Project: 6320 (Run 4, Clone 19, Gen 5)
Hostile
Post by Hostile »
This unit had been running very smoothly up until the 73%. This is a Fedora 12 computer with a Pentium 4. Here's the log:
[17:09:10] Project: 6320 (Run 4, Clone 19, Gen 5)
[17:09:10]
[17:09:10] Assembly optimizations on if available.
[17:09:10] Entering M.D.
[17:09:30] (Starting from checkpoint)
[17:09:30] Protein: Fs_coil_ff99sb
[17:09:30]
[17:09:30] Writing local files
[17:09:30] Completed 1825000 out of 2500000 steps  (73%)
[17:09:30] Extra SSE boost OK.
[17:19:31] Timered checkpoint triggered.
[17:22:13] Writing local files
[17:22:13] Completed 1850000 out of 2500000 steps  (74%)
[17:29:48] Quit 101 - Fatal error: NaN detected: (ener[13])
[17:29:48]
[17:29:48] Simulation instability has been encountered. The run has entered a
[17:29:48]   state from which no further progress can be made.
[17:29:48] This may be the correct result of the simulation, however if you
[17:29:48]   often see other project units terminating early like this
[17:29:48]   too, you may wish to check the stability of your computer (issues
[17:29:48]   such as high temperature, overclocking, etc.).
[17:29:48] Going to send back what have done.
[17:29:48] logfile size: 92826
[17:29:48] - Writing 93389 bytes of core data to disk...
[17:29:48] Done: 92877 -> 7375 (compressed to 7.9 percent)
[17:29:48]   ... Done.
[17:30:00]
[17:30:00] Folding@home Core Shutdown: EARLY_UNIT_END
[17:30:08] CoreStatus = 72 (114)
[17:30:08] Sending work to server
[17:30:08] - Read packet limit of 540015616... Set to 524286976.
[17:30:08] + Attempting to send results
[17:30:08] - Reading file work/wuresults_09.dat from core
[17:30:08]   (Read 7887 bytes from disk)
[17:30:08] Connecting to http://171.64.65.60:8080/
[17:30:08] Posted data.
[17:30:08] Initial: 0000; Conversation time very short, giving reduced weight in bandwidth avg
[17:30:08] - Uploaded at ~17 kB/s
[17:30:08] - Averaged speed for that direction ~60 kB/s
[17:30:08] + Results successfully sent
[17:30:08] Thank you for your contribution to Folding@Home.
Fedora 12
6.02 Linux CPU client, Pentium 4 2.8Ghz OC'd to 3.01Ghz
Re: Project: 6320 (Run 4, Clone 19, Gen 5)
It looks like someone else has been able to complete it ...
