Sun Leaks 6-core Intel Xeon, Nehalem Details
http://www.dailytech.com/Sun+Leaks+6cor ... e10834.htm
excerpt from article wrote:Dunnington, Intel's 45nm six-core Xeon processor from the Penryn family, will succeed the Xeon Tigerton processor. Whereas Tigerton is essentially two 65nm Core 2 Duo processors fused on one package, Dunnington will be Intel's first Core 2 Duo processor with three dual-core banks.
Dunnington includes 16MB of L3 cache shared by all six processors. Each pair of cores can also access 3MB of local L2 cache.
Time to get a SMP client (by Q4 08) with more than 4 fahcores. ;)
Re: Sun Leaks 6-core Intel Xeon, Nehalem Details
Maybe in 2017 :roll:
kasson
Pande Group Member
Post by kasson »
We'll have a F@H SMP core ready by that time that can handle the required number of CPU cores.
zanth
Post by zanth »
That's really cool, tho unfortunately that would mean a person like myself(I'm completely linux stupid) would have to upgrade to vista, since XP would see that as three processors.
Flathead74
Post by Flathead74 »
Windows XP Professional can support up to two processors regardless of the number of cores on the processor.
from this page.
Microsoft Windows XP Home supports one processor
alancabler
Post by alancabler »
kasson wrote:We'll have a F@H SMP core ready by that time that can handle the required number of CPU cores.
Sure you will.
Facts are not truth. Facts are merely facets of the shining diamond of truth.
Nonymoussurfer
Hardware configuration: Q6600 G0 @3.0GHz - 9657AB, OCZ600SXS 2x8800GS 1x running GPU2, VM-Notfred SMP (2), Vista 32bit
Q6600 G0 @3.0GHz -IP35V, EA430, Notfred SMP diskless
Q6600 G0 @3.0GHz -IP35E, Antec 650W. Notfred SMP diskless
X3210 B3 @3.0GHz - P5B-965 Deluxe EA430, Notfred SMP diskless
X3210 G0 @2.8GHz - GA-G31M-S2L EA380, Notfred SMP diskless
E6300 B2 @3.0GHz - GA-965P-DS3,, CP-500T, HD3870 GPU2, XP MCE
E2160@1.8GHz generic emachine, EA380, 9600GSO GPU2,1 CPU client, vista 32bit
P4@3.2GHz generic emachine, NEO380, 8800GT GPU2, XP MCE
Athlon64@2.2GHz - NFK8AB-RS, EA430, 8800GT GPU2, XP Pro 32bit
Post by Nonymoussurfer »
et tu cabler?
from this page.
This is one physical processor, one socket if you like it better. Logical processors (Hyperthreading) and cores in the same processors are all on the same socket, so it is supported.
P.S : XP Pro supports two physical processors (I run a bi-opteron 2212 under XP Pro, which is a dual socket F system : two physical processors, four cores (2*2))
zanth
Post by zanth »
I was told that the Intel chips, in the case of the Quad, 2 dual cores on one socket, but still counted as two processors, each with two cores. Thus a box with two of AMD's Quad's would work under XP Pro, but two of Intel's would not. Is this actually not the case? XP just displays each core as a processor under Device Manager. If I am mistaken, I take back my previous comment. :)
Edit: Sentence didn't make much sense, still is a bit off, but meh, its comprehensible.
zanth wrote:I was told that the Intel chips, in the case of the Quad, 2 dual cores on one socket, but still counted as two processors, each with two cores. Thus a box with two of AMD's Quad's would work under XP Pro, but two of Intel's would not. Is this actually not the case? XP just displays each core as a processor under Device Manager. If I am mistaken, I take back my previous comment. :)
You were told incorrectly.
I published the list of supported processor sockets per MS operating system in the Known Bugs List sticky post at the top of the Windows SMP Beta section of the forum. MS only looks at sockets, not cores, and doesn't care about Intel vs. AMD. My list probably came from the same link Flathead74 posted above.
uncle fuzzy
Post by uncle fuzzy »
I'm running a q6600 with XP Home- 4 cores, one socket, works fine.
neilrieck
Hardware configuration: Various platforms all sporting graphics cards: six x86-64 systems running Linux Mint
Post by neilrieck »
7im wrote:http://www.dailytech.com/Sun+Leaks+6cor ... e10834.htm
Here are two more articles:
http://arstechnica.com/news.ars/post/20 ... essor.html
http://gizmodo.com/360476/intels-6+core ... ors-leaked
Neil Rieck
Kitchener/Waterloo, Ontario, Canada.
Neil Rieck
zanth
Post by zanth »
Ah, thats very good to know, thank you for setting me straight. :) The more you know and all that.
