Project: 5740 (Run 1, Clone 12, Gen 1197)
csp4.0
Post by csp4.0 »
[09:34:25]
[09:34:25] *------------------------------*
[09:34:25] Folding@Home GPU Core - Beta
[09:34:25] Version 1.24 (Mon Feb 9 11:00:12 PST 2009)
[09:34:25]
[09:34:25] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[09:34:25] Build host: amoeba
[09:34:25] Board Type: AMD
[09:34:25] Core      :
[09:34:25] Preparing to commence simulation
[09:34:25] - Looking at optimizations...
[09:34:25] - Created dyn
[09:34:25] - Files status OK
[09:34:26] - Expanded 70236 -> 360060 (decompressed 512.6 percent)
[09:34:26] Called DecompressByteArray: compressed_data_size=70236 data_size=360060, decompressed_data_size=360060 diff=0
[09:34:26] - Digital signature verified
[09:34:26]
[09:34:26] Project: 5740 (Run 2, Clone 70, Gen 1079)
[09:34:26]
[09:34:26] Assembly optimizations on if available.
[09:34:26] Entering M.D.
[09:34:32] Tpr hash work/wudata_01.tpr:  607379791 1786713848 4098917683 2195072921 3029874957
[09:34:32] Working on Protein
[09:34:32] Client config found, loading data.
[09:34:33] Starting GUI Server
[09:34:35] mdrun_gpu returned
[09:34:35] NANs detected on GPU
[09:34:35]
[09:34:35] Folding@home Core Shutdown: UNSTABLE_MACHINE
[09:34:37] CoreStatus = 7A (122)
[09:34:37] Sending work to server
[09:34:37] Project: 5740 (Run 2, Clone 70, Gen 1079)
[09:34:37] - Read packet limit of 540015616... Set to 524286976.
[09:34:37] - Error: Could not get length of results file work/wuresults_01.dat
[09:34:37] - Error: Could not read unit 01 file. Removing from queue.
[09:34:37] Trying to send all finished work units
[09:34:37] + No unsent completed units remaining.
[09:34:37] - Preparing to get new work unit...
[09:34:37] + Attempting to get work packet
[09:34:37] - Will indicate memory of 6135 MB
[09:34:37] - Detect CPU. Vendor: GenuineIntel, Family: 6, Model: 10, Stepping: 5
[09:34:37] - Connecting to assignment server
[09:34:37] Connecting to http://assign-GPU.stanford.edu:8080/
[09:34:38] Posted data.
[09:34:38] Initial: 40AB; - Successful: assigned to (171.64.65.102).
[09:34:38] + News From Folding@Home: Welcome to Folding@Home
[09:34:38] Loaded queue successfully.
[09:34:38] Connecting to http://171.64.65.102:8080/
[09:34:39] Posted data.
[09:34:39] Initial: 0000; - Error: Bad packet type from server, expected work assignment
[09:34:39] - Attempt #1  to get work failed, and no other work to do.
Waiting before retry.
[09:34:59] + Attempting to get work packet
[09:34:59] - Will indicate memory of 6135 MB
[09:34:59] - Connecting to assignment server
[09:34:59] Connecting to http://assign-GPU.stanford.edu:8080/
[09:35:00] Posted data.
[09:35:00] Initial: 40AB; - Successful: assigned to (171.64.65.102).
[09:35:00] + News From Folding@Home: Welcome to Folding@Home
[09:35:00] Loaded queue successfully.
[09:35:00] Connecting to http://171.64.65.102:8080/
[09:35:01] Posted data.
[09:35:01] Initial: 0000; - Receiving payload (expected size: 70722)
[09:35:02] - Downloaded at ~69 kB/s
[09:35:02] - Averaged speed for that direction ~69 kB/s
[09:35:02] + Received work.
[09:35:02] Trying to send all finished work units
[09:35:02] + No unsent completed units remaining.
[09:35:02] + Closed connections
[09:35:07]
[09:35:07] + Processing work unit
[09:35:07] Core required: FahCore_11.exe
[09:35:07] Core found.
[09:35:07] Working on queue slot 02 [May 2 09:35:07 UTC]
[09:35:07] + Working ...
[09:35:07] - Calling '.\FahCore_11.exe -dir work/ -suffix 02 -priority 96 -checkpoint 15 -verbose -lifeline 4008 -version 623'
[09:35:07]
[09:35:07] *------------------------------*
[09:35:07] Folding@Home GPU Core - Beta
[09:35:07] Version 1.24 (Mon Feb 9 11:00:12 PST 2009)
[09:35:07]
[09:35:07] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[09:35:07] Build host: amoeba
[09:35:07] Board Type: AMD
[09:35:07] Core      :
[09:35:07] Preparing to commence simulation
[09:35:07] - Looking at optimizations...
[09:35:07] - Created dyn
[09:35:07] - Files status OK
[09:35:07] - Expanded 70210 -> 360060 (decompressed 512.8 percent)
[09:35:07] Called DecompressByteArray: compressed_data_size=70210 data_size=360060, decompressed_data_size=360060 diff=0
[09:35:07] - Digital signature verified
[09:35:07]
[09:35:07] Project: 5740 (Run 1, Clone 12, Gen 1197)
[09:35:07]
[09:35:07] Assembly optimizations on if available.
[09:35:07] Entering M.D.
[09:35:13] Tpr hash work/wudata_02.tpr:  1864511416 4263006544 3452505367 2987114801 2759452750
[09:35:14] Working on Protein
[09:35:14] Client config found, loading data.
[09:35:14] Starting GUI Server
[09:35:17] mdrun_gpu returned
[09:35:17] NANs detected on GPU
[09:35:17]
[09:35:17] Folding@home Core Shutdown: UNSTABLE_MACHINE
[09:35:20] CoreStatus = 7A (122)
[09:35:20] Sending work to server
[09:35:20] Project: 5740 (Run 1, Clone 12, Gen 1197)
[09:35:20] - Read packet limit of 540015616... Set to 524286976.
[09:35:20] - Error: Could not get length of results file work/wuresults_02.dat
[09:35:20] - Error: Could not read unit 02 file. Removing from queue.
[09:35:20] Trying to send all finished work units
[09:35:20] + No unsent completed units remaining.
[09:35:20] - Preparing to get new work unit...
[09:35:20] + Attempting to get work packet
[09:35:20] - Will indicate memory of 6135 MB
[09:35:20] - Connecting to assignment server
[09:35:20] Connecting to http://assign-GPU.stanford.edu:8080/
[09:35:21] Posted data.
[09:35:21] Initial: 40AB; - Successful: assigned to (171.64.65.102).
[09:35:21] + News From Folding@Home: Welcome to Folding@Home
[09:35:21] Loaded queue successfully.
[09:35:21] Connecting to http://171.64.65.102:8080/
[09:35:21] Initial: 0000; - Receiving payload (expected size: 70722)
[09:35:23] - Downloaded at ~34 kB/s
[09:35:23] - Averaged speed for that direction ~57 kB/s
[09:35:23] + Received work.
[09:35:23] Trying to send all finished work units
[09:35:23] + No unsent completed units remaining.
[09:35:23] + Closed connections
[09:35:28]
[09:35:28] + Processing work unit
[09:35:28] Core required: FahCore_11.exe
[09:35:28] Core found.
[09:35:28] Working on queue slot 03 [May 2 09:35:28 UTC]
[09:35:28] + Working ...
[09:35:28] - Calling '.\FahCore_11.exe -dir work/ -suffix 03 -priority 96 -checkpoint 15 -verbose -lifeline 4008 -version 623'
[09:35:28]
[09:35:28] *------------------------------*
[09:35:28] Folding@Home GPU Core - Beta
[09:35:28] Version 1.24 (Mon Feb 9 11:00:12 PST 2009)
[09:35:28]
[09:35:28] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[09:35:28] Build host: amoeba
[09:35:28] Board Type: AMD
[09:35:28] Core      :
[09:35:28] Preparing to commence simulation
[09:35:28] - Looking at optimizations...
[09:35:28] - Created dyn
[09:35:28] - Files status OK
[09:35:28] - Expanded 70210 -> 360060 (decompressed 512.8 percent)
[09:35:28] Called DecompressByteArray: compressed_data_size=70210 data_size=360060, decompressed_data_size=360060 diff=0
[09:35:28] - Digital signature verified
[09:35:28]
[09:35:28] Project: 5740 (Run 1, Clone 12, Gen 1197)
[09:35:28]
[09:35:28] Assembly optimizations on if available.
[09:35:28] Entering M.D.
[09:35:34] Tpr hash work/wudata_03.tpr:  1864511416 4263006544 3452505367 2987114801 2759452750
[09:35:35] Working on Protein
[09:35:35] Client config found, loading data.
[09:35:35] Starting GUI Server
[09:35:38] mdrun_gpu returned
[09:35:38] NANs detected on GPU
[09:35:38]
[09:35:38] Folding@home Core Shutdown: UNSTABLE_MACHINE
[09:35:40] CoreStatus = 7A (122)
[09:35:40] Sending work to server
[09:35:40] Project: 5740 (Run 1, Clone 12, Gen 1197)
[09:35:40] - Read packet limit of 540015616... Set to 524286976.
[09:35:40] - Error: Could not get length of results file work/wuresults_03.dat
[09:35:40] - Error: Could not read unit 03 file. Removing from queue.
[09:35:40] Trying to send all finished work units
[09:35:40] + No unsent completed units remaining.
[09:35:40] - Preparing to get new work unit...
[09:35:40] + Attempting to get work packet
[09:35:40] - Will indicate memory of 6135 MB
[09:35:40] - Connecting to assignment server
[09:35:40] Connecting to http://assign-GPU.stanford.edu:8080/
[09:35:41] Posted data.
[09:35:41] Initial: 40AB; - Successful: assigned to (171.64.65.102).
[09:35:41] + News From Folding@Home: Welcome to Folding@Home
[09:35:42] Loaded queue successfully.
[09:35:42] Connecting to http://171.64.65.102:8080/
[09:35:43] Posted data.
[09:35:43] Initial: 0000; - Receiving payload (expected size: 70722)
[09:35:44] - Downloaded at ~69 kB/s
[09:35:44] - Averaged speed for that direction ~60 kB/s
[09:35:44] + Received work.
[09:35:44] Trying to send all finished work units
[09:35:44] + No unsent completed units remaining.
[09:35:44] + Closed connections
[09:35:49]
[09:35:49] + Processing work unit
[09:35:49] Core required: FahCore_11.exe
[09:35:49] Core found.
[09:35:49] Working on queue slot 04 [May 2 09:35:49 UTC]
[09:35:49] + Working ...
[09:35:49] - Calling '.\FahCore_11.exe -dir work/ -suffix 04 -priority 96 -checkpoint 15 -verbose -lifeline 4008 -version 623'
[09:35:49]
[09:35:49] *------------------------------*
[09:35:49] Folding@Home GPU Core - Beta
[09:35:49] Version 1.24 (Mon Feb 9 11:00:12 PST 2009)
[09:35:49]
[09:35:49] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[09:35:49] Build host: amoeba
[09:35:49] Board Type: AMD
[09:35:49] Core      :
[09:35:49] Preparing to commence simulation
[09:35:49] - Looking at optimizations...
[09:35:49] - Created dyn
[09:35:49] - Files status OK
[09:35:49] - Expanded 70210 -> 360060 (decompressed 512.8 percent)
[09:35:49] Called DecompressByteArray: compressed_data_size=70210 data_size=360060, decompressed_data_size=360060 diff=0
[09:35:49] - Digital signature verified
[09:35:49]
[09:35:49] Project: 5740 (Run 1, Clone 12, Gen 1197)
[09:35:49]
[09:35:49] Assembly optimizations on if available.
[09:35:49] Entering M.D.
[09:35:55] Tpr hash work/wudata_04.tpr:  1864511416 4263006544 3452505367 2987114801 2759452750
[09:35:56] Working on Protein
[09:35:56] Client config found, loading data.
[09:35:56] Starting GUI Server
[09:35:59] mdrun_gpu returned
[09:35:59] NANs detected on GPU
[09:35:59]
[09:35:59] Folding@home Core Shutdown: UNSTABLE_MACHINE
[09:36:01] CoreStatus = 7A (122)
[09:36:01] Sending work to server
[09:36:01] Project: 5740 (Run 1, Clone 12, Gen 1197)
[09:36:01] - Read packet limit of 540015616... Set to 524286976.
[09:36:01] - Error: Could not get length of results file work/wuresults_04.dat
[09:36:01] - Error: Could not read unit 04 file. Removing from queue.
[09:36:01] Trying to send all finished work units
[09:36:01] + No unsent completed units remaining.
[09:36:01] - Preparing to get new work unit...
[09:36:01] + Attempting to get work packet
[09:36:01] - Will indicate memory of 6135 MB
[09:36:01] - Connecting to assignment server
[09:36:01] Connecting to http://assign-GPU.stanford.edu:8080/
[09:36:02] Posted data.
[09:36:02] Initial: 40AB; - Successful: assigned to (171.64.65.102).
[09:36:02] + News From Folding@Home: Welcome to Folding@Home
[09:36:03] Loaded queue successfully.
[09:36:03] Connecting to http://171.64.65.102:8080/
[09:36:04] Posted data.
[09:36:04] Initial: 0000; - Receiving payload (expected size: 70722)
[09:36:05] - Downloaded at ~69 kB/s
[09:36:05] - Averaged speed for that direction ~62 kB/s
[09:36:05] + Received work.
[09:36:05] Trying to send all finished work units
[09:36:05] + No unsent completed units remaining.
[09:36:05] + Closed connections
[09:36:10]
[09:36:10] + Processing work unit
[09:36:10] Core required: FahCore_11.exe
[09:36:10] Core found.
[09:36:10] Working on queue slot 05 [May 2 09:36:10 UTC]
[09:36:10] + Working ...
[09:36:10] - Calling '.\FahCore_11.exe -dir work/ -suffix 05 -priority 96 -checkpoint 15 -verbose -lifeline 4008 -version 623'
[09:36:10]
[09:36:10] *------------------------------*
[09:36:10] Folding@Home GPU Core - Beta
[09:36:10] Version 1.24 (Mon Feb 9 11:00:12 PST 2009)
[09:36:10]
[09:36:10] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[09:36:10] Build host: amoeba
[09:36:10] Board Type: AMD
[09:36:10] Core      :
[09:36:10] Preparing to commence simulation
[09:36:10] - Looking at optimizations...
[09:36:10] - Created dyn
[09:36:10] - Files status OK
[09:36:10] - Expanded 70210 -> 360060 (decompressed 512.8 percent)
[09:36:10] Called DecompressByteArray: compressed_data_size=70210 data_size=360060, decompressed_data_size=360060 diff=0
[09:36:10] - Digital signature verified
[09:36:10]
[09:36:10] Project: 5740 (Run 1, Clone 12, Gen 1197)
[09:36:10]
[09:36:10] Assembly optimizations on if available.
[09:36:10] Entering M.D.
[09:36:16] Tpr hash work/wudata_05.tpr:  1864511416 4263006544 3452505367 2987114801 2759452750
[09:36:17] Working on Protein
[09:36:17] Client config found, loading data.
[09:36:17] Starting GUI Server
[09:36:20] mdrun_gpu returned
[09:36:20] NANs detected on GPU
[09:36:20]
[09:36:20] Folding@home Core Shutdown: UNSTABLE_MACHINE
[09:36:22] CoreStatus = 7A (122)
[09:36:22] Sending work to server
[09:36:22] Project: 5740 (Run 1, Clone 12, Gen 1197)
[09:36:22] - Read packet limit of 540015616... Set to 524286976.
[09:36:22] - Error: Could not get length of results file work/wuresults_05.dat
[09:36:22] - Error: Could not read unit 05 file. Removing from queue.
[09:36:22] EUE limit exceeded. Pausing 24 hours.
Re: Project: 5740 (Run 1, Clone 12, Gen 1197)
Are you sure that's a problem with the WU in the title ? Because I see it also failed with Project: 5740 (Run 2, Clone 70, Gen 1079) ...
csp40
Post by csp40 »
:O Thanks for noticing!
Though, doesn't explain why my 5870 successfully completed multiple WUs previously, with no change to the OS whatsoever :/
-sigh- It might be time for another reinstall...
Wasting Electricity with a 5870.
codysluder
Post by codysluder »
toTOW wrote:Are you sure that's a problem with the WU in the title ? Because I see it also failed with Project: 5740 (Run 2, Clone 70, Gen 1079) ...
Have either of these projects been completed by someone else? If so, is there any way to tell whether it's due to a difference in the gpu or a difference in something else like a hardware error or an overclocking issue.
csp40
Post by csp40 »
According to viewtopic.php?f=52&t=7965
Project 5740 is affected.
csp40 wrote:According to viewtopic.php?f=52&t=7965
Just because one WU is listed in the topic does not mean that the entire project is suspect. A few percent of the WUs in all projects may encounter EUEs and be classified as bad WUs, but that's why we ask that you report issues with a specific WU in this forum, not two or three which happen to be from the same project.
Both of the aforementioned WUs have been completed successfully.
Hi xxxx (team xx),
Your WU (P5740 R1 C12 G1197) was added to the stats database on 2010-05-02 20:05:01 for 384 points of credit.
Hi xxxx (team xx),
Your WU (P5740 R2 C70 G1079) was added to the stats database on 2010-05-01 08:06:17 for 0 points of credit.
Hi xxxx (team xxx),
Your WU (P5740 R2 C70 G1079) was added to the stats database on 2010-05-01 23:04:29 for 384 points of credit.
Hi xxxx (team xx),
Your WU (P5740 R2 C70 G1079) was added to the stats database on 2010-05-02 00:04:42 for 384 points of credit.
