Project: 4612 (Run 13, Clone 98, Gen 56)
Got an EUE with Project: 4612 (Run 13, Clone 98, Gen 56)
Can somebody tell me if this is a bad WU or not?
[18:38:32] + Attempting to get work packet
[18:38:32] - Will indicate memory of 3582 MB
[18:38:32] - Connecting to assignment server
[18:38:32] Connecting to http://assign.stanford.edu:8080/
[18:38:40] Posted data.
[18:38:40] Initial: E6A9; - Successful: assigned to (169.230.26.30).
[18:38:40] + News From Folding@Home: Welcome to Folding@Home
[18:38:40] Loaded queue successfully.
[18:38:40] Connecting to http://169.230.26.30:8080/
[18:39:09] Posted data.
[18:39:09] Initial: 0000; - Receiving payload (expected size: 19369)
[18:39:12] - Downloaded at ~6 kB/s
[18:39:12] - Averaged speed for that direction ~10 kB/s
[18:39:12] + Received work.
[18:39:12] Trying to send all finished work units
[18:39:12] + No unsent completed units remaining.
[18:39:12] + Closed connections
[18:39:12]
[18:39:12] + Processing work unit
[18:39:12] Core required: FahCore_82.exe
[18:39:12] Core found.
[18:39:12] Working on queue slot 07 [March 15 18:39:12 UTC]
[18:39:12] + Working ...
[18:39:12] - Calling '.\FahCore_82.exe -dir work/ -suffix 07 -nocpulock -checkpoint 15 -forceasm -verbose -lifeline 4952 -version 623'
[18:39:12]
[18:39:12] *------------------------------*
[18:39:12] Folding@Home PMD Core
[18:39:12] Version 1.03 (September 7, 2005)
[18:39:12]
[18:39:12] Preparing to commence simulation
[18:39:12] - Assembly optimizations manually forced on.
[18:39:12] - Not checking prior termination.
[18:39:12] - Expanded 18857 -> 120013 (decompressed 636.4 percent)
[18:39:12]
[18:39:12] Project: 4612 (Run 13, Clone 98, Gen 56)
[18:39:12]
[18:39:12] Assembly optimizations on if available.
[18:39:12] Entering M.D.
[18:39:18] Going to send back what have done.
[18:39:18] logfile size: 5649
[18:39:18] - Writing 6169 bytes of core data to disk...
[18:39:18]   ... Done.
[18:39:18]
[18:39:18] Folding@home Core Shutdown: EARLY_UNIT_END
[18:39:22] CoreStatus = 72 (114)
[18:39:22] Sending work to server
[18:39:22] Project: 4612 (Run 13, Clone 98, Gen 56)
[18:39:22] - Read packet limit of 540015616... Set to 524286976.
[18:39:22] + Attempting to send results [March 15 18:39:22 UTC]
[18:39:22] - Reading file work/wuresults_07.dat from core
[18:39:22]   (Read 6169 bytes from disk)
[18:39:22] Connecting to http://169.230.26.30:8080/
[18:39:28] Posted data.
[18:39:28] Initial: 0000; - Uploaded at ~1 kB/s
[18:39:28] - Averaged speed for that direction ~2 kB/s
[18:39:28] + Results successfully sent
[18:39:28] Thank you for your contribution to Folding@Home.
[18:39:32] Trying to send all finished work units
[18:39:32] + No unsent completed units remaining.
Thanks
Re: Project: 4612 (Run 13, Clone 98, Gen 56)
Panther-X wrote:Got an EUE with Project: 4612 (Run 13, Clone 98, Gen 56)
Not yet.
I didn't find any other reports of problems with this WU nor do I see a string of 0 point credits from a series of different users.
There are now 6 similar reports in the DB, I marked the WU as bad.
