Project: 10004 (Run 2410, Clone 2, Gen 5)
wan.ardiles
Post by wan.ardiles »
[05:18:01] Digital signatures verified
[05:18:02] Completed 468300 out of 500000 steps (93%)
[05:21:37] Completed 470000 out of 500000 steps (94%)
[05:31:04] Completed 475000 out of 500000 steps (95%)
[05:40:26] Completed 480000 out of 500000 steps (96%)
[05:49:47] Completed 485000 out of 500000 steps (97%)
[05:59:09] Completed 490000 out of 500000 steps (98%)
[06:08:33] Completed 495000 out of 500000 steps (99%)
[06:17:56] Completed 500000 out of 500000 steps (100%)
[06:17:56] Saving result file logfile_02.txt
[06:17:56] Saving result file checkpt
[06:17:56] Saving result file checkpt.crc
[06:17:56] Saving result file log.txt
[06:18:01] Saving result file protomol.conf
[06:18:01] Saving result file ww.dcd
[06:18:01] Saving result file ww_exteq_nowater1.341.pos
[06:18:01] Saving result file ww_exteq_nowater1.341.vel
[06:18:01] Folding@home Core Shutdown: FINISHED_UNIT
[06:18:03] CoreStatus = 64 (100)
[06:18:03] Sending work to server
[06:18:03] Project: 10004 (Run 2410, Clone 2, Gen 5)
[06:18:03] + Attempting to send results [March 10 06:18:03 UTC]
[06:18:24] - Couldn't send HTTP request to server
[06:18:24] + Could not connect to Work Server (results)
[06:18:24] (129.74.85.48:8080)
[06:18:24] + Retrying using alternative port
[06:18:45] - Couldn't send HTTP request to server
[06:18:45] + Could not connect to Work Server (results)
[06:18:45] (129.74.85.48:80)
[06:18:45] - Error: Could not transmit unit 02 (completed March 10) to work server.
[06:18:45] Keeping unit 02 in queue.
[06:18:45] Project: 10004 (Run 2410, Clone 2, Gen 5)
[06:18:45] + Attempting to send results [March 10 06:18:45 UTC]
[06:25:31] - Couldn't send HTTP request to server
[06:25:31] + Could not connect to Work Server (results)
[06:25:31] (129.74.85.48:8080)
[06:25:31] + Retrying using alternative port
[06:25:52] - Couldn't send HTTP request to server
[06:25:52] + Could not connect to Work Server (results)
[06:25:52] (129.74.85.48:80)
[06:25:52] - Error: Could not transmit unit 02 (completed March 10) to work server.
[06:25:52] + Attempting to send results [March 10 06:25:52 UTC]
[06:27:58] - Server reports problem with unit.
[06:27:58] Successfully sent unit 02 to Collection server.
[06:27:58] - Preparing to get new work unit...
[06:27:58] + Attempting to get work packet
[06:27:58] - Connecting to assignment server
[06:27:59] - Successful: assigned to (134.139.127.31).
[06:27:59] + News From Folding@Home: Welcome to Folding@Home
[06:27:59] Loaded queue successfully.
[06:28:58] + Closed connections
I'm a new guy here. 1st WU sent perfectly. May I know what is happening to my 2nd WU? Why no credit?
Richard_Sephton
Re: Project: 10004 (Run 2410, Clone 2, Gen 5)
Post by Richard_Sephton »
how long has it been like that? have you tried restarting the client mine does that some times because of my bad internet connection
wan.ardiles
Didn't restarting the client. Just wait and see the error, then the client pick-up the new WU. And the real question is: Why the credit is still missing? Until today, no credit given.
Did your problematic WU earns you the credit?
Richard_Sephton
yes they get the credit aslong as they are completed and sent before the deadline how long did it take between downloading and sucessfully sendingalso if it i your first unit it does take time to appear
Your log shows that you got a new WU to fold, but no successful upload of the results ... you won't get credit unless your WU is successfully returned to the server ...
wan.ardiles
As stated before, this is the 2nd WUs. The deadline is 30 days, but managed to completed & sent it in 3 days. My 4th WUs have been sent successfully, and I saw my points increased. But not from the 2nd WUs.
Is it normal to sometime losing a few WU's credit?
toTOW: Is there any different between work server & collection server?
What do you mean by "successfully returned to the server"?
From my previous reading in this forum, there's a case that someone else could be completed the same WU. Is it possible?
Welcome to foldingforum.org, wan.ardiles.
wan.ardiles wrote:[06:25:52] + Attempting to send results [March 10 06:25:52 UTC]
[06:27:58] Successfully sent unit 02 to Collection server.[/code]
Unfortunately I do not have a good explanation for the message "Server reports problem with unit." There are many possibilities such as an overdue WU, a corrupt result, a duplicate WU for which you have already received credit, etc.
I can see no record of this WU in your account so I can't help you with your question.
The work server and the collection server are physically two different computers and the software running on them is somewhat different, but the isn't supposed to matter which one you return a result to. Sometimes it helps to track the data, though, if you know which one was involved with your upload.
Under normal circumstances, only one person will be working on a specific WU. (There's way too much science that needs to be done to waste time duplicating work.) Nevertheless, there are some cases where a WU will be assigned to more than one person, but when that happens, they'll both get credit for it if they both complete it before it expires.
wan.ardiles
May I know what info you'll need? Snapshot, log?
**Thanks for the welcoming greeting :)
The Pande Group gives forum Moderators a limited access to some database entries, and it's not listed there. Only a Pande Group member can figure out what problem was detected with that WU.
I can see from your log that the "Server reports problem with unit." message was [March 10 06:25:52 UTC]. What was the date-time when that WU was originally downloaded? What was the MachineID and UserID assigned to that client?
John_Weatherman
Post by John_Weatherman »
Sounds like the same thing that happened to me at http://foldingforum.org/viewtopic.php?f=19&t=13772
wan.ardiles
--- Opening Log file [March 9 02:51:58 UTC]
# Windows CPU Systray Edition #################################################
                          http://folding.stanford.edu
Launch directory: C:\Documents and Settings\root\Application Data\Folding@home-x86
[02:51:58] - Ask before connecting: Yes
[02:51:58] - User name: wan.ardiles@xxxx.xxx (Team 2999)
[02:51:58] - User ID: 51CA9AE53E28415A
[02:51:58] - Machine ID: 1
[02:51:58]
[02:51:58] Loaded queue successfully.
[02:51:59] Initialization complete
[02:51:59]
[02:51:59] + Processing work unit
[02:51:59] Core required: FahCore_b4.exe
[02:51:59] Core found.
[02:51:59] Working on queue slot 02 [March 9 02:51:59 UTC]
[02:51:59] + Working ...
[02:52:03] *********************** Log Started 09/Mar/2010 02:52:03 ***********************
[02:52:03] ************************** ProtoMol Folding@Home Core **************************
[02:52:03]   Version: 22
[02:52:03]      Type: 180
[02:52:03]      Core: ProtoMol
[02:52:03]   Website: http://folding.stanford.edu/
[02:52:03] Copyright: (c) 2009 Stanford University
[02:52:03]    Author: Joseph Coffland <joseph@cauldrondevelopment.com>
[02:52:03]      Args: -dir work/ -suffix 02 -cpu 94 -checkpoint 3 -lifeline 2276 -version
[02:52:03]            623
[02:52:03] ************************************ Build *************************************
[02:52:03]      Date: Jan 21 2010
[02:52:03]      Time: 19:16:23
[02:52:03]  Revision: 1756
[02:52:03]  Compiler: Intel(R) C++ MSVC 1500 mode 1110
[02:52:03]   Options: /TP /nologo /EHsc /wd4297 /wd4103 /wd1786 /arch:IA32 /Ox
[02:52:03]            /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qrestrict /MT
[02:52:03]  Platform: Windows XP
[02:52:03]      Bits: 32
[02:52:03]      Mode: Release
[02:52:03] ************************************ System ************************************
[02:52:03]        OS: Microsoft Windows XP Professional
[02:52:03]       CPU: Intel(R) Pentium(R) 4 CPU 2.80GHz
[02:52:03]    CPU ID: GenuineIntel Family 15 Model 2 Stepping 9
[02:52:03]      CPUs: 1 Logical, 1 Physical
[02:52:03]    Memory: 1023 MB
[02:52:03]   Threads: Windows
[02:52:03] ********************************************************************************
[02:52:03] Project: 10004 (Run 2410, Clone 2, Gen 5)
[02:52:03] Digital signatures verified
[02:52:04] Completed 127700 out of 500000 steps (25%)
[02:52:46] CoreStatus = 62 (98)
[02:52:46] + Restarting core (settings changed)
[02:52:49]
[02:52:49] + Processing work unit
[02:52:49] Core required: FahCore_b4.exe
[02:52:49] Core found.
[02:52:49] Working on queue slot 02 [March 9 02:52:49 UTC]
[02:52:49] + Working ...
[02:52:52] *********************** Log Started 09/Mar/2010 02:52:52 ***********************
[02:52:52] ************************** ProtoMol Folding@Home Core **************************
[02:52:52]   Version: 22
[02:52:52]      Type: 180
[02:52:52]      Core: ProtoMol
[02:52:52]   Website: http://folding.stanford.edu/
[02:52:52] Copyright: (c) 2009 Stanford University
[02:52:52]    Author: Joseph Coffland <joseph@cauldrondevelopment.com>
[02:52:52]      Args: -dir work/ -suffix 02 -cpu 91 -checkpoint 14 -notermcheck -lifeline
[02:52:52]            2276 -version 623
[02:52:52] ************************************ Build *************************************
[02:52:52]      Date: Jan 21 2010
[02:52:52]      Time: 19:16:23
[02:52:52]  Revision: 1756
[02:52:52]  Compiler: Intel(R) C++ MSVC 1500 mode 1110
[02:52:52]   Options: /TP /nologo /EHsc /wd4297 /wd4103 /wd1786 /arch:IA32 /Ox
[02:52:52]            /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qrestrict /MT
[02:52:52]  Platform: Windows XP
[02:52:52]      Bits: 32
[02:52:52]      Mode: Release
[02:52:52] ************************************ System ************************************
[02:52:52]        OS: Microsoft Windows XP Professional
[02:52:52]       CPU: Intel(R) Pentium(R) 4 CPU 2.80GHz
[02:52:52]    CPU ID: GenuineIntel Family 15 Model 2 Stepping 9
[02:52:52]      CPUs: 1 Logical, 1 Physical
[02:52:52]    Memory: 1023 MB
[02:52:52]   Threads: Windows
[02:52:52] ********************************************************************************
[02:52:52] Project: 10004 (Run 2410, Clone 2, Gen 5)
[02:52:52] Digital signatures verified
[02:52:53] Completed 127700 out of 500000 steps (25%)
[02:57:19] Completed 130000 out of 500000 steps (26%)
[03:06:52] Completed 135000 out of 500000 steps (27%)
[03:16:32] Completed 140000 out of 500000 steps (28%)
[03:26:49] Completed 145000 out of 500000 steps (29%)
[03:35:57] CoreStatus = 62 (98)
[03:35:57] + Restarting core (settings changed)
[03:35:57]
[03:35:57] + Processing work unit
[03:35:57] Core required: FahCore_b4.exe
[03:35:57] Core found.
[03:35:57] Working on queue slot 02 [March 9 03:35:57 UTC]
[03:35:57] + Working ...
[03:35:59] *********************** Log Started 09/Mar/2010 03:35:59 ***********************
[03:35:59] ************************** ProtoMol Folding@Home Core **************************
[03:35:59]   Version: 22
[03:35:59]      Type: 180
[03:35:59]      Core: ProtoMol
[03:35:59]   Website: http://folding.stanford.edu/
[03:35:59] Copyright: (c) 2009 Stanford University
[03:35:59]    Author: Joseph Coffland <joseph@cauldrondevelopment.com>
[03:35:59]      Args: -dir work/ -suffix 02 -cpu 80 -checkpoint 21 -notermcheck -lifeline
[03:35:59]            2276 -version 623
[03:35:59] ************************************ Build *************************************
[03:35:59]      Date: Jan 21 2010
[03:35:59]      Time: 19:16:23
[03:35:59]  Revision: 1756
[03:35:59]  Compiler: Intel(R) C++ MSVC 1500 mode 1110
[03:35:59]   Options: /TP /nologo /EHsc /wd4297 /wd4103 /wd1786 /arch:IA32 /Ox
[03:35:59]            /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qrestrict /MT
[03:35:59]  Platform: Windows XP
[03:35:59]      Bits: 32
[03:35:59]      Mode: Release
[03:35:59] ************************************ System ************************************
[03:35:59]        OS: Microsoft Windows XP Professional
[03:35:59]       CPU: Intel(R) Pentium(R) 4 CPU 2.80GHz
[03:35:59]    CPU ID: GenuineIntel Family 15 Model 2 Stepping 9
[03:35:59]      CPUs: 1 Logical, 1 Physical
[03:35:59]    Memory: 1023 MB
[03:35:59]   Threads: Windows
[03:35:59] ********************************************************************************
[03:35:59] Project: 10004 (Run 2410, Clone 2, Gen 5)
[03:35:59] Digital signatures verified
[03:36:00] Completed 149000 out of 500000 steps (29%)
[03:38:26] Completed 150000 out of 500000 steps (30%)
[03:50:12] Completed 155000 out of 500000 steps (31%)
[04:01:08] Completed 160000 out of 500000 steps (32%)
[04:12:20] Completed 165000 out of 500000 steps (33%)
[04:27:27] Completed 170000 out of 500000 steps (34%)
[04:38:17] Completed 175000 out of 500000 steps (35%)
[04:51:14] Completed 180000 out of 500000 steps (36%)
[05:03:07] Completed 185000 out of 500000 steps (37%)
[05:08:59] CoreStatus = 62 (98)
[05:08:59] + Restarting core (settings changed)
[05:08:59]
[05:08:59] + Processing work unit
[05:08:59] Core required: FahCore_b4.exe
[05:08:59] Core found.
[05:08:59] Working on queue slot 02 [March 9 05:08:59 UTC]
[05:08:59] + Working ...
[05:09:02] *********************** Log Started 09/Mar/2010 05:09:02 ***********************
[05:09:02] ************************** ProtoMol Folding@Home Core **************************
[05:09:02]   Version: 22
[05:09:02]      Type: 180
[05:09:02]      Core: ProtoMol
[05:09:02]   Website: http://folding.stanford.edu/
[05:09:02] Copyright: (c) 2009 Stanford University
[05:09:02]    Author: Joseph Coffland <joseph@cauldrondevelopment.com>
[05:09:02]      Args: -dir work/ -suffix 02 -cpu 98 -checkpoint 21 -notermcheck -lifeline
[05:09:02]            2276 -version 623
[05:09:02] ************************************ Build *************************************
[05:09:02]      Date: Jan 21 2010
[05:09:02]      Time: 19:16:23
[05:09:02]  Revision: 1756
[05:09:02]  Compiler: Intel(R) C++ MSVC 1500 mode 1110
[05:09:02]   Options: /TP /nologo /EHsc /wd4297 /wd4103 /wd1786 /arch:IA32 /Ox
[05:09:02]            /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qrestrict /MT
[05:09:02]  Platform: Windows XP
[05:09:02]      Bits: 32
[05:09:02]      Mode: Release
[05:09:02] ************************************ System ************************************
[05:09:02]        OS: Microsoft Windows XP Professional
[05:09:02]       CPU: Intel(R) Pentium(R) 4 CPU 2.80GHz
[05:09:02]    CPU ID: GenuineIntel Family 15 Model 2 Stepping 9
[05:09:02]      CPUs: 1 Logical, 1 Physical
[05:09:02]    Memory: 1023 MB
[05:09:02]   Threads: Windows
[05:09:02] ********************************************************************************
[05:09:02] Project: 10004 (Run 2410, Clone 2, Gen 5)
[05:09:02] Digital signatures verified
[05:09:03] Completed 184000 out of 500000 steps (36%)
[05:10:44] Completed 185000 out of 500000 steps (37%)
[05:19:02] Completed 190000 out of 500000 steps (38%)
[05:27:17] Completed 195000 out of 500000 steps (39%)
[05:35:54] Completed 200000 out of 500000 steps (40%)
[05:44:52] Completed 205000 out of 500000 steps (41%)
[05:53:30] Completed 210000 out of 500000 steps (42%)
[06:02:15] Completed 215000 out of 500000 steps (43%)
[06:11:04] Completed 220000 out of 500000 steps (44%)
[06:19:46] Completed 225000 out of 500000 steps (45%)
[06:28:23] Completed 230000 out of 500000 steps (46%)
[06:37:10] Completed 235000 out of 500000 steps (47%)
[06:38:23] Opening http://fah-web.stanford.edu/cgi-bin/main.py?qtype=userpage&username=wan.ardiles@...
[06:45:43] Completed 240000 out of 500000 steps (48%)
[06:54:32] Completed 245000 out of 500000 steps (49%)
[07:02:50] Completed 250000 out of 500000 steps (50%)
[07:11:21] Completed 255000 out of 500000 steps (51%)
[07:20:02] Completed 260000 out of 500000 steps (52%)
[07:28:35] Completed 265000 out of 500000 steps (53%)
[07:29:16] CoreStatus = 62 (98)
[07:29:16] + Restarting core (settings changed)
[07:29:16]
[07:29:16] + Processing work unit
[07:29:16] Core required: FahCore_b4.exe
[07:29:16] Core found.
[07:29:16] Working on queue slot 02 [March 9 07:29:16 UTC]
[07:29:16] + Working ...
[07:29:18] *********************** Log Started 09/Mar/2010 07:29:18 ***********************
[07:29:18] ************************** ProtoMol Folding@Home Core **************************
[07:29:18]   Version: 22
[07:29:18]      Type: 180
[07:29:18]      Core: ProtoMol
[07:29:18]   Website: http://folding.stanford.edu/
[07:29:18] Copyright: (c) 2009 Stanford University
[07:29:18]    Author: Joseph Coffland <joseph@cauldrondevelopment.com>
[07:29:18]      Args: -dir work/ -suffix 02 -cpu 98 -checkpoint 27 -notermcheck -lifeline
[07:29:18]            2276 -version 623
[07:29:18] ************************************ Build *************************************
[07:29:18]      Date: Jan 21 2010
[07:29:18]      Time: 19:16:23
[07:29:18]  Revision: 1756
[07:29:18]  Compiler: Intel(R) C++ MSVC 1500 mode 1110
[07:29:18]   Options: /TP /nologo /EHsc /wd4297 /wd4103 /wd1786 /arch:IA32 /Ox
[07:29:18]            /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qrestrict /MT
[07:29:18]  Platform: Windows XP
[07:29:18]      Bits: 32
[07:29:18]      Mode: Release
[07:29:18] ************************************ System ************************************
[07:29:18]        OS: Microsoft Windows XP Professional
[07:29:18]       CPU: Intel(R) Pentium(R) 4 CPU 2.80GHz
[07:29:18]    CPU ID: GenuineIntel Family 15 Model 2 Stepping 9
[07:29:18]      CPUs: 1 Logical, 1 Physical
[07:29:18]    Memory: 1023 MB
[07:29:18]   Threads: Windows
[07:29:18] ********************************************************************************
[07:29:18] Project: 10004 (Run 2410, Clone 2, Gen 5)
[07:29:18] Digital signatures verified
[07:29:19] Completed 257400 out of 500000 steps (51%)
[07:33:55] Completed 260000 out of 500000 steps (52%)
[07:44:13] Completed 265000 out of 500000 steps (53%)
[07:54:05] Completed 270000 out of 500000 steps (54%)
[07:56:00] + Paused
--- Opening Log file [March 9 08:03:45 UTC]
[08:03:45] - Ask before connecting: Yes
[08:03:45] - User name: wan.ardiles@xxx.xxx (Team 2999)
[08:03:45] - User ID: 51CA9AE53E28415A
[08:03:45] - Machine ID: 1
[08:03:45]
[08:03:45] Loaded queue successfully.
[08:03:45] Initialization complete
[08:03:45]
[08:03:45] + Processing work unit
[08:03:45] Core required: FahCore_b4.exe
[08:03:45] Core found.
[08:03:45] Working on queue slot 02 [March 9 08:03:45 UTC]
[08:03:45] + Working ...
[08:03:50] *********************** Log Started 09/Mar/2010 08:03:50 ***********************
[08:03:50] ************************** ProtoMol Folding@Home Core **************************
[08:03:50]   Version: 22
[08:03:50]      Type: 180
[08:03:50]      Core: ProtoMol
[08:03:50]   Website: http://folding.stanford.edu/
[08:03:50] Copyright: (c) 2009 Stanford University
[08:03:50]    Author: Joseph Coffland <joseph@cauldrondevelopment.com>
[08:03:50]      Args: -dir work/ -suffix 02 -cpu 98 -checkpoint 27 -lifeline 3176 -version
[08:03:50]            623
[08:03:50] ************************************ Build *************************************
[08:03:50]      Date: Jan 21 2010
[08:03:50]      Time: 19:16:23
[08:03:50]  Revision: 1756
[08:03:50]  Compiler: Intel(R) C++ MSVC 1500 mode 1110
[08:03:50]   Options: /TP /nologo /EHsc /wd4297 /wd4103 /wd1786 /arch:IA32 /Ox
[08:03:50]            /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qrestrict /MT
[08:03:50]  Platform: Windows XP
[08:03:50]      Bits: 32
[08:03:50]      Mode: Release
[08:03:50] ************************************ System ************************************
[08:03:50]        OS: Microsoft Windows XP Professional
[08:03:50]       CPU: Intel(R) Pentium(R) 4 CPU 2.80GHz
[08:03:50]    CPU ID: GenuineIntel Family 15 Model 2 Stepping 9
[08:03:50]      CPUs: 1 Logical, 1 Physical
[08:03:50]    Memory: 1023 MB
[08:03:50]   Threads: Windows
[08:03:50] ********************************************************************************
[08:03:50] Project: 10004 (Run 2410, Clone 2, Gen 5)
[08:03:50] Digital signatures verified
[08:03:51] Completed 257400 out of 500000 steps (51%)
[08:04:14] Opening C:\Documents and Settings\root\Application Data\Folding@home-x86\MyFolding.html...
[08:05:15] CoreStatus = 62 (98)
[08:05:15] + Restarting core (settings changed)
[08:05:15]
[08:05:15] + Processing work unit
[08:05:15] Core required: FahCore_b4.exe
[08:05:15] Core found.
[08:05:15] Working on queue slot 02 [March 9 08:05:15 UTC]
[08:05:15] + Working ...
[08:05:17] *********************** Log Started 09/Mar/2010 08:05:17 ***********************
[08:05:17] ************************** ProtoMol Folding@Home Core **************************
[08:05:17]   Version: 22
[08:05:17]      Type: 180
[08:05:17]      Core: ProtoMol
[08:05:17]   Website: http://folding.stanford.edu/
[08:05:17] Copyright: (c) 2009 Stanford University
[08:05:17]    Author: Joseph Coffland <joseph@cauldrondevelopment.com>
[08:05:17]      Args: -dir work/ -suffix 02 -cpu 88 -checkpoint 27 -notermcheck -lifeline
[08:05:17]            3176 -version 623
[08:05:17] ************************************ Build *************************************
[08:05:17]      Date: Jan 21 2010
[08:05:17]      Time: 19:16:23
[08:05:17]  Revision: 1756
[08:05:17]  Compiler: Intel(R) C++ MSVC 1500 mode 1110
[08:05:17]   Options: /TP /nologo /EHsc /wd4297 /wd4103 /wd1786 /arch:IA32 /Ox
[08:05:17]            /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qrestrict /MT
[08:05:17]  Platform: Windows XP
[08:05:17]      Bits: 32
[08:05:17]      Mode: Release
[08:05:17] ************************************ System ************************************
[08:05:17]        OS: Microsoft Windows XP Professional
[08:05:17]       CPU: Intel(R) Pentium(R) 4 CPU 2.80GHz
[08:05:17]    CPU ID: GenuineIntel Family 15 Model 2 Stepping 9
[08:05:17]      CPUs: 1 Logical, 1 Physical
[08:05:17]    Memory: 1023 MB
[08:05:17]   Threads: Windows
[08:05:17] ********************************************************************************
[08:05:17] Project: 10004 (Run 2410, Clone 2, Gen 5)
[08:05:17] Digital signatures verified
[08:05:18] Completed 257400 out of 500000 steps (51%)
[08:10:43] Completed 260000 out of 500000 steps (52%)
[08:20:53] Completed 265000 out of 500000 steps (53%)
[08:26:35] Opening C:\Documents and Settings\root\Application Data\Folding@home-x86\MyFolding.html...
[08:30:54] CoreStatus = 62 (98)
[08:30:54] + Restarting core (settings changed)
[08:30:54]
[08:30:54] + Processing work unit
[08:30:54] Core required: FahCore_b4.exe
[08:30:54] Core found.
[08:30:54] Working on queue slot 02 [March 9 08:30:54 UTC]
[08:30:54] + Working ...
[08:30:56] *********************** Log Started 09/Mar/2010 08:30:56 ***********************
[08:30:56] ************************** ProtoMol Folding@Home Core **************************
[08:30:56]   Version: 22
[08:30:56]      Type: 180
[08:30:56]      Core: ProtoMol
[08:30:56]   Website: http://folding.stanford.edu/
[08:30:56] Copyright: (c) 2009 Stanford University
[08:30:56]    Author: Joseph Coffland <joseph@cauldrondevelopment.com>
[08:30:56]      Args: -dir work/ -suffix 02 -cpu 95 -checkpoint 18 -notermcheck -lifeline
[08:30:56]            3176 -version 623
[08:30:56] ************************************ Build *************************************
[08:30:56]      Date: Jan 21 2010
[08:30:56]      Time: 19:16:23
[08:30:56]  Revision: 1756
[08:30:56]  Compiler: Intel(R) C++ MSVC 1500 mode 1110
[08:30:56]   Options: /TP /nologo /EHsc /wd4297 /wd4103 /wd1786 /arch:IA32 /Ox
[08:30:56]            /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qrestrict /MT
[08:30:56]  Platform: Windows XP
[08:30:56]      Bits: 32
[08:30:56]      Mode: Release
[08:30:56] ************************************ System ************************************
[08:30:56]        OS: Microsoft Windows XP Professional
[08:30:56]       CPU: Intel(R) Pentium(R) 4 CPU 2.80GHz
[08:30:56]    CPU ID: GenuineIntel Family 15 Model 2 Stepping 9
[08:30:56]      CPUs: 1 Logical, 1 Physical
[08:30:56]    Memory: 1023 MB
[08:30:56]   Threads: Windows
[08:30:56] ********************************************************************************
[08:30:56] Project: 10004 (Run 2410, Clone 2, Gen 5)
[08:30:56] Digital signatures verified
[08:30:57] Completed 257400 out of 500000 steps (51%)
[08:35:23] CoreStatus = 62 (98)
[08:35:23] + Restarting core (settings changed)
[08:35:23]
[08:35:23] + Processing work unit
[08:35:23] Core required: FahCore_b4.exe
[08:35:23] Core found.
[08:35:23] Working on queue slot 02 [March 9 08:35:23 UTC]
[08:35:23] + Working ...
[08:35:25] *********************** Log Started 09/Mar/2010 08:35:25 ***********************
[08:35:25] ************************** ProtoMol Folding@Home Core **************************
[08:35:25]   Version: 22
[08:35:25]      Type: 180
[08:35:25]      Core: ProtoMol
[08:35:25]   Website: http://folding.stanford.edu/
[08:35:25] Copyright: (c) 2009 Stanford University
[08:35:25]    Author: Joseph Coffland <joseph@cauldrondevelopment.com>
[08:35:25]      Args: -dir work/ -suffix 02 -checkpoint 18 -notermcheck -lifeline 3176
[08:35:25]            -version 623
[08:35:25] ************************************ Build *************************************
[08:35:25]      Date: Jan 21 2010
[08:35:25]      Time: 19:16:23
[08:35:25]  Revision: 1756
[08:35:25]  Compiler: Intel(R) C++ MSVC 1500 mode 1110
[08:35:25]   Options: /TP /nologo /EHsc /wd4297 /wd4103 /wd1786 /arch:IA32 /Ox
[08:35:25]            /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qrestrict /MT
[08:35:25]  Platform: Windows XP
[08:35:25]      Bits: 32
[08:35:25]      Mode: Release
[08:35:25] ************************************ System ************************************
[08:35:25]        OS: Microsoft Windows XP Professional
[08:35:25]       CPU: Intel(R) Pentium(R) 4 CPU 2.80GHz
[08:35:25]    CPU ID: GenuineIntel Family 15 Model 2 Stepping 9
[08:35:25]      CPUs: 1 Logical, 1 Physical
[08:35:25]    Memory: 1023 MB
[08:35:25]   Threads: Windows
[08:35:25] ********************************************************************************
[08:35:25] Project: 10004 (Run 2410, Clone 2, Gen 5)
[08:35:25] Digital signatures verified
[08:35:26] Completed 257400 out of 500000 steps (51%)
[08:39:51] Completed 260000 out of 500000 steps (52%)
[08:48:06] Completed 265000 out of 500000 steps (53%)
[08:56:54] Completed 270000 out of 500000 steps (54%)
[08:57:46] CoreStatus = 62 (98)
[08:57:46] + Restarting core (settings changed)
[08:57:46]
[08:57:46] + Processing work unit
[08:57:46] Core required: FahCore_b4.exe
[08:57:46] Core found.
[08:57:46] Working on queue slot 02 [March 9 08:57:46 UTC]
[08:57:46] + Working ...
[08:57:48] *********************** Log Started 09/Mar/2010 08:57:48 ***********************
[08:57:48] ************************** ProtoMol Folding@Home Core **************************
[08:57:48]   Version: 22
[08:57:48]      Type: 180
[08:57:48]      Core: ProtoMol
[08:57:48]   Website: http://folding.stanford.edu/
[08:57:48] Copyright: (c) 2009 Stanford University
[08:57:48]    Author: Joseph Coffland <joseph@cauldrondevelopment.com>
[08:57:48]      Args: -dir work/ -suffix 02 -cpu 89 -checkpoint 12 -notermcheck -lifeline
[08:57:48]            3176 -version 623
[08:57:48] ************************************ Build *************************************
[08:57:48]      Date: Jan 21 2010
[08:57:48]      Time: 19:16:23
[08:57:48]  Revision: 1756
[08:57:48]  Compiler: Intel(R) C++ MSVC 1500 mode 1110
[08:57:48]   Options: /TP /nologo /EHsc /wd4297 /wd4103 /wd1786 /arch:IA32 /Ox
[08:57:48]            /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qrestrict /MT
[08:57:48]  Platform: Windows XP
[08:57:48]      Bits: 32
[08:57:48]      Mode: Release
[08:57:48] ************************************ System ************************************
[08:57:48]        OS: Microsoft Windows XP Professional
[08:57:48]       CPU: Intel(R) Pentium(R) 4 CPU 2.80GHz
[08:57:48]    CPU ID: GenuineIntel Family 15 Model 2 Stepping 9
[08:57:48]      CPUs: 1 Logical, 1 Physical
[08:57:48]    Memory: 1023 MB
[08:57:48]   Threads: Windows
[08:57:48] ********************************************************************************
[08:57:48] Project: 10004 (Run 2410, Clone 2, Gen 5)
[08:57:48] Digital signatures verified
[08:57:49] Completed 268100 out of 500000 steps (53%)
[09:01:40] Completed 270000 out of 500000 steps (54%)
[09:11:38] Completed 275000 out of 500000 steps (55%)
[09:21:49] Completed 280000 out of 500000 steps (56%)
[09:25:48] CoreStatus = 62 (98)
[09:25:48] + Restarting core (settings changed)
[09:25:48]
[09:25:48] + Processing work unit
[09:25:48] Core required: FahCore_b4.exe
[09:25:48] Core found.
[09:25:48] Working on queue slot 02 [March 9 09:25:48 UTC]
[09:25:48] + Working ...
[09:25:51] *********************** Log Started 09/Mar/2010 09:25:51 ***********************
[09:25:51] ************************** ProtoMol Folding@Home Core **************************
[09:25:51]   Version: 22
[09:25:51]      Type: 180
[09:25:51]      Core: ProtoMol
[09:25:51]   Website: http://folding.stanford.edu/
[09:25:51] Copyright: (c) 2009 Stanford University
[09:25:51]    Author: Joseph Coffland <joseph@cauldrondevelopment.com>
[09:25:51]      Args: -dir work/ -suffix 02 -cpu 94 -checkpoint 15 -notermcheck -lifeline
[09:25:51]            3176 -version 623
[09:25:51] ************************************ Build *************************************
[09:25:51]      Date: Jan 21 2010
[09:25:51]      Time: 19:16:23
[09:25:51]  Revision: 1756
[09:25:51]  Compiler: Intel(R) C++ MSVC 1500 mode 1110
[09:25:51]   Options: /TP /nologo /EHsc /wd4297 /wd4103 /wd1786 /arch:IA32 /Ox
[09:25:51]            /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qrestrict /MT
[09:25:51]  Platform: Windows XP
[09:25:51]      Bits: 32
[09:25:51]      Mode: Release
[09:25:51] ************************************ System ************************************
[09:25:51]        OS: Microsoft Windows XP Professional
[09:25:51]       CPU: Intel(R) Pentium(R) 4 CPU 2.80GHz
[09:25:51]    CPU ID: GenuineIntel Family 15 Model 2 Stepping 9
[09:25:51]      CPUs: 1 Logical, 1 Physical
[09:25:51]    Memory: 1023 MB
[09:25:51]   Threads: Windows
[09:25:51] ********************************************************************************
[09:25:51] Project: 10004 (Run 2410, Clone 2, Gen 5)
[09:25:51] Digital signatures verified
[09:25:51] Completed 280100 out of 500000 steps (56%)
[09:34:19] Completed 285000 out of 500000 steps (57%)
[09:43:36] Completed 290000 out of 500000 steps (58%)
[09:53:00] Completed 295000 out of 500000 steps (59%)
[10:01:30] Completed 300000 out of 500000 steps (60%)
[10:10:01] Completed 305000 out of 500000 steps (61%)
[10:18:36] Completed 310000 out of 500000 steps (62%)
[10:27:15] Completed 315000 out of 500000 steps (63%)
[10:30:33] CoreStatus = 62 (98)
[10:30:33] + Restarting core (settings changed)
[10:30:33]
[10:30:33] + Processing work unit
[10:30:33] Core required: FahCore_b4.exe
[10:30:33] Core found.
[10:30:33] Working on queue slot 02 [March 9 10:30:33 UTC]
[10:30:33] + Working ...
[10:30:36] *********************** Log Started 09/Mar/2010 10:30:36 ***********************
[10:30:36] ************************** ProtoMol Folding@Home Core **************************
[10:30:36]   Version: 22
[10:30:36]      Type: 180
[10:30:36]      Core: ProtoMol
[10:30:36]   Website: http://folding.stanford.edu/
[10:30:36] Copyright: (c) 2009 Stanford University
[10:30:36]    Author: Joseph Coffland <joseph@cauldrondevelopment.com>
[10:30:36]      Args: -dir work/ -suffix 02 -cpu 96 -checkpoint 21 -notermcheck -lifeline
[10:30:36]            3176 -version 623
[10:30:36] ************************************ Build *************************************
[10:30:36]      Date: Jan 21 2010
[10:30:36]      Time: 19:16:23
[10:30:36]  Revision: 1756
[10:30:36]  Compiler: Intel(R) C++ MSVC 1500 mode 1110
[10:30:36]   Options: /TP /nologo /EHsc /wd4297 /wd4103 /wd1786 /arch:IA32 /Ox
[10:30:36]            /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qrestrict /MT
[10:30:36]  Platform: Windows XP
[10:30:36]      Bits: 32
[10:30:36]      Mode: Release
[10:30:36] ************************************ System ************************************
[10:30:36]        OS: Microsoft Windows XP Professional
[10:30:36]       CPU: Intel(R) Pentium(R) 4 CPU 2.80GHz
[10:30:36]    CPU ID: GenuineIntel Family 15 Model 2 Stepping 9
[10:30:36]      CPUs: 1 Logical, 1 Physical
[10:30:36]    Memory: 1023 MB
[10:30:36]   Threads: Windows
[10:30:36] ********************************************************************************
[10:30:36] Project: 10004 (Run 2410, Clone 2, Gen 5)
[10:30:36] Digital signatures verified
[10:30:36] Completed 314500 out of 500000 steps (62%)
[10:31:29] Completed 315000 out of 500000 steps (63%)
[10:40:03] Completed 320000 out of 500000 steps (64%)
[10:48:41] Completed 325000 out of 500000 steps (65%)
[10:57:18] Completed 330000 out of 500000 steps (66%)
[11:05:58] Completed 335000 out of 500000 steps (67%)
[11:15:24] Completed 340000 out of 500000 steps (68%)
[11:25:11] Completed 345000 out of 500000 steps (69%)
[11:34:19] Completed 350000 out of 500000 steps (70%)
[11:38:33] CoreStatus = 62 (98)
[11:38:33] + Restarting core (settings changed)
[11:38:33]
[11:38:33] + Processing work unit
[11:38:33] Core required: FahCore_b4.exe
[11:38:33] Core found.
[11:38:33] Working on queue slot 02 [March 9 11:38:33 UTC]
[11:38:33] + Working ...
[11:38:35] *********************** Log Started 09/Mar/2010 11:38:35 ***********************
[11:38:35] ************************** ProtoMol Folding@Home Core **************************
[11:38:35]   Version: 22
[11:38:35]      Type: 180
[11:38:35]      Core: ProtoMol
[11:38:35]   Website: http://folding.stanford.edu/
[11:38:35] Copyright: (c) 2009 Stanford University
[11:38:35]    Author: Joseph Coffland <joseph@cauldrondevelopment.com>
[11:38:35]      Args: -dir work/ -suffix 02 -checkpoint 12 -notermcheck -lifeline 3176
[11:38:35]            -version 623
[11:38:35] ************************************ Build *************************************
[11:38:35]      Date: Jan 21 2010
[11:38:35]      Time: 19:16:23
[11:38:35]  Revision: 1756
[11:38:35]  Compiler: Intel(R) C++ MSVC 1500 mode 1110
[11:38:35]   Options: /TP /nologo /EHsc /wd4297 /wd4103 /wd1786 /arch:IA32 /Ox
[11:38:35]            /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qrestrict /MT
[11:38:35]  Platform: Windows XP
[11:38:35]      Bits: 32
[11:38:35]      Mode: Release
[11:38:35] ************************************ System ************************************
[11:38:35]        OS: Microsoft Windows XP Professional
[11:38:35]       CPU: Intel(R) Pentium(R) 4 CPU 2.80GHz
[11:38:35]    CPU ID: GenuineIntel Family 15 Model 2 Stepping 9
[11:38:35]      CPUs: 1 Logical, 1 Physical
[11:38:35]    Memory: 1023 MB
[11:38:35]   Threads: Windows
[11:38:35] ********************************************************************************
[11:38:35] Project: 10004 (Run 2410, Clone 2, Gen 5)
[11:38:35] Digital signatures verified
[11:38:36] Completed 349800 out of 500000 steps (69%)
[11:38:57] Completed 350000 out of 500000 steps (70%)
[11:48:14] Completed 355000 out of 500000 steps (71%)
[11:58:17] Completed 360000 out of 500000 steps (72%)
[12:09:56] Completed 365000 out of 500000 steps (73%)
[12:20:02] Completed 370000 out of 500000 steps (74%)
[12:28:36] Completed 375000 out of 500000 steps (75%)
[12:30:57] + Paused
--- Opening Log file [March 9 12:34:26 UTC]
[12:34:27] - Ask before connecting: Yes
[12:34:27] - User name: wan.ardiles@xxx.xxx (Team 2999)
[12:34:27] - User ID: 51CA9AE53E28415A
[12:34:27] - Machine ID: 1
[12:34:27]
[12:34:27] Loaded queue successfully.
[12:34:27] Initialization complete
[12:34:27]
[12:34:27] + Processing work unit
[12:34:27] Core required: FahCore_b4.exe
[12:34:27] Core found.
[12:34:27] Working on queue slot 02 [March 9 12:34:27 UTC]
[12:34:27] + Working ...
[12:34:31] *********************** Log Started 09/Mar/2010 12:34:31 ***********************
[12:34:31] ************************** ProtoMol Folding@Home Core **************************
[12:34:31]   Version: 22
[12:34:31]      Type: 180
[12:34:31]      Core: ProtoMol
[12:34:31]   Website: http://folding.stanford.edu/
[12:34:31] Copyright: (c) 2009 Stanford University
[12:34:31]    Author: Joseph Coffland <joseph@cauldrondevelopment.com>
[12:34:31]      Args: -dir work/ -suffix 02 -checkpoint 12 -lifeline 3000 -version 623
[12:34:31] ************************************ Build *************************************
[12:34:31]      Date: Jan 21 2010
[12:34:31]      Time: 19:16:23
[12:34:31]  Revision: 1756
[12:34:31]  Compiler: Intel(R) C++ MSVC 1500 mode 1110
[12:34:31]   Options: /TP /nologo /EHsc /wd4297 /wd4103 /wd1786 /arch:IA32 /Ox
[12:34:31]            /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qrestrict /MT
[12:34:31]  Platform: Windows XP
[12:34:31]      Bits: 32
[12:34:31]      Mode: Release
[12:34:31] ************************************ System ************************************
[12:34:31]        OS: Microsoft Windows XP Professional
[12:34:31]       CPU: Intel(R) Pentium(R) 4 CPU 2.80GHz
[12:34:31]    CPU ID: GenuineIntel Family 15 Model 2 Stepping 9
[12:34:31]      CPUs: 1 Logical, 1 Physical
[12:34:31]    Memory: 1023 MB
[12:34:31]   Threads: Windows
[12:34:31] ********************************************************************************
[12:34:31] Project: 10004 (Run 2410, Clone 2, Gen 5)
[12:34:31] Digital signatures verified
[12:34:32] Completed 374100 out of 500000 steps (74%)
[12:36:25] Completed 375000 out of 500000 steps (75%)
[12:47:13] Completed 380000 out of 500000 steps (76%)
[12:54:45] CoreStatus = 62 (98)
[12:54:45] + Restarting core (settings changed)
[12:54:45]
[12:54:45] + Processing work unit
[12:54:45] Core required: FahCore_b4.exe
[12:54:45] Core found.
[12:54:45] Working on queue slot 02 [March 9 12:54:45 UTC]
[12:54:45] + Working ...
[12:54:48] *********************** Log Started 09/Mar/2010 12:54:48 ***********************
[12:54:48] ************************** ProtoMol Folding@Home Core **************************
[12:54:48]   Version: 22
[12:54:48]      Type: 180
[12:54:48]      Core: ProtoMol
[12:54:48]   Website: http://folding.stanford.edu/
[12:54:48] Copyright: (c) 2009 Stanford University
[12:54:48]    Author: Joseph Coffland <joseph@cauldrondevelopment.com>
[12:54:48]      Args: -dir work/ -suffix 02 -cpu 91 -checkpoint 3 -notermcheck -lifeline
[12:54:48]            3000 -version 623
[12:54:48] ************************************ Build *************************************
[12:54:48]      Date: Jan 21 2010
[12:54:48]      Time: 19:16:23
[12:54:48]  Revision: 1756
[12:54:48]  Compiler: Intel(R) C++ MSVC 1500 mode 1110
[12:54:48]   Options: /TP /nologo /EHsc /wd4297 /wd4103 /wd1786 /arch:IA32 /Ox
[12:54:48]            /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qrestrict /MT
[12:54:48]  Platform: Windows XP
[12:54:48]      Bits: 32
[12:54:48]      Mode: Release
[12:54:48] ************************************ System ************************************
[12:54:48]        OS: Microsoft Windows XP Professional
[12:54:48]       CPU: Intel(R) Pentium(R) 4 CPU 2.80GHz
[12:54:48]    CPU ID: GenuineIntel Family 15 Model 2 Stepping 9
[12:54:48]      CPUs: 1 Logical, 1 Physical
[12:54:48]    Memory: 1023 MB
[12:54:48]   Threads: Windows
[12:54:48] ********************************************************************************
[12:54:48] Project: 10004 (Run 2410, Clone 2, Gen 5)
[12:54:48] Digital signatures verified
[12:54:49] Completed 379800 out of 500000 steps (75%)
[12:55:25] Completed 380000 out of 500000 steps (76%)
[13:15:17] Completed 385000 out of 500000 steps (77%)
[13:19:12] + Paused
--- Opening Log file [March 10 01:35:04 UTC]
[01:35:04] - Ask before connecting: Yes
[01:35:04] - User name: wan.ardiles@xxx.xxx (Team 2999)
[01:35:04] - User ID: 51CA9AE53E28415A
[01:35:04] - Machine ID: 1
[01:35:04]
[01:35:04] Loaded queue successfully.
[01:35:04] Initialization complete
[01:35:04]
[01:35:04] + Processing work unit
[01:35:04] Core required: FahCore_b4.exe
[01:35:04] Core found.
[01:35:04] Working on queue slot 02 [March 10 01:35:04 UTC]
[01:35:04] + Working ...
[01:35:08] *********************** Log Started 10/Mar/2010 01:35:08 ***********************
[01:35:08] ************************** ProtoMol Folding@Home Core **************************
[01:35:08]   Version: 22
[01:35:08]      Type: 180
[01:35:08]      Core: ProtoMol
[01:35:08]   Website: http://folding.stanford.edu/
[01:35:08] Copyright: (c) 2009 Stanford University
[01:35:08]    Author: Joseph Coffland <joseph@cauldrondevelopment.com>
[01:35:08]      Args: -dir work/ -suffix 02 -cpu 91 -checkpoint 3 -lifeline 3044 -version
[01:35:08]            623
[01:35:08] ************************************ Build *************************************
[01:35:08]      Date: Jan 21 2010
[01:35:08]      Time: 19:16:23
[01:35:08]  Revision: 1756
[01:35:08]  Compiler: Intel(R) C++ MSVC 1500 mode 1110
[01:35:08]   Options: /TP /nologo /EHsc /wd4297 /wd4103 /wd1786 /arch:IA32 /Ox
[01:35:08]            /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qrestrict /MT
[01:35:08]  Platform: Windows XP
[01:35:08]      Bits: 32
[01:35:08]      Mode: Release
[01:35:08] ************************************ System ************************************
[01:35:08]        OS: Microsoft Windows XP Professional
[01:35:08]       CPU: Intel(R) Pentium(R) 4 CPU 2.80GHz
[01:35:08]    CPU ID: GenuineIntel Family 15 Model 2 Stepping 9
[01:35:08]      CPUs: 1 Logical, 1 Physical
[01:35:08]    Memory: 1023 MB
[01:35:08]   Threads: Windows
[01:35:08] ********************************************************************************
[01:35:08] Project: 10004 (Run 2410, Clone 2, Gen 5)
[01:35:08] Digital signatures verified
[01:35:09] Completed 386100 out of 500000 steps (77%)
[01:40:55] CoreStatus = 62 (98)
[01:40:55] + Restarting core (settings changed)
[01:40:55]
[01:40:55] + Processing work unit
[01:40:55] Core required: FahCore_b4.exe
[01:40:55] Core found.
[01:40:55] Working on queue slot 02 [March 10 01:40:55 UTC]
[01:40:55] + Working ...
[01:40:57] *********************** Log Started 10/Mar/2010 01:40:57 ***********************
[01:40:57] ************************** ProtoMol Folding@Home Core **************************
[01:40:57]   Version: 22
[01:40:57]      Type: 180
[01:40:57]      Core: ProtoMol
[01:40:57]   Website: http://folding.stanford.edu/
[01:40:57] Copyright: (c) 2009 Stanford University
[01:40:57]    Author: Joseph Coffland <joseph@cauldrondevelopment.com>
[01:40:57]      Args: -dir work/ -suffix 02 -cpu 46 -checkpoint 3 -notermcheck -lifeline
[01:40:57]            3044 -version 623
[01:40:57] ************************************ Build *************************************
[01:40:57]      Date: Jan 21 2010
[01:40:57]      Time: 19:16:23
[01:40:57]  Revision: 1756
[01:40:57]  Compiler: Intel(R) C++ MSVC 1500 mode 1110
[01:40:57]   Options: /TP /nologo /EHsc /wd4297 /wd4103 /wd1786 /arch:IA32 /Ox
[01:40:57]            /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qrestrict /MT
[01:40:57]  Platform: Windows XP
[01:40:57]      Bits: 32
[01:40:57]      Mode: Release
[01:40:57] ************************************ System ************************************
[01:40:57]        OS: Microsoft Windows XP Professional
[01:40:57]       CPU: Intel(R) Pentium(R) 4 CPU 2.80GHz
[01:40:57]    CPU ID: GenuineIntel Family 15 Model 2 Stepping 9
[01:40:57]      CPUs: 1 Logical, 1 Physical
[01:40:57]    Memory: 1023 MB
[01:40:57]   Threads: Windows
[01:40:57] ********************************************************************************
[01:40:57] Project: 10004 (Run 2410, Clone 2, Gen 5)
[01:40:57] Digital signatures verified
[01:40:58] Completed 387800 out of 500000 steps (77%)
[01:48:56] Completed 390000 out of 500000 steps (78%)
[02:07:59] Completed 395000 out of 500000 steps (79%)
[02:26:38] Completed 400000 out of 500000 steps (80%)
[02:44:43] Completed 405000 out of 500000 steps (81%)
[02:56:19] CoreStatus = 62 (98)
[02:56:19] + Restarting core (settings changed)
[02:56:19]
[02:56:19] + Processing work unit
[02:56:19] Core required: FahCore_b4.exe
[02:56:19] Core found.
[02:56:19] Working on queue slot 02 [March 10 02:56:19 UTC]
[02:56:19] + Working ...
[02:56:25] *********************** Log Started 10/Mar/2010 02:56:25 ***********************
[02:56:25] ************************** ProtoMol Folding@Home Core **************************
[02:56:25]   Version: 22
[02:56:25]      Type: 180
[02:56:25]      Core: ProtoMol
[02:56:25]   Website: http://folding.stanford.edu/
[02:56:25] Copyright: (c) 2009 Stanford University
[02:56:25]    Author: Joseph Coffland <joseph@cauldrondevelopment.com>
[02:56:25]      Args: -dir work/ -suffix 02 -cpu 73 -checkpoint 3 -notermcheck -lifeline
[02:56:25]            3044 -version 623
[02:56:25] ************************************ Build *************************************
[02:56:25]      Date: Jan 21 2010
[02:56:25]      Time: 19:16:23
[02:56:25]  Revision: 1756
[02:56:25]  Compiler: Intel(R) C++ MSVC 1500 mode 1110
[02:56:25]   Options: /TP /nologo /EHsc /wd4297 /wd4103 /wd1786 /arch:IA32 /Ox
[02:56:25]            /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qrestrict /MT
[02:56:25]  Platform: Windows XP
[02:56:25]      Bits: 32
[02:56:25]      Mode: Release
[02:56:25] ************************************ System ************************************
[02:56:25]        OS: Microsoft Windows XP Professional
[02:56:25]       CPU: Intel(R) Pentium(R) 4 CPU 2.80GHz
[02:56:25]    CPU ID: GenuineIntel Family 15 Model 2 Stepping 9
[02:56:25]      CPUs: 1 Logical, 1 Physical
[02:56:25]    Memory: 1023 MB
[02:56:25]   Threads: Windows
[02:56:25] ********************************************************************************
[02:56:25] Project: 10004 (Run 2410, Clone 2, Gen 5)
[02:56:25] Digital signatures verified
[02:56:26] Completed 408200 out of 500000 steps (81%)
[03:00:42] Completed 410000 out of 500000 steps (82%)
[03:12:10] Completed 415000 out of 500000 steps (83%)
[03:23:41] Completed 420000 out of 500000 steps (84%)
[03:35:22] Completed 425000 out of 500000 steps (85%)
[03:46:50] Completed 430000 out of 500000 steps (86%)
[03:58:24] Completed 435000 out of 500000 steps (87%)
[04:02:44] CoreStatus = 62 (98)
[04:02:44] + Restarting core (settings changed)
[04:02:44]
[04:02:44] + Processing work unit
[04:02:44] Core required: FahCore_b4.exe
[04:02:44] Core found.
[04:02:44] Working on queue slot 02 [March 10 04:02:44 UTC]
[04:02:44] + Working ...
[04:02:49] *********************** Log Started 10/Mar/2010 04:02:49 ***********************
[04:02:49] ************************** ProtoMol Folding@Home Core **************************
[04:02:49]   Version: 22
[04:02:49]      Type: 180
[04:02:49]      Core: ProtoMol
[04:02:49]   Website: http://folding.stanford.edu/
[04:02:49] Copyright: (c) 2009 Stanford University
[04:02:49]    Author: Joseph Coffland <joseph@cauldrondevelopment.com>
[04:02:49]      Args: -dir work/ -suffix 02 -cpu 85 -checkpoint 3 -notermcheck -lifeline
[04:02:49]            3044 -version 623
[04:02:49] ************************************ Build *************************************
[04:02:49]      Date: Jan 21 2010
[04:02:49]      Time: 19:16:23
[04:02:49]  Revision: 1756
[04:02:49]  Compiler: Intel(R) C++ MSVC 1500 mode 1110
[04:02:49]   Options: /TP /nologo /EHsc /wd4297 /wd4103 /wd1786 /arch:IA32 /Ox
[04:02:49]            /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qrestrict /MT
[04:02:49]  Platform: Windows XP
[04:02:49]      Bits: 32
[04:02:49]      Mode: Release
[04:02:49] ************************************ System ************************************
[04:02:49]        OS: Microsoft Windows XP Professional
[04:02:49]       CPU: Intel(R) Pentium(R) 4 CPU 2.80GHz
[04:02:49]    CPU ID: GenuineIntel Family 15 Model 2 Stepping 9
[04:02:49]      CPUs: 1 Logical, 1 Physical
[04:02:49]    Memory: 1023 MB
[04:02:49]   Threads: Windows
[04:02:49] ********************************************************************************
[04:02:49] Project: 10004 (Run 2410, Clone 2, Gen 5)
[04:02:49] Digital signatures verified
[04:02:50] Completed 435500 out of 500000 steps (87%)
[04:11:42] Completed 440000 out of 500000 steps (88%)
[04:21:36] Completed 445000 out of 500000 steps (89%)
[04:31:34] Completed 450000 out of 500000 steps (90%)
[04:45:35] Completed 455000 out of 500000 steps (91%)
[04:56:11] Completed 460000 out of 500000 steps (92%)
[05:07:12] Completed 465000 out of 500000 steps (93%)
[05:17:57] CoreStatus = 62 (98)
[05:17:57] + Restarting core (settings changed)
[05:17:57]
[05:17:57] + Processing work unit
[05:17:57] Core required: FahCore_b4.exe
[05:17:57] Core found.
[05:17:57] Working on queue slot 02 [March 10 05:17:57 UTC]
[05:17:57] + Working ...
[05:18:01] *********************** Log Started 10/Mar/2010 05:18:01 ***********************
[05:18:01] ************************** ProtoMol Folding@Home Core **************************
[05:18:01]   Version: 22
[05:18:01]      Type: 180
[05:18:01]      Core: ProtoMol
[05:18:01]   Website: http://folding.stanford.edu/
[05:18:01] Copyright: (c) 2009 Stanford University
[05:18:01]    Author: Joseph Coffland <joseph@cauldrondevelopment.com>
[05:18:01]      Args: -dir work/ -suffix 02 -cpu 91 -checkpoint 18 -notermcheck -lifeline
[05:18:01]            3044 -version 623
[05:18:01] ************************************ Build *************************************
[05:18:01]      Date: Jan 21 2010
[05:18:01]      Time: 19:16:23
[05:18:01]  Revision: 1756
[05:18:01]  Compiler: Intel(R) C++ MSVC 1500 mode 1110
[05:18:01]   Options: /TP /nologo /EHsc /wd4297 /wd4103 /wd1786 /arch:IA32 /Ox
[05:18:01]            /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qrestrict /MT
[05:18:01]  Platform: Windows XP
[05:18:01]      Bits: 32
[05:18:01]      Mode: Release
[05:18:01] ************************************ System ************************************
[05:18:01]        OS: Microsoft Windows XP Professional
[05:18:01]       CPU: Intel(R) Pentium(R) 4 CPU 2.80GHz
[05:18:01]    CPU ID: GenuineIntel Family 15 Model 2 Stepping 9
[05:18:01]      CPUs: 1 Logical, 1 Physical
[05:18:01]    Memory: 1023 MB
[05:18:01]   Threads: Windows
[05:18:01] ********************************************************************************
[05:18:01] Project: 10004 (Run 2410, Clone 2, Gen 5)
[06:28:58]
[06:28:58] + Processing work unit
[06:28:58] Core required: FahCore_a0.exe
[06:28:58] Core not found.
[06:28:58] - Core is not present or corrupted.
[06:28:58] - Attempting to download new core...
[06:28:58] + Downloading new core: FahCore_a0.exe
Log posted as requested. Can someone help me?
wan.ardiles
Queue slot: 2
Unit information:
Status: Empty/Deleted
Project: 10004 (Run 2410, Clone 2, Gen 5), Core: b4
Work server: 129.74.85.48:8080
Collection server: 129.74.85.49
Download date: March 8 08:50:01
Deadline date: April 7 06:28:58
Finished date: March 10 06:18:03
Failed uploads: 2
PF: 0.912372 based on last 2 slot(s)
Some more extra information.
You've done an amazing number of changes to the settings. I don't recommend that, but it's not necessarily the cause of your problem. Fah works best if you start it and just let it run.
Also, I see that you paused and then shut down -- twice. That has been known to cause problems with other cores, though it might not with ProtoMol. The purpose of the Pause function is to temporarily suspend FAH while you do something else. You're expected to resume work. If your intention is to shut down, you should either not pause at all or Resume before shutting down.
wan.ardiles
I know I've re-setting a lot, found out myself before paste-ing into this reply box. :)
I never knew about the spesific function of the Pause. Have read the FAQ, even from my team's forum, no one have ever said about the not-to-Pause protocol :)
I'm a beginner, just more than 1 week doing folding. Is there any do's & dont's while running F@H?
Any solution/remark for my missing WU?
Unfortunately, there's no record of the WU in the Moderator database. I can tell that the same client had successfully uploaded a WU before that, but I have no explanation why the serve saw a problem with your next WU.
Hi wan.ardiles (team 2999),
Your WU (P10007 R3725 C1 G3) was added to the stats database on 2010-03-08 01:05:20 PST for 126.4 points of credit.
Days taken to complete WU: 4.18
