171.67.108.22 (bigadv) Missing credits?
statesidecoma
171.67.108.22 can't upload -bigadv WU
Somebody give this work server a swift kick, now the -bigadv units don't want to upload to work server. Also 171.67.108.25 didn't let it upload either.
Re: 171.67.108.22 can't upload -bigadv WU
Indeed, it's in Reject mode :
I guess it might come back in a couple of hours since it's still very early in the morning at Stanford.
171.67.108.22 classic vsp16v kasson full RejectRe: 171.67.108.22 can't upload -bigadv WU
Down again:
171.67.108.22 - vsp16v - No Response
Grandpa_01
- Hardware configuration: 3 - Supermicro H8QGi-F AMD MC 6174=144 cores 2.5Ghz, 96GB G.Skill DDR3 1333Mhz Ubuntu 10.10
So does Down in the connections column mean they are doing maint. or is it just messed up.
2 - I7 980X 4.4Ghz 2-GTX680
1 - 2700k 4.4Ghz GTX680
Total = 464 cores folding
Restarting now...
jimerickson
- Hardware configuration: Parts:
Intel Core i7 8700 cpu (X2)
Veddha 8 gpu miner case (X2)
Thermaltake hsf (X2)
Ubit riser card (X16) - Location: ames, iowa
thank you kasson
171.67.108.22 Missing credit?
The following section of the log file shows successful completion and upload; however I can't tell if the points were credited. The stats page on the extremeoverclocking site does not show points for this WU, but does show credit for follow-on WU's
Any help would be appreciated.
[10:53:07] Folding@home Core Shutdown: FINISHED_UNIT
[10:54:11] CoreStatus = 64 (100)
[10:54:11] Unit 3 finished with 58 percent of time to deadline remaining.
[10:54:11] Updated performance fraction: 0.582305
[10:54:11] Sending work to server
[10:54:11] [b]Project: 2683 (Run 0, Clone 18, Gen 44[/b])
[10:54:11] + Attempting to send results [[b]March 12 10:54:11 UTC[/b]]
[10:54:11] - Reading file work/wuresults_03.dat from core
[10:54:11] (Read 99088514 bytes from disk)
[10:54:11] Connecting to http://171.67.108.22:8080/
[11:18:33] Posted data.
[11:18:33] Initial: 0000; - Uploaded at ~66 kB/s
[11:18:34] - Averaged speed for that direction ~57 kB/s
[11:18:34] + Results successfully sent
[11:18:34] Thank you for your contribution to Folding@Home.
[11:18:34] + Number of Units Completed: 47
Re: 171.67.108.22 Missing credit?
Hi AutoGrog (team 39286),
Your WU (P2683 R0 C18 G44) was added to the stats database on 2010-03-12 04:04:58 for 0 points of credit.
The status code in the DB indicate that the server thinks this WU is a duplicate, or invalid. Do you sneakernet your WU between machines ?
This system has never been involved in sneaker netting, and as far as I know this the only -bigadv WU that has gone astray.
ChelseaOilman
Any chance you could run qd and post the output here?
The database shows the WU was downloaded to your machine 2010-03-12 03:19:39 then uploaded less than an hour later at 2010-03-12 04:04:40. There's something wrong there. Maybe if you posted your log starting from the last few frames of the previous WU through to the upload of the WU in question we could see what happened.
[20:42:13] Completed 245000 out of 250000 steps (98%)
[21:12:39] - Autosending finished units... [March 9 21:12:39 UTC]
[21:12:39] Trying to send all finished work units
[21:12:39] + No unsent completed units remaining.
[21:12:39] - Autosend completed
[21:18:05] Completed 247500 out of 250000 steps (99%)
[21:54:20] Completed 250000 out of 250000 steps (100%)
[21:54:29] DynamicWrapper: Finished Work Unit: sleep=10000
[21:54:40]
[21:54:40] Finished Work Unit:
[21:54:40] - Reading up to 52713120 from "work/wudata_02.trr": Read 52713120
[21:54:40] trr file hash check passed.
[21:54:40] - Reading up to 42719204 from "work/wudata_02.xtc": Read 42719204
[21:54:40] xtc file hash check passed.
[21:54:40] edr file hash check passed.
[21:54:40] logfile size: 200535
[21:54:40] Leaving Run
[21:54:41] - Writing 95798167 bytes of core data to disk...
[21:54:45] ... Done.
[22:07:22] - Shutting down core
[22:07:22]
[22:07:22] Folding@home Core Shutdown: FINISHED_UNIT
[22:08:28] CoreStatus = 64 (100)
[22:08:28] Unit 2 finished with 58 percent of time to deadline remaining.
[22:08:28] Updated performance fraction: 0.582372
[22:08:28] Sending work to server
[22:08:28] Project: 2681 (Run 4, Clone 6, Gen 76)
[22:08:28] + Attempting to send results [March 9 22:08:28 UTC]
[22:08:28] - Reading file work/wuresults_02.dat from core
[22:08:28] (Read 95798167 bytes from disk)
[22:08:28] Connecting to http://171.67.108.22:8080/
[22:32:04] Posted data.
[22:32:04] Initial: 0000; - Uploaded at ~53 kB/s
[22:37:25] - Averaged speed for that direction ~53 kB/s
[22:37:25] + Results successfully sent
[22:37:25] Thank you for your contribution to Folding@Home.
[22:37:25] + Number of Units Completed: 46
[22:40:47] - Warning: Could not delete all work unit files (2): Core file absent
[22:40:47] Trying to send all finished work units
[22:40:47] + No unsent completed units remaining.
[22:40:47] - Preparing to get new work unit...
[22:40:47] Cleaning up work directory
[22:40:47] + Attempting to get work packet
[22:40:47] Passkey found
[22:40:47] - Will indicate memory of 5918 MB
[22:40:47] - Connecting to assignment server
[22:40:47] Connecting to http://assign.stanford.edu:8080/
[22:40:48] Posted data.
[22:40:48] Initial: 43AB; - Successful: assigned to (171.67.108.22).
[22:40:48] + News From Folding@Home: Welcome to Folding@Home
[22:40:48] Loaded queue successfully.
[22:40:48] Connecting to http://171.67.108.22:8080/
[22:41:26] Posted data.
[22:41:26] Initial: 0000; - Receiving payload (expected size: 30239005)
[22:44:09] - Downloaded at ~181 kB/s
[22:44:09] - Averaged speed for that direction ~181 kB/s
[22:44:09] + Received work.
[22:44:09] Trying to send all finished work units
[22:44:09] + No unsent completed units remaining.
[22:44:09] + Closed connections
[22:44:09]
[22:44:09] + Processing work unit
[22:44:09] Core required: FahCore_a2.exe
[22:44:09] Core found.
[22:44:09] Working on queue slot 03 [March 9 22:44:09 UTC]
[22:44:09] + Working ...
[22:44:09] - Calling './mpiexec -np 8 -host 127.0.0.1 ./FahCore_a2.exe -dir work/ -nice 19 -suffix 03 -checkpoint 30 -verbose -lifeline 24291 -version 629'
[22:44:09]
[22:44:09] *------------------------------*
[22:44:09] Folding@Home Gromacs SMP Core
[22:44:09] Version 2.10 (Sun Aug 30 03:43:28 CEST 2009)
[22:44:09]
[22:44:09] Preparing to commence simulation
[22:44:09] - Ensuring status. Please wait.
[22:44:13] Called DecompressByteArray: compressed_data_size=30238493 data_size=159270593, decompressed_data_size=159270593 diff=0
[22:44:14] - Digital signature verified
[22:44:14]
[22:44:14] Project: 2683 (Run 0, Clone 18, Gen 44)
[22:44:14]
[22:44:14] Assembly optimizations on if available.
[22:44:14] Entering M.D.
[22:44:25] (Run 0, Clone 18, Gen 44)
[22:44:25]
[22:44:25] Entering M.D.
[22:44:47] Completed 0 out of 250000 steps (0%)
[23:20:33] Completed 2500 out of 250000 steps (1%)
[23:56:03] Completed 5000 out of 250000 steps (2%)
[00:31:34] Completed 7500 out of 250000 steps (3%)
[01:07:02] Completed 10000 out of 250000 steps (4%)
[01:42:34] Completed 12500 out of 250000 steps (5%)
[02:18:04] Completed 15000 out of 250000 steps (6%)
[02:53:36] Completed 17500 out of 250000 steps (7%)
[03:12:39] - Autosending finished units... [March 10 03:12:39 UTC]
[03:12:39] Trying to send all finished work units
[03:12:39] + No unsent completed units remaining.
[03:12:39] - Autosend completed
[03:29:49] Completed 20000 out of 250000 steps (8%)
[04:05:20] Completed 22500 out of 250000 steps (9%)
[04:40:49] Completed 25000 out of 250000 steps (10%)
[05:16:21] Completed 27500 out of 250000 steps (11%)
[05:51:51] Completed 30000 out of 250000 steps (12%)
[06:27:21] Completed 32500 out of 250000 steps (13%)
[07:02:52] Completed 35000 out of 250000 steps (14%)
[07:38:24] Completed 37500 out of 250000 steps (15%)
[08:13:56] Completed 40000 out of 250000 steps (16%)
[08:49:28] Completed 42500 out of 250000 steps (17%)
[09:12:39] - Autosending finished units... [March 10 09:12:39 UTC]
[09:12:39] Trying to send all finished work units
[09:12:39] + No unsent completed units remaining.
[09:12:39] - Autosend completed
[07:46:38] - Autosending finished units... [March 12 07:46:38 UTC]
[07:46:38] Trying to send all finished work units
[07:46:38] + No unsent completed units remaining.
[07:46:38] - Autosend completed
[08:17:42] Completed 240000 out of 250000 steps (96%)
[08:53:15] Completed 242500 out of 250000 steps (97%)
[09:28:51] Completed 245000 out of 250000 steps (98%)
[10:04:26] Completed 247500 out of 250000 steps (99%)
[10:40:00] Completed 250000 out of 250000 steps (100%)
[10:40:09] DynamicWrapper: Finished Work Unit: sleep=10000
[10:40:19]
[10:40:19] Finished Work Unit:
[10:40:19] - Reading up to 52544928 from "work/wudata_03.trr": Read 52544928
[10:40:20] trr file hash check passed.
[10:40:20] - Reading up to 46178896 from "work/wudata_03.xtc": Read 46178896
[10:40:20] xtc file hash check passed.
[10:40:20] edr file hash check passed.
[10:40:20] logfile size: 199774
[10:40:20] Leaving Run
[10:40:21] - Writing 99088514 bytes of core data to disk...
[10:40:25] ... Done.
[10:53:07] - Shutting down core
[10:53:07]
[10:54:11] Project: 2683 (Run 0, Clone 18, Gen 44)
[10:54:11] + Attempting to send results [March 12 10:54:11 UTC]
[11:22:03] - Warning: Could not delete all work unit files (3): Core file absent
[11:22:03] Trying to send all finished work units
[11:22:03] + No unsent completed units remaining.
[11:22:03] - Preparing to get new work unit...
[11:22:03] Cleaning up work directory
[11:22:03] + Attempting to get work packet
[11:22:03] Passkey found
[11:22:03] - Will indicate memory of 5918 MB
[11:22:03] - Connecting to assignment server
[11:22:03] Connecting to http://assign.stanford.edu:8080/
[11:22:04] Posted data.
Please post the first several bytes and the last few bytes of the UserID assigned to that machine as well as the MachineID that you've set.autogrog wrote:Code: Select all
[22:41:26] Initial: 0000; - Receiving payload (expected size: 30239005) [22:44:09] - Downloaded at ~181 kB/s [22:44:09] + Received work. [22:44:14] Project: 2683 (Run 0, Clone 18, Gen 44) [03:12:39] - Autosending finished units... [March 10 03:12:39 UTC] [07:46:38] - Autosending finished units... [March 12 07:46:38 UTC] [10:54:11] Unit 3 finished with 58 percent of time to deadline remaining. [10:54:11] Updated performance fraction: 0.582305 [10:54:11] Sending work to server [10:54:11] Project: 2683 (Run 0, Clone 18, Gen 44) [10:54:11] + Attempting to send results [March 12 10:54:11 UTC] [10:54:11] - Reading file work/wuresults_03.dat from core [10:54:11] (Read 99088514 bytes from disk) [10:54:11] Connecting to http://171.67.108.22:8080/ [11:18:33] Posted data. [11:18:33] Initial: 0000; - Uploaded at ~66 kB/s [11:18:34] - Averaged speed for that direction ~57 kB/s [11:18:34] + Results successfully sent [11:18:34] Thank you for your contribution to Folding@Home. [11:18:34] + Number of Units Completed: 47
User ID: 59A******FC7D
Machine ID: 1
Machine ID: 1
orion
- Hardware configuration: 4p/4 MC ES @ 3.0GHz/32GB
4p/4x6128 @ 2.47GHz/32GB
2p/2 IL ES @ 2.7GHz/16GB
1p/8150/8GB
1p/1090T/4GB - Location: neither here nor there
Bigadv No Credit - Project: 2681 (Run 3, Clone 3, Gen 89)
The points for this WU didn't seem to update today. It finished the upload about 8-10 hr ago and picked up this one P2683 (0,18,48)
Does it show up anywhere?
My 4P did show up P2683 (1,11,847)
Team#: 36837
Team#: 36837
[18:02:12]
[18:02:12] *------------------------------*
[18:02:12] Folding@Home Gromacs SMP Core
[18:02:12] Version 2.10 (Sun Aug 30 03:43:28 CEST 2009)
[18:02:12]
[18:02:12] Preparing to commence simulation
[18:02:12] - Ensuring status. Please wait.
[18:02:18] Called DecompressByteArray: compressed_data_size=30329103 data_size=1
59726549, decompressed_data_size=159726549 diff=0
[18:02:19] - Digital signature verified
[18:02:19]
[18:02:19] Project: 2681 (Run 3, Clone 3, Gen 89)
[18:02:19]
[18:02:19] Assembly optimizations on if available.
[18:02:19] Entering M.D.
[18:02:28] (Run 3, Clone 3, Gen 89)
[18:02:28]
[18:02:35] Entering M.D.
NNODES=8, MYRANK=4, HOSTNAME=linux-2yeg
NNODES=8, MYRANK=7, HOSTNAME=linux-2yeg
NNODES=8, MYRANK=1, HOSTNAME=linux-2yeg
NNODES=8, MYRANK=2, HOSTNAME=linux-2yeg
NNODES=8, MYRANK=5, HOSTNAME=linux-2yeg
NNODES=8, MYRANK=6, HOSTNAME=linux-2yeg
NNODES=8, MYRANK=3, HOSTNAME=linux-2yeg
NNODES=8, MYRANK=0, HOSTNAME=linux-2yeg
NODEID=0 argc=20
NODEID=1 argc=20
NODEID=2 argc=20
NODEID=4 argc=20
NODEID=5 argc=20
NODEID=6 argc=20
NODEID=3 argc=20
Reading file work/wudata_03.tpr, VERSION 3.3.99_development_20070618 (single pre
cision)
NODEID=7 argc=20
Note: tpx file_version 48, software version 68
NOTE: The tpr file used for this simulation is in an old format, for less memory
usage and possibly more performance create a new tpr file with an up to date ve
rsion of grompp
Making 1D domain decomposition 8 x 1 x 1
starting mdrun 'SINGLE VESICLE in water'
22500000 steps, 90000.0 ps (continuing from step 22250000, 89000.0 ps).
[18:44:00] pleted 2500 out of 250000 steps (1%)
[19:25:03] Completed 5000 out of 250000 steps (2%)
[20:06:06] Completed 7500 out of 250000 steps (3%)
[20:47:06] Completed 10000 out of 250000 steps (4%)
[20:49:07] - Autosending finished units... [March 17 20:49:07 UTC]
[20:49:07] Trying to send all finished work units
[20:49:07] + No unsent completed units remaining.
[20:49:07] - Autosend completed
[21:28:08] Completed 12500 out of 250000 steps (5%)
[22:09:10] Completed 15000 out of 250000 steps (6%)
[22:50:12] Completed 17500 out of 250000 steps (7%)
[23:31:11] Completed 20000 out of 250000 steps (8%)
[00:12:14] Completed 22500 out of 250000 steps (9%)
[00:53:15] Completed 25000 out of 250000 steps (10%)
[01:34:19] Completed 27500 out of 250000 steps (11%)
[02:15:19] Completed 30000 out of 250000 steps (12%)
[02:49:07] - Autosending finished units... [March 18 02:49:07 UTC]
[02:49:07] Trying to send all finished work units
[02:49:07] + No unsent completed units remaining.
[02:49:07] - Autosend completed
[02:56:20] Completed 32500 out of 250000 steps (13%)
[03:37:22] Completed 35000 out of 250000 steps (14%)
[04:18:24] Completed 37500 out of 250000 steps (15%)
[04:59:24] Completed 40000 out of 250000 steps (16%)
[05:40:32] Completed 42500 out of 250000 steps (17%)
[06:22:09] Completed 45000 out of 250000 steps (18%)
[07:03:46] Completed 47500 out of 250000 steps (19%)
[07:45:22] Completed 50000 out of 250000 steps (20%)
[08:26:59] Completed 52500 out of 250000 steps (21%)
[08:49:07] - Autosending finished units... [March 18 08:49:07 UTC]
[08:49:07] Trying to send all finished work units
[08:49:07] + No unsent completed units remaining.
[08:49:07] - Autosend completed
[09:08:36] Completed 55000 out of 250000 steps (22%)
[09:50:39] Completed 57500 out of 250000 steps (23%)
[10:32:47] Completed 60000 out of 250000 steps (24%)
[11:14:57] Completed 62500 out of 250000 steps (25%)
[11:57:08] Completed 65000 out of 250000 steps (26%)
[12:39:18] Completed 67500 out of 250000 steps (27%)
[13:21:27] Completed 70000 out of 250000 steps (28%)
[14:03:36] Completed 72500 out of 250000 steps (29%)
[14:45:39] Completed 75000 out of 250000 steps (30%)
[14:49:07] - Autosending finished units... [March 18 14:49:07 UTC]
[14:49:07] Trying to send all finished work units
[14:49:07] + No unsent completed units remaining.
[14:49:07] - Autosend completed
[15:27:35] Completed 77500 out of 250000 steps (31%)
[16:09:30] Completed 80000 out of 250000 steps (32%)
[16:51:25] Completed 82500 out of 250000 steps (33%)
[17:33:20] Completed 85000 out of 250000 steps (34%)
[18:15:14] Completed 87500 out of 250000 steps (35%)
[18:57:10] Completed 90000 out of 250000 steps (36%)
[19:39:05] Completed 92500 out of 250000 steps (37%)
[20:20:59] Completed 95000 out of 250000 steps (38%)
[20:49:07] - Autosending finished units... [March 18 20:49:07 UTC]
[21:02:52] Completed 97500 out of 250000 steps (39%)
[21:44:46] Completed 100000 out of 250000 steps (40%)
[22:26:41] Completed 102500 out of 250000 steps (41%)
[23:08:35] Completed 105000 out of 250000 steps (42%)
[23:50:30] Completed 107500 out of 250000 steps (43%)
[00:32:24] Completed 110000 out of 250000 steps (44%)
[01:14:20] Completed 112500 out of 250000 steps (45%)
[01:56:14] Completed 115000 out of 250000 steps (46%)
[02:38:08] Completed 117500 out of 250000 steps (47%)
[02:49:07] - Autosending finished units... [March 19 02:49:07 UTC]
[03:20:03] Completed 120000 out of 250000 steps (48%)
[04:01:56] Completed 122500 out of 250000 steps (49%)
[04:43:50] Completed 125000 out of 250000 steps (50%)
[05:25:45] Completed 127500 out of 250000 steps (51%)
[06:07:42] Completed 130000 out of 250000 steps (52%)
[06:49:37] Completed 132500 out of 250000 steps (53%)
[07:31:32] Completed 135000 out of 250000 steps (54%)
[08:13:27] Completed 137500 out of 250000 steps (55%)
[08:49:07] - Autosending finished units... [March 19 08:49:07 UTC]
[08:55:23] Completed 140000 out of 250000 steps (56%)
[09:37:19] Completed 142500 out of 250000 steps (57%)
[10:19:15] Completed 145000 out of 250000 steps (58%)
[11:01:09] Completed 147500 out of 250000 steps (59%)
[11:43:10] Completed 150000 out of 250000 steps (60%)
[12:25:48] Completed 152500 out of 250000 steps (61%)
[13:08:25] Completed 155000 out of 250000 steps (62%)
[13:51:02] Completed 157500 out of 250000 steps (63%)
[14:33:39] Completed 160000 out of 250000 steps (64%)
[14:49:07] - Autosending finished units... [March 19 14:49:07 UTC]
[15:16:15] Completed 162500 out of 250000 steps (65%)
[15:58:52] Completed 165000 out of 250000 steps (66%)
[16:41:29] Completed 167500 out of 250000 steps (67%)
[17:24:06] Completed 170000 out of 250000 steps (68%)
[18:06:43] Completed 172500 out of 250000 steps (69%)
[18:49:21] Completed 175000 out of 250000 steps (70%)
[19:31:57] Completed 177500 out of 250000 steps (71%)
[20:14:34] Completed 180000 out of 250000 steps (72%)
[20:49:07] - Autosending finished units... [March 19 20:49:07 UTC]
[20:57:10] Completed 182500 out of 250000 steps (73%)
[21:39:46] Completed 185000 out of 250000 steps (74%)
[22:22:22] Completed 187500 out of 250000 steps (75%)
[23:04:58] Completed 190000 out of 250000 steps (76%)
[23:47:27] Completed 192500 out of 250000 steps (77%)
[00:29:24] Completed 195000 out of 250000 steps (78%)
[01:11:21] Completed 197500 out of 250000 steps (79%)
[01:53:17] Completed 200000 out of 250000 steps (80%)
[02:35:12] Completed 202500 out of 250000 steps (81%)
[02:49:07] - Autosending finished units... [March 20 02:49:07 UTC]
[03:17:05] Completed 205000 out of 250000 steps (82%)
[03:59:00] Completed 207500 out of 250000 steps (83%)
[04:40:55] Completed 210000 out of 250000 steps (84%)
[05:22:50] Completed 212500 out of 250000 steps (85%)
[06:04:44] Completed 215000 out of 250000 steps (86%)
[06:46:36] Completed 217500 out of 250000 steps (87%)
[07:28:31] Completed 220000 out of 250000 steps (88%)
[08:10:25] Completed 222500 out of 250000 steps (89%)
[08:49:07] - Autosending finished units... [March 20 08:49:07 UTC]
[08:52:20] Completed 225000 out of 250000 steps (90%)
[09:34:16] Completed 227500 out of 250000 steps (91%)
[10:16:10] Completed 230000 out of 250000 steps (92%)
[10:58:06] Completed 232500 out of 250000 steps (93%)
[11:40:01] Completed 235000 out of 250000 steps (94%)
[12:22:34] Completed 237500 out of 250000 steps (95%)
[13:05:09] Completed 240000 out of 250000 steps (96%)
[13:47:41] Completed 242500 out of 250000 steps (97%)
[14:30:16] Completed 245000 out of 250000 steps (98%)
[14:49:07] - Autosending finished units... [March 20 14:49:07 UTC]
[15:12:47] Completed 247500 out of 250000 steps (99%)
[15:55:16] Completed 250000 out of 250000 steps (100%)
Writing final coordinates.
Average load imbalance: 0.1 %
Part of the total run time spent waiting due to load imbalance: 0.0 %
Steps where the load balancing was limited by -rdd, -rcon and/or -dds: X 0 %
Parallel run - timing based on wallclock.
NODE (s) Real (s) (%)
Time: 251549.597 251549.597 100.0
2d21h52:29
(Mnbf/s) (GFlops) (ns/day) (hour/ns)
Performance: 362.660 19.740 0.343 69.875
gcq#0: Thanx for Using GROMACS - Have a Nice Day
[15:55:26] DynamicWrapper: Finished Work Unit: sleep=10000
[15:55:36]
[15:55:36] Finished Work Unit:
[15:55:36] - Reading up to 52713120 from "work/wudata_03.trr": Read 52713120
[15:55:36] trr file hash check passed.
[15:55:36] - Reading up to 47064884 from "work/wudata_03.xtc": Read 47064884
[15:55:36] xtc file hash check passed.
[15:55:36] edr file hash check passed.
[15:55:36] logfile size: 209980
[15:55:36] Leaving Run
[15:55:41] - Writing 100152900 bytes of core data to disk...
[15:55:48] ... Done.
[15:56:33] - Shutting down core
[15:56:33]
[15:56:33] Folding@home Core Shutdown: FINISHED_UNIT
Attempting to use an MPI routine after finalizing MPICH
[15:59:00] CoreStatus = 64 (100)
[15:59:00] Unit 3 finished with 51 percent of time to deadline remaining.
[15:59:00] Updated performance fraction: 0.473372
[15:59:00] Sending work to server
[15:59:00] Project: 2681 (Run 3, Clone 3, Gen 89)
[15:59:00] + Attempting to send results [March 20 15:59:00 UTC]
[15:59:00] - Reading file work/wuresults_03.dat from core
[15:59:00] (Read 100152900 bytes from disk)
[15:59:00] Connecting to http://171.67.108.22:8080/
[16:23:43] Posted data.
[16:23:43] Initial: 0000; - Uploaded at ~65 kB/s
[16:23:44] - Averaged speed for that direction ~55 kB/s
[16:23:44] + Results successfully sent
[16:23:44] Thank you for your contribution to Folding@Home.
[16:23:44] + Number of Units Completed: 50
iustus quia...
Re: Project: 2681 (Run 3, Clone 3, Gen 89)
Project: 2681, Run 3, Clone 3, Gen 89
No data back from query
