Project: 10009 (Run 3408, Clone 0, Gen 0) (ERROR 0x0)
Hyperlife
Post by Hyperlife »
This WU died at 72% with a CoreStatus = 0 (0), and the WU was deleted before an upload was attempted:
[05:54:03] + Processing work unit
[05:54:03] Core required: FahCore_b4.exe
[05:54:03] Core found.
[05:54:03] Working on Unit 01 [April 8 05:54:03]
[05:54:03] + Working ...
[05:54:03] - Calling './FahCore_b4.exe -dir work/ -suffix 01 -checkpoint 30 -forceasm -verbose -lifeline 25221 -version 602'
[05:54:03] *********************** Log Started 08/Apr/2010 05:54:03 ***********************
[05:54:03] ************************** ProtoMol Folding@Home Core **************************
[05:54:03]   Version: 23
[05:54:03]      Type: 180
[05:54:03]      Core: ProtoMol
[05:54:03]   Website: http://folding.stanford.edu/
[05:54:03] Copyright: (c) 2009 Stanford University
[05:54:03]    Author: Joseph Coffland <joseph@cauldrondevelopment.com>
[05:54:03]      Args: -dir work/ -suffix 01 -checkpoint 30 -forceasm -verbose -lifeline
[05:54:03]            25221 -version 602
[05:54:03] ************************************ Build *************************************
[05:54:03]      Date: Mar 21 2010
[05:54:03]      Time: 10:27:10
[05:54:03]  Revision: 1789
[05:54:03]  Compiler: Intel(R) C++ g++ 4.1 mode 1110
[05:54:03]   Options: -std=gnu++98 -mia32 -O3 -funroll-loops
[05:54:03]            -axSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 -restrict
[05:54:03]   Defines: NDEBUG _REENTRANT HAVE_GEEKINFO HAVE_PTHREADS HAVE_PTHREADS
[05:54:03]            HAVE_EXPAT HAVE_OPENSSL HAVE_LIBFAH HAVE_LAPACK
[05:54:03]  Platform: Linux 2.4.27-3-386
[05:54:03]      Bits: 32
[05:54:03]      Mode: Release
[05:54:03] ************************************ System ************************************
[05:54:03]        OS: Linux 2.6.16 i686
[05:54:03]       CPU: Intel(R) Pentium(R) 4 CPU 2.80GHz
[05:54:03]    CPU ID: GenuineIntel Family 15 Model 4 Stepping 9
[05:54:03]      CPUs: 1 Logical, 1 Physical
[05:54:03]    Memory: 1014 MB
[05:54:03]   Threads: Linux
[05:54:03] ********************************************************************************
[05:54:03] Project: 10009 (Run 3408, Clone 0, Gen 0)
[05:54:03] Reading tar file par_all27_prot_lipid.inp
[05:54:03] Reading tar file scpismQuartic.inp
[05:54:03] Reading tar file ww_structure_14_charm.pdb
[05:54:03] Reading tar file ww_structure_14_charm.psf
[05:54:03] Reading tar file ww_structure_14_charm.vel
[05:54:03] Reading tar file protomol.conf
[05:54:03] Reading tar file core.xml
[05:54:03] Digital signatures verified
[05:54:04] GUI Server started
[05:54:04] Completed 0 out of 499375 steps (0%)
[05:59:53] Completed 5000 out of 499375 steps (1%)
[06:05:55] Completed 10000 out of 499375 steps (2%)
[17:59:46] Completed 349600 out of 499375 steps (70%)
[18:12:15] Completed 354600 out of 499375 steps (71%)
[18:24:24] Completed 359500 out of 499375 steps (71%)
[18:36:50] Completed 364500 out of 499375 steps (72%)
[18:45:37] CoreStatus = 0 (0)
[18:45:37] Client-core communications error: ERROR 0x0
[18:45:37] Deleting current work unit & continuing...
[18:45:41] Trying to send all finished work units
[18:45:41] + No unsent completed units remaining.
System info is in the log -- it's a fileserver so there's no overclock. Client is v6.02 (32-bit Linux under FreeBSD).
Re: Project: 10009 (Run 3408, Clone 0, Gen 0) (ERROR 0x0)
There are more reported errors in the dB, I marked the WU as bad.
