How can I...
fredex
How can I...
Post by fredex »
How can I tell whether I'm being given "big" WUs or not? (Linux ver 6.x client)
tks!
P5-133XL
Machine #2:
Machine 3:
Re: How can I...
Post by P5-133XL »
There are several questions you need to ask. The first is if you are using the SMP client (All SMP WU's are "Big"). If you are using the uniprocessor client then go to the configuration and then look to see if you allow Big WU's because you won't get them if you don't explicitly allow them. Third, you can look at the logs specifically for the lines that specify how much data was written to disk: The big ones write a lot more data (20+MB) than the small ones (~1.5MB).
fredex
Re: How can I...
Post by fredex »
NOT smp client, and yes it's configured for big WUs.
but I don't see anything in any of the log files (that I can find) that mentions the size, nor how many bytes are written to disk either when initially downloading the WU, or uploded when it's completed.
What am I overlooking?
Thanks!
P5-133XL
Machine #2:
Machine 3:
Re: How can I...
Post by P5-133XL »
Are you using the -verbosity 9 flag? I suggest adding it.
Then you should get output that looks somewhat like:
[16:59:20] Completed 500000 out of 500000 steps (100%)
[16:59:21] DynamicWrapper: Finished Work Unit: sleep=10000
[16:59:31]
[16:59:31] Finished Work Unit:
[16:59:31] - Reading up to 20317968 from "work/wudata_09.trr": Read 20317968
[16:59:31] trr file hash check passed.
[16:59:31] edr file hash check passed.
[16:59:31] logfile size: 57029
[16:59:31] Leaving Run
[16:59:36] - Writing 20409273 bytes of core data to disk...
[16:59:37] ... Done.
[16:59:47] - Shutting down core
[16:59:47]
Just note that not all cores send the same data to the log so your may look slightly different.
Re: How can I...
The "size" of the WU can relate to three things (simultaneously or not) :
- download size
- upload size
- memory usage
You could also post your PRCG numbers : we might know the status of the WU if someone else already folded it ...
P5-133XL
Machine #2:
Machine 3:
Re: How can I...
Post by P5-133XL »
toTOW wrote:The "size" of the WU can relate to three things (simultaneously or not) :
- download size
- upload size
- memory usage
At no point did he say he had a problem or something he needed checked. It was just asked how to distinguish between big and small WU's.
Re: How can I...
I know ... and I'm asking for the WU references because I (or someone else) might know whether the project is big or not ...
Re: How can I...
BigWUs also receive the Big WU bonus, so if your PPD is significantly higher on some WUs than others, you know those are the big work units.
Note that using the Big setting does not guarantee you a BigWU every time. It only states a preference to receive those WUs, if they are available to download for your client type, settings, etc.
fredex
Re: How can I...
Post by fredex »
from the FAHlog.txt for a recent WU:
  • [11:58:30] Completed 499300 out of 499375 steps (99%)
    [11:58:36] Saving result file logfile_05.txt
    [11:58:36] Saving result file checkpt
    [11:58:36] Saving result file checkpt.crc
    [11:58:36] Saving result file log.txt
    [11:58:40] Saving result file protomol.conf
    [11:58:40] Saving result file ww.36.pos
    [11:58:40] Saving result file ww.36.vel
    [11:58:40] Saving result file ww.dcd
    [11:58:41] Folding@home Core Shutdown: FINISHED_UNIT
    [11:58:41] CoreStatus = 64 (100)
    [11:58:41] Sending work to server
    [11:58:41] - Read packet limit of 540015616... Set to 524286976.
    [11:58:41] + Attempting to send results
    [11:59:59] + Results successfully sent
    [11:59:59] Thank you for your contribution to Folding@Home.
    [11:59:59] + Number of Units Completed: 320
    [11:59:59] - Preparing to get new work unit...
    [11:59:59] + Attempting to get work packet
    [11:59:59] - Connecting to assignment server
    [12:00:00] - Successful: assigned to (129.74.85.15).
    [12:00:00] + News From Folding@Home: Welcome to Folding@Home
    [12:00:00] Loaded queue successfully.
    [12:00:01] + Closed connections
I don't see anything there about the WU size, so this particular core must not be "divulging" that info.
I'm running two separate instances of FAH on a dual-core Phenom II under 32-bit Linux. I'm also using fahmon, and it shows these things for the two WUs currently being processed:
PPD                  PRCG
262.32               P10017 (R843, C1, G1)
244.64               P10017 (R2811, C0, G1)
and the "work unit information" pane says "Credit: 126 points" for each WU.
Re: How can I...
Are you using the -verbosity 9 switch as recommended above?
Plus I don't think any of the Protomol WUs are BigWUs. So you're probably right about it not writing that size info to the log.
P.S. I recommend putting a bit more info in your title next time. A lot of people will skip threads with titles like that.
kzaske
Hardware configuration: System Specs: GIGABYTE 990FXA-UD3; AMD Phenom II x6 1090T; 8GB Corsair Dominator CMD8GX3M4A1333C7; XFX HD-6950-CNFC 2G
Re: How can I...
Post by kzaske »
Given the title of this thread I think I will post my question here: How can I tell when I first signed up with F@H? I know the data has to be hiding somewhere...
Re: How can I...
My exact point about thread titles... :roll:
First signed up info? That info is not hiding. It's just not published anywhere. Some of the 3rd party stats sites publish the date of the first record they have regarding your first returned work unit. For example, EOC shows your first WU as being 02.06.07 http://folding.extremeoverclocking.com/ ... =&u=207325 top right corner
