open DNS filtering and dl WU's
sgb101
Post by sgb101 »
not sure if this is a silly question -
i have just set up the open DNS web filtering on my home network and its set quite tight so it have to grant access to most sites eg, FB, google mail, msn.
will this effect the upload of the WU's? what is the address/ip of where the units come from as i can add it and there will then defo be no issues.
i5 750@3.47-4Gb ddr3-HD5850-Win 7 64bit
i7 920@3.87-6Gb ddr3-9800GT- Win7 64bit
Re: open DNS filtering and dl WU's
All the servers used by FAH are listed here : http://fah-web.stanford.edu/serverstat.html
sgb101
Post by sgb101 »
cheers. wow there's a fair few. since i posted one WU finished and downloaded fresh one so all seems good.
i bookmark the page in case of any future issues.
thanks stephen.
