HFM default web settings
tmillic
Hardware configuration: AMD3200+ w/ NVIDIA GT220.
Tyan S2912 with 1 Opteron 2347HE.
Via C3.
Post by tmillic »
Under Preferences, Web Settings, HFM indicates default values for User ID and Team. What's the purpose of this?
chrisretusn
Hardware configuration: AMD Athlon(tm) 64 X2 Dual Core Processor 4000+
AMD Athlon(tm) XP 2600+
Re: HFM default web settings
Post by chrisretusn »
User ID is your folding name.
Team is the team number you are a member of.
Folding on Slackware Linux.
tmillic
Via C3.
Post by tmillic »
OK. I'd just assumed it would use the values in the log file.
Thanks.
It uses those settings for two purposes.
1) It will retreive the data from EOC and display it at the bottom of the screen
2) It will compare your expected UserName/Team against the values in the log (warning against accidental credits to the wrong User Name and Team).
sgb101
Post by sgb101 »
it also asks for a Extreme overclocking User id, what is this as it will only let you add numbers.
i just signed up to ex o/c as i thought it would give me the a separate numeric id, but it seems not.
any ideas.
i5 750@3.47-4Gb ddr3-HD5850-Win 7 64bit
i7 920@3.87-6Gb ddr3-9800GT- Win7 64bit
bollix47
Post by bollix47 »
It's on the left side User: 487808
http://folding.extremeoverclocking.com/ ... =&u=487808
or the end of your link.
i.e. 487808
ChelseaOilman
Post by ChelseaOilman »
sgb101 wrote:it also asks for a Extreme overclocking User id, what is this
Go to your stats page at EOC and look for your number at the end of the web address or in the info in the left hand column.
I looked, it's 487808.
bollix47 beat me by 1 minute. :lol:
sgb101
Post by sgb101 »
cheers guys, sorry took so long to get back, parents evening. great fun.
what is it for?
also on the eoc site it shows i have around 22kppd today but in my table below only 11k. how come they are not the same?
