Project: 5781 (Run 3, Clone 0, Gen 18)
Teddy
Post by Teddy »
Can't seem to shake off this crappy unit, immediate self-test failure, unit then pauses the GPU client for 24hrs, this keeps happening day after day.
Attempts to delete this unit & grab something else fail miserably.
That GPU is being turned off for the time being as when it does grab another unit this folds fine in fact it completed 15 units successfully before I got the same Project, R, C, G back again.
What gives Stanford how many other people is this happening too.
Once you get a shitty unit you can't seem to shake it off???
Teddy
Re: Project: 5781 (Run 3, Clone 0, Gen 18)
Apparently every time you had an error, another copy was dispatched to someone else. It looks like eight people have completed that same WU plus two more which may have had problems similar to yours. Is your FAH name "Teddy"?
In the past, a self-test failure indicated that something was wrong with the hardware. Have you run memtestg80 recently?
Teddy
Post by Teddy »
Teddy2(OCAU) is my nickname....
I just checked I am still being assigned that unit!!!!!!!!!!!!!!!!!!!
Teddy
Post by Teddy »
If that is the case I can no longer Fold on that card.
Frustrated
bollix47
Post by bollix47 »
Have you tried deleting queue.dat and the contents of the work folder, then going into the GPU's configuration and changing the MachineID to a different number(not one currently being used by other clients on that computer)? By changing that the server should assign you a different WU.
Teddy
Post by Teddy »
machineid that's one I have never heard of before, already deleted work folder & queue.dat numerous times & full reinstall & reconfigured but no change.
I do not understand Stanford server assignments!
