Download work units
Jack S
Download work units
Post by Jack S »
More problems, first work units that won't upload, units that just disappear and now work units that won't download.
For the last four days after my last work uploaded my machine has been attemptingto get a new work unit. It goes on and on and shows "steps" clear up to 1000. Log file shows connection but says work unit address is invalid. How do I clear this problem and get a work unit? Also, what went wrong?
Thanks
Re: Download work units
As with any problem, posting the first 35 lines of your fahlog.txt file helps answer many questions about your setup. Then posting the last 50 or so lines of the file, showing the problem, is very helpful as well. Much of what we might suggest would change based on the info in the log, such as client type, error, etc. Then we can better help you. Thanks.
P5-133XL
Machine #2:
Machine 3:
Post by P5-133XL »
Like 7im said, we need more detailed information to be able to help you in any meaningful way. Please post your FAHLog.txt file.
