Project 5772 (Run 6, Clone 182, Gen 671)
AK419
Post by AK419 »
Is it just me, or is anyone else having problem with this WU as well? Below is the end of the log just before I was paused for 24 hours.
[11:40:42] + Processing work unit
[11:40:42] Core required: FahCore_11.exe
[11:40:42] Core found.
[11:40:42] Working on queue slot 08 [March 19 11:40:42 UTC]
[11:40:42] + Working ...
[11:40:42] - Calling '.\FahCore_11.exe -dir work/ -suffix 08 -priority 96 -nocpulock -checkpoint 30 -verbose -lifeline 74112 -version 623'
[11:40:42]
[11:40:42] *------------------------------*
[11:40:42] Folding@Home GPU Core
[11:40:42] Version 1.31 (Tue Sep 15 10:57:42 PDT 2009)
[11:40:42]
[11:40:42] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[11:40:42] Build host: amoeba
[11:40:42] Board Type: Nvidia
[11:40:42] Core      :
[11:40:42] Preparing to commence simulation
[11:40:42] - Looking at optimizations...
[11:40:42] DeleteFrameFiles: successfully deleted file=work/wudata_08.ckp
[11:40:42] - Created dyn
[11:40:42] - Files status OK
[11:40:42] - Expanded 45694 -> 251112 (decompressed 549.5 percent)
[11:40:42] Called DecompressByteArray: compressed_data_size=45694 data_size=251112, decompressed_data_size=251112 diff=0
[11:40:42] - Digital signature verified
[11:40:42]
[11:40:42] Project: 5772 (Run 6, Clone 182, Gen 671)
[11:40:42]
[11:40:42] Assembly optimizations on if available.
[11:40:42] Entering M.D.
[11:40:48] Tpr hash work/wudata_08.tpr:  3566180424 1664061760 566461962 121813205 101343748
[11:40:48]
[11:40:48] Calling fah_main args: 14 usage=100
[11:40:48]
[11:40:49] Working on Protein
[11:40:49] mdrun_gpu returned
[11:40:49] Self-test failure
[11:40:49]
[11:40:49] Folding@home Core Shutdown: UNSTABLE_MACHINE
[11:40:53] CoreStatus = 7A (122)
[11:40:53] Sending work to server
[11:40:53] Project: 5772 (Run 6, Clone 182, Gen 671)
[11:40:53] - Read packet limit of 540015616... Set to 524286976.
[11:40:53] - Error: Could not get length of results file work/wuresults_08.dat
[11:40:53] - Error: Could not read unit 08 file. Removing from queue.
[11:40:53] EUE limit exceeded. Pausing 24 hours.
Re: Project 5772 (Run 6, Clone 182, Gen 671)
Several others have had trouble with this WU. I've reported it as "bad"
