Project: 10106 (Run 96, Clone 1, Gen 2)
shdbcamping
Hardware configuration: XPS 720 Q6600 9800GX2 3gig RAM
750W primary PSU 650W Aux VGA PSU
Post by shdbcamping »
I don't know what to think of this :? .
As the code shows... all the same client.... no erase... just shutdowns and restarts :shock:
Help :wink:
[12:49:22] + Processing work unit
[12:49:22] Core required: FahCore_11.exe
[12:49:22] Core found.
[12:49:22] Working on queue slot 06 [March 8 12:49:22 UTC]
[12:49:22] + Working ...
[12:49:22]
[12:49:22] *------------------------------*
[12:49:22] Folding@Home GPU Core
[12:49:22] Version 1.31 (Tue Sep 15 10:57:42 PDT 2009)
[12:49:22]
[12:49:22] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[12:49:22] Build host: amoeba
[12:49:22] Board Type: Nvidia
[12:49:22] Core      :
[12:49:22] Preparing to commence simulation
[12:49:22] - Looking at optimizations...
[12:49:22] DeleteFrameFiles: successfully deleted file=work/wudata_06.ckp
[12:49:22] - Created dyn
[12:49:22] - Files status OK
[12:49:22] - Expanded 88651 -> 447307 (decompressed 504.5 percent)
[12:49:22] Called DecompressByteArray: compressed_data_size=88651 data_size=447307, decompressed_data_size=447307 diff=0
[12:49:22] - Digital signature verified
[12:49:22]
[12:49:22] Project: 10106 (Run 96, Clone 1, Gen 2)
[12:49:22]
[12:49:22] Assembly optimizations on if available.
[12:49:22] Entering M.D.
[12:49:28] Tpr hash work/wudata_06.tpr:  1725156609 2891410245 3795927272 312815133 2393708436
[12:49:28]
[12:49:28] Calling fah_main args: 14 usage=100
[12:49:28]
[12:49:29] Working on p10106_lambda_370K
[12:49:30] Client config found, loading data.
[12:49:30] Starting GUI Server
[12:50:11] Completed 1%
[12:50:11] mdrun_gpu returned
[12:50:11] NANs detected on GPU
[12:50:11]
[12:50:11] Folding@home Core Shutdown: UNSTABLE_MACHINE
[12:50:14] CoreStatus = 7A (122)
[12:50:14] Sending work to server
[12:50:14] Project: 10106 (Run 96, Clone 1, Gen 2)
[12:50:14] - Read packet limit of 540015616... Set to 524286976.
[12:50:14] - Error: Could not get length of results file work/wuresults_06.dat
[12:50:14] - Error: Could not read unit 06 file. Removing from queue.
[12:50:14] EUE limit exceeded. Pausing 24 hours.
Folding@Home Client Shutdown.
--- Opening Log file [March 9 04:37:20 UTC]
                          http://folding.stanford.edu
Launch directory: C:\GPU2
Executable: C:\GPU2\GPU2.exe
Arguments: -gpu 2
[04:37:20] - Ask before connecting: No
[04:37:20] - User name: statesidecoma (Team 80856)
[04:37:20] - User ID: 65C7E7AF0E907C50
[04:37:20] - Machine ID: 7
[04:37:20]
[04:37:20] Loaded queue successfully.
[04:37:20] - Preparing to get new work unit...
[04:37:20] + Attempting to get work packet
[04:37:20] - Connecting to assignment server
[04:37:25] - Successful: assigned to (171.64.65.71).
[04:37:25] + News From Folding@Home: Welcome to Folding@Home
[04:37:26] Loaded queue successfully.
[04:37:29] + Closed connections
[04:37:29]
[04:37:29] + Processing work unit
[04:37:29] Core required: FahCore_11.exe
[04:37:29] Core found.
[04:37:29] Working on queue slot 07 [March 9 04:37:29 UTC]
[04:37:29] + Working ...
[04:37:29]
[04:37:29] *------------------------------*
[04:37:29] Folding@Home GPU Core
[04:37:29] Version 1.31 (Tue Sep 15 10:57:42 PDT 2009)
[04:37:29]
[04:37:29] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[04:37:29] Build host: amoeba
[04:37:29] Board Type: Nvidia
[04:37:29] Core      :
[04:37:29] Preparing to commence simulation
[04:37:29] - Looking at optimizations...
[04:37:29] DeleteFrameFiles: successfully deleted file=work/wudata_07.ckp
[04:37:29] - Created dyn
[04:37:29] - Files status OK
[04:37:29] - Expanded 88651 -> 447307 (decompressed 504.5 percent)
[04:37:29] Called DecompressByteArray: compressed_data_size=88651 data_size=447307, decompressed_data_size=447307 diff=0
[04:37:29] - Digital signature verified
[04:37:29]
[04:37:29] Project: 10106 (Run 96, Clone 1, Gen 2)
[04:37:29]
[04:37:29] Assembly optimizations on if available.
[04:37:29] Entering M.D.
[04:37:35] Tpr hash work/wudata_07.tpr:  1725156609 2891410245 3795927272 312815133 2393708436
[04:37:35]
[04:37:35] Calling fah_main args: 14 usage=100
[04:37:35]
[04:37:36] Working on p10106_lambda_370K
[04:37:37] Client config found, loading data.
[04:37:37] Starting GUI Server
[04:38:36] Completed 1%
[04:39:19] Completed 2%
[04:39:19] mdrun_gpu returned
[04:39:19] NANs detected on GPU
[04:39:19]
[04:39:19] Folding@home Core Shutdown: UNSTABLE_MACHINE
[04:39:21] CoreStatus = 7A (122)
[04:39:21] Sending work to server
[04:39:21] Project: 10106 (Run 96, Clone 1, Gen 2)
[04:39:21] - Read packet limit of 540015616... Set to 524286976.
[04:39:21] - Error: Could not get length of results file work/wuresults_07.dat
[04:39:21] - Error: Could not read unit 07 file. Removing from queue.
[04:39:21] - Preparing to get new work unit...
[04:39:21] + Attempting to get work packet
[04:39:21] - Connecting to assignment server
[04:39:22] - Successful: assigned to (171.64.65.71).
[04:39:22] + News From Folding@Home: Welcome to Folding@Home
[04:39:22] Loaded queue successfully.
[04:39:23] + Closed connections
[04:39:28]
[04:39:28] + Processing work unit
[04:39:28] Core required: FahCore_11.exe
[04:39:28] Core found.
[04:39:28] Working on queue slot 08 [March 9 04:39:28 UTC]
[04:39:28] + Working ...
[04:39:28]
[04:39:28] *------------------------------*
[04:39:28] Folding@Home GPU Core
[04:39:28] Version 1.31 (Tue Sep 15 10:57:42 PDT 2009)
[04:39:28]
[04:39:28] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[04:39:28] Build host: amoeba
[04:39:28] Board Type: Nvidia
[04:39:28] Core      :
[04:39:28] Preparing to commence simulation
[04:39:28] - Looking at optimizations...
[04:39:28] DeleteFrameFiles: successfully deleted file=work/wudata_08.ckp
[04:39:28] - Created dyn
[04:39:28] - Files status OK
[04:39:28] - Expanded 88651 -> 447307 (decompressed 504.5 percent)
[04:39:28] Called DecompressByteArray: compressed_data_size=88651 data_size=447307, decompressed_data_size=447307 diff=0
[04:39:28] - Digital signature verified
[04:39:28]
[04:39:28] Project: 10106 (Run 96, Clone 1, Gen 2)
[04:39:28]
[04:39:28] Assembly optimizations on if available.
[04:39:28] Entering M.D.
[04:39:34] Tpr hash work/wudata_08.tpr:  1725156609 2891410245 3795927272 312815133 2393708436
[04:39:34]
[04:39:34] Calling fah_main args: 14 usage=100
[04:39:34]
[04:39:35] Working on p10106_lambda_370K
[04:39:36] Client config found, loading data.
[04:39:36] Starting GUI Server
[04:40:24] Completed 1%
[04:40:24] mdrun_gpu returned
[04:40:24] NANs detected on GPU
[04:40:24]
[04:40:24] Folding@home Core Shutdown: UNSTABLE_MACHINE
[04:40:26] CoreStatus = 7A (122)
[04:40:26] Sending work to server
[04:40:26] Project: 10106 (Run 96, Clone 1, Gen 2)
[04:40:26] - Read packet limit of 540015616... Set to 524286976.
[04:40:26] - Error: Could not get length of results file work/wuresults_08.dat
[04:40:26] - Error: Could not read unit 08 file. Removing from queue.
[04:40:26] - Preparing to get new work unit...
[04:40:26] + Attempting to get work packet
[04:40:26] - Connecting to assignment server
[04:40:27] - Successful: assigned to (171.64.65.71).
[04:40:27] + News From Folding@Home: Welcome to Folding@Home
[04:40:27] Loaded queue successfully.
[04:40:28] + Closed connections
[04:40:33]
[04:40:33] + Processing work unit
[04:40:33] Core required: FahCore_11.exe
[04:40:33] Core found.
[04:40:33] Working on queue slot 09 [March 9 04:40:33 UTC]
[04:40:33] + Working ...
[04:40:33]
[04:40:33] *------------------------------*
[04:40:33] Folding@Home GPU Core
[04:40:33] Version 1.31 (Tue Sep 15 10:57:42 PDT 2009)
[04:40:33]
[04:40:33] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[04:40:33] Build host: amoeba
[04:40:33] Board Type: Nvidia
[04:40:33] Core      :
[04:40:33] Preparing to commence simulation
[04:40:33] - Looking at optimizations...
[04:40:33] DeleteFrameFiles: successfully deleted file=work/wudata_09.ckp
[04:40:33] - Created dyn
[04:40:33] - Files status OK
[04:40:33] - Expanded 88651 -> 447307 (decompressed 504.5 percent)
[04:40:33] Called DecompressByteArray: compressed_data_size=88651 data_size=447307, decompressed_data_size=447307 diff=0
[04:40:33] - Digital signature verified
[04:40:33]
[04:40:33] Project: 10106 (Run 96, Clone 1, Gen 2)
[04:40:33]
[04:40:33] Assembly optimizations on if available.
[04:40:33] Entering M.D.
[04:40:39] Tpr hash work/wudata_09.tpr:  1725156609 2891410245 3795927272 312815133 2393708436
[04:40:39]
[04:40:39] Calling fah_main args: 14 usage=100
[04:40:39]
[04:40:39] Working on p10106_lambda_370K
[04:40:41] Client config found, loading data.
[04:40:41] Starting GUI Server
[04:41:30] Completed 1%
[04:41:30] mdrun_gpu returned
[04:41:30] NANs detected on GPU
[04:41:30]
[04:41:30] Folding@home Core Shutdown: UNSTABLE_MACHINE
[04:41:33] CoreStatus = 7A (122)
[04:41:33] Sending work to server
[04:41:33] Project: 10106 (Run 96, Clone 1, Gen 2)
[04:41:33] - Read packet limit of 540015616... Set to 524286976.
[04:41:33] - Error: Could not get length of results file work/wuresults_09.dat
[04:41:33] - Error: Could not read unit 09 file. Removing from queue.
[04:41:33] - Preparing to get new work unit...
[04:41:33] + Attempting to get work packet
[04:41:33] - Connecting to assignment server
[04:41:34] - Successful: assigned to (171.64.65.71).
[04:41:34] + News From Folding@Home: Welcome to Folding@Home
[04:41:34] Loaded queue successfully.
[04:41:35] + Closed connections
[04:41:40]
[04:41:40] + Processing work unit
[04:41:40] Core required: FahCore_11.exe
[04:41:40] Core found.
[04:41:40] Working on queue slot 00 [March 9 04:41:40 UTC]
[04:41:40] + Working ...
[04:41:40]
[04:41:40] *------------------------------*
[04:41:40] Folding@Home GPU Core
[04:41:40] Version 1.31 (Tue Sep 15 10:57:42 PDT 2009)
[04:41:40]
[04:41:40] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[04:41:40] Build host: amoeba
[04:41:40] Board Type: Nvidia
[04:41:40] Core      :
[04:41:40] Preparing to commence simulation
[04:41:40] - Looking at optimizations...
[04:41:40] DeleteFrameFiles: successfully deleted file=work/wudata_00.ckp
[04:41:40] - Created dyn
[04:41:40] - Files status OK
[04:41:40] - Expanded 88651 -> 447307 (decompressed 504.5 percent)
[04:41:40] Called DecompressByteArray: compressed_data_size=88651 data_size=447307, decompressed_data_size=447307 diff=0
[04:41:40] - Digital signature verified
[04:41:40]
[04:41:40] Project: 10106 (Run 96, Clone 1, Gen 2)
[04:41:40]
[04:41:40] Assembly optimizations on if available.
[04:41:40] Entering M.D.
[04:41:46] Tpr hash work/wudata_00.tpr:  1725156609 2891410245 3795927272 312815133 2393708436
[04:41:46]
[04:41:46] Calling fah_main args: 14 usage=100
[04:41:46]
[04:41:46] Working on p10106_lambda_370K
[04:41:48] Client config found, loading data.
[04:41:48] Starting GUI Server
[04:42:31] Completed 1%
[04:42:31] mdrun_gpu returned
[04:42:31] NANs detected on GPU
[04:42:31]
[04:42:31] Folding@home Core Shutdown: UNSTABLE_MACHINE
[04:42:34] CoreStatus = 7A (122)
[04:42:34] Sending work to server
[04:42:34] Project: 10106 (Run 96, Clone 1, Gen 2)
[04:42:34] - Read packet limit of 540015616... Set to 524286976.
[04:42:34] - Error: Could not get length of results file work/wuresults_00.dat
[04:42:34] - Error: Could not read unit 00 file. Removing from queue.
[04:42:34] - Preparing to get new work unit...
[04:42:34] + Attempting to get work packet
[04:42:34] - Connecting to assignment server
[04:42:35] - Successful: assigned to (171.64.65.71).
[04:42:35] + News From Folding@Home: Welcome to Folding@Home
[04:42:35] Loaded queue successfully.
[04:42:36] + Closed connections
[04:42:41]
[04:42:41] + Processing work unit
[04:42:41] Core required: FahCore_11.exe
[04:42:41] Core found.
[04:42:41] Working on queue slot 01 [March 9 04:42:41 UTC]
[04:42:41] + Working ...
[04:42:41]
[04:42:41] *------------------------------*
[04:42:41] Folding@Home GPU Core
[04:42:41] Version 1.31 (Tue Sep 15 10:57:42 PDT 2009)
[04:42:41]
[04:42:41] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[04:42:41] Build host: amoeba
[04:42:41] Board Type: Nvidia
[04:42:41] Core      :
[04:42:41] Preparing to commence simulation
[04:42:41] - Looking at optimizations...
[04:42:41] DeleteFrameFiles: successfully deleted file=work/wudata_01.ckp
[04:42:41] - Created dyn
[04:42:41] - Files status OK
[04:42:41] - Expanded 88651 -> 447307 (decompressed 504.5 percent)
[04:42:41] Called DecompressByteArray: compressed_data_size=88651 data_size=447307, decompressed_data_size=447307 diff=0
[04:42:41] - Digital signature verified
[04:42:41]
[04:42:41] Project: 10106 (Run 96, Clone 1, Gen 2)
[04:42:41]
[04:42:41] Assembly optimizations on if available.
[04:42:41] Entering M.D.
[04:42:47] Tpr hash work/wudata_01.tpr:  1725156609 2891410245 3795927272 312815133 2393708436
[04:42:47]
[04:42:47] Calling fah_main args: 14 usage=100
[04:42:47]
[04:42:47] Working on p10106_lambda_370K
[04:42:49] Client config found, loading data.
[04:42:49] Starting GUI Server
--- Opening Log file [March 9 14:12:27 UTC]
Arguments: -gpu 2
[14:12:27] - Ask before connecting: No
[14:12:27] - User name: statesidecoma (Team 80856)
[14:12:27] - User ID: 65C7E7AF0E907C50
[14:12:27] - Machine ID: 7
[14:12:27]
[14:12:27] Loaded queue successfully.
[14:12:27]
[14:12:27] + Processing work unit
[Mar12 97] Core required: FahCore_11.exe
[14:12:27] Core found.
[14:12:27] Working on queue slot 01 [March 9 14:12:27 UTC]
[14:12:27] + Working ...
[14:12:27]
[14:12:27] *------------------------------*
[14:12:27] Folding@Home GPU Core
[14:12:27] Version 1.31 (Tue Sep 15 10:57:42 PDT 2009)
[14:12:27]
[14:12:27] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[14:12:27] Build host: amoeba
[14:12:27] Board Type: Nvidia
[14:12:27] Core      :
[14:12:27] Preparing to commence simulation
[14:12:27] - Looking at optimizations...
[14:12:27] - Files status OK
[14:12:27] - Expanded 88651 -> 447307 (decompressed 504.5 percent)
[14:12:27] Called DecompressByteArray: compressed_data_size=88651 data_size=447307, decompressed_data_size=447307 diff=0
[14:12:27] - Digital signature verified
[14:12:27]
[14:12:27] Project: 10106 (Run 96, Clone 1, Gen 2)
[14:12:27]
[14:12:27] Assembly optimizations on if available.
[14:12:27] Entering M.D.
[14:12:33] Will resume from checkpoint file
[14:12:33] Tpr hash work/wudata_01.tpr:  1725156609 2891410245 3795927272 312815133 2393708436
[14:12:33]
[14:12:33] Calling fah_main args: 14 usage=100
[14:12:33]
[14:12:34] Working on p10106_lambda_370K
[14:12:35] Client config found, loading data.
[14:12:36] Starting GUI Server
[14:12:36] Resuming from checkpoint
[14:12:36] fcCheckPointResume: retreived and current tpr file hash:
[14:12:36]    0   1725156609   1725156609
[14:12:36]    1   2891410245   2891410245
[14:12:36]    2   3795927272   3795927272
[14:12:36]    3    312815133    312815133
[14:12:36]    4   2393708436   2393708436
[14:12:36] fcCheckPointResume: file hashes same.
[14:12:36] fcCheckPointResume: state restored.
[14:12:36] Verified work/wudata_01.log
[14:12:36] Verified work/wudata_01.edr
[14:12:36] Verified work/wudata_01.xtc
[14:13:34] Completed 1%
[14:14:33] Completed 2%
[14:15:23] Completed 3%
[14:15:23] mdrun_gpu returned
[14:15:23] NANs detected on GPU
[14:15:23]
[14:15:23] Folding@home Core Shutdown: UNSTABLE_MACHINE
[14:15:25] CoreStatus = 7A (122)
[14:15:25] Sending work to server
[14:15:25] Project: 10106 (Run 96, Clone 1, Gen 2)
[14:15:25] - Read packet limit of 540015616... Set to 524286976.
[14:15:25] - Error: Could not get length of results file work/wuresults_01.dat
[14:15:25] - Error: Could not read unit 01 file. Removing from queue.
[14:15:25] - Preparing to get new work unit...
[14:15:25] + Attempting to get work packet
[14:15:25] - Connecting to assignment server
[14:15:26] - Successful: assigned to (171.64.65.71).
[14:15:26] + News From Folding@Home: Welcome to Folding@Home
[14:15:26] Loaded queue successfully.
[14:15:27] + Closed connections
[14:15:32]
[14:15:32] + Processing work unit
[14:15:32] Core required: FahCore_11.exe
[14:15:32] Core found.
[14:15:32] Working on queue slot 02 [March 9 14:15:32 UTC]
[14:15:32] + Working ...
[14:15:32]
[14:15:32] *------------------------------*
[14:15:32] Folding@Home GPU Core
[14:15:32] Version 1.31 (Tue Sep 15 10:57:42 PDT 2009)
[14:15:32]
[14:15:32] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[14:15:32] Build host: amoeba
[14:15:32] Board Type: Nvidia
[14:15:32] Core      :
[14:15:32] Preparing to commence simulation
[14:15:32] - Looking at optimizations...
[14:15:32] DeleteFrameFiles: successfully deleted file=work/wudata_02.ckp
[14:15:32] - Created dyn
[14:15:32] - Files status OK
[14:15:32] - Expanded 88651 -> 447307 (decompressed 504.5 percent)
[14:15:32] Called DecompressByteArray: compressed_data_size=88651 data_size=447307, decompressed_data_size=447307 diff=0
[14:15:32] - Digital signature verified
[14:15:32]
[14:15:32] Project: 10106 (Run 96, Clone 1, Gen 2)
[14:15:32]
[14:15:32] Assembly optimizations on if available.
[14:15:32] Entering M.D.
[14:15:38] Tpr hash work/wudata_02.tpr:  1725156609 2891410245 3795927272 312815133 2393708436
[14:15:38]
[14:15:38] Calling fah_main args: 14 usage=100
[14:15:38]
[14:15:39] Working on p10106_lambda_370K
[14:15:40] Client config found, loading data.
[14:15:40] Starting GUI Server
[14:16:23] Completed 1%
[14:16:23] mdrun_gpu returned
[14:16:23] NANs detected on GPU
[14:16:23]
[14:16:23] Folding@home Core Shutdown: UNSTABLE_MACHINE
[14:16:26] CoreStatus = 7A (122)
[14:16:26] Sending work to server
[14:16:26] Project: 10106 (Run 96, Clone 1, Gen 2)
[14:16:26] - Read packet limit of 540015616... Set to 524286976.
[14:16:26] - Error: Could not get length of results file work/wuresults_02.dat
[14:16:26] - Error: Could not read unit 02 file. Removing from queue.
[14:16:26] - Preparing to get new work unit...
[14:16:26] + Attempting to get work packet
[14:16:26] - Connecting to assignment server
[14:16:27] - Successful: assigned to (171.64.65.71).
[14:16:27] + News From Folding@Home: Welcome to Folding@Home
[14:16:27] Loaded queue successfully.
[14:16:28] + Closed connections
[14:16:33]
[14:16:33] + Processing work unit
[14:16:33] Core required: FahCore_11.exe
[14:16:33] Core found.
[14:16:33] Working on queue slot 03 [March 9 14:16:33 UTC]
[14:16:33] + Working ...
[14:16:33]
[14:16:33] *------------------------------*
[14:16:33] Folding@Home GPU Core
[14:16:33] Version 1.31 (Tue Sep 15 10:57:42 PDT 2009)
[14:16:33]
[14:16:33] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[14:16:33] Build host: amoeba
[14:16:33] Board Type: Nvidia
[14:16:33] Core      :
[14:16:33] Preparing to commence simulation
[14:16:33] - Looking at optimizations...
[14:16:33] DeleteFrameFiles: successfully deleted file=work/wudata_03.ckp
[14:16:33] - Created dyn
[14:16:33] - Files status OK
[14:16:33] - Expanded 88651 -> 447307 (decompressed 504.5 percent)
[14:16:33] Called DecompressByteArray: compressed_data_size=88651 data_size=447307, decompressed_data_size=447307 diff=0
[14:16:33] - Digital signature verified
[14:16:33]
[14:16:33] Project: 10106 (Run 96, Clone 1, Gen 2)
[14:16:33]
[14:16:33] Assembly optimizations on if available.
[14:16:33] Entering M.D.
[14:16:39] Tpr hash work/wudata_03.tpr:  1725156609 2891410245 3795927272 312815133 2393708436
[14:16:39]
[14:16:39] Calling fah_main args: 14 usage=100
[14:16:39]
[14:16:40] Working on p10106_lambda_370K
[14:16:41] Client config found, loading data.
[14:16:41] Starting GUI Server
[14:17:28] Completed 1%
[14:17:28] mdrun_gpu returned
[14:17:28] NANs detected on GPU
[14:17:28]
[14:17:28] Folding@home Core Shutdown: UNSTABLE_MACHINE
[14:17:31] CoreStatus = 7A (122)
[14:17:31] Sending work to server
[14:17:31] Project: 10106 (Run 96, Clone 1, Gen 2)
[14:17:31] - Read packet limit of 540015616... Set to 524286976.
[14:17:31] - Error: Could not get length of results file work/wuresults_03.dat
[14:17:31] - Error: Could not read unit 03 file. Removing from queue.
[14:17:31] - Preparing to get new work unit...
[14:17:31] + Attempting to get work packet
[14:17:31] - Connecting to assignment server
[14:17:32] - Successful: assigned to (171.64.65.71).
[14:17:32] + News From Folding@Home: Welcome to Folding@Home
[14:17:32] Loaded queue successfully.
[14:17:33] + Closed connections
[14:17:38]
[14:17:38] + Processing work unit
[14:17:38] Core required: FahCore_11.exe
[14:17:38] Core found.
[14:17:38] Working on queue slot 04 [March 9 14:17:38 UTC]
[14:17:38] + Working ...
[14:17:38]
[14:17:38] *------------------------------*
[14:17:38] Folding@Home GPU Core
[14:17:38] Version 1.31 (Tue Sep 15 10:57:42 PDT 2009)
[14:17:38]
[14:17:38] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[14:17:38] Build host: amoeba
[14:17:38] Board Type: Nvidia
[14:17:38] Core      :
[14:17:38] Preparing to commence simulation
[14:17:38] - Looking at optimizations...
[14:17:38] DeleteFrameFiles: successfully deleted file=work/wudata_04.ckp
[14:17:38] - Created dyn
[14:17:38] - Files status OK
[14:17:38] - Expanded 88651 -> 447307 (decompressed 504.5 percent)
[14:17:38] Called DecompressByteArray: compressed_data_size=88651 data_size=447307, decompressed_data_size=447307 diff=0
[14:17:38] - Digital signature verified
[14:17:38]
[14:17:38] Project: 10106 (Run 96, Clone 1, Gen 2)
[14:17:38]
[14:17:38] Assembly optimizations on if available.
[14:17:38] Entering M.D.
[14:17:44] Tpr hash work/wudata_04.tpr:  1725156609 2891410245 3795927272 312815133 2393708436
[14:17:44]
[14:17:44] Calling fah_main args: 14 usage=100
[14:17:44]
[14:17:45] Working on p10106_lambda_370K
[14:17:46] Client config found, loading data.
[14:17:46] Starting GUI Server
[14:18:32] Completed 1%
[14:18:32] mdrun_gpu returned
[14:18:32] NANs detected on GPU
[14:18:32]
[14:18:32] Folding@home Core Shutdown: UNSTABLE_MACHINE
[14:18:34] CoreStatus = 7A (122)
[14:18:34] Sending work to server
[14:18:34] Project: 10106 (Run 96, Clone 1, Gen 2)
[14:18:34] - Read packet limit of 540015616... Set to 524286976.
[14:18:34] - Error: Could not get length of results file work/wuresults_04.dat
[14:18:34] - Error: Could not read unit 04 file. Removing from queue.
[14:18:34] - Preparing to get new work unit...
[14:18:34] + Attempting to get work packet
[14:18:34] - Connecting to assignment server
[14:18:35] - Successful: assigned to (171.64.65.71).
[14:18:35] + News From Folding@Home: Welcome to Folding@Home
[14:18:35] Loaded queue successfully.
[14:18:36] + Closed connections
[14:18:41]
[14:18:41] + Processing work unit
[14:18:41] Core required: FahCore_11.exe
[14:18:41] Core found.
[14:18:41] Working on queue slot 05 [March 9 14:18:41 UTC]
[14:18:41] + Working ...
[14:18:41]
[14:18:41] *------------------------------*
[14:18:41] Folding@Home GPU Core
[14:18:41] Version 1.31 (Tue Sep 15 10:57:42 PDT 2009)
[14:18:41]
[14:18:41] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[14:18:41] Build host: amoeba
[14:18:41] Board Type: Nvidia
[14:18:41] Core      :
[14:18:41] Preparing to commence simulation
[14:18:41] - Looking at optimizations...
[14:18:41] DeleteFrameFiles: successfully deleted file=work/wudata_05.ckp
[14:18:41] - Created dyn
[14:18:41] - Files status OK
[14:18:41] - Expanded 88651 -> 447307 (decompressed 504.5 percent)
[14:18:41] Called DecompressByteArray: compressed_data_size=88651 data_size=447307, decompressed_data_size=447307 diff=0
[14:18:41] - Digital signature verified
[14:18:41]
[14:18:41] Project: 10106 (Run 96, Clone 1, Gen 2)
[14:18:41]
[14:18:41] Assembly optimizations on if available.
[14:18:41] Entering M.D.
[14:18:47] Tpr hash work/wudata_05.tpr:  1725156609 2891410245 3795927272 312815133 2393708436
[14:18:47]
[14:18:47] Calling fah_main args: 14 usage=100
[14:18:47]
[14:18:47] Working on p10106_lambda_370K
[14:18:49] Client config found, loading data.
[14:18:49] Starting GUI Server
[14:19:32] Completed 1%
[14:19:32] mdrun_gpu returned
[14:19:32] NANs detected on GPU
[14:19:32]
[14:19:32] Folding@home Core Shutdown: UNSTABLE_MACHINE
[14:19:35] CoreStatus = 7A (122)
[14:19:35] Sending work to server
[14:19:35] Project: 10106 (Run 96, Clone 1, Gen 2)
[14:19:35] - Read packet limit of 540015616... Set to 524286976.
[14:19:35] - Error: Could not get length of results file work/wuresults_05.dat
[14:19:35] - Error: Could not read unit 05 file. Removing from queue.
[14:19:35] EUE limit exceeded. Pausing 24 hours.
Re: Project: 10106 (Run 96, Clone 1, Gen 2)
That's weird ... I see in the DB about 50-50% failures like yours (immediate EUE/UM) vs. successful returns ... among many entries :?
shdbcamping
toTOW wrote:That's weird ... I see in the DB about 50-50% failures like yours (immediate EUE/UM) vs. successful returns ... among many entries :?
Soooooooo, Any progress here :ewink: ?
I am still having issues with particular Projects and (R,C,X) shotgroups. A lot too many to constantly post on them :( . I've been around a bit, so the newer Folding 'Partners' have got to be going nuts.
Has there been any 'positive' thoughts on Pande being to ship work based on 'returned' work by Client ID?
Fold on all, no setback is worth UN folding :D .
Sean
As you already know, Fixing a problem is a multi-step process. They're working on it and as it progresses through those steps, those working on it know that it's progressing, but from the external point of view, the only thing we call progress is the final step when the fix is released.
No doubt. :P
This is not a new concept and it has always been on the list of things that would be nice to have, but I sincerely doubt it will get any attention right now, given the other issues that you can read about in current problem reports.
The simple step of trying to download a new WU from the same server to which you just returned a result would be a step in that direction, but you would also need logic to disable that feature if you're having problems with WUs from that server -- and either way, at that moment, there may not be another server that can issue WUs that have a good fit for the profile of your client.
It's not a simple problem.
