GuruMeditation?
theteofscuba
Hardware configuration: PS3, Phenom II X4, QX9775, HD 8570
GuruMeditation?
Post by theteofscuba »
I'm not sure what this error is.
[19:21:25] Completed 196600 out of 499375 steps (39%)
[19:26:51] Completed 199800 out of 499375 steps (40%)
[19:35:36] Completed 204800 out of 499375 steps (41%)
[19:44:08] Completed 209800 out of 499375 steps (42%)
[19:52:33] Completed 214700 out of 499375 steps (42%)
[20:01:34] Completed 219700 out of 499375 steps (43%)
[20:10:00] Completed 224700 out of 499375 steps (44%)
[20:18:39] Completed 229700 out of 499375 steps (45%)
[20:21:33] WARNING: Console control signal 6 on PID 120
[20:21:33] Exiting, please wait. . .
--- Opening Log file [April 17 20:22:17 UTC]
                          http://folding.stanford.edu
Launch directory: C:\fah2
Service: C:\fah2\folding@home-win32-x86
Arguments: -svcstart -d C:\fah2
Launched as a service.
Entered C:\fah2 to do work.
[20:22:17] - Ask before connecting: No
[20:22:17] - User name: theteofscuba (Team 0)
[20:22:17] - User ID: 62DCDDC63FFA48EA
[20:22:17] - Machine ID: 2
[20:22:17]
A potential conflict was detected:
Process 1812 is currently running and may also be a client with Mach. ID 2.
The program will now exit. Upon restart, this check will not be done --
You may wish to check that no client is currently running in
C:\fah2 before restarting.
Please press any key to exit.
--- Opening Log file [April 17 23:00:38 UTC]
[23:00:38] - Ask before connecting: No
[23:00:38] - User name: theteofscuba (Team 0)
[23:00:38] - User ID: 62DCDDC63FFA48EA
[23:00:38] - Machine ID: 2
[23:00:38]
[23:00:38] Loaded queue successfully.
[23:00:38]
[23:00:38] + Processing work unit
[23:00:38] Core required: FahCore_b4.exe
[23:00:38] Core found.
[23:00:38] Working on queue slot 04 [April 17 23:00:38 UTC]
[23:00:38] + Working ...
[23:00:42] *********************** Log Started 17/Apr/2010 23:00:42 ***********************
[23:00:42] ************************** ProtoMol Folding@Home Core **************************
[23:00:42]   Version: 23
[23:00:42]      Type: 180
[23:00:42]      Core: ProtoMol
[23:00:42]   Website: http://folding.stanford.edu/
[23:00:42] Copyright: (c) 2009 Stanford University
[23:00:42]    Author: Joseph Coffland <joseph@cauldrondevelopment.com>
[23:00:42]      Args: -dir work/ -suffix 04 -checkpoint 15 -service -lifeline 1132 -version
[23:00:42]            623
[23:00:42] ************************************ Build *************************************
[23:00:42]      Date: Mar 22 2010
[23:00:42]      Time: 16:55:15
[23:00:42]  Revision: 1789
[23:00:42]  Compiler: Intel(R) C++ MSVC 1500 mode 1110
[23:00:42]   Options: /TP /nologo /EHsc /wd4297 /wd4103 /wd1786 /arch:IA32 /Ox
[23:00:42]            /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qrestrict /MT
[23:00:42]   Defines: _CRT_SECURE_NO_WARNINGS NDEBUG HAVE_GEEKINFO BOOST_ALL_NO_LIB
[23:00:42]            XML_STATIC HAVE_EXPAT HAVE_OPENSSL HAVE_LIBFAH HAVE_SIMTK_LAPACK
[23:00:42]  Platform: Windows XP
[23:00:42]      Bits: 32
[23:00:42]      Mode: Release
[23:00:42] ************************************ System ************************************
[23:00:42]        OS: Microsoft Windows 7 Ultimate
[23:00:42]       CPU: AMD Phenom(tm) II X4 945 Processor
[23:00:42]    CPU ID: AuthenticAMD Family 16 Model 4 Stepping 2
[23:00:42]      CPUs: 4 Logical, 4 Physical
[23:00:42]    Memory: 2.00 GB
[23:00:42]   Threads: Windows
[23:00:42] ********************************************************************************
[23:00:42] Project: 10014 (Run 2556, Clone 1, Gen 2)
[23:00:42] Digital signatures verified
[23:00:42] ERROR: Guru Meditation #4a11e16225babe15.9d46bf8e5ea751fb (2219316.2219316) 'work/04/ww.dcd'
[23:00:42] WARNING: Unexpected exit() call
[23:00:43] WARNING: Unexpected exit from science code
[23:00:43] Saving result file logfile_04.txt
[23:00:43] Saving result file checkpt
[23:00:43] Saving result file checkpt.crc
[23:00:43] Saving result file log.txt
[23:00:46] Saving result file protomol.conf
[23:00:46] Saving result file ww.114.pos
[23:00:46] Saving result file ww.114.vel
[23:00:46] ERROR: Guru Meditation #4a11e16225babe15.9d46bf8e5ea751fb (2219316.2219316) 'work/04/ww.dcd'
[23:00:48] CoreStatus = 70 (112)
[23:00:48] + The core could not validate the current work unit for processing.
[23:00:48] Deleting current work unit & continuing...
[23:00:54] - Preparing to get new work unit...
Re: GuruMeditation?
ProtoMol (FahCore_b4.exe) has a known bug in Version 23. A fix for it is being worked on, but I'm not sure how soon it will be ready. In the meantime, assume that you cannot stop and restart a ProtoMol project, so do whatever you can to wait until the current WU finishes.
Re: GuruMeditation?
This is exactly the problem mentioned in the warning in the announcement of latest Protomol projects : http://en.fah-addict.net/news/news-0-19 ... 019-20.php ;)
Grendel
Hardware configuration: Q6600, Q9560 + GTX 660, i7-3770K + GTX 760
Re: GuruMeditation?
Post by Grendel »
Heh, one of the b4 coders must be an Amiga fan :)
