Problem editing/preparing replies to message contain [Code]
Locked
ParrLeyne
Post by ParrLeyne »
I was posting a reply to a message (http://foldingforum.org/viewtopic.php?f ... 97#p134693) which contains a rather long Code block.
I found that the reply message box was having a real problem allowing me to edit the message (especially when the code block was in the visual display area).
Does anyone else have this problem?
I am running IE 8 on WinXP 64.
ChelseaOilman
Re: Problem editing/preparing replies to message contain [Code]
Post by ChelseaOilman »
ParrLeyne wrote:Does anyone else have this problem?
You mean like the text keeps jumping around when you want to add something at the very bottom making it almost impossible to see what your typing?
Yes. It's aggravating! :x
P5-133XL
Machine #2:
Machine 3:
Post by P5-133XL »
Use compatibility mode for IE8.
uncle_fungus
Post by uncle_fungus »
*cough* Use a browser that actually works.
ChelseaOilman
uncle_fungus wrote:*cough* Use a browser that actually works.
Or this forum could be fixed so it works with IE8! :P
Actually, P5-133XL's suggestion seems to work. :)
Thanks P5-133XL :!:
What is IE8 ? I though it was only meant to download Firefox ... :mrgreen:
ChelseaOilman
toTOW wrote:What is IE8 ? I though it was only meant to download Firefox ... :mrgreen:
It's the thing you use to get Windows updates. Try doing that with Firefox. :lol:
So it only has two usages ... download firefox and windows updates ... I wish we could use something else for Windows Update so that I could save some space on my HDD :mrgreen:
If you use FF 3.5.8 with IE Tab add-on, then you never have to even open IE for anything. I just use it to import website into OneNote as FF add-on is experimental.
Locked
