0% GPU Usage, 0 PPD
0% GPU Usage, 0 PPD
I have been trying to uninstall and reinstall latest drivers, then older drivers, the f@h program, over and over and over for over a month now and my 2nd folding machine refuses to fold the way it used to. when the F@H program is running my 2nd folding machine with gts 250 the temp is at 35C....when folding and the fans kicked up using EVGA precision on my 1st folding machine it runs 60c and actually folds. I have tried to swap cards and got the same results.
What do I need to do to get my machine folding again?
Amd regor 245,2gb ddr 2 dual channel, MSI twin frozr gts 250,500w liberty power supply... this thing used to rock but ever since the "server issue" its never been the same.
current drivers are 197.13 I have also tried the cuda drivers with no success.
please help!
please help!
patonb
- Hardware configuration: WooHoo= SR-2 -- L5639 @ ?? -- Evga 560ti FPB -- 12Gig Corsair XMS3 -- Corsair 1050hx -- Blackhawk Ultra
Re: 0% GPU Usage, 0 PPD
So swapping the 250s results in the working machine not working?
What does the log show?
when i swap video cards there is no change...the 1st machine will fold fine...the 2nd machine will continue to do nearly nothing. Im not sure what to look for on the log file...I can copy and paste the past few days.
--- Opening Log file [March 28 23:02:30 UTC]
# Windows CPU Systray Edition #################################################
http://folding.stanford.edu
Launch directory: C:\Documents and Settings\Wet Fart\Application Data\Folding@home-x86
[23:02:30] - Ask before connecting: No
[23:02:30] - User name: Esuich (Team 111065)
[23:02:30] - User ID: 60CE2DB85EE96B46
[23:02:30] - Machine ID: 2
[23:02:30]
[23:02:30] Loaded queue successfully.
[23:02:30] Initialization complete
[23:02:30]
[23:02:30] + Processing work unit
[23:02:32] Core required: FahCore_a0.exe
[23:02:32] Core found.
[23:02:32] Working on queue slot 04 [March 28 23:02:32 UTC]
[23:02:32] + Working ...
[23:02:33]
[23:02:33] *------------------------------*
[23:02:33] Folding@Home Gromacs 3.3 Core
[23:02:33] Version 1.93 (July 23, 2008)
[23:02:33]
[23:02:33] Preparing to commence simulation
[23:02:33] - Looking at optimizations...
[23:02:33] - Files status OK
[23:02:36] - Expanded 2422642 -> 15040253 (decompressed 620.8 percent)
[23:02:38]
[23:02:38] Project: 1773 (Run 9, Clone 70, Gen 0)
[23:02:38]
[23:02:38] Assembly optimizations on if available.
[23:02:38] Entering M.D.
[23:02:45] FAH Init
[23:02:45] Checkpoint file:
[23:02:50] (Starting from checkpoint)
[23:02:50] Read checkpoint
[23:02:50] Protein: solvate output: 19 Na ions added to 1P0I.gro with min_sep 0.5 in water
[23:02:51] Writing local files
[23:02:51] Completed 440000 out of 500000 steps (88 percent)
[23:02:53] Extra SSE boost OK.
[23:45:53] Writing local files
[23:45:53] Completed 445000 out of 500000 steps (89 percent)
[00:28:31] Writing local files
[00:28:31] Completed 450000 out of 500000 steps (90 percent)
[01:11:09] Writing local files
[01:11:09] Completed 455000 out of 500000 steps (91 percent)
[01:57:05] Writing local files
[01:57:06] Completed 460000 out of 500000 steps (92 percent)
--- Opening Log file [March 29 03:38:07 UTC]
[03:38:07] - Ask before connecting: No
[03:38:07] - User name: Esuich (Team 111065)
[03:38:07] - User ID: 60CE2DB85EE96B46
[03:38:07] - Machine ID: 2
[03:38:07]
[03:38:08] Loaded queue successfully.
[03:38:08] Initialization complete
[03:38:08]
[03:38:08] + Processing work unit
[03:38:08] Core required: FahCore_a0.exe
[03:38:08] Core found.
[03:38:08] Working on queue slot 04 [March 29 03:38:08 UTC]
[03:38:08] + Working ...
[03:38:12]
[03:38:12] *------------------------------*
[03:38:12] Folding@Home Gromacs 3.3 Core
[03:38:12] Version 1.93 (July 23, 2008)
[03:38:12]
[03:38:12] Preparing to commence simulation
[03:38:12] - Looking at optimizations...
[03:38:12] - Files status OK
[03:38:15] - Expanded 2422642 -> 15040253 (decompressed 620.8 percent)
[03:38:19]
[03:38:19] Project: 1773 (Run 9, Clone 70, Gen 0)
[03:38:19]
[03:38:21] Assembly optimizations on if available.
[03:38:21] Entering M.D.
[03:38:27] FAH Init
[03:38:27] Checkpoint file:
[03:38:33] (Starting from checkpoint)
[03:38:33] Read checkpoint
[03:38:33] Protein: solvate output: 19 Na ions added to 1P0I.gro with min_sep 0.5 in water
[03:38:33] Writing local files
[03:38:33] Completed 463200 out of 500000 steps (92 percent)
[03:38:36] Extra SSE boost OK.
[03:54:07] Writing local files
[03:54:07] Completed 465000 out of 500000 steps (93 percent)
[04:37:54] Writing local files
[04:37:54] Completed 470000 out of 500000 steps (94 percent)
[05:20:57] Writing local files
[05:20:57] Completed 475000 out of 500000 steps (95 percent)
[06:03:32] Writing local files
[06:03:32] Completed 480000 out of 500000 steps (96 percent)
[06:46:10] Writing local files
[06:46:11] Completed 485000 out of 500000 steps (97 percent)
[07:28:53] Writing local files
[07:28:53] Completed 490000 out of 500000 steps (98 percent)
[08:11:33] Writing local files
[08:11:33] Completed 495000 out of 500000 steps (99 percent)
[08:54:12] Writing local files
[08:54:13] Completed 500000 out of 500000 steps (100 percent)
[08:54:13] Writing final coordinates.
[08:54:13] Past main M.D. loop
[08:55:13]
[08:55:13] Finished Work Unit:
[08:55:13] - Reading up to 2364000 from "work/wudata_04.arc": Read 2364000
[08:55:13] - Reading up to 3941060 from "work/wudata_04.xtc": Read 3941060
[08:55:13] goefile size: 0
[08:55:13] Leaving Run
[08:55:14] - Writing 6315272 bytes of core data to disk...
[08:55:14] ... Done.
[08:55:14] - Error deleting work files.
[08:55:14] - Shutting down core
[08:55:14]
[08:55:14] Folding@home Core Shutdown: FINISHED_UNIT
[08:55:17] CoreStatus = 64 (100)
[08:55:17] Sending work to server
[08:55:17] Project: 1773 (Run 9, Clone 70, Gen 0)
[08:55:17] - Read packet limit of 540015616... Set to 524286976.
[08:55:17] + Attempting to send results [March 29 08:55:17 UTC]
[08:55:43] + Results successfully sent
[08:55:43] Thank you for your contribution to Folding@Home.
[08:55:43] + Number of Units Completed: 3
[08:55:47] - Preparing to get new work unit...
[08:55:47] + Attempting to get work packet
[08:55:47] - Connecting to assignment server
[08:55:48] - Successful: assigned to (171.64.65.111).
[08:55:48] + News From Folding@Home: Welcome to Folding@Home
[08:55:48] Loaded queue successfully.
[08:55:54] + Closed connections
[08:55:54]
[08:55:54] + Processing work unit
[08:55:54] Core required: FahCore_78.exe
[08:55:54] Core found.
[08:55:54] Working on queue slot 05 [March 29 08:55:54 UTC]
[08:55:54] + Working ...
[08:55:55]
[08:55:55] *------------------------------*
[08:55:55] Folding@Home Gromacs Core
[08:55:55] Version 1.90 (March 8, 2006)
[08:55:55]
[08:55:55] Preparing to commence simulation
[08:55:55] - Looking at optimizations...
[08:55:55] - Created dyn
[08:55:55] - Files status OK
[08:55:55] - Expanded 463830 -> 2244013 (decompressed 483.8 percent)
[08:55:55] - Starting from initial work packet
[08:55:55]
[08:55:55] Project: 6315 (Run 585, Clone 12, Gen 47)
[08:55:55]
[08:55:55] Assembly optimizations on if available.
[08:55:55] Entering M.D.
[08:56:01] Protein: p6315_sh3_with_ALA_frags
[08:56:01]
[08:56:01] Writing local files
[08:56:01] Extra SSE boost OK.
[08:56:02] Writing local files
[08:56:02] Completed 0 out of 500000 steps (0%)
[09:07:02] Writing local files
[09:07:02] Completed 5000 out of 500000 steps (1%)
[09:18:02] Writing local files
[09:18:02] Completed 10000 out of 500000 steps (2%)
[09:29:02] Writing local files
[09:29:02] Completed 15000 out of 500000 steps (3%)
--- Opening Log file [March 29 10:38:14 UTC]
[10:38:15] - Ask before connecting: No
[10:38:15] - User name: Esuich (Team 111065)
[10:38:15] - User ID: 60CE2DB85EE96B46
[10:38:15] - Machine ID: 2
[10:38:15]
[10:38:15] Loaded queue successfully.
[10:38:15] Initialization complete
[10:38:15]
[10:38:15] + Processing work unit
[10:38:16] Core required: FahCore_78.exe
[10:38:16] Core found.
[10:38:16] Working on queue slot 05 [March 29 10:38:16 UTC]
[10:38:16] + Working ...
[10:38:16]
[10:38:16] *------------------------------*
[10:38:16] Folding@Home Gromacs Core
[10:38:16] Version 1.90 (March 8, 2006)
[10:38:16]
[10:38:16] Preparing to commence simulation
[10:38:16] - Looking at optimizations...
[10:38:16] - Files status OK
[10:38:17] - Expanded 463830 -> 2244013 (decompressed 483.8 percent)
[10:38:18]
[10:38:18] Project: 6315 (Run 585, Clone 12, Gen 47)
[10:38:18]
[10:38:18] Assembly optimizations on if available.
[10:38:18] Entering M.D.
[10:38:38] (Starting from checkpoint)
[10:38:38] Protein: p6315_sh3_with_ALA_frags
[10:38:38]
[10:38:38] Writing local files
[10:38:38] Completed 15000 out of 500000 steps (3%)
[10:38:38] Extra SSE boost OK.
[10:49:50] Writing local files
[10:49:50] Completed 20000 out of 500000 steps (4%)
[11:00:58] Writing local files
[11:00:58] Completed 25000 out of 500000 steps (5%)
--- Opening Log file [March 29 22:16:14 UTC]
[22:16:14] - Ask before connecting: No
[22:16:14] - User name: Esuich (Team 111065)
[22:16:14] - User ID: 60CE2DB85EE96B46
[22:16:14] - Machine ID: 2
[22:16:14]
[22:16:14] Loaded queue successfully.
[22:16:15] Initialization complete
[22:16:15]
[22:16:15] + Processing work unit
[22:16:15] Core required: FahCore_78.exe
[22:16:15] Core found.
[22:16:15] Working on queue slot 05 [March 29 22:16:15 UTC]
[22:16:15] + Working ...
[22:16:18]
[22:16:18] *------------------------------*
[22:16:18] Folding@Home Gromacs Core
[22:16:18] Version 1.90 (March 8, 2006)
[22:16:18]
[22:16:18] Preparing to commence simulation
[22:16:18] - Looking at optimizations...
[22:16:18] - Files status OK
[22:16:18] - Expanded 463830 -> 2244013 (decompressed 483.8 percent)
[22:16:19]
[22:16:19] Project: 6315 (Run 585, Clone 12, Gen 47)
[22:16:19]
[22:16:19] Assembly optimizations on if available.
[22:16:19] Entering M.D.
[22:16:40] (Starting from checkpoint)
[22:16:40] Protein: p6315_sh3_with_ALA_frags
[22:16:40]
[22:16:40] Writing local files
[22:16:40] Completed 25000 out of 500000 steps (5%)
[22:16:40] Extra SSE boost OK.
[22:27:41] Writing local files
[22:27:41] Completed 30000 out of 500000 steps (6%)
[22:38:50] Writing local files
[22:38:50] Completed 35000 out of 500000 steps (7%)
[22:50:02] Writing local files
[22:50:02] Completed 40000 out of 500000 steps (8%)
[23:01:13] Writing local files
[23:01:13] Completed 45000 out of 500000 steps (9%)
[23:12:24] Writing local files
[23:12:24] Completed 50000 out of 500000 steps (10%)
[23:23:42] Writing local files
[23:23:42] Completed 55000 out of 500000 steps (11%)
[23:35:04] Writing local files
[23:35:04] Completed 60000 out of 500000 steps (12%)
[23:46:28] Writing local files
[23:46:28] Completed 65000 out of 500000 steps (13%)
[23:57:51] Writing local files
[23:57:51] Completed 70000 out of 500000 steps (14%)
[00:09:13] Writing local files
[00:09:13] Completed 75000 out of 500000 steps (15%)
[00:20:31] Writing local files
[00:20:32] Completed 80000 out of 500000 steps (16%)
[00:31:44] Writing local files
[00:31:44] Completed 85000 out of 500000 steps (17%)
[00:40:04] Opening http://fah-web.stanford.edu/cgi-bin/main.py?qtype=userpage&username=Esuich...
[00:42:54] Writing local files
[00:42:54] Completed 90000 out of 500000 steps (18%)
[00:54:05] Writing local files
[00:54:05] Completed 95000 out of 500000 steps (19%)
--- Opening Log file [March 30 01:02:43 UTC]
[01:02:43] - Ask before connecting: No
[01:02:43] - User name: Esuich (Team 111065)
[01:02:43] - User ID: 60CE2DB85EE96B46
[01:02:43] - Machine ID: 1
[01:02:43]
[01:02:44] Loaded queue successfully.
[01:02:44] Initialization complete
[01:02:44]
[01:02:44] + Processing work unit
[01:02:44] Core required: FahCore_78.exe
[01:02:44] Core found.
[01:02:44] Working on queue slot 05 [March 30 01:02:44 UTC]
[01:02:44] + Working ...
[01:02:46]
[01:02:46] *------------------------------*
[01:02:46] Folding@Home Gromacs Core
[01:02:46] Version 1.90 (March 8, 2006)
[01:02:46]
[01:02:46] Preparing to commence simulation
[01:02:46] - Looking at optimizations...
[01:02:46] - Files status OK
[01:02:47] - Expanded 463830 -> 2244013 (decompressed 483.8 percent)
[01:02:47]
[01:02:47] Project: 6315 (Run 585, Clone 12, Gen 47)
[01:02:47]
[01:02:47] Assembly optimizations on if available.
[01:02:47] Entering M.D.
Folding@Home Client Shutdown.
--- Opening Log file [March 30 01:06:28 UTC]
[01:06:28] - Ask before connecting: No
[01:06:28] - User name: Esuich (Team 111065)
[01:06:28] - User ID: 60CE2DB85EE96B46
[01:06:28] - Machine ID: 1
[01:06:28]
[01:06:28] Loaded queue successfully.
[01:06:28] Initialization complete
[01:06:28]
[01:06:28] + Processing work unit
[01:06:28] Core required: FahCore_78.exe
[01:06:28] Core found.
[01:06:28] Working on queue slot 05 [March 30 01:06:28 UTC]
[01:06:28] + Working ...
[01:06:29]
[01:06:29] *------------------------------*
[01:06:29] Folding@Home Gromacs Core
[01:06:29] Version 1.90 (March 8, 2006)
[01:06:29]
[01:06:29] Preparing to commence simulation
[01:06:29] - Looking at optimizations...
[01:06:29] - Files status OK
[01:06:30] - Expanded 463830 -> 2244013 (decompressed 483.8 percent)
[01:06:30]
[01:06:30] Project: 6315 (Run 585, Clone 12, Gen 47)
[01:06:30]
[01:06:30] Assembly optimizations on if available.
[01:06:30] Entering M.D.
[01:06:53] (Starting from checkpoint)
[01:06:53] Protein: p6315_sh3_with_ALA_frags
[01:06:53]
[01:06:54] Writing local files
[01:06:54] Completed 95000 out of 500000 steps (19%)
[01:06:54] Extra SSE boost OK.
[01:07:26] Opening C:\Documents and Settings\Wet Fart\Application Data\Folding@home-x86\MyFolding.html...
[01:18:01] Writing local files
[01:18:01] Completed 100000 out of 500000 steps (20%)
[01:29:03] Writing local files
[01:29:03] Completed 105000 out of 500000 steps (21%)
[01:40:02] Writing local files
[01:40:02] Completed 110000 out of 500000 steps (22%)
[01:51:17] Writing local files
[01:51:17] Completed 115000 out of 500000 steps (23%)
[02:02:15] Writing local files
[02:02:16] Completed 120000 out of 500000 steps (24%)
[02:13:13] Writing local files
[02:13:13] Completed 125000 out of 500000 steps (25%)
[02:24:10] Writing local files
[02:24:10] Completed 130000 out of 500000 steps (26%)
[02:35:17] Writing local files
[02:35:17] Completed 135000 out of 500000 steps (27%)
[02:46:32] Writing local files
[02:46:32] Completed 140000 out of 500000 steps (28%)
[02:57:51] Writing local files
[02:57:51] Completed 145000 out of 500000 steps (29%)
[03:09:04] Writing local files
[03:09:04] Completed 150000 out of 500000 steps (30%)
[03:20:13] Writing local files
[03:20:13] Completed 155000 out of 500000 steps (31%)
[03:31:24] Writing local files
[03:31:24] Completed 160000 out of 500000 steps (32%)
[03:42:33] Writing local files
[03:42:33] Completed 165000 out of 500000 steps (33%)
[03:53:42] Writing local files
[03:53:42] Completed 170000 out of 500000 steps (34%)
[04:04:52] Writing local files
[04:04:52] Completed 175000 out of 500000 steps (35%)
[04:16:03] Writing local files
[04:16:03] Completed 180000 out of 500000 steps (36%)
[04:27:11] Writing local files
[04:27:11] Completed 185000 out of 500000 steps (37%)
[04:38:24] Writing local files
[04:38:24] Completed 190000 out of 500000 steps (38%)
[04:49:36] Writing local files
[04:49:36] Completed 195000 out of 500000 steps (39%)
[05:00:49] Writing local files
[05:00:49] Completed 200000 out of 500000 steps (40%)
[05:12:00] Writing local files
[05:12:00] Completed 205000 out of 500000 steps (41%)
[05:23:09] Writing local files
[05:23:09] Completed 210000 out of 500000 steps (42%)
[05:34:20] Writing local files
[05:34:20] Completed 215000 out of 500000 steps (43%)
[05:45:30] Writing local files
[05:45:30] Completed 220000 out of 500000 steps (44%)
[05:56:41] Writing local files
[05:56:41] Completed 225000 out of 500000 steps (45%)
[06:07:46] Writing local files
[06:07:46] Completed 230000 out of 500000 steps (46%)
[06:18:44] Writing local files
[06:18:44] Completed 235000 out of 500000 steps (47%)
[06:29:43] Writing local files
[06:29:43] Completed 240000 out of 500000 steps (48%)
[06:40:41] Writing local files
[06:40:41] Completed 245000 out of 500000 steps (49%)
[06:51:39] Writing local files
[06:51:39] Completed 250000 out of 500000 steps (50%)
[07:02:37] Writing local files
[07:02:37] Completed 255000 out of 500000 steps (51%)
[07:06:28] + Working...
[07:13:36] Writing local files
[07:13:36] Completed 260000 out of 500000 steps (52%)
[07:24:35] Writing local files
[07:24:35] Completed 265000 out of 500000 steps (53%)
[07:35:34] Writing local files
[07:35:34] Completed 270000 out of 500000 steps (54%)
[07:46:32] Writing local files
[07:46:32] Completed 275000 out of 500000 steps (55%)
[07:57:30] Writing local files
[07:57:31] Completed 280000 out of 500000 steps (56%)
[08:08:29] Writing local files
[08:08:29] Completed 285000 out of 500000 steps (57%)
[08:19:27] Writing local files
[08:19:27] Completed 290000 out of 500000 steps (58%)
[08:30:26] Writing local files
[08:30:26] Completed 295000 out of 500000 steps (59%)
[08:41:24] Writing local files
[08:41:24] Completed 300000 out of 500000 steps (60%)
[08:52:21] Writing local files
[08:52:22] Completed 305000 out of 500000 steps (61%)
[09:03:19] Writing local files
[09:03:19] Completed 310000 out of 500000 steps (62%)
[09:14:18] Writing local files
[09:14:18] Completed 315000 out of 500000 steps (63%)
[09:25:16] Writing local files
[09:25:16] Completed 320000 out of 500000 steps (64%)
[09:36:15] Writing local files
[09:36:15] Completed 325000 out of 500000 steps (65%)
[09:47:13] Writing local files
[09:47:13] Completed 330000 out of 500000 steps (66%)
[09:58:11] Writing local files
[09:58:11] Completed 335000 out of 500000 steps (67%)
[10:09:12] Writing local files
[10:09:12] Completed 340000 out of 500000 steps (68%)
[10:18:55] Opening http://fah-web.stanford.edu/cgi-bin/main.py?qtype=userpage&username=Esuich...
[10:20:13] Writing local files
[10:20:13] Completed 345000 out of 500000 steps (69%)
[10:30:52] Writing local files
[10:30:52] Completed 350000 out of 500000 steps (70%)Re: 0% GPU Usage, 0 PPD
Are you starting one with -gpu 0 and the second with -gpu 1?
The other command line argument that may help is -forcegpu nvidia_g80 used on both clients.
You can add this to your shortcut command line or by starting the clients with -configonly or -config and adding the option to the additional parameters field or if using the systray a right click on the systray icon will lead you to the configuration section where you can add the options.
p.s. the logs you show are not for a GPU client, they are for a CPU client.
Welcome to the Forum Esuich
The log that you have posted is of CPU Uniprocessor 6.23 Systray Edition and the according to the log, you have sucessfully completed and uploaded 3 WUs. Your first post states that you have a problem with the GPU so you have to post the GPU Client log. Also in your second post you mentioned that swapping the GPUs has no effect on the second system. This could mean that the PSU is not delivering enough power to the GPU as it may be damaged or something. If by switching the PSU, you still can't fold, it could be possible that the PCI-E lane in the motherboard is damaged. If there is another PCI-E lane, use it and see if it solves the problem.
Hope this helps you.
Yes, I was also wondering about your 500W PSU. The Minimum Recommended System Power is 450W when using just one gts250.
http://www.nvidia.com/object/product_ge ... 50_us.html
So running two on a 500W could be a problem.
I guess the GPU would work better if you used the GPU client ...
It used to fold great before the server issue last month. Its a high quality power supply with 34 amps on the 12v rail.
I will try to use the other pcie slot on my MB
Did I download the wrong software? sorry but I dont know what a "GPU client" is
Im not sure how to change settings can someone please guide me ..thanks.
1- Visit this URL (http://folding.stanford.edu/English/DownloadWinOther).
2- Under High Performance Clients, Download the second one. (the first is for ATI so it won't work with your Nvidia 250GTS).
3- Install the latest Nvidia Driver and then install the GPU Client that you downloaded.
4- Run the GPU Client.
5- Wait for few minutes.
6- Right click the GPU F@H Icon in the taskbar -> Status -> Log File.
7- A text file will open in Notepad.
8- Copy everything and paste it here using the code tag
9- If everything went fine, the F@H Log won't have any errors otherwise if it does, hopefully we can help you.
BTW the server issue was resolved for the Nvidia GPU and so far I haven't come cross any problems. The only "problem" is that the uniprocessor client of mine takes couple of attempts (around 5) to get a WU and according to the F@H Blog, they are aware of it and are working on new projects so that in the future, there won't be any WU shortages.
The log will appear like thisBTW the server issue was resolved for the Nvidia GPU and so far I haven't come cross any problems. The only "problem" is that the uniprocessor client of mine takes couple of attempts (around 5) to get a WU and according to the F@H Blog, they are aware of it and are working on new projects so that in the future, there won't be any WU shortages.
thank you! I will try it during my lunch break and post an update!
success!!! I have no idea why it stopped working one day...I have downloaded from the same spot every time...thank you everyone
