 3
Project: 6062 (Run 0, Clone 32, Gen 14) EUE
Re: Project: 6062 (Run 0, Clone 32, Gen 14) EUE
There are multiple immediate EUE reports in the stats db ... so I marked this WU as bad.
My client is still downloading this unit and of course generating the eue.
You may want to delete the work folder and the queue.dat file and restart the client and hopefully, you will be assigned another WU
I had tried the deletions at least a dozen times and no help. I deleted and then waited about an hour and a half, restarted and now have a different unit. All is right with the world.
