[14:10:00] Completed 98%
[14:11:24] Completed 99%
[14:11:59] - Autosending finished units... [April 6 14:11:59 UTC]
[14:11:59] Trying to send all finished work units
[14:11:59] + No unsent completed units remaining.
[14:11:59] - Autosend completed
[14:11:59] + Working...
[14:12:48] Completed 100%
[14:12:48] Successful run
[14:12:48] DynamicWrapper: Finished Work Unit: sleep=10000
[14:12:58] Reserved 109420 bytes for xtc file; Cosm status=0
[14:12:58] Allocated 109420 bytes for xtc file
[14:12:58] - Reading up to 109420 from "work/wudata_04.xtc": Read 109420
[14:12:58] Read 109420 bytes from xtc file; available packet space=786321044
[14:12:58] xtc file hash check passed.
[14:12:58] Reserved 21912 21912 786321044 bytes for arc file=<work/wudata_04.trr> Cosm status=0
[14:12:58] Allocated 21912 bytes for arc file
[14:12:58] - Reading up to 21912 from "work/wudata_04.trr": Read 21912
[14:12:58] Read 21912 bytes from arc file; available packet space=786299132
[14:12:58] trr file hash check passed.
[14:12:58] Allocated 560 bytes for edr file
[14:12:58] Read bedfile
[14:12:58] edr file hash check passed.
[14:12:58] Logfile not read.
[14:12:58] GuardedRun: success in DynamicWrapper
[14:12:58] GuardedRun: done
[14:12:58] Run: GuardedRun completed.
[14:12:59] + Opened results file
[14:12:59] - Writing 132404 bytes of core data to disk...
[14:12:59] Done: 131892 -> 130899 (compressed to 99.2 percent)
[14:12:59] ... Done.
[14:12:59] DeleteFrameFiles: successfully deleted file=work/wudata_04.ckp
[14:12:59] Shutting down core
[14:12:59]
[14:12:59] Folding@home Core Shutdown: FINISHED_UNIT
[14:13:02] CoreStatus = 64 (100)
[14:13:02] Unit 4 finished with 99 percent of time to deadline remaining.
[14:13:02] Updated performance fraction: 0.987387
[14:13:02] Sending work to server
[14:13:02] Project: 10503 (Run 328, Clone 97, Gen 0)
[14:13:02] + Attempting to send results [April 6 14:13:02 UTC]
[14:13:02] - Reading file work/wuresults_04.dat from core
[14:13:02] (Read 131411 bytes from disk)
[14:13:02] Connecting to http://171.67.108.21:8080/
[14:13:04] Posted data.
[14:13:04] Initial: 0000; - Uploaded at ~64 kB/s
[14:13:04] - Averaged speed for that direction ~52 kB/s
[14:13:04] - Server does not have record of this unit. Will try again later.
[14:13:04] - Error: Could not transmit unit 04 (completed April 6) to work server.
[14:13:04] - 1 failed uploads of this unit.
[14:13:04] Keeping unit 04 in queue.
[14:13:04] Trying to send all finished work units
[14:13:04] Project: 10503 (Run 328, Clone 97, Gen 0)
[14:13:04] + Attempting to send results [April 6 14:13:04 UTC]
[14:13:04] - Reading file work/wuresults_04.dat from core
[14:13:04] (Read 131411 bytes from disk)
[14:13:04] Connecting to http://171.67.108.21:8080/
[14:13:08] Posted data.
[14:13:08] Initial: 0000; - Uploaded at ~32 kB/s
[14:13:08] - Averaged speed for that direction ~48 kB/s
[14:13:08] - Server does not have record of this unit. Will try again later.
[14:13:08] - Error: Could not transmit unit 04 (completed April 6) to work server.
[14:13:08] - 2 failed uploads of this unit.
[14:13:08] + Attempting to send results [April 6 14:13:08 UTC]
[14:13:08] - Reading file work/wuresults_04.dat from core
[14:13:08] (Read 131411 bytes from disk)
[14:13:08] Connecting to http://171.67.108.26:8080/
[14:13:09] - Couldn't send HTTP request to server
[14:13:09] + Could not connect to Work Server (results)
[14:13:09] (171.67.108.26:8080)
[14:13:09] + Retrying using alternative port
[14:13:09] Connecting to http://171.67.108.26:80/
[14:13:10] - Couldn't send HTTP request to server
[14:13:10] (Got status 503)
[14:13:10] + Could not connect to Work Server (results)
[14:13:10] (171.67.108.26:80)
[14:13:10] Could not transmit unit 04 to Collection server; keeping in queue.
[14:13:10] + Sent 0 of 1 completed units to the server
[14:13:10] - Preparing to get new work unit...
[14:13:10] + Attempting to get work packet
[14:13:10] - Will indicate memory of 2046 MB
[14:13:10] - Connecting to assignment server
[14:13:10] Connecting to http://assign-GPU.stanford.edu:8080/
[14:13:11] Posted data.
[14:13:11] Initial: 40AB; - Successful: assigned to (171.64.65.71).
[14:13:11] + News From Folding@Home: Welcome to Folding@Home
[14:13:11] Loaded queue successfully.
[14:13:11] Connecting to http://171.64.65.71:8080/
[14:13:12] Posted data.
[14:13:12] Initial: 0000; - Receiving payload (expected size: 89109)
[14:13:12] Conversation time very short, giving reduced weight in bandwidth avg
[14:13:12] - Downloaded at ~174 kB/s
[14:13:12] - Averaged speed for that direction ~82 kB/s
[14:13:12] + Received work.
[14:13:12] Trying to send all finished work units
[14:13:12] Project: 10503 (Run 328, Clone 97, Gen 0)
[14:13:12] + Attempting to send results [April 6 14:13:12 UTC]
[14:13:12] - Reading file work/wuresults_04.dat from core
[14:13:12] (Read 131411 bytes from disk)
[14:13:12] Connecting to http://171.67.108.21:8080/
[14:13:14] Posted data.
[14:13:14] Initial: 0000; - Uploaded at ~64 kB/s
[14:13:14] - Averaged speed for that direction ~51 kB/s
[14:13:14] - Server does not have record of this unit. Will try again later.
[14:13:14] - Error: Could not transmit unit 04 (completed April 6) to work server.
[14:13:14] - 3 failed uploads of this unit.
[14:13:14] + Attempting to send results [April 6 14:13:14 UTC]
[14:13:14] - Reading file work/wuresults_04.dat from core
[14:13:14] (Read 131411 bytes from disk)
[14:13:14] Connecting to http://171.67.108.26:8080/
[14:13:16] - Couldn't send HTTP request to server
[14:13:16] + Could not connect to Work Server (results)
[14:13:16] (171.67.108.26:8080)
[14:13:16] + Retrying using alternative port
[14:13:16] Connecting to http://171.67.108.26:80/
[14:13:16] (Got status 503)
[14:13:16] (171.67.108.26:80)
[14:13:16] Could not transmit unit 04 to Collection server; keeping in queue.
[14:13:16] + Sent 0 of 1 completed units to the server
[14:13:16] + Closed connections
[14:13:16]
[14:13:16] + Processing work unit
[14:13:16] Core required: FahCore_11.exe
[14:13:16] Core found.
[14:13:16] Working on queue slot 05 [April 6 14:13:16 UTC]
[14:13:16] + Working ...
[14:13:16] - Calling '.\FahCore_11.exe -dir work/ -suffix 05 -checkpoint 15 -verbose -lifeline 1908 -version 623'
[14:13:16]
[14:13:16] *------------------------------*
[14:13:16] Folding@Home GPU Core
[14:13:16] Version 1.31 (Tue Sep 15 10:57:42 PDT 2009)
[14:13:16]
[14:13:16] Compiler : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[14:13:16] Build host: amoeba
[14:13:16] Board Type: Nvidia
[14:13:16] Core :
[14:13:16] Preparing to commence simulation
[14:13:16] - Looking at optimizations...
[14:13:16] DeleteFrameFiles: successfully deleted file=work/wudata_05.ckp
[14:13:16] - Created dyn
[14:13:16] - Files status OK
[14:13:16] - Expanded 88597 -> 447307 (decompressed 504.8 percent)
[14:13:16] Called DecompressByteArray: compressed_data_size=88597 data_size=447307, decompressed_data_size=447307 diff=0
[14:13:16] - Digital signature verified
[14:13:16]
[14:13:16] Project: 10103 (Run 33, Clone 5, Gen 10)
[14:13:16]
[14:13:16] Assembly optimizations on if available.
[14:13:16] Entering M.D.
[14:13:22] Tpr hash work/wudata_05.tpr: 3589874957 2720480723 1183591085 3488171980 3394489799
[14:13:22]
[14:13:22] Calling fah_main args: 14 usage=100
[14:13:22]
[14:13:23] Working on p10103_lambda_370K
[14:13:25] Client config found, loading data.
[14:13:25] Starting GUI Server
[14:14:57] Completed 1%
[14:16:29] Completed 2%pointing the client to CS6 doesn't help at all either
a joint register for the WS group could help with pointing them to 'Active' CSes and would make it easy to take CS6 out of the loop (in this case)
