Same error also seen on this thread:
With all due respect I don't think so. The old P4 computer these two WUs were completed on has been running a v5 F@H client for about three years now and until this issue occurred it has been fine. IMHO this is a problem on the PG side, not with the contributors.bruce wrote:When you get the message "Server reports problem with unit." it must be just discarding the WU. I've never found a record of the WU on the server. I've never seen an explanation of what this message means. Someone else completed this WU, though, so there's a high probability that something is wrong on your end but I don't know what it might be.wan.ardiles wrote:Hello guys. This is my 2nd problem. Still no credit, same "Server reports problem with unit." error.
It does look like the completed WUs are just discarded. No credit is posted. And in support of the problem being with the server, after both instances of "Server reports problem with unit" it then took over 90 minutes before a new WU was sent. Not a normal occurrence and again not a problem with the contributor's system.
Project: 10004 (Run 3930, Clone 1, Gen 14):
[19:04:02] + Attempting to send results
[19:07:09] + Results successfully sent
[19:07:09] Thank you for your contribution to Folding@Home.
[19:07:09] + Number of Units Completed: 379
[19:07:24] - Preparing to get new work unit...
[19:07:24] + Attempting to get work packet
[19:07:25] - Connecting to assignment server
[19:07:25] - Successful: assigned to (129.74.85.48).
[19:07:25] + News From Folding@Home: Welcome to Folding@Home
[19:07:25] Loaded queue successfully.
[19:07:32] + Closed connections
[19:07:32]
[19:07:32] + Processing work unit
[19:07:32] Core required: FahCore_b4.exe
[19:07:32] Core found.
[19:07:32] Working on Unit 01 [March 26 19:07:32]
[19:07:32] + Working ...
[19:07:34] *********************** Log Started 26/Mar/2010 19:07:34 ***********************
[19:07:34] ************************** ProtoMol Folding@Home Core **************************
[19:07:34] Version: 22
[19:07:34] Type: 180
[19:07:34] Core: ProtoMol
[19:07:34] Website: http://folding.stanford.edu/
[19:07:34] Copyright: (c) 2009 Stanford University
[19:07:34] Author: Joseph Coffland <joseph@cauldrondevelopment.com>
[19:07:34] Args: -dir work/ -suffix 01 -checkpoint 3 -forceasm -lifeline 1776 -version
[19:07:34] 504
[19:07:34]
[19:07:34] ************************************ Build *************************************
[19:07:34] Date: Jan 21 2010
[19:07:34] Time: 19:16:23
[19:07:34] Revision: 1756
[19:07:34] Compiler: Intel(R) C++ MSVC 1500 mode 1110
[19:07:34] Options: /TP /nologo /EHsc /wd4297 /wd4103 /wd1786 /arch:IA32 /Ox
[19:07:34] /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qrestrict /MT
[19:07:34] Platform: Windows XP
[19:07:34] Bits: 32
[19:07:34] Mode: Release
[19:07:34] ************************************ System ************************************
[19:07:34] OS: Microsoft Windows XP Home Edition
[19:07:34] CPU: Intel(R) Pentium(R) 4 CPU 2.80GHz
[19:07:34] CPU ID: GenuineIntel Family 15 Model 4 Stepping 1
[19:07:34] CPUs: 2 Logical, 1 Physical
[19:07:34] Memory: 1023 MB
[19:07:34] Threads: Windows
[19:07:34] ********************************************************************************
[19:07:34] Project: 10004 (Run 3930, Clone 1, Gen 14)
[19:07:34] Reading tar file par_all27_prot_lipid.inp
[19:07:34] Reading tar file scpismQuartic.inp
[19:07:34] Reading tar file ww_exteq_nowater1.pdb
[19:07:34] Reading tar file ww_exteq_nowater1.psf
[19:07:34] Reading tar file checkpt
[19:07:34] Reading tar file ww_exteq_nowater1.989.pos
[19:07:34] Reading tar file ww_exteq_nowater1.989.vel
[19:07:34] Reading tar file protomol.conf
[19:07:34] Reading tar file core.xml
[19:07:34] Digital signatures verified
[19:07:38] Completed 0 out of 500000 steps (0)
[19:19:08] Completed 5000 out of 500000 steps (1)
[19:30:40] Completed 10000 out of 500000 steps (2)
<snip>
[14:29:02] Completed 495000 out of 500000 steps (99)
[14:40:38] Completed 500000 out of 500000 steps (100)
[14:40:39] Saving result file logfile_01.txt
[14:40:39] Saving result file checkpt
[14:40:39] Saving result file checkpt.crc
[14:40:39] Saving result file log.txt
[14:40:42] Saving result file protomol.conf
[14:40:42] Saving result file ww.dcd
[14:40:44] Saving result file ww_exteq_nowater1.1365.pos
[14:40:44] Saving result file ww_exteq_nowater1.1365.vel
[14:40:44] Folding@home Core Shutdown: FINISHED_UNIT
[14:40:49] CoreStatus = 64 (100)
[14:40:49] Sending work to server
[14:40:49] + Attempting to send results
[14:45:59] - Couldn't send HTTP request to server
[14:45:59] + Could not connect to Work Server (results)
[14:45:59] (129.74.85.48:8080)
[14:45:59] - Error: Could not transmit unit 01 (completed March 27) to work server.
[14:45:59] Keeping unit 01 in queue.
[14:45:59] + Attempting to send results
[14:51:08] - Couldn't send HTTP request to server
[14:51:08] + Could not connect to Work Server (results)
[14:51:08] (129.74.85.48:8080)
[14:51:08] - Error: Could not transmit unit 01 (completed March 27) to work server.
[14:51:08] + Attempting to send results
[14:51:54] - Server reports problem with unit.
[14:51:54] Successfully sent unit 01 to Collection server.
[14:51:54] - Preparing to get new work unit...
[14:51:54] + Attempting to get work packet
[14:51:55] - Connecting to assignment server
[14:51:55] - Successful: assigned to (134.139.127.32).
[14:51:55] + News From Folding@Home: Welcome to Folding@Home
[14:51:55] Loaded queue successfully.
[14:52:28] + Closed connections
Project: 10006 (Run 25, Clone 4, Gen 5):
[16:30:46] + Attempting to get work packet
[16:30:46] - Connecting to assignment server
[16:30:46] - Successful: assigned to (129.74.85.48).
[16:30:46] + News From Folding@Home: Welcome to Folding@Home
[16:30:46] Loaded queue successfully.
[16:30:49] + Closed connections
[16:30:49]
[16:30:49] + Processing work unit
[16:30:49] Core required: FahCore_b4.exe
[16:30:49] Core found.
[16:30:49] Working on Unit 01 [March 27 16:30:49]
[16:30:49] + Working ...
[16:30:57] *********************** Log Started 27/Mar/2010 16:30:57 ***********************
[16:30:57] ************************** ProtoMol Folding@Home Core **************************
[16:30:57] Version: 22
[16:30:57] Type: 180
[16:30:57] Core: ProtoMol
[16:30:57] Website: http://folding.stanford.edu/
[16:30:57] Copyright: (c) 2009 Stanford University
[16:30:57] Author: Joseph Coffland <joseph@cauldrondevelopment.com>
[16:30:57] Args: -dir work/ -suffix 01 -checkpoint 3 -forceasm -lifeline 3564 -version
[16:30:57] 504
[16:30:57]
[16:30:57] ************************************ Build *************************************
[16:30:57] Date: Jan 21 2010
[16:30:57] Time: 19:16:23
[16:30:57] Revision: 1756
[16:30:57] Compiler: Intel(R) C++ MSVC 1500 mode 1110
[16:30:57] Options: /TP /nologo /EHsc /wd4297 /wd4103 /wd1786 /arch:IA32 /Ox
[16:30:57] /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qrestrict /MT
[16:30:57] Platform: Windows XP
[16:30:57] Bits: 32
[16:30:57] Mode: Release
[16:30:57] ************************************ System ************************************
[16:30:57] OS: Microsoft Windows XP Home Edition
[16:30:57] CPU: Intel(R) Pentium(R) 4 CPU 2.80GHz
[16:30:57] CPU ID: GenuineIntel Family 15 Model 4 Stepping 1
[16:30:57] CPUs: 2 Logical, 1 Physical
[16:30:57] Memory: 1023 MB
[16:30:57] Threads: Windows
[16:30:57] ********************************************************************************
[16:30:57] Project: 10006 (Run 25, Clone 4, Gen 5)
[16:30:58] Reading tar file par_all27_prot_lipid.inp
[16:30:58] Reading tar file scpismQuartic.inp
[16:30:58] Reading tar file ww_exteq_nowater1.pdb
[16:30:58] Reading tar file ww_exteq_nowater1.psf
[16:30:58] Reading tar file checkpt
[16:30:58] Reading tar file ww_exteq_nowater1.267.pos
[16:30:58] Reading tar file ww_exteq_nowater1.267.vel
[16:30:58] Reading tar file protomol.conf
[16:30:58] Reading tar file core.xml
[16:30:58] Digital signatures verified
[16:31:02] Completed 0 out of 500000 steps (0)
[16:49:25] Completed 5000 out of 500000 steps (1)
[17:08:47] Completed 10000 out of 500000 steps (2)
<snip>
[20:28:17] Completed 495000 out of 500000 steps (99)
[20:43:10] Completed 500000 out of 500000 steps (100)
[20:43:11] Saving result file logfile_01.txt
[20:43:11] Saving result file checkpt
[20:43:11] Saving result file checkpt.crc
[20:43:11] Saving result file log.txt
[20:43:19] Saving result file protomol.conf
[20:43:19] Saving result file ww.dcd
[20:43:22] Saving result file ww_exteq_nowater1.800.pos
[20:43:22] Saving result file ww_exteq_nowater1.800.vel
[20:43:22] Folding@home Core Shutdown: FINISHED_UNIT
[20:43:27] CoreStatus = 64 (100)
[20:43:27] Sending work to server
[20:43:27] + Attempting to send results
[20:43:48] - Couldn't send HTTP request to server
[20:43:48] + Could not connect to Work Server (results)
[20:43:48] (129.74.85.48:8080)
[20:43:48] - Error: Could not transmit unit 01 (completed March 28) to work server.
[20:43:48] Keeping unit 01 in queue.
[20:43:48] + Attempting to send results
[20:44:09] - Couldn't send HTTP request to server
[20:44:09] + Could not connect to Work Server (results)
[20:44:09] (129.74.85.48:8080)
[20:44:09] - Error: Could not transmit unit 01 (completed March 28) to work server.
[20:44:09] + Attempting to send results
[20:46:07] - Server reports problem with unit.
[20:46:07] Successfully sent unit 01 to Collection server.
[20:46:07] - Preparing to get new work unit...
[20:46:07] + Attempting to get work packet
[20:46:07] - Connecting to assignment server
[20:46:08] - Successful: assigned to (129.74.85.48).
[20:46:08] + News From Folding@Home: Welcome to Folding@Home
[20:46:08] Loaded queue successfully.
[20:46:29] - Couldn't send HTTP request to server
[20:46:29] + Could not connect to Work Server
[20:46:29] - Error: Attempt #1 to get work failed, and no other work to do.
Waiting before retry.
[20:46:38] + Attempting to get work packet
[20:46:38] - Connecting to assignment server
[20:46:38] - Successful: assigned to (129.74.85.48).
[20:46:38] + News From Folding@Home: Welcome to Folding@Home
[20:46:39] Loaded queue successfully.
[20:47:00] - Couldn't send HTTP request to server
[20:47:00] + Could not connect to Work Server
[20:47:00] - Error: Attempt #2 to get work failed, and no other work to do.
[20:47:11] + Attempting to get work packet
[20:47:11] - Connecting to assignment server
[20:47:12] - Successful: assigned to (129.74.85.48).
[20:47:12] + News From Folding@Home: Welcome to Folding@Home
[20:47:12] Loaded queue successfully.
[20:47:33] - Couldn't send HTTP request to server
[20:47:33] + Could not connect to Work Server
[20:47:33] - Error: Attempt #3 to get work failed, and no other work to do.
[20:47:55] + Attempting to get work packet
[20:48:02] - Connecting to assignment server
[20:48:02] - Successful: assigned to (129.74.85.48).
[20:48:02] + News From Folding@Home: Welcome to Folding@Home
[20:48:03] Loaded queue successfully.
[20:53:12] - Couldn't send HTTP request to server
[20:53:12] + Could not connect to Work Server
[20:53:12] - Error: Attempt #4 to get work failed, and no other work to do.
[20:53:53] + Attempting to get work packet
[20:53:53] - Connecting to assignment server
[20:53:53] - Successful: assigned to (0.0.0.0).
[20:53:53] + News From Folding@Home: Welcome to Folding@Home
[20:53:53] Work Unit has an invalid address.
[20:53:53] - Error: Attempt #5 to get work failed, and no other work to do.
[20:55:15] + Attempting to get work packet
[20:55:15] - Connecting to assignment server
[20:55:15] - Successful: assigned to (0.0.0.0).
[20:55:15] + News From Folding@Home: Welcome to Folding@Home
[20:55:15] Work Unit has an invalid address.
[20:55:15] - Error: Attempt #6 to get work failed, and no other work to do.
[20:58:05] + Attempting to get work packet
[20:58:05] - Connecting to assignment server
[20:58:05] - Successful: assigned to (0.0.0.0).
[20:58:05] + News From Folding@Home: Welcome to Folding@Home
[20:58:05] Work Unit has an invalid address.
[20:58:05] - Error: Attempt #7 to get work failed, and no other work to do.
[21:03:35] + Attempting to get work packet
[21:03:35] - Connecting to assignment server
[21:03:35] - Successful: assigned to (129.74.85.48).
[21:03:35] + News From Folding@Home: Welcome to Folding@Home
[21:03:35] Loaded queue successfully.
[21:08:44] - Couldn't send HTTP request to server
[21:08:44] + Could not connect to Work Server
[21:08:44] - Error: Attempt #8 to get work failed, and no other work to do.
[21:19:37] + Attempting to get work packet
[21:19:37] - Connecting to assignment server
[21:19:38] - Successful: assigned to (129.74.85.48).
[21:19:38] + News From Folding@Home: Welcome to Folding@Home
[21:19:38] Loaded queue successfully.
[21:19:59] - Couldn't send HTTP request to server
[21:19:59] + Could not connect to Work Server
[21:19:59] - Error: Attempt #9 to get work failed, and no other work to do.
[21:41:26] + Attempting to get work packet
[21:41:26] - Connecting to assignment server
[21:41:26] - Successful: assigned to (171.67.108.13).
[21:41:26] + News From Folding@Home: Welcome to Folding@Home
[21:41:26] Loaded queue successfully.
[21:41:29] + Could not connect to Work Server
[21:41:29] - Error: Attempt #10 to get work failed, and no other work to do.
[22:24:21] + Attempting to get work packet
[22:24:21] - Connecting to assignment server
[22:24:22] - Successful: assigned to (129.74.85.48).
[22:24:22] + News From Folding@Home: Welcome to Folding@Home
[22:24:22] Loaded queue successfully.
[22:24:29] + Closed connections
[22:24:29]
[22:24:29] + Processing work unit
[22:24:29] Core required: FahCore_b4.exe
[22:24:29] Core found.
[22:24:29] Working on Unit 02 [March 28 22:24:29]
[22:24:29] + Working ...
[22:24:45] *********************** Log Started 28/Mar/2010 22:24:45 ***********************
[22:24:45] ************************** ProtoMol Folding@Home Core **************************
[22:24:45] Version: 22
[22:24:45] Type: 180
[22:24:45] Core: ProtoMol
[22:24:45] Website: http://folding.stanford.edu/
[22:24:45] Copyright: (c) 2009 Stanford University
[22:24:45] Author: Joseph Coffland <joseph@cauldrondevelopment.com>
[22:24:45] Args: -dir work/ -suffix 02 -checkpoint 3 -forceasm -lifeline 3564 -version
[22:24:45] 504
[22:24:45]
[22:24:45] ************************************ Build *************************************
[22:24:45] Date: Jan 21 2010
[22:24:45] Time: 19:16:23
[22:24:45] Revision: 1756
[22:24:45] Compiler: Intel(R) C++ MSVC 1500 mode 1110
[22:24:45] Options: /TP /nologo /EHsc /wd4297 /wd4103 /wd1786 /arch:IA32 /Ox
[22:24:45] /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qrestrict /MT
[22:24:45] Platform: Windows XP
[22:24:45] Bits: 32
[22:24:45] Mode: Release
[22:24:45] ************************************ System ************************************
[22:24:45] OS: Microsoft Windows XP Home Edition
[22:24:45] CPU: Intel(R) Pentium(R) 4 CPU 2.80GHz
[22:24:45] CPU ID: GenuineIntel Family 15 Model 4 Stepping 1
[22:24:45] CPUs: 2 Logical, 1 Physical
[22:24:45] Memory: 1023 MB
[22:24:45] Threads: Windows
[22:24:45] ********************************************************************************
[22:24:45] Project: 10007 (Run 2924, Clone 0, Gen 6)
[22:24:45] Reading tar file par_all27_prot_lipid.inp
[22:24:45] Reading tar file scpismQuartic.inp
[22:24:45] Reading tar file ww_exteq_nowater1.pdb
[22:24:45] Reading tar file ww_exteq_nowater1.psf
[22:24:45] Reading tar file checkpt
[22:24:45] Reading tar file ww_exteq_nowater1.576.pos
[22:24:45] Reading tar file ww_exteq_nowater1.576.vel
[22:24:45] Reading tar file protomol.conf
[22:24:45] Reading tar file core.xml
[22:24:45] Digital signatures verified
[22:24:48] Completed 0 out of 500000 steps (0)
Log also includes 90 minutes of attempts to download another new WU.
If this WU fails I will shut off the client and report back again.
