Project: 10006 (Run 275, Clone 5, Gen 9) [protomol restart]
Robby_Firefox
Hardware configuration: Homebuilt Windows 10
Intel Core i7-4770 ~ started in early 2014 or 2015
32 GB RAM (up from 8 GB in 2018)
64-Bit Operating System
On 31 Mar 2020, installed a GigaByte GEFORCE GTX 1660 GPU
Post by Robby_Firefox »
Hello,
About a week ago or so, I had the 10006 job die (that's after 'gracefully') shutting down FAH before doing a Windows XP Pro restart. Did this around 0542Z. FAH had trouble finding this job around 0551Z and deleted it after a few minutes. After reading others with similar problems, decided to post what occurred here. I have -advmethods selected as the option for the 'classic' FAH 6.23 client. Below is from the FAHlog file.
Lastly, a question about the points awarded for the 10000 series; they seem too low -- or is my 4 year old AMD X2 4200 beginning to show its age? Would the same process/job work better with Linux or Intel type processor?? I am thinking about going GPU and/or a newer machine in a year or so.?
Thanks,
Robby -- Team Firefox
--- Opening Log file [March 31 04:55:20 UTC]
# Windows CPU Systray Edition #################################################
                          http://folding.stanford.edu
Launch directory: C:\Documents and Settings\Robby\Application Data\Folding@home-x86
Arguments: -advmethods
[04:55:20] - Ask before connecting: No
[04:55:20] - User name: Robby (Team 39299)
[04:55:20] - User ID: *****B0E6
[04:55:20] - Machine ID: 1
[04:55:20]
[04:55:20] Loaded queue successfully.
[04:55:20] Initialization complete
[04:55:20]
[04:55:20] + Processing work unit
[04:55:20] Core required: FahCore_b4.exe
[04:55:20] Core found.
[04:55:20] Working on queue slot 03 [March 31 04:55:20 UTC]
[04:55:20] + Working ...
[04:55:56] *********************** Log Started 31/Mar/2010 04:55:55 ***********************
[04:55:56] ************************** ProtoMol Folding@Home Core **************************
[04:55:56]   Version: 23
[04:55:56]      Type: 180
[04:55:56]      Core: ProtoMol
[04:55:56]   Website: http://folding.stanford.edu/
[04:55:56] Copyright: (c) 2009 Stanford University
[04:55:56]    Author: Joseph Coffland <joseph@cauldrondevelopment.com>
[04:55:56]      Args: -dir work/ -suffix 03 -checkpoint 15 -lifeline 1552 -version 623
[04:55:56] ************************************ Build *************************************
[04:55:56]      Date: Mar 22 2010
[04:55:56]      Time: 16:55:15
[04:55:56]  Revision: 1789
[04:55:56]  Compiler: Intel(R) C++ MSVC 1500 mode 1110
[04:55:56]   Options: /TP /nologo /EHsc /wd4297 /wd4103 /wd1786 /arch:IA32 /Ox
[04:55:56]            /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qrestrict /MT
[04:55:56]   Defines: _CRT_SECURE_NO_WARNINGS NDEBUG HAVE_GEEKINFO BOOST_ALL_NO_LIB
[04:55:56]            XML_STATIC HAVE_EXPAT HAVE_OPENSSL HAVE_LIBFAH HAVE_SIMTK_LAPACK
[04:55:56]  Platform: Windows XP
[04:55:56]      Bits: 32
[04:55:56]      Mode: Release
[04:55:56] ************************************ System ************************************
[04:55:56]        OS: Microsoft Windows XP Professional
[04:55:56]       CPU: AMD Athlon(tm) 64 X2 Dual Core Processor 4200+
[04:55:56]    CPU ID: AuthenticAMD Family 15 Model 75 Stepping 2
[04:55:56]      CPUs: 2 Logical, 2 Physical
[04:55:56]    Memory: 3.00 GB
[04:55:56]   Threads: Windows
[04:55:56] ********************************************************************************
[04:55:56] Project: 10006 (Run 275, Clone 5, Gen 9)
[04:55:56] Digital signatures verified
[04:56:02] Completed 379500 out of 500000 steps (75%)
[04:58:15] Completed 380000 out of 500000 steps (76%)
[05:20:33] Completed 385000 out of 500000 steps (77%)
[05:42:42] Completed 390000 out of 500000 steps (78%)
Folding@Home Client Shutdown.
--- Opening Log file [March 31 05:51:38 UTC]
[05:51:38] - Ask before connecting: No
[05:51:38] - User name: Robby (Team 39299)
[05:51:38] - User ID: ****0E6
[05:51:38] - Machine ID: 1
[05:51:38]
[05:51:39] Loaded queue successfully.
[05:51:39] Initialization complete
[05:51:39]
[05:51:39] + Processing work unit
[05:51:39] Core required: FahCore_b4.exe
[05:51:39] Core found.
[05:51:39] Working on queue slot 03 [March 31 05:51:39 UTC]
[05:51:39] + Working ...
[05:52:13] *********************** Log Started 31/Mar/2010 05:52:12 ***********************
[05:52:13] ************************** ProtoMol Folding@Home Core **************************
[05:52:13]   Version: 23
[05:52:13]      Type: 180
[05:52:13]      Core: ProtoMol
[05:52:13]   Website: http://folding.stanford.edu/
[05:52:13] Copyright: (c) 2009 Stanford University
[05:52:13]    Author: Joseph Coffland <joseph@cauldrondevelopment.com>
[05:52:13]      Args: -dir work/ -suffix 03 -checkpoint 15 -lifeline 1120 -version 623
[05:52:13] ************************************ Build *************************************
[05:52:13]      Date: Mar 22 2010
[05:52:13]      Time: 16:55:15
[05:52:13]  Revision: 1789
[05:52:13]  Compiler: Intel(R) C++ MSVC 1500 mode 1110
[05:52:13]   Options: /TP /nologo /EHsc /wd4297 /wd4103 /wd1786 /arch:IA32 /Ox
[05:52:13]            /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qrestrict /MT
[05:52:13]   Defines: _CRT_SECURE_NO_WARNINGS NDEBUG HAVE_GEEKINFO BOOST_ALL_NO_LIB
[05:52:13]            XML_STATIC HAVE_EXPAT HAVE_OPENSSL HAVE_LIBFAH HAVE_SIMTK_LAPACK
[05:52:13]  Platform: Windows XP
[05:52:13]      Bits: 32
[05:52:13]      Mode: Release
[05:52:13] ************************************ System ************************************
[05:52:13]        OS: Microsoft Windows XP Professional
[05:52:13]       CPU: AMD Athlon(tm) 64 X2 Dual Core Processor 4200+
[05:52:13]    CPU ID: AuthenticAMD Family 15 Model 75 Stepping 2
[05:52:13]      CPUs: 2 Logical, 2 Physical
[05:52:13]    Memory: 3.00 GB
[05:52:13]   Threads: Windows
[05:52:13] ********************************************************************************
[05:52:13] Project: 10006 (Run 275, Clone 5, Gen 9)
[05:52:13] Digital signatures verified
[05:52:14] ERROR: Guru Meditation #4917496d987138b1.699592fe3ebd00ad (2555556.2555556) 'work/03/ww.dcd'
[05:52:14] WARNING: Unexpected exit() call
[05:52:14] WARNING: Unexpected exit from science code
[05:52:15] Saving result file logfile_03.txt
[05:52:15] Saving result file checkpt
[05:52:15] Saving result file checkpt.crc
[05:52:15] Saving result file log.txt
[05:52:45] Saving result file protomol.conf
[05:52:45] ERROR: Guru Meditation #4917496d987138b1.699592fe3ebd00ad (2555556.2555556) 'work/03/ww.dcd'
[05:52:48] CoreStatus = 70 (112)
[05:52:48] + The core could not validate the current work unit for processing.
[05:52:48] Deleting current work unit & continuing...
[05:52:54] - Preparing to get new work unit...
[05:52:54] + Attempting to get work packet
[05:52:54] - Connecting to assignment server
[05:52:55] + No appropriate work server was available; will try again in a bit.
[05:52:55] + Couldn't get work instructions.
[05:52:55] - Attempt #1  to get work failed, and no other work to do.
Waiting before retry.
[05:53:01] + Attempting to get work packet
[05:53:01] - Connecting to assignment server
[05:53:01] + No appropriate work server was available; will try again in a bit.
[05:53:01] + Couldn't get work instructions.
[05:53:01] - Attempt #2  to get work failed, and no other work to do.
[05:53:25] + Attempting to get work packet
[05:53:25] - Connecting to assignment server
[05:53:25] + No appropriate work server was available; will try again in a bit.
[05:53:25] + Couldn't get work instructions.
[05:53:25] - Attempt #3  to get work failed, and no other work to do.
[05:53:50] + Attempting to get work packet
[05:53:50] - Connecting to assignment server
[05:53:51] + No appropriate work server was available; will try again in a bit.
[05:53:51] + Couldn't get work instructions.
[05:53:51] - Attempt #4  to get work failed, and no other work to do.
Processor: I7-4770 Memory: 32Gig RAM GPU: GeForce GTX 1660 MB: GigaByte GA-B85M-D3H
Re: Project: 10006 (Run 275, Clone 5, Gen 9)
Some new projects were announced yesterday. Part of that announcement mentioned a problem with the v23 ProtoMol core preserving work from a shutdown/restart. Until it's fixed, you can either remove -advmethods or you can wait for a more opportune time to restart.
viewtopic.php?f=24&t=14093
Robby_Firefox
Hi bruce,
Thanks for a quick answer. The -advmethods option otherwise works fine, especially in getting the older Amber 4600 series jobs.
Am still curious on the points for the 10000 series. It takes this machine a day or more to complete just one at 126 or so points per run.
- Robby
