Thanks for the replies to my previous questions.
I just updated to 6.23 and it seems to work much better that the 5.x. Somewhere when I was downloading I saw some thing about deadlines and what happens to WU that aren't returned in time and also how to stop downloads for vacation breaks. I can not now find either. Can someone direct me to those spots or answer the questions?
Thanks again
WU deadlines and stopping download for vacations
Re: WU deadlines and stopping download for vacations
Use the oneunit flag if you don't want to download a new WU when you've finished the one you're working on - see Wiki page. ThisWiki page explains deadlines and why they exsist. If you overrun the final deadline the WU it is just deleted and you've wasted your time and electricity.
John, thanks for info. WU clear but, how do I use the -oneunit flag? I am using the systray version and don't see any place that allows me to give commands.
- Hardware configuration: WooHoo= SR-2 -- L5639 @ ?? -- Evga 560ti FPB -- 12Gig Corsair XMS3 -- Corsair 1050hx -- Blackhawk Ultra
Put it in the shortcut you use to start it up.
in the systray right click on the icon and select 'pause when done'
But then it won't send, you can right click the icon> configure>advanced> Additional Client parameters.. put the flag there and restart to take effect.k1wi wrote:in the systray right click on the icon and select 'pause when done'
"Pause when done" as the same effect as -pause flag :
- process the WU
- send it
- pause
Oneunit is a bit different :
- process the WU
- send it
- exit the client
- process the WU
- send it
- pause
- process the WU
- send it
- exit the client
