FAH refusing to upload
Locked
*hondo*
Hardware configuration: Geoforce 250 GTS Active for F@H
4 Core Intel not used at all for F@H
Post by *hondo* »
Hello folks :) the WU below has been trying to upload for plus 9 hours now. Is anyone aware of what the problem is please?
Thanks *hondo*
Slot 02 Done
Project: 5783 (Run 10, Clone 20, Gen 109), Core: 11
Work server: 171.67.108.21:8080
Collection server: 171.67.108.26
Download date: March 8 22:51:42
Finished date: March 9 02:52:33
Failed uploads: 12
bollix47
Re: FAH refusing to upload
Post by bollix47 »
If you look at the Server Status link (top of this page) you will see that both servers have a CONNECT state of Reject.
Server 108.21 has been alternating between Accept and Reject for a number of hours.
It's a little early on the west coast so it may be a couple hours before the situation can be rectified at which time the WUs should upload.
Re-starting the client or simply waiting(mine takes around 12 minutes before it gives up and moves on) should get you assigned to a different server and allow for a different Project but until 108.21 is Accepting again there will be a delay at the end of each WU while the client retries to send 5783.
*hondo*
Post by *hondo* »
:) Thanx bollix47 for the reply, the odd thing is I can successfully ping 171.67.108.26 :?
:shock: They should work nights!! I've been up & at it now for 7.5 hours :lol: LMAO :wink:
bollix47
Post by bollix47 »
A server that's in Reject is not the same as being DOWN. I believe that Reject means the server is not accepting any connections but ping should still work as the server is 'alive'. Server 108.26 has been in Reject for a few weeks now. I seem to recall that it was being worked on to iron out some issues. So we will have to wait for 108.21 to return to "Accepting".
lol .... I hear you. :lol:
*hondo*
Post by *hondo* »
Ah, yes 171.67.108.26 is in reject mode too.
:oops: My memory isn't what it was, but I recall that now, I thought then initially the problem was at my end so I formatted the PC, after the loss of the of 5 queued WUs I found the issue was with Stanford. I wasn't at all an happy bunny.
Thanx again bollix47 :)
This has already been reported (in the right forum) : viewtopic.php?f=18&t=12930
Thread locked.
Locked
