Unit 2665 (3 138 196) Not credited to my stats
shunter
Post by shunter »
Can someone check what happened to this unit please - it completed and uploaded last night but no credit has been given as far as I can tell from analysing my stats as at 2.00 pm GMT today. Details from log are below
Thanks
Shunter
[20:09:53] Completed 250000 out of 250000 steps (100 percent)
[20:09:53] Writing final coordinates.
[20:09:55] Past main M.D. loop
[20:09:56] Will end MPI now
[20:10:56]
[20:10:56] Finished Work Unit:
[20:10:56] - Reading up to 21310704 from "work/wudata_02.arc": Read 21310704
[20:10:57] - Reading up to 557048 from "work/wudata_02.xtc": Read 557048
[20:10:57] goefile size: 0
[20:10:57] logfile size: 203291
[20:10:57] Leaving Run
[20:10:59] - Writing 22077415 bytes of core data to disk...
[20:10:59] ... Done.
[20:11:00] - Failed to delete work/wudata_02.sas
[20:11:00] - Failed to delete work/wudata_02.goe
[20:11:00] Warning: check for stray files
[20:11:00] - Shutting down core
[20:13:00]
[20:13:00] Folding@home Core Shutdown: FINISHED_UNIT
[20:13:00]
[20:13:07] CoreStatus = 64 (100)
[20:13:07] Unit 2 finished with 80 percent of time to deadline remaining.
[20:13:07] Updated performance fraction: 0.799286
[20:13:07] Sending work to server
[20:13:07] Project: 2665 (Run 3, Clone 138, Gen 196)
[20:13:07] + Attempting to send results [March 5 20:13:07 UTC]
[20:13:07] - Reading file work/wuresults_02.dat from core
[20:13:07] (Read 22077415 bytes from disk)
[20:13:07] Connecting to http://171.64.65.64:8080/
[20:19:06] Posted data.
[20:19:06] Initial: 0000; - Uploaded at ~59 kB/s
[20:19:10] - Averaged speed for that direction ~55 kB/s
[20:19:10] + Results successfully sent
[20:19:10] Thank you for your contribution to Folding@Home.
[20:19:10] + Number of Units Completed: 640
[20:19:15] - Warning: Could not delete all work unit files (2): Core returned invalid code
[20:19:15] Trying to send all finished work units
[20:19:15] + No unsent completed units remaining.
[20:19:15] - Preparing to get new work unit...
[20:19:15] Cleaning up work directory
[20:19:15] + Attempting to get work packet
[20:19:15] - Will indicate memory of 2046 MB
[20:19:15] - Connecting to assignment server
[20:19:15] Connecting to http://assign.stanford.edu:8080/
[20:19:16] Posted data.
Re: Unit 2665 (3 138 196) Not credited to my stats
Hi shunter (team 46590),
Your WU (P2665 R3 C138 G196) was added to the stats database on 2010-03-05 13:03:18 for 1920 points of credit.
shunter
Post by shunter »
Thanks toTOW. I've rechecked my numbers and regretably found that I had double counted this unit. My apologies for wasting your time
Regards
Shunter
Making a DB query didn't take so much time ... :roll:
