Hello, someone can tell me why 'while using two clients for several hours a day on two different PCs, after the first day and my score is not' most 'moving? Thank you.
Gigigeni from Italy.
Counting problems WU
Re: Counting problems WU
Welcome to the forum gigigeni
If you could tell us what client type you are using, then it would be helpful. Also one client has uploaded the results to Stanford, not 2. I am guessing that you are using Uniprocessor Client and if you get a large WU, it can take more than 24 hours to process it. I once recieved a WU that was processed for roughly 2 days and was worth 2000 points on Uniprocessor. You could download FahMon so that you can have a better idea about how long the WUs take to finish and how many credits it is worth.
Hope this helps you
Hope this helps you
P5-133XL
Machine #2:
Machine 3:
Your score will only change a few hours after you return the WU's. Since you have only folded for several hours of one day, my assumption is that you haven't completed a WU yet.
If you look at your log and tell us the project(run, clone, gen) numbers that you have completed then a moderator can look those up to see if they have been credited or not.
